Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
> Engineering/Technical |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
Engine rpm going to 3-4k when applying brakes.
CVT better than manual?
help blows hot when driving not when stopped
infector diagnosis
Adjusted v clearance, now stutter on throttle
Looking for an in line fan
Engine Control COmputer Programming
Transmission mounting problem
How is this done?
electric water pump
Radiator to frame
01 Yukon auto ride
Disadvantages of not having a hood...
hydraulic clutch problems
1998 3.0 pushrods/rocker arm installation
I Need Help
Auto Ride Error Message
All Wheel Drive
ects snow feature
small radiator problem
Need help on this..
Fuel under the valve cover???
Slipping reverse Chevy Venture
Random rpm loss in 2002 millenia
Swapping Air Conditioner System
Tire pressure affect on tire size
Poor MPG on a New Rabbit
CNG engines
differences between diesel and gasoline fuel
Hubcap ID
Escort mk2 track control arm
1991 c3500 chevy brake hydroboost
1995 talon wont start
How do i install a wiper motor?
94 taurus
brakes?
Question about max rpms
How 2 Write Complex Device Driver In Autosar
How do I clean my truck's cap?
95 Discover Range Rover stuck in park. Please help
stolen car advice needed please
Starter?
Physics of Engine Vibration?
Name of a Part?
Cylinder Head interchange
Stripping rear bumper Paint
I need two know the firing order of 95 firebird..
Hm, just a thought. Multiple brake pedals?
Should i have coated my intake manifold?
Problem with the Chevy 3100 engine
Engine stand setup?
acceleration problem
Brake Question, need help
sway bar link problem.
HID Questions...
exhuast question
Missing on 2 cylinders
Can a jump start kill your starter?
new starter?
Tahoe Barn Doors Removal
Starting problems on 84 Chevy 305
1988 GMC Sierra Exterior Door Handle
93 suburban wiper motor intermitant
Rotary enginess
V6 question
Head Gasket Question.
replacing key to a 1997 Ford Mustang
Body Panel Name
Intresting problem
octaine question
Anti-Roll Bar bushes
alarm sensitivity
Roll Cage Materials
Please Help
MAP or MAF Sensor?
simple question concerning junk cars
electronic ignition
steam engine
premium
Replacing door in 1998 Olds 88
Battery Recharge Question
Wiper blades
Six Stroke - The answer to our addiction to oil.
Olds Cup Holder
job hunting
4g63 swap in s10
Dodge Omni Fuel issue
Suggestions for heating box with canopy? really Need help!
Thermostat opening temp
automotive magazines
99 grand prix gtp. Annoying problem no heat!..Cold!!
dex-cool leak venture 2000
"car turns over, but wont start"
Hydrolock
Computer Compatability?
Shifter boot
2006 Vue... alignment?
Warped rotors again
civic trans swap
Olds 350 motor mounts
underbody rust
Can I fix a bent aluminum alloy rim??
01 honda civic timing belt replaced no start
Ethanol Compression Ignition.
Acetylene as a fuel
Side Airbag
2001 Grand Cherokee Laredo jerks as I accelerate
Brake grinding issues
Rear wheel/tire noise
Engine question
Windshield Help
Making a car more efficient by adding a turbo??
Power surges... resulting in damage in mazda 626
Check engine light
getting started?
2000 Dodge B3500 Conversion Van
replacing a windshield
Brake rotors and pads
89 Oldsmobile Cutlass Ciera Dies!
catalytic converter Q
Grounding Troubles
Where are my spark plugs?
Roll Cages
RPMs raise as I drive.
Good Idea or Not?
94windstar/91taurus drivetrain swap
turbo or no
Dead Battery - not enough driving
Do these gadgets really work?
93 S10 Blazer Western Unimount plow not working...
Gear Shift Problem....Please Help!
Subaru Tranaxles in Kit Car
wont start
how come... deseal
propane
Switch from AC to heater
Variable length intake runners
Seat Repair Side Airbag Deployment
Airbag, brake lights on !!! Help please!!!
knock
what meter do i need 4 power in batt?
ground wire question
Dropped oil pan, do I need to prime the pump?
Need help...
2002 saab 9-5 relay
super vs turbo
radiator?
what's this noise?
what school is better?
Suddenly won't start
motor swap
limited slip dif.
How to get a torque converter off a van
AutoXray 4000 extended codes
Cat-Back Exhaust Question
sensor cost
Clicking noise when braking after changing front axle
Air Conditioner is always on
V8, V6, cylinders
Civic Intake?
Problem with my Prelude
HELP LHS Starting issues PROB easy fix
think my gears stuck
question i always wanted to ask
swar bar for two cars
cluch?
Problem at Warm-up
Synthetic to Conventional Oil
Where do I find my ECM on a 95 C2500
Oil filter sales by rank
how to check valve seals and valve guides
Recommendations
where can i learn more
Clutch Failed
Isuzu Hybrid Truck.
twilight sentinal
leaking transmission fluid 77 vette auto
95 JGC Stalling
New to cars - need lots of info
Transmission Differential
how do i adjust my adjustable suspention?
diesel engines
quick q
Project: Lincoln LS Drivetrain
98 Galant
1k or 5k tune up.
ball joint boot crack: replace or re-grease every 3K Miles
remote starter
Help!!!
B&M Shifter...
transmission woes. please help!
'96 Jeep w/'98 trans ???
fire under hood!
Sun Visor Sticker
egr
my turbo'd spitfire
89' ranger 2.3l 5 speed tranny swap
4 and no more
Silverado pass. Window!
Trailer Hitch, class I or class II?
Aviator low voltage problem
I'm toast!
cooling system on my saturn
Gas Gauge Broken
Gas won't flow steady into tank
cooling systems on a car
to convert ngv to electrical energy
95 chevy 2500 454 with spark and fuel wont start
crankcase ventilation system
Canadian Tire's "CounterACT"
1969 volkswagen sandrail engine timing
Reading Fault Codes OBD2
TH400 trans. w/ ratchet shifter question...
Gasket Advice
AWD question
Brake Job: Dealer versus Muffler Shop
http://www.performancechip.us/
Stalling my car
95 Corolla DX - HP Limit
wanna beat an evo
Unusual Technical Question
98 tahoe 5.7
Spark Plug Socket Boot
about a compression test...
One problem to another... starter
engine swap
gas have lubricating values ?
Trouble with installing neon lights!
Looking for Supplier
narrow and wide band O2 sensors
engine braking effect
volt meter verses amp meter
AXOD trans
please help with advise
Car won't start
MOD Chips - What are you thoughts?
thieft
alternator rectifier smoothing
08 ford backup camara
Scan Tool review
Looking for the truth on a buncha different topics...
Your opinon about PhotoBlocker? Does it work?
1992 Toyota 4 runner alarm issue
Alarm troubleshooting
Need Help Buying Tires - Please!
obd 2
Passenger seat won't lock into position
restore my camry's performance
e250 messin with me!
Cheap and easy Lowering Kits
Web
AF
