View Full Version : Engineering/Technical
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45
  1. Cheapest place for H22a
  2. 88-89 prelude jdm ecu
  3. Reset? Huh?
  4. Clutch goin...
  5. blow off valve
  6. stock ex clutch questions...
  7. engine info
  8. Spoon?????
  9. 89 accord wagon h22a?
  10. torque converter
  11. H22A in a 94-97 Accord questions
  12. Exhaust for around $300
  13. Intake\Filter Question
  14. Anyone ever seen this before?
  15. NoCal Hybrid Swap Shop?
  16. headers
  17. AEM Engine Mangement System Question?
  18. Question about shorter gears. Important!!
  19. equal boost but more power?
  20. D16 head swap?
  21. Short Shifter Quality?
  22. is it still legal???
  23. swap a 1.5 pgm-fi to a SI 1.6 pgm-fi
  24. swap a 1.5 pgm-fi to a SI 1.6 pgm-fi?
  25. Please Check Out My Auction
  26. how to recondition a 240k mi engine?
  27. Which engine? JDM/USDM?
  28. B16a opinion?
  29. Need Suggestion for Shock
  30. ITR AIRBOX FIT ON A 95 ciVic ex?
  31. auto tranny...
  32. Lookin for a H22 5psd
  33. 385hp SOHC NON-vtec ~~ I want one!
  34. Need some advice on making my engine look better...
  35. Auto-Manual Parts locating I need your help
  36. clutch problems
  37. Common Cause of A/C death in accord?
  38. towtruck/towing questions
  39. VIN stamped on USDM engines?
  40. ...
  41. Dohc Zc
  42. Complete system rebuild . . .
  43. transmission numbers?
  44. umm tha d16a6 -- what tha hell is that from?
  45. can you have a/c on a gsr hatchback swap?
  46. anything better about B20b over B18b besides it is a 2 liter?
  47. price differences
  48. Cat. Converter Deterioration
  49. Rod bearing about to go?
  50. rattling
  51. EF3 Si questions
  52. Lots of Brake Dust?!
  53. Just Dyno'd My Car Again
  54. '91 CRX turbo
  55. Dual Exhaust
  56. please help: oil leak
  57. synthetic + VTEC
  58. cross-drilled/slotted or just slotted
  59. I finished my b16 swap!! HELP!!!!
  60. fuel system parts
  61. Magnaflow exhaust?
  62. Engine comparison site/chart
  63. 5th Gen Civic Swap with a 93 Integra LS?????
  64. DC Sports 4-2-1 or 4-1?
  65. 4000 bhp Honda Intregra
  66. mandrell bent or no?
  67. Greddy Power Extreme for Turbo's
  68. question???
  69. honda motors online...
  70. what is ps opposed to hp?
  71. Dohc Zc Vtec
  72. List the Causes!!!
  73. VTEC and fuel economy?
  74. Cold start problem.
  75. 99 Civic Mugen Front Lip
  76. aem cold air intake
  77. Civic 96
  78. what's better for swap B16b, B18c1, B18c5
  79. "Kerplunk" sound!
  80. Technical AC Question
  81. valve adjusting???
  82. transmission out or torque convertere?
  83. JDM Legend
  84. Photoshop?
  85. OBD-1 and OBD-2
  86. Gull Wing Doors!?
  87. Apex Dunk
  88. Going Rate for JDM B20B and B18B
  89. Diff between H22 and H22A
  90. low idle?
  91. battery not charging
  92. Cams
  93. Best fuel system cleaner
  94. Head Gasket Questions!!!
  95. Very weird electrical problem
  96. Odyssey - the ultimate sleeper...
  97. d16y5 cam in d16y7?
  98. 1990 accord automatic to manual transmission swap
  99. Skunk2 Intake Manifold
  100. exhaust?
  101. Are the Stock 99 Si pads organic or semi-metallic?
  102. VTEC Problem
  103. Civic cam question
  104. custom or catback exhaust?
  105. K&N or Spoon drop in filter?
  106. shifter problems
  107. b20b+b16a head durable?
  108. alcohol carburator to gas
  109. VTEC Head
  110. here's a link
  111. Cubic Inches
  112. Need proffessional Help?!
  113. Perhaps, a stupid question
  114. Will this pass the smog test?
  115. 92 Civic HB VX
  116. What are underdrive pulleys?
  117. H22 Vs. B18C
  118. Looking for a truck.
  119. vafc question
  120. Shaved Door Handle How To???
  121. Underdrive pulleys??
  122. NGK or VITEK...
  123. paxton in-line fuel pump...
  124. Engine revs by it self on G3 teg.
  125. i have a ?
  126. Not sure what this is, need Help
  127. Looking for B16A install in 90 integra on east coast...
  128. The Murciélago's Engine
  129. Canadian Legal Issues
  130. Changing the drivetrain
  131. port & polish
  132. Does anyone have any Honda performance Mechanical skills?
  133. Engine Wash?
  134. Ignition Systems
  135. Nissan SR20DET Engine
  136. what kind of pistons?
  137. money burning a hole in my pocket
  138. h22 in a civic
  139. Which Vehicle Speed Sensor to use in B16
  140. Rebuilding engine
  141. cross drilled VS slotted brakes
  142. how hard would it be to.......
  143. Anyone with an Automatic Turbo or anyone have any knowledge on the subject?
  144. B16 B18 H22?????
  145. RAM Air VS. Cold Air
  146. Aftermarket Tachometer
  147. Help me out here!
  148. A/C Filter
  149. Honda Chassis Codes - JDM
  150. speed govenor
  151. GAINS: Cams -vs- Pistons
  152. BiG block, Small Block
  153. I'm so not car savy.
  154. CAI Injen or Aem
  155. Axle gone bad?
  156. PLEASE HELP! B16A wont start up!
  157. how does twin turbo work..
  158. which manual?
  159. D16 "mini-me" swap, is it worth it???
  160. transmission trouble?
  161. PermaPlate
  162. b18c1 in a 3g accord
  163. CTR Pistons in B16a -- Install
  164. ITR or CTR pistons in my b18c1?
  165. B18 motor, in a 1990 Civic Hatch.
  166. b18a in a 88hb
  167. Choosing an engine for your Cobra
  168. When to change a timing belt?
  169. parts after swap
  170. Help with H23 swap
  171. oil pressure....
  172. PTS Shiftronic?
  173. what cai do i use?
  174. Just kinda wonering why you come in here.
  175. DC sport CC headers worth the money?
  176. oxygen sensor gone bad?
  177. is this an indication of a transmission problem?
  178. Supersprint
  179. b18c1 swap JDM wiring?
  180. Port & Polish on SOHC VTEC... gains?
  181. Where to go to school to become an Auto Mechanic?
  182. Anyone try the Tornado?
  183. Bent connecting rod???
  184. internals #deuce
  185. brake pads
  186. What does "stock" mean?
  187. CTR pistons in my b18c1
  188. fuel relay question
  189. Torque steer vs understeer
  190. Easiest way to run under under 13's in a civic
  191. FYI: Group buy on engine swaps in group buy section!
  192. spec needed
  193. Bliker problem
  194. motor mounts
  195. f20c
  196. Rotary Engines
  197. What is the best ECU?
  198. Turbo & High-Tech Performance
  199. A h22 in a 3g civic
  200. underdrive pulleys
  201. LS-1 Motor block casting process??
  202. "I need NAWS I need NAWS!!! (seriously, safe use of Nitrous)
  203. HELP:A/F ratio meter in 92 civic
  204. Octane #
  205. dyno charts?
  206. 5th gen accord w/ H22A or 2nd gen Teg w/ b18C1
  207. What is that site that shows the washer / bolt trick for camber?
  208. Fritz, got one for you....ok two.
  209. The Mixing Of Oils.
  210. Am I paying too much for a new head+gasket?
  211. N1 vs Racing Medalion
  212. Port and Polish
  213. b18 internals
  214. '99 dx hatch w/ JRSC......my alternator/speed sensor fuse keeps popping......WHY?HELP
  215. 4th Gen B16 Swap
  216. Correct Fuses To Reset ECU
  217. jsm b20a5
  218. How to be a good driver
  219. '87
  220. turbo prep...Crower Cams & Pistons?
  221. PTC Receives $1 Million Order from Lamborghini
  222. good tech info site?
  223. flywheel installation cost
  224. Walbro fuel pump problem
  225. 4th gen ignition upgrade!?!?!?
  226. internals
  227. b20 head swap
  228. 300zx Engine Transfer
  229. 17 flashes on ECU???
  230. Civic HB Swap dilemma
  231. Tuning an Apexi VAFC
  232. Canada Swaps
  233. computers necessary
  234. Fuses??
  235. Potential hybrid?
  236. Wheel issue
  237. Tanabe Racing Medalion
  238. fuel injector leak, should i change myself?
  239. Hondata
  240. Whats Wrong wit my auto?
  241. Turbo/Supercharger question
  242. Engine Bay
  243. 300M engine into 94 Intrepid
  244. Need Opinion
  245. Jr Vpac
  246. will a b16a2 work on a 90 civic si
  247. Air Intake?
  248. popping after clutch release.
  249. Painting Ceramic Header
  250. Other AF tech forums.
