View Full Version : Engineering/Technical
  1. Apex-i N1 exhaust on d16y8...
  2. civic hx (what motor swap)
  3. welding.....
  4. Could someone offer some advice to a certified car-idiot like me?
  5. Electrical system problems??
  6. short ram or cold air
  7. Strange Question....
  8. b18 swap into an 88-91 crx and the difficulties
  9. greetings fellow mopar heads
  10. Get your PRO-SUV / Offroad Stuff Here...
  11. Get your 4x4 / PRO-SUV / Offroad Stuff Here
  12. Which Head?
  13. 79 pontiac trans am 4 sale
  14. 79 pontiac Trans am 4 sale
  15. An 100mpg car
  16. auto trans won't shift up
  17. Oils, Mobile 1 Amsoil and the Others
  18. Fishcat is a faaaaag
  19. chevy LT1 350 ,carbable?
  20. Lower end work while the head is off?
  21. civic radiator fit on integra?
  22. Chevy trucker(s) ..
  23. FORD trucker(s) ??
  24. Advice on low mileage driving with new car - remote starter, oil changes, etc.
  25. water on engine from vented hood
  26. G-Tech Pro Performance Meter
  27. Which Head?
  28. A Bad Tranny??
  29. rusty exhaust bolts
  30. cost for a B18c swap into EG civic
  31. wiggley shifter
  32. Help settle an argument.
  33. car wont start at times???
  34. 4wd Vs. Awd
  35. looking for a motor
  36. Busted the bleeder screw part of my water outlet.
  37. Tahoe road feel
  38. vtec for a cobra? Whaaa?
  39. "Hundreds More Will Die"
  40. U gonna shop asylumms.com? dont, chargebacks and scammers is all they are
  41. questions about the exhaust note
  42. B18 weight.
  43. Del Sol WON'T START
  44. Need Info Fast! motor shipping costs?
  45. 250whp LS tegra
  46. Selling b16a2
  47. civic type r
  48. Civic Type-R Style Front Grill
  49. paying for swap job
  50. anyone have a chiltons manual for a b16a?
  51. ticking noise b/t head and manifold
  52. b16a need help
  53. Oil leaks on a B18A & B16A
  54. Can't get those head lights to close...
  55. 5Zigen Borderslash axleback
  56. My Integra XSi
  57. 67 Firebird w/ 400
  58. Ffasssttt Integra Ls
  59. IS a turbo worth it??
  60. v8 in civic???!!!
  61. b16 parts?
  62. Normal riding stance is low at front, why?
  63. oil pan gasket kit F/S
  64. F/S soft top / flip open for wrangler 97-02
  65. I ran over something and it tore my gas tank open..
  66. would u consider this a muscle car?
  67. Please identify this car for me...
  68. where to go??
  69. What Next
  70. Manual Tansmission Conversion
  71. dohc zc head/d16 block
  72. Whats a sleeve
  73. i need help quck im desperate
  74. Coolant leak
  75. J-spec H22A in a Civic
  76. b16 coolant problem
  77. Exhaust system vs. Exhaust tip
  78. 426 max wedge block potential
  79. cam gears
  80. 03 F-350 Super Duty Deisel
  81. What happens when your CAI sucks up water???
  82. newbie vtec help
  83. Is The Plaintiffs' Bar Paying For The SUV Wars?
  84. iNSXtegra
  85. motor trade
  86. Gains from cam sprockets?
  87. Chevy vs Dodge vs Ford vs Toyota (FSPU)
  88. Rebuild 302 Windsor
  89. Headers
  90. N00b
  91. engine swap
  92. Clutchity clutch clutch
  93. Help!! Need parts!!
  94. what are the best exhaust system?
  95. P N R D 2 1 <-shifting for speed
  96. Solid axle rear coil over suspension help?
  97. I'm beginning the process...
  98. Tranny Troubles Need some Technical Expertise
  99. Problem starting my 91 honda civic
  100. Head-Turning High-Tech Minivans
  101. wiring headache
  102. Vtec indicator light problem
  103. How much HP can I expect with my 400?
  104. 90-93 Accord Swap
  105. testing the DPS unit from K&G
  106. I Need Some Good WEBSITES FOR ENGINES!
  107. Bed painting
  108. swap making rattling sound
  109. My car VS my dad's, your opinion?
  110. 87 or 93?
  111. 1 thread...2 questions
  112. s2000 upgrades
  113. tap tap taparoo
  114. Aftermarket Header Install on 2000 Prelude VTEC
  115. First car...
  116. power window crap
  117. Quarter Mile
  118. Improved Fuel Economy for Full Sized Pickups
  119. B16A ==> B18A Wire Harness
  120. my vtec is very loud why
  121. A Threat To More Than Just Hummers
  122. engine swap
  123. part question
  124. Blown motor 91 accord
  125. can a car keep running with no battery?
  126. Concern About Main Bearing Journals (On The Block Side)
  127. Internals or Turbo 1st??
  128. What is an ECU??
  129. Custom Turbo For H22a Vtec
  130. '99 acura 3.2TL: FUSE OUT or st else?
  131. Engine ID
  132. Tranny problems?
  133. one time use head bolts
  134. B18C1 swap i need price info!
  135. Good price to yank out your engine.
  136. Power Steering
  137. Maintain vehicle in North USA w/sand HOW ??
  138. 94 civic for 7000$ is it worth it? need OPINIONS!
  139. chevy 305 heads
  140. Port and Polish?
  141. 1964 Gto
  142. Help, I killed it!
  143. cheap b18c5
  144. When Would My 95' Civic Vtec Engine Kick In?
  145. 2003 Civic SI interior hatch assembly
  146. Hydraulics to the Flywheel: Clutch Operation Explained
  147. engine swap
  148. Starting a 6 Month Dormant 924
  149. Will an H22 engine fit in a 92 teg!?!
  150. radar jammers
  151. Motor Swap Help Please!!!!
  152. 50's muscle cars
  153. Wet Sleeves vs Dry Sleeves
  154. Exhaust for 95 integra rs
  155. 1998 Lumina LTZ - 3800 engine
  156. For all you LS/VETC guys
  157. H23 engine parts
  158. carburetor problems...
  159. Couple of Questions
  160. ls/vtec swap
  161. Engine swap on Mustang
  162. Engine swap on Mustang
  163. JDM Headlights for sale
  164. new ls swap!!!!!!!
  165. Steering problems
  166. Nissan Primera GX 2.0 TD - stalling problem
  167. Difference between B16A1 and B16A2
  168. Increasing underbody downforce
  169. Lightweight steel cars?
  170. rebuilding d16y8?
  171. Engine swap part replacments...
  172. Lsvtec?!?!
  173. Why would a wheel wobble??
  174. Why is it so hard to SHIFT GEARS?
  175. Need technical explanation of Valve Float
  176. Eco-Terrorism: Coming Soon To A Suburb Near You
  177. OBD II Scanner purchase help
  178. i want to knoe
  179. Good move or not? y8 head on z6 block?
  180. Confusing question
  181. JDM Prelude Tranny
  182. JDM H22A into 98 Prelude SH....
  183. JDM Tranny Codes
  184. transporting old motor/tranny
  185. I need Help
  186. which cams should i get
  187. Seeing Nature's Beauty Through an SUV
  188. Light Trucks With Even More Family Features
  189. SUVs: "Motorized Scapegoats For Other Peoples' Biases"
  190. Cold Air Intake Installation..."mounting brackets"?
  191. Need speed sensor for 98 civic ex
  192. how to remove the valve cover ?
  193. Parts needed for...
  194. jdm cr-x front conversion
  195. Brake Drum Question.
  196. Engine HELP
  197. boosting ls/vtec
  198. 89 Honda Civic Hatchback
  199. amc suv
  200. Type-R Head Swap
  201. intake swapping.
  202. I own a Chevy?
  203. Motor swap info
  204. DX to MPFI swap with AC
  205. honda car codes
  206. oil Burn in Vtec
  207. com. chips
  208. HELP! Lost on engine swap
  209. Dodge Coronet, My first restoration project!
  210. Head Gasket took a shit???
  211. What HP should this run?
  212. Fuel Question (Octane)
  213. 86 legend questions (engine, etc.)
  214. Headlight bulbs
  215. sport shifter in a civic auto?
  216. power steering cap? how to open?
  217. Suspension Series 101: Tire Basics by Dezoris
  218. Radio code?
  219. How Do I start a Shop, Piece by Piece
  220. JDM Honda Prelude
  221. Battery Help Please!
  222. My favorite light truck.
  223. replacing the IAC
  224. '72 Duster
  225. diagram of a car and how it works
  226. my 93 Civic Lx is DEAD!! HELP ME
  227. new pipes?
  228. Shift Knob Question
  229. Is this normal ??
  230. Speedometer stopped working
  231. [95 Accord VTeC] Engine turns over, butdoesn't start
  232. Remote Start Flashing LED's
  233. Coolant Problem.. Pls help
  234. the sound of fear
  235. B16a alternator??
  236. 95 and everything dies
  237. how to turn 10,000 plus rpms??????
  238. light pickups
  239. Lookin For Power in a GS-R
  240. Putting a fuel rail for a 94 gsr on a 91 rs integra
  241. stock fenders
  242. Sunroof stopped working
  243. OHV vs. OHC
  244. Muffler sound
  245. Selecting A Turbo For Your Car
  246. type r pistons on gsr
  247. H22 in a Del Sol
  248. direct parts from Japan
  249. Vega for sale up the road from me
  250. ? about Idle
