View Full Version : Engineering/Technical
  1. engine swap
  2. Oil-changing tip
  3. how to install my tach on a b16?
  4. 2 liter gsr build
  5. GSR or CR-V????
  6. classic argument
  7. Finally
  8. Power window problems
  9. Turbo B15 help ASAP
  10. getting 4g's on the 15 and 2g's pn the 29th
  11. Turbo Question
  12. i need help with motor swap
  13. ignition ?
  14. OBD 1 type R ECU
  15. How to replace Headlights 94-97 Integras?
  16. B16A Head Polished and Ported
  17. V-8 S-10
  18. idle problem
  19. V4 advantage
  20. HELP need more power from the D16y
  21. thoughts
  22. b16 engine problem help!!!!!
  23. How VTEC works
  24. 3rd gear grind
  25. turbo on a b18c5
  26. mugen twin loop copy
  27. 2nd grind...
  28. Air Bypass Valve
  29. Tranny swap
  30. Starting problems
  31. V8 Cam profiles
  32. Full H22 system swap for del sol
  33. Type r parts
  34. Drum problem
  35. best for turbo
  36. Project help needed
  37. UnderDrive Pulleys ECT, are they worth it?? COMMENTS!!
  38. USDM parts in Japan?
  39. mini me swap
  40. should i get JDM
  41. how to rev to 9k ?
  42. ls or b16?
  43. crane cam ignition.
  44. Tranny Problem
  45. Aftermarket anti-lock brakes?
  46. my cars slow?
  47. roadrunner
  48. Physical difference between GSR and Type R motor (B18c1 and B18c5)
  49. Cheap pontiac muscle
  50. Cars you wished you'd kept.
  51. D16z6 swap
  52. b18b1 prices
  53. Questions on 71 Javelin AMX
  54. Is an EGR valve like eating poop?
  55. new synchros
  56. '87 Gnx
  57. engine swap help plz
  58. vtec controller
  59. Clutch noise
  60. Engine Swap
  61. was up
  62. power steering
  63. Sound Clips/Videos so I can hear the sound of ur muffler!
  64. Hydrolocking
  65. Downpipe
  66. free stuff
  67. What v-tech would best fit my 84 prelude
  68. Timing Belt Change
  69. full jdm conversions??
  70. H22 timeslips???
  71. flat 8
  72. Need a RHD steering conversion facility
  73. Is double clutching bad?
  74. whats faster LS/v-tech or h22
  75. Compression Ratio for Pump Gas
  76. Fog Light install
  77. New guy with a few cold air questions
  78. B16 hesitation and unplugged holes
  79. Timing belt jumped?
  80. Help, I need some Flywheel recomendations NOW!!
  81. What to do?!?
  82. b18b1 cam gear timing
  83. General Lee
  84. vaccum/fuel prob 96 kia sehia
  85. Ecu
  86. Someone help me with a engine swap!!!!!
  87. in need of a b18
  88. 1991 Honda Prelude 16V 140HP
  89. geo prism remote
  90. Newbie Need Help!
  91. In need of HELP!
  92. Engine & Transmission
  93. Timing Problem
  94. No fuel to carb.
  95. Chevelle Build Up
  96. Dohc & Sohc
  97. A little help for a nUbie
  98. teg GSR vs. lude si
  99. suspension settingsTEIN
  100. Pronunciation of Mugen
  101. Engine Swap
  102. best head for b20
  103. Good Engine Swap
  104. Engine stalled while charging AC
  105. Electronics Problem
  106. Rev limiter??? Distributor???
  107. VOTE for your favourite classic Aussie coupe!
  108. b16a SIR 1 in a 98 civic
  109. VOTE for you're favourite Aussie muscle car!
  110. Compression Test on DOHC Vtec engines
  111. Need help please
  112. CTR headlights bulb designations HELP
  113. Need help with my civic
  114. swaps in nj
  115. Help with a 73 duster!!!!!!!!!!!!!!
  116. need help please
  117. JDM Type R
  118. throttle body size?
  119. Convertible Top Repair Myself
  120. anyone know how to install coilovers on a 97 accord?
  121. trueth about magnets on air and fuel hoses?
  122. Which Valve Angle to grind
  123. RB20DET/SR20DET for my 2000 Civic
  124. Coil
  125. Car Wont Start
  126. H22a Swap Question?
  127. To Swap or not to Swap
  128. Is it worth it to fix up an '85?
  129. Q. on Shift Problem
  130. Help me go faster
  131. head gasket swap
  132. 99% Noobie
  133. C32b
  134. i need help with a new decision
  135. muscle car quick trivia
  136. Question for ctr engine owners
  137. civic header question
  138. Blow Off Valve required?
  139. my b20 vtec
  140. b16a idle bouncing once warm
  141. b16a idle problems bouncing when warm
  142. Wheel and Tire sizes
  143. If you are a 95 Civic EX owner you might/need to know
  144. got a question and i gotta know soon! Garrett TA-51 turbo
  145. Valve Lash???
  146. K20A2 stock cams
  147. Fuel Cell Car Performance Specs
  148. Need help with switches, LEDs and fuses ...
  149. Please Help!!
  150. The Best 60's Pontiacs
  151. Anyone ever buy an engine online??????
  152. Welcome MuscleCarClub.com
  153. Rb26dett
  154. Rb26dett
  155. Fuel Injector Life Expectency
  156. CRVtec
  157. ebay chips
  158. 1979 Buick Roadhawk
  159. Yenko Vega Stinger
  160. Cable vs. hydraulic tranny
  161. body differences between 96-98 civic &99-00 civic
  162. D16a1 Swap
  163. was up
  164. Quiafe LSD
  165. teggy compression
  166. Pantera owners?
  167. tuning recommendations
  168. I need help with this decision
  169. first car- exhaust
  170. Separating Type R Tranaxle from Engine Block
  171. Header for Crx w/B16A
  172. Welcome!
  173. Welcome!
  174. Welcome
  175. Welcome!
  176. Lsd
  177. North Carolina Emission Laws?
  178. What type of car do you have?
  179. Low fuel indicator light
  180. Welcome Pontiac muscle car fans!
  181. Welcome Plymouth muscle car fans!
  182. Welcome Oldsmobile muscle car fans!
  183. Welcome Mercury muscle car fans!
  184. Welcome Ford muscle car fans!
  185. Welcome Dodge muscle car fans!
  186. Welcome Chyrsler muscle car fans!
  187. Welcome Chevrolet muscle car fans!
  188. Welcome Buick fans!
  189. Welcome AMC muscle car fans!
  190. Welcome! (A message from the moderator)
  191. EDM B16A1 engine
  192. Electrical Issues/troubleshooting
  193. No posts?
  194. 1970 buick GSX
  195. Own a B16B too
  196. So many motors? but what should i do
  197. Which engine would you recommend?
  198. Which engine do u prefer?
  199. check engine light on hELP!
  200. Tranny Troubleshooting
  201. Regain Performance On Beat Up Engine and Trans
  202. what head to put on b20?
  203. D-series engine swap
  204. fuel pressure riser (stillen)
  205. quick start question
  206. Check This Out
  207. quick question about torque converters. . .
  208. Diff intakes
  209. H22 in Civic
  210. jdm engine dealers
  211. Question about KYB AGX Shocks & Struts
  212. Performane Chip Questions
  213. new driver, new car
  214. Air intake for Integra
  215. power steering fluid replacement
  216. Power steering
  217. b16 NA
  218. The TORNADO
  219. ZC compression
  220. Which b16 engine do you recommend for a 5th gen. civic?
  221. H22 Swap .... info needed
  222. Small Dent Removal
  223. Could you ?
  224. Moonroof
  225. how to remove door panel from a 92 civic for speaker installation????
  226. tranny
  227. information required
  228. Obd2 sample source code
  229. HKS Hiper Exhaust!
  230. possible bad alternator?
  231. 94 civic b18c5 swap?
  232. transmission swap from auto to manual????
  233. K20 Mugen ECU
  234. Drive axle question
  235. stripped altenator bots
  236. b20 turbo swap
  237. Need Suggestions on engine
  238. what's this noise i'm hearing??
  239. NAPA Exact Fit wiper blades
  240. engine width-wise
  241. Motor will not start.
  242. B18c into a 91 integra
  243. Need help passing MA emmissions test
  244. unorthodox racing Sc (street crank) pulley
  245. Problems with My 92 Cavalier
  246. b16a
  247. b16A3 or b18b1? Turbo or NA???????
  248. CE light after installing coldair intake
  249. Wastegates and BOV's
  250. adding horsepower
