View Full Version : Engineering/Technical
  1. B18C or B18C5?
  2. Need EGR Help
  3. gsr, or not to gsr
  4. i wanna get more power out of my b17 what do i do
  5. flywheel
  6. vtec controller
  7. help delsol nonv-tec with gsr vtec
  8. Turbo Timer Problems > Starter Motor
  9. Honda CRV head on Integra LS block?
  10. Honda 2.2L problem
  11. tranny swap for a lude
  12. 88 prelude swap
  13. will it fit?
  14. need 2 b taught
  15. Voltage Regulator Stuck?
  16. Replacing B16A3 with.........
  17. Supercharge, turbocharge, what will they do
  18. Can someone explain compression to me in english
  19. Honda Prelude Swamp B21A1 with B20A5
  20. looking to start building slowly..any suggestions?
  21. Engine Control Modules
  22. Conversion
  23. B18C1 vs. B18C5 vs. LS/GSR
  24. Prelude Engine swap help!!!
  25. B18C1 vs B18C5 vs LS/GSR
  26. Sun roof leaking
  27. Gutting a 1997 Honda Accord
  28. Type R fuel injectors
  29. Integra ECU for b18a vtec?????
  30. need advice!
  31. Honda Fuel System
  32. help on swap
  33. I need help swap b16 which tranny to get
  34. Cheapest Engine?
  35. Mugen Grill for 94-97 Accord
  36. ECU Question
  37. Catalytic Converter Question
  38. hello
  39. hello
  40. Help for a friend!
  41. obd2 to obd1 cost?
  42. hondata
  43. car flooding itself
  44. 89' crx with B18A motor swap...questions.....
  45. Transmission? problems
  46. Buying Intake etc. for a swapped engine
  47. Need help with 1990 Accord
  48. Kinda dumb but: Iridium vs Silver?
  49. honda civic swap
  50. Throttle 'Lag'
  51. mix and match
  52. Im clue less
  53. B16B buildup questions
  54. inline 6 honda motor??
  55. h22 swap
  56. clutch shrudder
  57. B16A or B18C
  58. How do i change gear oil?
  59. Tranny removal on 98 civic Si
  60. when do I have to check transmission fluid?
  61. Performance of a B16B
  62. DX harness
  63. New to Fiberglass
  64. Civic Type R specs and pics
  65. CAMS and Stroker kits
  66. Moon Roof
  67. oil in spark plugs
  68. JDM Companies
  69. failing clutch?
  70. times
  71. timing belt
  72. H22
  73. What's better mini-me or D16Z6?
  74. Air Conditiong-Old vs New
  75. Transmissions
  76. JDM Engines
  77. Car started rough after car wash
  78. What is the most effective way to increase torque and low to mid end power?
  79. Pushrod vs DOHC
  80. Diff. between turbo and supercharger?
  81. Disc Brake Problem: Frequent Scoring.
  82. just a lil confused on swap
  83. Engine Identification
  84. b18a and b18b whats the difference really need to know!!
  85. Longblock or shortblock?
  86. Oil?
  87. Lights question
  88. Civic EX or Integra GS-R?
  89. H22a swap
  90. I swear i didnt write that! sorry for the bs!
  91. H23a head swap!! ? need help
  92. Civic Ferio logo
  93. JDM Type r Wheels specs
  94. ported polished and milled
  95. OEM Tail Lights
  96. 01 civic swap info
  97. 90 civic si hb engine swap help
  98. '97 JDM Accord SiR into 'USDM 93 Accord SE....any problems???
  99. check engine light on jdm b18c
  100. suicide doors
  101. super or turbo
  102. 4th Generation Power Folding Mirrors
  103. 2003 civic engine swap
  104. VIN checks
  105. When do I need a FPR?
  106. 4wd Integra? Likely possible.
  107. oxy enrichment
  108. Short wheel base vs. Long wheel base
  109. I have no clue what the hell that means!
  110. Civic 2002 Engine code
  111. 90 civic hb
  112. Engine doing something VERY strange...
  113. Help aftermarket info
  114. HElp plz
  115. What fits in my car?... I want most possible torque and hp available...
  116. Straight pipes
  117. help gsr wire harness
  118. Turbo on an LS
  119. battery
  120. S2000 engine code
  121. Where can I get a high flow cat. converter...
  122. Engines
  123. v-tec???
  124. Please Help Me
  125. Getting to Hard to reach Spark Plugs
  126. Air conditioning recharge question...
  127. Levelling Brake and Accel pedals. Also wiper fluid nozzle.
  128. cost of crvtec?
  129. How to install rear seats on 97" GSR?
  130. 1996 Cavalier - cylinder 4 misfire, barely runs
  131. b16a1 into a 98 EX
  132. Help Gsr
  133. Ok, who knows cars? help me out here
  134. Rods And Pistons
  135. Plz Help - Car Goes Vrrruuuuut
  136. W engines???
  137. rough running lumina HELP
  138. Maintenance Requires Indicator
  139. Reglage Apexi V-AFC on B16A2
  140. Exhaust Video Clips
  141. How to Install Rear Speakers?
  142. How to instal ground wires
  143. Cam Gear Installation
  144. !!! Important, Dirtbike Owners !!!
  145. How much should i offer this dude?
  146. What should I do?
  147. b18 head on what bottum end?
  148. One Piece headlights
  149. Civic or Integra engine??????
  150. strut bar
  151. Mach 10 Chip
  152. Where to get oil line for B20/VTEC
  153. fuel pumps
  154. H22/F22 parts
  155. H22 or H23 for Accord?
  156. passing smog test
  157. b21A1 swap in a 87 si
  158. Smoged car didn't pass Knox
  159. Adding HP with bolt ons...
  160. 1984 Mercedes Benz
  161. To do or not to? H22A swap
  162. Accord Front swap?
  163. LS/Vtec (Conversion/Swap)
  164. make up my mind
  165. buying h23
  166. motor swap
  167. Engine specs
  168. top speed
  169. 98 Civic and 91 Integra swap questions
  170. cam gears, help please!!
  171. computer
  172. Cam Gears, what are best?
  173. Cam Gears, what are best?
  174. shotpeened
  175. Does anyone here own a..
  176. internals---JDM or not????????/
  177. !!!!!HELP ME !! No more VTEC at 5 RPM
  178. Spoon Engines???
  179. H23 Dohc Vtec Blue Valve Cover?
  180. H23 Dohc Vtec Motor Bloue Valve Cover????
  181. Spoon Specs?
  182. Balljoints Question
  183. 85 S-10 Blazer
  184. Merkur XR4Ti Turbo
  185. wiring diagram for civic o2 sensor
  186. info
  187. o2 sensors with b16a1
  188. Oiltemp sensor B16A1
  189. 1999 Accord swap for 2003 accord?
  190. Manual Transmission for 01 Accord LX Coupe
  191. 96 civic hatch engine swap ?????
  192. swap decision time? help
  193. having problems
  194. stripped bolt what do i do!!
  195. iridium plug cracking and falling into piston?
  196. intercooler design
  197. clutch
  198. Post you Hp Per Cubic Inch.
  199. Cam timing marks
  200. wierd noise at 3000 rpms
  201. AEM V2 Intake
  202. VAFC or SVAFC???
  203. Everything Flickering
  204. Does anyone know actual engine weights?
  205. F/S JDM FIELD SFCVTEC controller
  206. Complete list of swap parts
  207. Serious help needed on Toyota Camry
  208. Spoon info
  209. rev limitor at 4 1/2?
  210. 2001 Accord brake pads last 3000 miles???
  211. H22 in a 96 HB?
  212. Question About Diesel Engines + Emissions.
  213. Changing to synthetic oil
  214. changing a muffler
  215. droping weight
  216. Help!!!
  217. RPM Gage
  218. sidemarker placement (EK)
  219. Where can I buy....
  220. Torqe Wrench Use?
  221. b16 into a 98 civic
  222. supercharging an h22
  223. Have an odd electrical question
  224. 4 bolt pattern....?
  225. 92-95 civic steering going out?
  226. JDM / UK Shop Manuals
  227. ECU in B16a?
  228. KYB AGX Gas Shocks for Civic
  229. Wiring for swap question
  230. h23 into my 88 htch dx???
  231. ZC into 91 civic LX
  232. Fuel
  233. Exhaust & Air Intake
  234. Building a racing automatic tranny
  235. axle question/problem?
  236. what should i swap into an accord?
  237. C2 tranny?
  238. speedometer acting crazy
  239. How do I do these things?
  240. power to weight and torque
  241. apexi
  242. Problems after b16a swap
  243. Exhaust Problem Help!
  244. What Is A Cat Grrrrrrrr
  245. Cat removal
  246. which one would be more practical?
  247. Auto to Manual Conversion?
  248. Bunch of Exhaust Questions
  249. info on engine!
  250. ground wire kits?
