View Full Version : Engineering/Technical
  1. An Answer For Negative Grounding Of Vehicles
  2. It Happened Again!
  3. Noise from Engine Bay
  4. bleeding air out of power steering
  5. Mechanical choices.....
  6. Seeking advice on scratch built car design/ideas
  7. Front end alignment?
  8. honda civic motor siezed up
  9. Which sensor will cut fuel pump?
  10. What color Antifreeze!
  11. PVC Valve
  12. ase certification
  13. flushing the heater core
  14. Did Discount Tire Store Rip me Off?
  15. Any current cars with timing chains rather than belts
  16. Replacing Passenger Front Axle
  17. Ants in my car...!
  18. Van halla
  19. heater question
  20. Replacing Old Tires
  21. All-In-One Service Centers
  22. HELP Green marking on master cylinder
  23. what is this part called?
  24. Pro Start 3471 Thermistor Value
  25. Prostart CT 3300 No start and 3 blinks?
  26. Help. What is this?
  27. engine oil in coolant
  28. Always Fun: What is your favorite muscle car!?
  29. Crickets . . . .(chirrp, chirrp, chirrp)
  30. camer93
  31. Crossmember Interchange
  32. Aldl monitoring software for L01
  33. Lighter performance parts
  34. is car servicing important
  35. Dificulty of engine swap
  36. HID xenon noise/interference???
  37. Power Steering whining!
  38. Cooling System Electrolisys
  39. ECU's, cams, and fault codes, oh my!
  40. Tire confusion
  41. CLogged, and I mean CLOGGED....
  42. a few parts pros and cons questions
  43. pass thru questions
  44. Does anyone know what this part is called? Need replacement
  45. emissions test set up for wrong engine
  46. Slightly oversized winter tires vs All-season
  47. Acura radio won't work
  48. Radiator fluid question
  49. Bad Torque Convertors
  50. 2.2L Ecotec timing slack question
  51. auto repair and towing
  52. Wild About Cars is looking for your help
  53. Mounting body over a spaceframe chassis ?
  54. radar detector not working.helpp!
  55. Good and Easy Anti-Theft Device?
  56. This voltage stabilizer helps save fuel
  57. Two deep scratches... need help
  58. Convert Gen-3 Firebird To Independent Rear End
  59. Air Conditioner damage
  60. Need to pass emissions test
  61. Engine size, IDs
  62. Transmission Repair
  63. Shaking Steering Wheel
  64. Pictures of 1980lb sports car that I built from scratch
  65. Transaxle for mid mounted BMW V10
  66. is it possible to have 4 wheel drive installed onto any car?
  67. Headlight Lens Repair Question
  68. Quick question on thermostat operation
  69. Broken Camshaft
  70. tighten steering 1974 cj-5 jeep
  71. Geo with 3 straight pipes?
  72. re-building 1954 gmc truck
  73. 3 Wheels From Sway Bar
  74. 2010 "Firebird"
  75. Radio control car
  76. Cylinder number 4
  77. No horn with remote lock function
  78. rims for 944 porsche
  79. Got in a small wreck and now car is making strange sound
  80. Improving Steering Feel/Tightness/Return
  81. Oil pressure light goes off when I'm driving downhill (Audi 80)
  82. why is my clutch down stuck on my nissan pathdinder??
  83. Ac pully question, need help fast.
  84. OBD non communication
  85. death upon acceleration
  86. vacumming AC system question
  87. Carburetor Guru needed
  88. Vibration while accelerating
  89. loss of power while driving engine doesn't shut off and idles fine
  90. lowering springs question...
  91. Car Battery Question
  92. damage from someone backing into me
  93. 2004 Grand Prix P0107
  94. PA Inspection
  95. Service Engine light goes on and then goes off.
  96. What are necessities and options in painting on fiberglass?
  97. Non-Mechanical Steering
  98. What enables a car to do this....? Crazy
  99. different price listings
  100. Silverado 1500 7 pin trailer light problem
  101. 1991 Ford Escort won't start
  102. 1997 gmc serria truck not starting (no spark)
  103. New pc based scanner and software.
  104. info on ecu repair
  105. 100,000 mile maintenance question
  106. Nissan trouble
  107. 2002 F250 7.3 Liter
  108. Easiest Way to replace a clutch?
  109. Car engine is shaking and I can't accelerate or reverse.
  110. Questions
  111. Horn+Head Lights will not turn off?
  112. Trans/clutch issue, what you think?
  113. Bleeding brakes is supposed to be simple right?
  114. Got a car. Have questions. Shifting, engine oil, and punctures.
  115. Would you pay to help assemble your next new car?
  116. Please solve this 'riddle'...
  117. Jeep Cherokee leaking coolant
  118. A/C & Fan Issues
  119. Really need advice on oil pressure issue
  120. Car jumps during turns at 50mph
  121. E-boss
  122. Computer problem?
  123. Part's i need to run 15 psi of boost on my stock B20b
  124. Antifreeze in gas tank
  125. cavalier oil pressure issue
  126. Apexi VAFC Question
  127. Front brake rubber hose twisted?
  128. lost power while driving
  129. 400
  130. Oil question
  131. honda clarity fcx
  132. need urgent help on this old red 1990s mirage
  133. Painting vinyl & plastic
  134. Burnt clutch?
  135. A/C Compressor short cycles after charge
  136. Tranny fluid on spark plugs
  137. Ignition Coil
  138. timing belt or chain toyota 2.7L ?
  139. basic clutch adjustment
  140. Process for making complex shapes in cars?
  141. Do It Yourself ATF Flush
  142. Proper clutch use and replacement.
  143. Automotive Maintenance Software
  144. P303 Misfire 2003 Hyundai Tiburon
  145. Lowering Springs Question
  146. How can forced induction increase engine efficiency?
  147. Do i need an oil change?
  148. no spark
  149. why does my fornt drivers side axle keep breaking on my Cavalier
  150. Over due oil change
  151. BBC No Oil Pressure
  152. my insurance company offers a sensor to track my driving habits
  153. Drooping O2 Sensor voltage?
  154. speedometer question
  155. Need help with my 05 dodge neon
  156. Tony DePillo's SS/B '64 Savoy Race Hemi
  157. Temperature gauge not reading right...?
  158. need holley experts
  159. Need expert advice on wire wheels
  160. Patching a radiator leak
  161. Engine oil for Civic ferio 2004
  162. left taillight wont work
  163. check engine light stays on
  164. Mechanic charged me for $400 and my car wont even work.
  165. Advanced Alternator/Battery Question
  166. Check Engine Light - weak acceleration
  167. old catalytic converter
  168. airco fill-up gone wrong?
  169. burnt clutch!!!
  170. Need Advice on Repairs For a '91 Ford Escort
  171. Coolant Temp Sensor and TPS sensor problems?
  172. Do Some Tires Have Better Straight-line Stability?
  173. 1990 camaro
  174. 86' bmw 325e won't start
  175. Carter Carb Help Question
  176. brakes dragging
  177. coolant temperture sensor
  178. Tire Balancing or Alignment?
  179. Pointing the front wheels straight ahead
  180. audi 1.8 turbo
  181. Vibrations / sound at high speed
  182. Need Help - Difficult Problem
  183. coolant question
  184. MultiAir / UniAir vs PatAir / PattAir
  185. belt in A.C.
  186. swap engines
  187. Knowledge about cars
  188. Wiring up some lights.
  189. ASE exams
  190. 2002 dodge stratus transmission
  191. Car starts will not stay running
  192. got new battery for old car, it wont start
  193. Engine finder
  194. A/C Help - 94 Plymouth Sundance Duster
  195. Signalltone air horns
  196. Need help using voltmeter...
  197. Need help understanding turbo surge from lack of preasure (air flow maps help)
  198. Engine and fuel efficiency. And other major factors.
  199. Rear end sag
  200. prostart remote starter
  201. internal engine damage
  202. What size cable/wire for indicators
  203. Oil Light
  204. chevy truck help
  205. Th350 Wont Shift
  206. Air dam fell off
  207. car only starts sometimes
  208. Peugeot 206 radio volume issue
  209. LCD info panel on Peugeot 206 broken up
  210. Leisure battery losing charge
  211. Would this kill my battery?
  212. Fuel in intake manifold
  213. Suggestions for donor car
  214. Suggest a 4WD that will go lower.
  215. Cylinder head question
  216. Increasing bike engine size
  217. Dyno Testing
  218. Pairing up old catalytic converterwith new one
  219. Input shaft end play
  220. 408 stroker motor
  221. Nail in tire. What are the dangers?
  222. 94 prizm transmission issues
  223. BIG problem with Power-assisted steering and brake servo
  224. Stuck wheel
  225. How much should replacing the front brake pads on a 2000 Grand Am GT cost?
  226. Car won't start after it gets hot
  227. Average temp ranges?
  228. Lean in combustion chamber, rich in exhaust. HOW???!! PLEASE HELp...
  229. engine immobilizer car will not start 2007 mustang
  230. Backfiring Through Carburetor
  231. GTO camshaft
  232. 4x4 everyting
  233. diameter
  234. Good with wiring? NEED HELP!
  235. fuel pressure low?
  236. Need answer ASAP about brake and Power steering fluid
  237. Jumper cables and possible surge issues to electronics with new vehicles
  238. Escort 8500 X50
  239. mid engine concept.....
  240. overheating
  241. CNG to Gasoline
  242. problems with ECU??
  243. distributor cap and rotor
  244. celica rear wheel jammed after winter storage
  245. Help: turbos differences?
  246. Mazda 2004 Code P0421
  247. "Rev protector"?
  248. question about car battery booster
  249. timing a corolla
  250. Whats driving a muscle car like?
