View Full Version : Engineering/ Technical
  1. Engine Swapping Questions
  2. OBD2 adpater?
  3. Cam Timing Differences with D18Z6/Y8
  4. tranny's clicking??
  5. cam timing?
  6. Stumped - Finished Swap - Car Won't Start
  7. Mugen Intake
  8. Is an MSD ignition worth it?
  9. 2 problems...both with headlights on '98 civic
  10. Popping noise under harsh acceleration
  11. hydro power??
  12. rattling sound from headers
  13. D16z6 HELP!!!
  14. Auto 2 Manual Conversion
  15. Car fluids
  16. TPS and nitrous
  17. Double wishbone suspension
  18. vafc install
  19. jdm intefra
  20. Help! Please????
  21. what do i need
  22. SOHC to DOHC conversion?
  23. BOV & Wastegate position (2JZ)
  24. what car to choose?
  25. Sell your vehicle for FREE?? Is it true?
  26. '88 teg in trouble
  27. Lurching engine when slowing down
  28. Are Nology Wires really worth the $150?
  29. please dont flame!
  30. Help
  31. little water problem...
  32. Tyre pressure effect on balance
  33. Can I use this OBD2 catalytic converter in my Eg hatch?
  34. Optimum Super Car Setup
  35. Dish Volume q's?
  36. Electrical Gremlins HELP!!!
  37. Clean Brakes
  38. Alternative Fuels
  39. Whats it mean when you're driving on Broken CV joints?
  40. gsr distributor
  41. Swap arrived with bag of bolts and stuff...... 56k grab a pillow!
  42. Brake Tru
  43. 89 accord gauge install
  44. ZC head on a D16z block
  45. what to do?
  46. wiper question
  47. swap question
  48. Best Cat Converter?
  49. 91 Accord Swap
  50. Pretty Loud!!!
  51. What would be louder/est...?
  52. year?
  53. b16a1 in a 91 civic hb PLEASE HELP IF YOU CAN!!!!!!!!!
  54. Best place to get Skunk2 stuff
  55. how to install 3 piece mid spoiler for civic hb
  56. Good eyes...
  57. How do I get ahold of one of these?!!!
  58. Overheating Problems b16a CRX
  59. Overheating Problems b16a CRX
  60. Louder Muffler!!!
  61. Header Transfer?
  62. Can anyone help me out......Or know a good shop?
  63. PhatNLow JDM imports - anyone ever buy anything from them??
  64. H22a Type-S - Change cam gears + pulley kit??
  65. code23?
  66. Question about Engineering Degree's
  67. Camshafts
  68. Help!! H22a or H22a Type-S worth it?
  69. B16a2 drive axles
  70. aftermarket support for B16b (U.S.)
  71. d15 firing order
  72. I Need Help
  73. 90 prelude swap ??
  74. radar detectors
  75. Anyone wanna help me out with the wiring
  76. how much will it cost to swap an integra type r engine in a 95 gsr
  77. Anyone else had problems with an engine from Street Imports?
  78. Supercharger
  79. how to tell if I have an LSD trans
  80. LOTSA problems :(
  81. Eating/drinking and excrement timing for motor racing
  82. Ovals-clockwise or anticlockwise?
  83. Painting and Clearing Head Lights Made easy
  84. h22 to 6G civic swap help
  85. Big time confused :(
  86. WyoTech?
  87. Proper way to bed in brake pads and rotors
  88. CTR cams
  89. At what slope does a car door no longer hold itself open?
  90. Flowtech Muffler
  91. how big is to big?
  92. anyone selling a jdm gauge cluster for 97-01 prelude?
  93. Odometer
  94. Best engine fo the 7th gen civic
  95. Ground points????
  96. O2 sensor help
  97. Cam Gears
  98. Knock Sensor
  99. Swap Advice
  100. compression
  101. h22 or h23?
  102. Chikara Header NEED HELP
  103. help please!!!! brake lights
  104. Mini Me Questions
  105. Idle problem with B16a2
  106. buick tech help
  107. B16A or ZC D16A8/A9
  108. what's jdm anyway?
  109. tranny swap
  110. how does a wrx motor wrk?
  111. PIAA H3C Light bulbs
  112. Questions About NOS
  113. B18B1 bottom end build
  114. gsr girdle
  115. why the hell'd you put a b16 into a GSR? dynos of B16a1 and B17a1 please
  116. need info
  117. Ditto Thread
  118. power lose over using the f22 trans over h22 trans?
  119. throttle troubles, HELP!!
  120. how do you do lambo style doors
  121. Front end Conversion
  122. 94 civic-94 integra front end swap
  123. Cross drilled rotors, better or not?
  124. Hemis
  125. Anybody swap a 96'or newer engine into a 4th gen. civic dx
  126. LSD questions
  127. civic std model same as hf crx model?
  128. B16a2 error codes.
  129. injector resister box location?
  130. header
  131. Available: Engine Swaps
  132. How much power will a b18c1 have with an non-vtec block???
  133. car dies at full stop...please help! 00civic EX AT
  134. 276 and 350 GM starters
  135. P0401 (EGR Flow Insufficient)
  136. Ned hep with putting a d16a7 out of a 96 into my 89?'
  137. Anyone know how to
  138. Dc Sports
  139. honda civic 92
  140. fuel pressure 88 hatch
  141. Swapping and need trans.
  142. Swapping and need trans
  143. Car isn't running very well
  144. Field's SFC-VTEC and Apexi V-AFC
  145. Y1 transmission
  146. mugen vs. greddy
  147. Cams or Cam Gears
  148. FS: CRX Si B16a $2,500
  149. Thermal Research vs. APEXi catbacks
  150. woody wood pecker?
  151. Anti-lag (misfiring) systems...
  152. All My Questions About Cars(Please Help Me)
  153. turbo parts
  154. Engine swap
  155. stock civic motors
  156. parts for sell.......
  157. 92+ civic z3 metal fenders brand new $140 shipped
  158. help need stuff 4 f20
  159. test pipe
  160. b16a from ebay?
  161. V-AFC problems
  162. No such thing as forged steel engine blocks?
  163. OBD0 into OBDI
  164. vtec performance bar
  165. please help me diagnose a problem
  166. The loudest 14inch long muffler out Their.
  167. It's going to drive me to insanity...
  168. Help
  169. blown plug
  170. heater core clogging
  171. :p
  172. Nowhere To Turn
  173. For all you honda motor buffs------->
  174. MSD Ignition....???
  175. Which Helm Manual?
  176. rotor upgrades.
  177. Replacing the starter
  178. lose plug
  179. Auto Jobs-stunt driving..on and on
  180. 88 hatch question
  181. Panthom grip
  182. how to remove struts
  183. Car revs by itself
  184. what parts can i swap to a non vtec f22
  185. Question for the mechanics out there..
  186. Parts
  187. B16 head on a d16 block?
  188. fuel filter bolt stuck
  189. jdm si hatchback spoiler?
  190. Experience with Gude?
  191. Cai
  192. Spaceframe versus monocoque
  193. Propane gas.
  194. kit car using accord 1990-1996
  195. helping out an old motor....
  196. b20b into 97 civic coupe
  197. Throttle Adjustment
  198. Why not more than 2 turbos?
  199. H22a or us H22?
  200. 5Zigen exhaust???
  201. Help!!!! I Need My Integra To Go Faster!!!
  202. strut bars?
  203. Share your experience
  204. New Voltage Regulator
  205. Exporting problems
  206. License plate light wiring???
  207. The "Rotten Egg" Smell.
  208. what goes with mugen lip?
  209. F20B in 4th gen accord
  210. V-TECing a LS...!...?
  211. strut bar
  212. What is torque?
  213. Any 2nd Gen CRX or 4th gen Civic with a B16a swap!
  214. 2002 Civic Help
  215. what does vvti stand for?
  216. building a D16Z6
  217. Emergency Engine Swap Need Help!!!!!
  218. what engine will fit this tranny
  219. Misc Problems with 95 Civic EX
  220. mugen or spoon racing chips???
  221. PR3 sub-harness
  222. My Frankenstein
  223. JDM Type R B18c w/ 94 GSR Head
  224. 60k service on 98 civic lx
  225. Hybrid Accord Questions...
  226. What exhaust should I get???
  227. ECU location?
  228. burning up distributors HELP!!!!
  229. Helms Service Manual
  230. Interesting battery problem...
  231. Civic Type R?
  232. changed Spark plugs and i found Oil...
  233. JET performance chip?
  234. Interga Type-r Conversion On A 99 Civic!?!?!?!?!?
  235. Crower Stage 4 Head Package
  236. Acura Gold Plated Emblem Kit
  237. engine stulmbles
  238. Jdm Odyssey In Uk
  239. ??????
  240. Axles
  241. Intake Manifold
  242. Slight engine vibration just before changing gears.
  243. silicone grease on plug wires?
  244. Zex vs. Gude vs. Crower Cams
  245. Totalled :*(
  246. Breather valves??
  247. B16a
  248. hydraulic pump
  249. Rock Chips Repair... Langka! anyone try this stuff?
  250. High Tension Wires Help
