View Full Version : Engineering/Technical
  1. Integra Cluster In Civic?????
  2. Catalytic Converters?
  3. B20 motor
  4. B18B and cable tranny???
  5. any INSPECTION sticker EXPERTS here ? HAWAII sticker question .
  6. GSR swap help Please
  7. Turbocharger and engine swap question...
  8. How to clean off engine?
  9. H22A Swap
  10. CRV-Tec
  11. engine question
  12. jun 2 cams
  13. FS - 92 GMC Typhoon
  14. Intake Manifold Swap Question
  15. gear ratios
  16. Brake Grinding....
  17. B20 Swap Help
  18. JDM B16A 2nd gen cams vs GSR cams
  19. water logged lights
  20. Best Swap?
  21. whats it worth?
  22. $'s the issue
  23. HKS vs APEXi
  24. Port size
  25. Cooling system desperation!
  26. damn you honda
  27. whats the diff
  28. Rough Idle HELP
  29. oil question?
  30. An idea?
  31. throttle bodies
  32. which h22 do we have here????
  33. rebuilt head... now rod bearing and oil ring shot... why?
  34. Rear road noise
  35. Help With reseting Used emanage
  36. CRVTEC base map
  37. Whining noise when in reverse.
  38. what would be a good engine swap 4 a 90 teg
  39. Ecu
  40. Angle Mounted Cat-back Exhausts
  41. Questions for the knowledgable: Type R Integra
  42. can you identify this distributor
  43. B18C5 swap
  44. K20a swap into 5th Gen. Hatch 92-95
  45. Reflective Tint??
  46. What is the best engine to put into a 97 civic LX?
  47. Engine does not start
  48. H22 Transmissions
  49. h22 mounts
  50. beef up the current motor or swap?
  51. gauge repair
  52. b16a lsd vs b16a non lsd
  53. no oil pressure to 70psi.?
  54. Cold Air Intake Question
  55. exhaust pop...
  56. Wiring and plumbing schematics
  57. 1971 Gs
  58. EX vs Si Civic
  59. CAI/Header Problem
  60. D series Transmissions
  61. f20c
  62. 2004 Gto
  63. 99 Accord,synth oil->engine making ringing sound
  64. sohc vtec...??
  65. Fuel Filter
  66. 94 delSol S with SOHC Non-Vtech. Mods?
  67. obd1 obd2
  68. Honda Inspire?
  69. Is an LS swap not worth doing?
  70. Tdc
  71. Alignment question
  72. Catalytic Converter
  73. S2000 W/ Turbo
  74. 1970 Roadrunner...Changing the starter.. =/
  75. 91 CRX HF Axles for B16A swap
  76. What do you think of my car?
  77. Engine swap cost!???
  78. Brake system replacement help
  79. Help with gauge cluster
  80. maintenance weekend project, need ideas.
  81. 2002 Honda Accord reverse gauges installation
  82. Clearing out the headlights on my 2002 Accord
  83. rear motor mount brackets
  84. Alcohol injection?
  85. Help ! Because of this I cant even drive to college !
  86. new kid on the block needs help!!
  87. turbo
  88. novas
  89. Stock motors
  90. s2000??
  91. EGR Valve & Port Cleaning Question...
  92. B20 Vs. H22 Which Swap Is Better????
  93. Rover V8 gearbox combos?
  94. Does size matter?
  95. Newbie checkin in.
  96. Any Torino owners?
  97. Gsr Head Gasket
  98. creating muffler fireballs
  99. Intake mani question
  100. have ls/vtec but rpms seem to rise slow
  101. Engine Codes...
  102. civic question
  103. Need some help in comparing Belt Tensioners
  104. Stage III Port/Polish Head Job
  105. the difference between h22a jdm&usdm
  106. the difference between h22a jdm&usdm
  107. Exhuast-CAI/Short Ram ?
  108. car problems valves or something else
  109. Cat Convertor
  110. exhaust manifold = car problems???? wtf??
  111. b16a2 swap info!?!
  112. engine swap or not??
  113. 88 Accord - My oil yearns to be free!!
  114. Getting ready to order JDM swap.......
  115. automatic to stick converstion
  116. Need some technical help
  117. oil pressure goin crazy
  118. AEM Tru Power Pulley kit
  119. H22a Into 94 Integra Ls Coupe
  120. Where do I hook up an A/F gauge on an Integra LS?
  121. Pricing on ported polished heads???
  122. Skunk2 Intake Mani.
  123. Distributor Cap
  124. about civic hb
  125. Oxygen Sensor and Code 1 CRX SI
  126. question about the infomation that subaru gives
  127. 99 Accord: Power steering stalls Engine?
  128. Custom exhaust and cold air intake
  129. Jdm Swap
  130. Looking for Onstar stories for article I'm writing
  131. Pinning?
  132. engine
  133. some Q's about my car
  134. 72 monte reastoraton or need to buy other monte
  135. jdm conversion
  136. intake manifold mixups
  137. White smoke????
  138. How do you...
  139. AIRMASS header?
  140. what to do?
  141. 01 Civic Engine Swap
  142. H22 Swap
  143. engine help
  144. Octane Booster
  145. Brake Questions
  146. Block sleeves
  147. Recommended Exhaust Systems
  148. dual throttles
  149. Painting plastic fascia?
  150. New cold air intake
  151. Project Mu?
  152. What do i need???
  153. Running with no muffler
  154. help sought!!!
  155. adjustable cam gear
  156. Dodge Grand Caravan Problems
  157. Changing TPS sensor..
  158. Catalytic Converter
  159. A few beginner questions
  160. A couple of beginner questions
  161. JDM/USDM shopping?
  162. losing some weight...
  163. Engine bearing help.
  164. Crower Valves springs and retainers
  165. anyone interested?
  166. Espelir Exhaust?
  167. Tripple Sticking -- Question for the Pros
  168. Ignition upgrade or not..........
  169. Ecu Codes
  170. redline when starting up the car
  171. Brakes help!
  172. external wastegate
  173. driving without power steering
  174. I need HELP, please?!?!
  175. jdm conversion
  176. Motor is screwd up and I Don't know whats wrong HELP!
  177. b16 question
  178. More Engine help please
  179. New engine swap problems, someone help me
  180. Cheap b16a's
  181. I Need Help??????????????
  182. Question about '99 Regal
  183. yet another s2k swap thread
  184. How do you tell the difference...
  185. How Much Boost...
  186. What Clutch To buy?
  187. uncontrolled reving
  188. B16 acting slow..
  189. B16 acting slow..
  190. horsepower definition?????
  191. New to hondas need help please
  192. Questions with Cougar!
  193. ls hatch
  194. holy shIIIt?
  195. COST$... H22 swap vs vtec head swap
  196. COST$... H22 swap vs vtec head swap
  197. help plz! my clutch??
  198. Help ! My clutch? help fast plz....
  199. 5th gen zc?
  200. JDM new and used parts
  201. Piston/rod questions
  202. Fuel Injectors...
  203. Resetting ecu worth anything
  204. Tornado: Waste or Must Have?
  205. HIgher RPMS
  206. help with color for 73 duster
  207. turbo dx or ls motor
  208. I just don't get these low horsepower ratings...
  209. B16a1 times
  210. Terminology
  211. 1.8 I/H/E versus 2.2 I/H/E
  212. B18C Oil Cooler on a B20
  213. 1971 javelin sst vin # help
  214. 88-91 civic parts...stuff must go
  215. accel plug wires on zc
  216. What can i do
  217. Please Help, I don't wanna walk
  218. Rebuilding Wrecked Cars...
  219. H22 or B18C5?
  220. 1971 amc sst
  221. MST research project
  222. N/A xperts...help
  223. Problem Help Please!!!!!!!!!!
  224. boost the zc or b16 or ?....please reply
  225. gas gauge light?
  226. Will d16y7 block work?
  227. D16Z6 in 93 Civic EX question
  228. rotten egg smell
  229. Jerking from my Toyota
  230. Big CAMS
  231. fog lamps on 2003 honda accord
  232. Crank Pulley questions
  233. ZC into 89' LS
  234. Help! loud screeching sound that stops when I disconnect the battery
  235. GSR ECU or H22 ECU?
  236. Put EX tranny into a DX any wiring needed
  237. Dealer engine swap?
  238. Need info on OBD II Codes
  239. 2002 SI exhaust
  240. help me out plz
  241. 1 pulse or 2 pulse
  242. Exhaust
  243. ls header fit b16a?
  244. 90 Honda Civic Electrical Problem
  245. porting
  246. Turbo & Tranny II
  247. DIY Cam Timing Adjustment
  248. AEM Pulleys=Upgrade Alternator?
  249. how to build lsvtec?????????
  250. Metallica Fans Check This Out!
