View Full Version : Engineering/Technical
  1. Turbo Vacuum
  2. Full Body Skirt For Toyota Levin
  3. 1994 Accord SiR
  4. autolamp sensitivity
  5. Crazy or what?
  6. What To Take In University???
  7. dash panel blues
  8. Dealer Experience: Lisle Honda
  9. Emissions Warranty Ext. 14yr/150k
  10. Have a little problem!
  11. please read...
  12. Prelude Parts Available On Ebay
  13. Hardware/Gasket for Header Install
  14. Alternator Question
  15. www.a1jdmengines.com
  16. 1991 accord swap info.....
  17. need help! usdm h23 to jdm h22 engine swap on 94 prelude
  18. B16a into 88-91 crx ??????
  19. Need help!
  20. An Automatic!!!! Article
  21. Preparing for winter
  22. H22a Engine problem?
  23. Suicide doors?
  24. Are the G-Tech/ Apexi Rev/ Speed Meter GP any good?
  25. where can I find templates for GMC savana
  26. radiator help
  27. Clutch Masters Stage 3
  28. how do you do a hydro conversion?
  29. 351 Cleveland, am I screwed??
  30. Spoilers
  31. Torque How 2 Question...
  32. Real Mugen Shift Boot?
  33. rechargable batteries?
  34. Best Tranny for 1st Gen B16a.
  35. gauge cluster question
  36. alero engine swap to v6
  37. How diesel engines are switched off?
  38. Replacing clock backlight...
  39. dx or hf? how to tell
  40. does backpressure affect top speed?
  41. ABS Diagnosis
  42. V-tec heads?
  43. sparco tach install
  44. PLEASE HELP!! Need ecu pin diagram 92 integra ls
  45. Best head for B16A2 motor?
  46. Timing Belt, Water Pump?
  47. s2000 engine into a civic
  48. SR20DET swap in a civic...
  49. good B16A2 (99-00si) motor setup
  50. Pajero 3.5l timing problem
  51. parts for b18c
  52. Common sense
  53. Removing Alternator -- HOW TO?!
  54. H22A-R motor in a Honda CRX
  55. Where to purchase a H22A-R motor????
  56. H22a
  57. most power out of a d16y7 motor? ***READ***
  58. What engine for a 93 Prelude
  59. Help driving a Manual?
  60. Some Questions I Have, please answer if possible.
  61. where to get an LS motor???
  62. Blow off Valve??
  63. which msd box
  64. Jdm Zc Tuning And Timing "help"
  65. Suspension Break-In?
  66. 89 accord dx clutch shifting sound
  67. Is it possible to make a 11 sec street legal Honda Civic???
  68. cost of rebuild?
  69. Please help on Vacuum hoses for b16a in crx dx!!!!!!!
  70. CD Player
  71. 91 Prelude ECU code
  72. Are gasoline engines limited to spark igntion?
  73. 97 Integra Type R owners...READ
  74. Why can't clutches be placed between the transmission and the differential?
  75. Heater on really help?
  76. Manual Ecu for Automatic? Will it work?
  77. S2000 starter switch, please help
  78. possible swaps in 85 crx dx?(carbed)
  79. what does "port & polish head" mean?
  80. Maintance Light (Civic)
  81. sunbird stalls HELP
  82. maint. reqd. light in 97 gsr
  83. Rattling noise after header/cat install
  84. tons of white smoke, help!!
  85. Tranny Problems...
  86. SOHC VTEC head
  87. slight backfire sound
  88. Idleing problem
  89. anyone know hp?
  90. Shifting sound
  91. springs and cambers
  92. Accord Euro R Final gear
  93. i found a .30 ci wankel rotary engine!
  94. building an engine
  95. tracking down f22 jdm and usdm
  96. What engine for a 96 Integra?
  97. engine problem, please help
  98. H22 or B18c in 92 hatch
  99. Have You Seen A Bad Pressure Plate
  100. vaccum lines
  101. Left side vs right side dirve swap ?????
  102. b16a on a 97 civic
  103. Yes another 'My brilliant idea'
  104. Low idle problem?
  105. Need some help from you techies
  106. best motor swap for a 1996 civic dx
  107. best motor swap for a 96 Civic DX
  108. Core supports on 96-98
  109. Wierd Problem
  110. valve covers for a sohc non vtec motor
  111. b18c3 in a 96 civic?
  112. Headlight Aim
  113. Turbo timer...
  114. Catalytic Converter SOLUTION!!!!
  115. Buying CRX...NEED INFO!!
  116. Damn those s.o.b's at Speedee
  117. EG-6 ecu code light location
  118. How do ya get a 1.75 rod/stroke ratio in a crvtec?
  119. F20C1 head swap on K20A2 block
  120. Need help with some electrical questions.
  121. I just had a brilliant idea. Time to shoot me down!
  122. best motor in 6th gen civic coupe
  123. H22a in civic hatch
  124. Claimed wieght
  125. Dual Exhaust on Civic
  126. a few quick questions on turbochargers and how to fix lag
  127. Fast & Furious shifting
  128. ripped off
  129. b16 with automatic transmissions
  130. super charging an olds. cutlass supreme
  131. Diagnostic testing
  132. need help ASAP... how to get the hub nut off
  133. Brake light help needed!
  134. Rear drive conversion
  135. zc block questions
  136. I need a zc motor
  137. Need help increasing displacement!!!!
  138. SRS Light
  139. lets build the ultimate street racing car...
  140. 92 chevy cavalier - backup lights
  141. D16z6 Motors
  142. LS/Vtec
  143. LS/Vtec
  144. Help please with friends 97 Accord LX & aftermarket ignition system
  145. increasing catback piping
  146. Trouble filling gas tank - backpressure
  147. tire size ?
  148. F22 engine efficiency
  149. Question about civic ex's vtec 96+
  150. Intercooler questions (kind of long)
  151. jdm engine serial numbers
  152. Engine/Drivetrain in Custom Built Car
  153. D16Z6 Question?
  154. HELP!! Check engine light. Pulled code 41
  155. JDM in the United States
  156. V-Afc questions
  157. H2O pump ?
  158. premium fuel
  159. tack install
  160. Vtec\Shift light
  161. Ranger Oil Pressure
  162. Got my JDM B20A for my 91 Prelude!!!
  163. please help clutch is clicking
  164. Remote oil filter systems
  165. Civic H22a clutch question
  166. Civic H22a clutch question
  167. Timing belt question. . . help!
  168. whats the fastest stock Honda/Acura sans the s2k
  169. B16 ECU to D16Y8
  170. Any Honda Techs In The House?
  171. Why do rings go bad???
  172. LS in a 98 civic LX (need info)
  173. Final Plans (B18C5 motor) questions first
  174. AWD Civic
  175. Best Cold Air Intake?
  176. oxygen sensor
  177. Turbo
  178. K20A Engine
  179. Can coolant/oil channels be machined into a block or must they be cast along with it?
  180. check engine light
  181. Radio looses station/date memory
  182. clutch noise
  183. i need help
  184. B18b, B18a
  185. motor mounts
  186. Civic h22a swap question
  187. b18c5 for 94 del sol
  188. Car won't start: Troubleshoot
  189. Car Won't Start: Troubleshoot
  190. T5 gearbox to cologne 4.0 V6
  191. is it possible for a b20/gsr frankenstein?
  192. jdm motor & parts infor/chat
  193. 92 civic CX swap to a h22a??
  194. Motor swap
  195. Racing chips???
  196. H22A Pricing
  197. engine swap
  198. Best motor in 5th gen. civic
  199. Synthetic oil
  200. Flaming Exhaust?
  201. what the hell is a spoon engine
  202. CTR Pistons in 1.7 DOHC VTEC
  203. B18C-R motor
  204. H22 AEM Pulleys
  205. Vtec
  206. Where on can I find Info about engine parts?
  207. Raising the RPM range.
  208. can I use an OBD0 or non OBD JDM ECU on my OBD1 GSR?
  209. What Next??
  210. 2000 Honda Civic EX
  211. cai for hybrid hatch
  212. short shifter for hybrid swap question
  213. Jdm Sucks Balls!!!
  214. The pics are in!!
  215. Oil leak
  216. anyone in Minneapolis area know of a good import shop
  217. need help H22A Engine Swap
  218. Has this happened to you?
  219. Catalytic Converter
  220. All 4 doors losing electrical power?
  221. Need some suggestions for reading material
  222. Got a problem with my H22
  223. How long until we see brake-by-wire on production cars?
  224. ecu ?'s when doing a swap
  225. Where can I find a loud exhaust?
  226. h22 swap
  227. Question about fuel pressure modifier ...
  228. A YES/NO question
  229. a few newbie quesions
  230. 93 Accord EX swap to a H22A
  231. H22
  232. High-Revving a B18C
  233. Rebuilt Engine won't start
  234. B16A and B18C Crank
  235. Noise when I turn my wheels
  236. Adjusting Valves?
  237. car wont start please help
  238. Got B16A ??
  239. b20b in civic?
  240. JDM Integra Front End Conversions?
  241. well that can't be good
  242. A Camber Confusion!!!
  243. Propane kit for setting mixture, 81 Civic
  244. Catalytic Converter / Header????
  245. 1990 Geo Prizm cranks, but will not start
  246. Nitrous additive...
  247. Prelude type-S air box
  248. Limited Slip Differential swap question
  249. 91 Plymouth Laser Transmission
  250. Valve Cover Oil Leak?
