Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
> Engineering/Technical |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
sensors on JDM B16A
transfering mods to another engine
Vtec not working!?
JDM EG B16A into a EF SiR?
crank pulley removal
JG Engine Dynamics
Question about fuel injectors?
Need Help!
shinning up the valve cover
B20z w/ B16a head swap
Matrix Headers?
Fritz is outta here! (for now)
AEM bypass valve
Drifting how to's, is this bad?
Ls valve cover on a b16?
RSX type-s motor into a 99 civic
Brakes: Fact vs Friction...
charge for check?
just a quick question on a zc
diesel vs. gasoline
Car care question
B16 Head Studs?
Anyone Hear of RK Sport?
intake
Electrical question....
2.25 inch vs 2.5 inch custom piping.
CRV engine. How much is it?
JDM integra front end
The right AEM Intake?
Exhaust piping
B16A ==> into 99 civic
Code 9??
99 civic ex
Need proffessional Help on a brake system!
Please Explain Port and Polish...
Accord Type-R Rims...
help with O2 sensor
for the JDM GURU's
With Mods on a stock 89 Civic Si engine, is the resulting bang worth the bucks?
Is it possible??
Cat-Back for 74 Cougar??
Prelude tech problem!!
CRX vs, Mustang 5.0
obd II question
Cheapest USDM engines??
AEM BYPASS VALVE hp losses?
spoon wheels
? about Mini-Me Sohc Vtec Head
Ignition Wires?
s2000 tranny swap
Best Spark Plugs and Wires for GS-R?
A question
what clutch
Way to check driveshafts?
Transmission Swap
What would you do...
Short Shifter info
What is mandrel piping?
Fourier analysis of cam profile
Stupid question, but please answer
Im Back
Superiority of different engine designs
parts help, install help in Cincinnati Ohio
6th gen Accord w/ bolt-ons
help!!!!
How does a Turbo work.
B18 swap question
How to adjust timing on a doch ?
Newbeeee18c enthusiest.
jdm or usdm engine?
D16 cams non-V-TECH
can i remove 180km/h limiter>??
514 Cobra Jet
DYNO cost????
Used Gunk to clean TB, should I have replaced gasket?
jdm GSR
Just Ordered New Exhaust!
Need help ! B16a into a 93 Civic
Auto change to manual
What is torque?
Glasspack help
Are the motor mounts on a 2000 Civic Si the same as 98-01 GSR?
Need More Help Please!!!
H22 in 5th gen and A/C??
Jackson Racing Boost Timing Controller kit
What is a safe boost on a stock engine?
engine internals
engine
Oil Change
Is this bad?
garaging car
Q about Car Damage
where are clevite bearings at?
valve cover studs for b18c1
HELP! VSS removal/installation...
Where do i start?
Catalytic Converter
swapping B18b in 92 hatch, what year tranny?
APEXI Dunk, 50 State Legal?
optima blue top
I'm building an LS/VTEC, what else do I need, please read.
Need opinion on good brake pads
Temp sensor
need help on general Information about cars
Is... bad for my car???
EG SiR Guage HELP!!
chrysler/plymouth mechanics
Ignition.....where do I put it??
Aren't there some manuals that are on-line?
h22 in a 95 civic coupe!!!
Redline of ZC?
What's this noise???
were to find a h22 engine?
JDM valve cover for lude
Child Safety Locks??????
JDM Engine Sites?
ECU question
advice needed
VTEC indicator light
head swapping
Ok, tell me what I need!!!
ls block and gsr block?
Looking for 88-89 Accord Corner lights
tech heads - read this please ;) another j.fuggi dilemma
99 ex Tranny & ACT clutch
97 Civic Ex auto tranny to manual swap
Turbo exhaust
Anyone heard or have OBX spark plug wires (10 mm)
new pics of my engine swap
NGK Platinum
B series Tranny needed, HELP!!!
DC Sports Any Good?
b18c into a crx
sits crooked
JDM PR3 ECU for sale
Racecar engineering schools
i-VTEC
88 z24 2.8 MPFI
Intake vs. switching to K&n filter
h22a accord?
I want an integra LS engine
i have 2 questions
Angeleye Projector headlight
what's jdm?
Cheapest places to get OEM Honda/Acura parts for a ZC?
HID help
Working Cali Law!!
Auto Painting Questions
1.5 way, or 2 way LSD??
Building my own Go-Cart/Car
OBD question
spoon parts for a 95 GSR
all motor or NOS?
Adjusting Rocker Arms.
closest place in cincy area for engine?
How do you shut that key in the ign beep?
interga R cluster will fit 92-95 civic eg?
vtec controller
b18c header?
header question
Poll What kind of oil do you use
radiator caps
Dream performance car? What am I missing?
tach wiring help
b16 tranny ???
ac fan question
HELP!! oil on spark plug?
resleeving
Splitfire Triple Platinum: Any good?
power band
why do cars have body roll
Type-S ?
New engine for 96 civic???
enigne swap
whats a robo shifter?
Transmission Conversion
Need to know how to program alpine alarm fro new remote
AEM cam gears and pullys???
Help!?
pulleys
I need some help!
How to straighten a Integra GSR motor mount that got slightly bent out of shape?
Anoyone Hear Of Reactive Exhaust?
I know its not a honda but i need ur help on a supra!
93 civic cx with dx motor
B16A non ODB
how hard is it to convert non ABS car to ABS?
Help...really bad please!
Split exhaust system
how to get rid of sticky substance on headlights
clutch question
Wheel bearing help needed
Is the stock Honda LSD really good?
question on oil and main req'd blinking
Governor and Ignition
can a ...
vafc tuning
Car suspensions
Spark Plugs + Spark Plug wires
Brake trouble
My little b18b1 project...
Shift light help
Tanabe Hyper Med or Apexi WS, Dunk?
oil analasys
B16a2?
Bosch Platinum +4
Swap B20A5 for B18a
engine build
Do you use this often?
help! piston rings
need h22a pistonrings-aftermarket!
spark plug replacement
AEM Fuel Rail Question
Help finding chip?!?!?!
How to remove 88 Accord front bumper?
CAI - lower revs?
Intermittent electric failure
2 questions
Bad for clutch??? or transmission
How will a wing effect my 4 door front wheel drive honda at 80 mph?
Resonator
Need Help Asap
ATTN: Moppie
Fuel light?
Lol Idiot!!
Any good sites for indepth specs on internal parts??
B16A1, A2, & A3 Which is which?
B16A Question
Cat-Back? Headers? Both?
how do u remove rear seats 93 civic
Diesal fuel Error
I have three quick questions.
need parts
rattling?
is this worth it
96-99 civic EK with h22a
Mugen spoiler on 5th gen lude
Engine for a 4th Gen Hatch
Honda Engine Manuals
jdm engine
dodge truck transmission
Transmission
Try the easiest thing first
got me a 90 integra
racing fan
Cheapest place for H22a
88-89 prelude jdm ecu
Reset? Huh?
Clutch goin...
Web
AF
