View Full Version : Engineering/Technical
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45
  1. b series
  2. Computer Board (ECU Tweeking)
  3. A/F Gauge Install
  4. Longblock? Shortblock?
  5. Boost Spikes
  6. 99 Civic EX - B18C Swap.. Questions???
  7. Clutch Recomendations..............
  8. Ecu??
  9. Ecu??
  10. Swap this Swap that.....
  11. H22-B18c1-B16a2
  12. Trans options for B16A JP VS USA spec
  13. Lamborghini,Porsche,Ferrari & Alfa Romeo
  14. build up... the most serious parts
  15. Mugen for '99 Accord EX
  16. Help me ...my car is dead!
  17. B20 long block+b18c5 head=?
  18. Tranny for LS??
  19. aftermarket parts installation
  20. a lil imput please
  21. starting valve and hose #8 from pgm-fi on a 4th gen accord?
  22. suspension questions
  23. Whats the best swap for a 97 civic
  24. Port and polish?
  25. EGR on my 4th gen accord?
  26. NEED help about parts for JDM front end!
  27. vtec
  28. fuel filter
  29. tach install?
  30. engine papers
  31. B18c-r swap into 96-98 civic
  32. Single Cam Mods...what should we do?
  33. B16A2 into Civic 4spd
  34. TECH: Switch for Reverse Indiglo Gauges?
  35. ls/vtec how about a f22/vtec
  36. HELP! How-To put a B18c1 into a 88-91 civic DX
  37. problems due to aftermarket parts
  38. I am In need of HELP!!!
  39. I need HELP!!!
  40. Usdm Gsr Swap
  41. Cams??
  42. LS help
  43. 5th gen b16A
  44. Sorry..Mitsu question but I need help and that forum is slooooooooooow
  45. AEM intakes
  46. b16a into 97 Civic DX... Cost?
  47. Check engine light
  48. B16a wiring and shift linkage questions
  49. Oil Burning?
  50. how difficult is it...
  51. Att: Moppie Jdm Bumper Lights
  52. h22 in a 2000 civic
  53. tune up question
  54. accord tranny on an h23
  55. Weird smell
  56. Best Radar detector for the money?
  57. Where did everyone get their swap
  58. Need Help
  59. b16a sir 1 vs. b16a sir 2
  60. Compression Ratios....drift..your sarcasm welcome hehe
  61. Swap in a Sedan
  62. iVTEC & VTEC
  63. History of Honda - Moppie? Fritz?
  64. cadaletic converter
  65. Brake Fluid Table
  66. Brake Fluid Chart
  67. Hey I've got a automatic transmission and i want to race with it....
  68. ATT: Moppie JDM PARTS WANTED
  69. airbag question
  70. Exhaust
  71. Brake Fluid
  72. How good are JDM cams
  73. Milling head good or bad?
  74. Engines
  75. H22a in 6th gen civic
  76. b16a
  77. Is JDM Engine Legal?
  78. Will a B16 head fit on a D16 block?
  79. B16A swap into 88-91 CRX
  80. What can I use on the Si ?
  81. 91hb 4speed to 91 B16a 5 speed? quick question
  82. Mods for New Type R
  83. Cheap Supercharging
  84. Crossed drilled/slotted rotors.
  85. squeeling throwout bearing!!
  86. Intriguing question for you tech nuts...
  87. B16a Speedo cable to trans
  88. wierd shifting stuff
  89. Mods for Type R
  90. ignition timing
  91. Civic Type-R Motor
  92. Question on Spark Plugs!!!
  93. Just thought of a JDM mod that ive never seen on a USDM
  94. Engine Weight?
  95. driving a 5 speed
  96. DC catbak exhaust
  97. Gude head on
  98. JDM steering wheel
  99. questions about an 2000 hx
  100. Accord Engine Swap? HELP!
  101. smoke???
  102. 3rd generation accord weight?
  103. ls buildup
  104. cost for H22?
  105. electomotive tech ll
  106. too much fuel?
  107. Is This Possible???
  108. ZC common probs?
  109. 2nd gen B16?
  110. Anybody have this???
  111. B16 smog in Cali
  112. reprogramming v-tec
  113. Fram Oil Filters
  114. what to check for?
  115. Bore and Stroke
  116. If I were to change my block...
  117. engine mounts
  118. distributor degrees (point dwell)
  119. JDM front end conversion question
  120. intercooler without turbo?
  121. bumper light wiring
  122. question on rotors
  123. exhaust
  124. Yo...Tech heads...shhhhh...V8 question...
  125. JDM B16A to in a 92 hatch
  126. quite exhaust
  127. Engine not heating up?
  128. Vtec
  129. does VAFC affect motor stability?
  130. Why VTEC???
  131. knocking/pinging/ticking @ start up.
  132. Air Intake Question....
  133. Spiking Revs
  134. JDM EF8 CRX question
  135. Cable arm on swaps
  136. distributor swap question!!
  137. Shave me, baby!
  138. B16a Ver 2
  139. b18c swap in civic...turbo or na
  140. coilover help 95 ex stabilizer bar
  141. Mugen FG-360 steering wheel
  142. inline fuel pump install
  143. Anyone Please Help me with chip install
  144. Apex-i Rev/Speed meter
  145. What to do to my B16
  146. steel braided radiator hose, anybody know where i can find...
  147. Spoon needed
  148. someone please tell me a link on a how-to clutch install for a 89 DX
  149. SAFC Clarification
  150. B16 engine needed
  151. Need info on LS/VTEC
  152. annual tune-up ?
  153. How to wire a tach
  154. are the spoon engines really shitty ?
  155. Spoon Headers.....
  156. Fluctuating RPM - '87 Accord
  157. Airbag suspensions
  158. brakes on a del sol
  159. wot the f*ck happened to my VTEC?
  160. Must Know
  161. Electrical question... wiring lights to a switch!
  162. Ceramic -vs- Stainless Steel headers
  163. CRV motor into 2002 Civic EX
  164. Gear Ratios?
  165. where to get jdm sidemarkers
  166. hypothetically...
  167. A/F ratio gauges
  168. Turning up the boost but how high????
  169. timing advance
  170. turbocharging my d16a6
  171. JDM engine in Cali
  172. Supercar v8 Flames out the sides
  173. p40 ecu -- whats it from?
  174. i want to build up my d16z6, how should i do it
  175. Eliminate v-tec? ...WHY?
  176. blown motor
  177. header preference
  178. Tech heads - check my work?
  179. Engine Specs
  180. AWD F-Body
  181. Compression check on an out-of-body engine?
  182. Brake ?
  183. Anyone know where to find this?
  184. Battery Vs. Alternator
  185. One more awesome site!
  186. Twin spark and Dual Sequential Ignition
  187. I have a dumb question~~
  188. b16 in a 91 hb civic si need info??
  189. Another Head Gasket, what am I doing wrong?
  190. Passport Engine Code?
  191. Anyone have any info on the "Rod to Stroke Ratio"
  192. D16d6 tranny in a D16z6
  193. 90 accord h22a swap
  194. Where to buy NEW motors?
  195. How to measure your camber using common tools
  196. Could someone please explain a blockguard and ductile iron sleeves to me???
  197. installing my new d16z6 head.....what do i
  198. jdm floormats...
  199. Turn in or out?
  200. JD@AF - a question that needs to be answered.
  201. smart people come here
  202. Forgive me, I'm stoopid...
  203. head and block mating surface?
  204. Would it be wrong????
  205. Q on B16 install...whoever has done one?
  206. 91 SiR guage cluster install Q....anyone done one?
  207. JDMFan.com: How-to's
  208. kick panel how-to
  209. 94 Honda Civic how-to's
  210. Engine how-to's
  211. n/a b20 build up/ cam questions
  212. SIR front clip question!!
  213. B16a + S-AFC?
  214. Make your own Cold Air Intake
  215. Hey Techies, Question
  216. "jdm"
  217. Please help me gather honda/acura specs
  218. turbo prelude motor in del sol
  219. Cat-Back???
  220. 1995 Honda Civic DX
  221. Paint Problems! 1990 Chev. S-10 Blazer
  222. HOLY CRIPES! What is this?????
  223. Synthetic Oil Opinions
  224. B18 Engine
  225. battery in the trunk
  226. Adding a SPOILER! Will it help or hurt?
  227. Somebody explain.
  228. B16A Torque Chart
  229. jdm itr
  230. Technical hybrid question...
  231. Intergra Type r
  232. H22 in a 6th gen civic
  233. Exhaust??????
  234. V-TEC head on an LS block?
  235. Blown Head Gasket... WHY???
  236. where is the secondary intake solinoid
  237. Boost in compression... HP gains?
  238. S2000 Swap???
  239. misfiring system
  240. Ok guys...anyone from Miami area...need some help!
  241. 2000 Sienna Carbon
  242. Here's a couple how-to pages (Vinyl, Hdlights, guages, Nitrous, Spoiler, Suspension)
  243. ITR exhaust and intake "perfect!" hrm?
  244. Whats a good motor?
  245. 25% drivetrain loss? WHAT?!?!
  246. speedo going nuts
  247. lights randomly dimming
  248. Stand Alone Engine Management Systems
  249. Mugen style muffler "Twin Loop"
  250. AEM Cam gears
