View Full Version : Engineering/Technical
  1. Question about Starters & Odd Rattle
  2. Civic O2 Sensor Eliminator
  3. indurence racing H22A or b series
  4. 1986 Cadillac Seville ht 4100 engine trouble
  5. Quiet down..
  6. JDM '98 Spec ITR Header
  7. b18c vs b16b
  8. !!To All High Performance Exhaust Users!!
  9. !!!!!! Serious Decision !!!!!!!
  10. Zcvtec
  11. vx motor into a crx
  12. Mini me with Gude head?
  13. Turbo
  14. 95 civic EX owners
  15. Power Enterprise Vtec Controller
  16. mazda meliena
  17. Turbo B18C1
  18. How high HP/Torque can NA engines get to?
  19. help installing a cd player for a honda
  20. universal joints
  21. JDM b18 or gsr b18
  22. LS exhaust vs. GSR exhaust
  23. Hondata Ecu
  24. Intake+Exhaust = Better or worse gas mileage?
  25. Torque steer or what?
  26. YES another question!!
  27. Is theftlock gonna be a problem...
  28. Stereo: Capacitor Diagram
  29. H22A, or B18 (series) ina integra
  30. injectors
  31. STUDY HALL!!!hehehehehe
  32. Honda DIY, How Tos, Info Updated Daily ''Must See''
  33. Small block Chevy heads
  34. Rare ecu
  35. fuel systems
  36. h22 install cost
  37. JDM Parts available
  38. Fields Vtec Controller
  39. mod for header?
  40. Acura Integra
  41. help passing emissions!
  42. Cam Springs
  43. how do rotery engines work
  44. Trouble Starting my car
  45. Brake lights
  46. Buying a Used Car
  47. How do car manufacturers decide on which technology to introduce in a car?
  48. Coolant pressure
  49. how does noss work?
  50. whats the best spark plugs?
  51. how does a twin or single turbo work and what does it do?
  52. anyone selling mounts or throw out assemblies? a ? also
  53. pcm pinouts needed
  54. swapping h22a type-s into stock type-sh
  55. Please read
  56. Single Turbo instead of TT???
  57. Hyper Blink
  58. units of compression ratio?
  59. stroker kit anyone?
  60. 10 Grand Redline?
  61. more swap ?'s
  62. which one is better
  63. IF you are looking for the right person or IF you want to refresh your view
  64. "Dressed engine weight"
  65. 96-00 hatchback
  66. insulating exhaust
  67. will 98 GSR axles work in B20b/S80 swap
  68. Vtec-E D16Y5
  69. Bogging and back firing
  70. B20a5
  71. 1977 buick car
  72. Swapping in VA?
  73. F22a to a H22 I have some questions...
  74. Public Domain Hi-Eff Engine Design
  75. spoon fan switch
  76. JDM headlights
  77. Exhaust
  78. B16a to B16B? B18B to B18C5?
  79. engine chart
  80. repair questions
  81. Stuck car door
  82. CRX JDM Front Conversion
  83. stage2 cams
  84. 2 stroke + 4 stroke = 6 stroke!
  85. how do you make B20hybrids?
  86. fab engine mounts for 86 lude? how much?
  87. Timing belts...
  88. fuel upgrade
  89. h22a type S into 95 accord
  90. wiring on swap
  91. Idle control motor???
  92. Turbo or Naturally Aspirated
  93. Engines...Explain please!!!
  94. starter ?
  95. Differential question
  96. Greddy Evo vs Apexi N1
  97. JDM B18C Type-R
  98. please read!!!
  99. What is a good first project car?
  100. transmission, but case is cracked
  101. b series headers? other ?'s also
  102. Car Alarm Starter Disable?
  103. Help, quick question spark plug gap
  104. What do you think about this article?
  105. rear seat in a crx
  106. what else do I need for this B20 swap?
  107. fuel injectors
  108. h23/h22?
  109. axle problems...
  110. home-made tools
  111. Hybrid Revolution?
  112. custom gauge faces
  113. technical questions about oil loss on honda 1.5
  114. Was throwing just code 22. Now, 22 is gone and it's CEL code 21, Why?
  115. Metal vibration noise
  116. WTB oil catch can... where is a good place
  117. at home B16A swap?
  118. Engine bay, really really warm...
  119. HELP!!?? no fuel through Bosch ke jetronic fi distributor
  120. Light Weight Flywheels????
  121. are obx hi-flow cat really hollow?
  122. Best swap for 88 teg?
  123. getting B20 to 1.75 r/s
  124. B16A2 into a '95 Ex coupe
  125. Breather Filter
  126. A Good JDM engine Dealer
  127. H22A or B16a SirII????
  128. VAFC settings for Walbro 255lph
  129. Installing brake pads
  130. K24 vtec
  131. Non V Tec 2.2...help
  132. Is this the right harness for CEL diagnostic? Pics inside!
  133. how can i open door with button??
  134. cam gear bolts
  135. b16a 5th gear to LS?
  136. Hesitation nobody can figure out!!!!
  137. engine mounts B16A
  138. PS pump question
  139. Help! Wiring Problem
  140. jacobs icepack not working Help
  141. P30 Ecu???
  142. Torque settings on Head bolts and cam bolts
  143. New S-AFCII...more tuning pts!
  144. VTEC Quit!!!
  145. Shot peen B16A Rods...any troubles?
  146. car problem
  147. can it be done twin turbo for a 99 honda civic
  148. shaved trunk how to?
  149. Distributer HELP PLEASE!!
  150. TURBO for RSX Type-S
  151. Suspension Help
  152. d15b vtec Fuel Cutoff?
  153. WRX motor in Integra???
  154. hp racing header?
  155. Turbo? or Na
  156. Where did YOU tap in to wire the IAB (secondary intake solenoid) for vtec???
  157. Eg / GSR swap is almost complete! Few various Q's with pics inside!
  158. Cheapest place for JDM front clip
  159. 1999 civic ex vtec
  160. honda accord 94-95 trunk on a 1997?
  161. Fuel Gauge Problem!
  162. knocking????
  163. no power
  164. b18c1 or b18c5 and a smog question
  165. Dsm?
  166. Green harness under intake manifold on GSR motor?? IAB solenoid?? PICS inside!
  167. 1999 civic vtec damaged?
  168. Installing the "bitch pin" (shift linkage at tranny), Best way?
  169. Jdm Ecu
  170. Check this Honda out guys :)
  171. 4 wire o2 shock tower wire locations! Pics w/ detailed text!
  172. interchangable parts
  173. mini me swap dual carbs
  174. Exhaust smells like gas
  175. motor swap cost
  176. 92 honda accord
  177. vtec solenoid
  178. Look!! how do i solve rusted headers???
  179. new clutch ?
  180. notcing the block
  181. Seat Belt problem in Civic!
  182. Long block and Short block
  183. d15b head swap
  184. Tranny
  185. ECM help.....please
  186. 89 CRX Radiator Support
  187. H22s cheaper in canada?
  188. Plasma Booster??
  189. h23 specs
  190. vtec wiring HELP! Couple Q's and Pics!
  191. temp sending unit?
  192. Climate Control
  193. Chassis DYNO shops in So. Cal.
  194. need car buying stories
  195. 18'wheels
  196. synthetic oil
  197. Nopi...
  198. How do you adjust t.p.s
  199. twin scroll turbo...
  200. vtec
  201. just a girl, please help
  202. No Thanks...4 Stroke For Me Please!
  203. speedo is out!!!
  204. dumb lights
  205. difference in exhaust
  206. a20->b18 head swap???
  207. screwed up electrical parts bad help
  208. 94 Accord JDM Bumper lens
  209. Shaved doors...
  210. hmm...
  211. Alternator doesnt work right in rain, WHYYYY!!! PLZ Help
  212. 97 olds aurora
  213. 89 integra
  214. Valve Specs
  215. 4 Pt Safety Belt vs. Standard
  216. Looking For A B16a1
  217. Speedometer is stuck at 40
  218. Question on Intakes
  219. I Have Motor Questions!!!
  220. B20 vs B18c5
  221. PLEASE HELP P1457 emission code
  222. Anyone ever seen this????
  223. Snorkel Hood scoop and Ram Air.
  224. mini me question
  225. Major Newb: Exhausts
  226. d16z6 od d16y8 head???
  227. Valves suck
  228. right hand drive conversion
  229. Wiring the Eg / GSR up! Pics inside! Help needed! *56k might get 0wn3d*
  230. 2.3cl swap for h22a
  231. I need some major help..
  232. Need second opinion for next mod
  233. 95 B16a in a 96 Civic Coupe?
  234. How to....
  235. cam shaft and cam gears in b16a
  236. Exhaust Headers
  237. oil question?
  238. H22 in an 88-91 CRX
  239. fuel cut-off at 3500 on new ZC motor!!! Anyone know why ??
  240. B20 with GSR head: Valve clearance problems
  241. Day 3 working on the Eg / GSR swap **56k stand back about 8 miles**
  242. power for my baby
  243. 87 non si swap
  244. prelude throttle body
  245. Piston to Valve clearance and CR questions.
  246. 99 B18C5 into 94 Civic EX
  247. Csrv
  248. Such thing as a 92-96 H22 Type-S???
  249. my ZC fuel cutoff is 3500, HELP
  250. Timing advance on a '96 Accord LX
