View Full Version : Engineering/Technical
  1. What else do I need?
  2. Throttle Body spacer question
  3. trust or spoon exhaust?????
  4. Engine Swap
  5. Want to swap engine in my 84 Civic!
  6. Accord swap with a 3S-GTE
  7. synthetic oil
  8. Peugeot 406
  9. Air intake
  10. gutting out crx???
  11. 72 Gs455
  12. turbo question!!!!!
  13. interior names?
  14. interior kits
  15. Indiglo Gauges
  16. Engine swap for an Accord
  17. DPS concern/question
  18. Motor Swap
  19. Lube control / Fuel Power
  20. anyone got an ls motor hatch/coupe
  21. spray it!?
  22. Injector ID on CRX
  23. petition for CAR CRAFT to reincarnate the Car Craft Magnum Force
  24. Lets slay some ricers!
  25. h22a into civic??
  26. What is synthetic
  27. B18c4???
  28. Can u help me
  29. questions...
  30. GM 305 Swap
  31. Battery Short (Internal)
  32. turbo idle
  33. help: Gearbox and Engine
  34. compression test
  35. help with 91 integra ls
  36. could a Y engine ever be produced?
  37. I forget, what is this part called?
  38. BuLbZ!!
  39. fuse box info
  40. any benefits to an auto civic
  41. Turbo: Vtec or no Vtec
  42. Suspension
  43. frankenstine swap!!! help!!
  44. remote starter
  45. puddle on floorboard!!!
  46. ctr cams in 99 gsr
  47. V8 Honda Civic
  48. 4G63 GSX Engine in an Integra
  49. transmission probelms
  50. What head can I use on a B18A1?
  51. h22a v. B18c1!! Help!!
  52. Fast Idle Honda Accord LX
  53. 87 Century T
  54. Double Clutch..
  55. what do I need
  56. Shaving side moldings-fiberglass?
  57. Vin Number
  58. Toughest bigblock??
  59. gasoline compression ignition?
  60. Thrust powerd car; can it be done??
  61. engine specs
  62. Nissan Silvia (S13) VS Skyline GTS (R32)
  63. Performance Exhausts- Do they get louder over time? PLEASE ANSWER
  64. Quick Muffler Question
  65. loud ticking noise
  66. throttle body question
  67. P1607 - Internal PCM Failure - what is the cause
  68. Lube control / Fuel Power
  69. dx head hf bottom????
  70. Cosmo Racing
  71. Engine Upgrades
  72. higher redline?
  73. b16 ecu
  74. B16A tuning question!
  75. Do I need to get a new ECU
  76. hot spots, what are they
  77. need help shift linkage
  78. ECU Location/Install
  79. is this a good deal??
  80. is this a good price ????
  81. tsudo catback
  82. D16z6 head on Del Sol 1.5 block
  83. h22 swap
  84. Cheap h22
  85. b18/b20 setups
  86. Weatherstripping removal help needed...
  87. Drag link install....
  88. Noob Question on ODM
  89. jdm or usdm h22, help!!!!!!!!
  90. stock fuel presure b16a1?
  91. chipping ecu's
  92. h22 engine swap
  93. dodge rampage
  94. painting
  95. Vtec not working and some other things, someone help!
  96. Litres to Horse Power conversion?
  97. 89 hatch, need help wiring mpfi in to hf
  98. ls vtec question.
  99. how do i make a signiture
  100. looking for help
  101. j-spec h22a into a 94 teg
  102. Stripped Bolt on Valve Cover
  103. crx b18 swap
  104. horsepower questions
  105. b16a g1 (SiR) swap
  106. ecu question HELP!!!
  107. Where can I find a Euro Type R H22A engine for 92 Accord
  108. possible help or opnions
  109. ecu question
  110. Apexi Vafc 2 tuning
  111. more precise shifting
  112. H22 into 90 accord
  113. looking for advice
  114. remote starter
  115. h22a in a 89 civic si?
  116. cat backs
  117. Painting Q's
  118. engines
  119. what do u think?
  120. weber carb
  121. what's the biggest motor and trans swap for a 89 civic si?
  122. new taillights
  123. A-body axle swap ?
  124. grinding noise while driving
  125. ITR / CTR cams
  126. exhaust system for '88-'91 crx
  127. B20 / B-series tranny
  128. newbie 94 civic electrical problem?
  129. Gasoline Diesel
  130. Valve Covers
  131. tranny
  132. existing exhaust?
  133. civic light
  134. strobes...
  135. parting out 65 plymouth satellite
  136. running rich
  137. I need some INFO!!
  138. 110 octane in a car
  139. Stock Valve Springs?
  140. Charcoal cannister.. emissions control question.
  141. How much money do i need?
  142. B16a2, B16b or H22
  143. automatic shifting question
  144. 396 bb
  145. suicide doors
  146. mufflers:which is better!? please help
  147. Has anyone done a Distributorless Ignition Conversion on a B-series Engine?
  148. engine died while driving
  149. air conditioning question
  150. apexi gt spec
  151. NEED Advice on engine choice
  152. Stratus R/T Keyless entry programing
  153. Can someone explain the difference...
  154. East Coast Distributers
  155. Obd2 B16a2 Engine!!!!!!
  156. hydraulics
  157. What's better, sports shift or manual?
  158. Engine Swap
  159. newbie motor question
  160. failed emissions help
  161. D15b Vti Swap
  162. b22a1 in a civic
  163. Topic: Where to buy cheap but quality power inverter?
  164. B16,18 & H22 ITB's on sale
  165. Throttle Problems
  166. H22 Motor...H23 (p14) ECU...will it run?
  167. need help replacing stock w/ coilovers
  168. Clutch problem with '03 Accord 6MT - HELP!
  169. wanted: integra gear knob
  170. how do you know when you re clutch is going?
  171. What is a spoon engine
  172. Nsx
  173. weight vs. hp
  174. Engine swap
  175. Pontiac hestitation & rough accel.
  176. Please help ASAP... very odd problem w/'98 Civic!!!!
  177. clutch adjustment - 96 integra
  178. deep sounding exhaust
  179. Integra Type R ecu on a B16a.
  180. New Guy w/ 79 Bonneville
  181. Trying to find drain plug!
  182. Remote start installation on a manual
  183. de-immobilise 02 honda accord for remote start
  184. 95 Avenger Help
  185. To buy or not to buy? Let me know :/
  186. inherited 70 chevelle SS...PLEASE help ID
  187. rotors on 2002 civic
  188. Will a Chevy 350 fit in my civic?
  189. wat are my options?
  190. WHats up with the redline on the skyline?
  191. Help on parts
  192. ECU how much $$ and where to buy?
  193. Overheating after block seal
  194. synthetic oil poll
  195. imports?
  196. Some help on low budget mods.
  197. license plate lights
  198. Weight Savings
  199. V-spec h22 vs Jdm h22 type s
  200. Grinding Noise
  201. What choice would you make
  202. V-tec not so high tec
  203. Engine running really rich.
  204. 2 step rev-limiter
  205. project sol
  206. ls/vtec
  207. top speed and integra questions
  208. b16a2
  209. ECU question
  210. Good place to buy a JDM D16 motor??
  211. alteration
  212. Fool a OBD11 accord ecu into thinkn rear O2 is ok?
  213. Can someone please tell me what "compression ratio" is?
  214. motor mounts: street, street/race, race??
  215. 96-98 Mugen Civic Lip Pictures..
  216. high compression & pump gas
  217. b18c
  218. Convert to power windows
  219. auto tranny lock-out???
  220. b20/vtec reving problems pr3 ecu
  221. How LSD and Positraction works??
  222. b16a PROBLEMS!!!! HELP ASAP
  223. fault codes Acura 3.0 1998?
  224. how much would u guys pay
  225. o2 sensor
  226. Intake Manifold PROBLEMZ PLZ HELP!!
  227. this freaked me out
  228. Attention wiring help for iacv.
  229. CEL error codes.
  230. 99 Acc. Steering wheel shake during braking
  231. Jdm Motors!!!!!!!!!!
  232. Rotary engines
  233. What exactly is torque?
  234. can the b18b gimmie wat im lookin for
  235. vtec controller
  236. Sumone PLease Answer....
  237. Tenzo R Muffler??
  238. JDM question...
  239. injectors not working
  240. injectors not working
  241. any luck
  242. ls/vtec
  243. jerky taurus
  244. Becoming an Auto Mechanic, how? what to do?
  245. prolly a stupid question
  246. Automotive Books
  247. where do i get a type R motor?
  248. Can spark still jump across an open wire???
  249. 454 drop
  250. 2wire vs 3 wire help!!
