View Full Version : Engineering/Technical
  1. Del Sol owner looking for B16 engine
  2. SiR2 Block From Japan w/ Internals...
  3. alternator belt for b20vtec in EG
  4. Gibson Exhaust for chevy blazer? good/bad?
  5. Calling all enthusiasts...
  6. Please Help!!!!!
  7. F20A Motor Swap
  8. DONT BUY FROM THIS GUY!! admins please make a sticky of this
  9. How fast will i be w/ a B16A w/LSD in a 93' hatch.
  10. 99 Si
  11. cheap mods!!!!!!!!
  12. E-Bay Auction
  13. What does the distributer do?
  14. Building a H23a Engine
  15. Help on project... (Turbocharging)
  16. What grade fuel do you use?
  17. Insurance on 60's cars?
  18. GReddy Profec-B VS. GReddy Profec-B Spec II
  19. Mustangs smoking me.......Help!
  20. Exhaust Theory
  21. messed up gearbox
  22. remote starter
  23. Engine Cranks Longer When Cold
  24. Surging idle after motor swap?
  25. Transmission leaking
  26. Knock/Ping?
  27. Ls B20
  28. Best Head Gasket
  29. how to take out my power steering??
  30. My guess
  31. ZC engine bogging
  32. air\fuel problem
  33. What Mods should be done to a F22a SOHC to boost HP's etc.
  34. skunk2 SFC or Apexi VAFC
  35. which handles better 69 camaro or mustang?
  36. n00b question- 2002 Civic head light question.
  37. What happens after 100K?
  38. 92 Integra JDM 1 piece headlights ... HELP!!!!
  39. Ground wires kit question
  40. Gauge Wiring problems
  41. bad a/c compressor
  42. how do i add a pic to my sig ?
  43. Problem: Blown Headgasket
  44. PCV Valve question
  45. just saying hello . any PITTSBURGH people here ?
  46. crx axle nut removal
  47. I have the same Clank
  48. gtech pro
  49. Newbie to engine mods
  50. noise when i turn
  51. 1993 Accord EX H22 or H23
  52. Engine Swap h22 in 99 honda civic
  53. Pcv Valve?
  54. ecu question
  55. b20b non-vtec
  56. GM fuel pressure regulator Q
  57. Question about variable vane turbochargers.
  58. installing clutch without dropping tranny?
  59. 92 Prelude F22a what is the HP????
  60. I am new, and I got questions
  61. 4-2-1 header in a one piece or two piece?
  62. JDM Type R Integra
  63. Maintenance Light
  64. B16
  65. quick question
  66. What should I expect to run in a LsVtec and a CrVtec both stock and fully built?
  67. dirty oil and emissions
  68. auto tranny question
  69. Tranny question
  70. Speedometer not working.
  71. b18b1 turbo (LS)
  72. JDM OBD-1 B16a head for sale, OBD-1 B16a engine harness for sale, GSR intake manifold
  73. I need a b18C5 for a swap
  74. b18c1 swap in my 93 teg
  75. what type of engine should i choose??????
  76. q's
  77. Where can I find a b20 block from a cr-vtec?
  78. What should I expect to run in a stock ls-vtec? And also a cr-vtec?
  79. h22a swap, emission tests
  80. What should I expect to run in a stock ls-vtec? And also a cr-vtec?
  81. Honda Acc Fuel Pump
  82. auto to manual mess up
  83. Turbo LS/VTEC.....
  84. 1972 Pontiac Lemans...your thoughts?
  85. COld Air Intake
  86. Found a car to put my motor in, need help
  87. headers
  88. B18c5 versus B18c1
  89. 69' BOSS 302 VS Camaro Z28
  90. used car/fluid questions
  91. B18B into 93 Civic
  92. 1998 S10 Question (electrical)
  93. What's typical compression on GM 3.8L?
  94. warming up my car
  95. gettin ls/vtec got some q's
  96. clutch questions
  97. japanmotorimport.com
  98. I really need help with this grinding sound problem that I can't locate
  99. Hondata and Turbos
  100. HP Without Dyno
  101. Specs
  102. b16a or NOT????
  103. comp cam???
  104. battery seems dead?? help
  105. Very odd engine problem..need help
  106. 95 CX HAtch Swap
  107. DIY Exhaust?
  108. bad coil?
  109. Horsepower Question
  110. Tranny Question?
  111. B18c into my EF civic HELP????
  112. AEM V2 intake installation
  113. AEM CAI for Accord 1997
  114. Shame on Mugen!
  115. timing belt help
  116. What b16 Cable tranny has the shortest gear ratios? Where can I find one?
  117. W-30 ?
  118. motor swap
  119. Type R
  120. f22a1 swap
  121. f22a1 swap
  122. swaping in to my civic
  123. first car
  124. Big brake/rotor kit install help
  125. General shifting question...
  126. spark plugs
  127. Squeeking noise when I shift in low gears?
  128. engine care
  129. accord engine type
  130. New here just saying hello
  131. wastegates and BOV's
  132. B18c1
  133. custom return line or not??????
  134. Altenator for home power!
  135. My Type-R
  136. High performance crate motors?
  137. Best Car Movie
  138. Best Muscle Car Song
  139. Type-R ITR tranny....
  140. speedo problem
  141. TSB's
  142. head gasket....?
  143. Differences are between chevelle ss and a nova ss?
  144. Difference between a Chevelle and Nova?
  145. about getting Sponsored
  146. Ricochet! B16B Q
  147. drifting in a acura and d1!!!!it was asowme
  148. b16a2 and V-AFC
  149. b16 swap into 6g
  150. '66 barracuda
  151. teach me about the B series motors...
  152. how to install new xenon bulbs
  153. 99 Civic EX Swap
  154. What is milling your head?
  155. What is the difference between boring and stroking a motor?
  156. Best Tranny for Ls-Vtec???
  157. I want a faster Civic for daily driving!
  158. V12 @ 8500 Rpm ???
  159. Electronics on the brink!
  160. Oil Filter!
  161. #--- Help I Need Air ---#
  162. can I do anything with this?
  163. HELP! Clutch Pedal won't come back up.
  164. shop swap rates
  165. powerful engine
  166. jdm d15b sohc vtec
  167. Jdm Motors And Accesories For Sale
  168. i am wanting to do an engine swap onmy 92 civic please help me out
  169. d16z6 swap info needed!
  170. reading ecu codes
  171. Whats wrong with my car?!
  172. auto to manual
  173. b16a valvve job
  174. ZC timing belt question
  175. Speedometer Fuse????
  176. Starter bad?
  177. 1991 Acura Integra RS - Starting Problem
  178. engine reinforcement
  179. Exhaust
  180. 94 Blazer 5.7 Missing and Hesitates when Excellerating
  181. is it possible to put a turbo and supercharger under one hood
  182. is it possible to put a turbo and supercharger under one hood
  183. More Power???
  184. Vtec Controller???
  185. 92-95 2door civic H22A conversion / need experienced comments
  186. Engine Mods
  187. how to adjust shifting cable
  188. Is it possible to convert from carb to fuel injection?
  189. ls 1/4 mile help?
  190. Cheap muscle cars
  191. Turbo Stock LS or B16a2 LS/Vtec
  192. Engine Weights...Effecting handling?
  193. timing belt
  194. Change Manual Tranny Fluid on B Series
  195. dc header question please HELP!!!
  196. Hardwireing a Passport 8500.....
  197. Knocking (Rod knock?)
  198. acura distributor
  199. Raising Redline
  200. B18C1 in crx
  201. how to install cold air intake 98 civic ex
  202. ODB2 conversion to ODB1
  203. b16b
  204. Civic Speaker Rewiring
  205. corner lights!
  206. OBD II or OBD I
  207. synthetic oil
  208. I Feel Power Loss!!!!
  209. prelude digital climate control
  210. zc question
  211. timing belt
  212. help me with a tranny swap
  213. JDM B16A or USDM B18C1
  214. engine all loud when cold
  215. O2 simulator Question?????
  216. battery question
  217. exhaust question
  218. Whats the best classic 2 restore?
  219. head gasket
  220. VTEC problem!!
  221. LS/Vtec Really that good?
  222. I-Vtec vs Vtec, compare and contrast
  223. anyone with b16a jdm help!!!!!!!!!
  224. Honda 2000 EX
  225. o.k. its a dumb question, but help
  226. Refurbish
  227. ringing noise???
  228. ATTS indicator light (on your gauges)
  229. I think I have been dupped ?
  230. Grim Tranny Reaper (repair)
  231. 1994 S-10 pickup running rough
  232. best of the basics help
  233. tailgate locking mechanism problems
  234. engineering software
  235. Anyone ever seen this? Oil filter??
  236. gsr parts bolt to b20crv?
  237. crvtec or ls/vtec
  238. f22 exhaust
  239. white smoke???
  240. VTEC or not??
  241. Idle Fluctuation
  242. OZ Wheels - Cast or Forged?
  243. Please help! Whats crankshaft Horsepower?
  244. Missing Vacuum Hose
  245. Oil Tac gone crazy
  246. 2000 Civic EX Swap!?
  247. "Technical" learning websites?
  248. idle revving problem, mpfi swap ...
  249. why the swap?
  250. engine/tranny conversion
