View Full Version : Engineering/Technical
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45
  1. Friend Need Help Please!!
  2. '99+ B18C integra tyoe R in '99 civic EX
  3. 351 Cleveland, Big/Small Block??
  4. Jdm b16a swao in 96 civic
  5. Non-US D series transmissions
  6. Strange growling from left front.
  7. I have a dillemma!! (HELP)
  8. 4g usdm to jdm front clip conversion
  9. Loud motor/Exhaust leak?
  10. any jdm parts for 2001 and newer civic?
  11. Relocating battery
  12. Another picture question
  13. parts from f22 fit on f23?
  14. Import Builders
  15. Oxygen sensor locations
  16. Best engine coatings?
  17. 95 Accord not getting good Accel.
  18. HeLP
  19. HeLP
  20. Clutch Replacement
  21. do the 2001 civics and the 2002 have the same motors?
  22. I have a 2002 civic hx and want to know who makes the best exhaust,intake,headers....
  23. arent the 2002 civic hx and ex the same motor other than the emisions thing?
  24. clutch problem
  25. stage 2 cams ???
  26. when are they coming out with SPOON and MUGEN for 2002
  27. price for b16a
  28. Is this fixable?
  29. JDM Honda Civic B16A SiR II with an auto transmission
  30. Good Deals!?
  31. upgrading fuel system for a civic
  32. how do you go about changing an engine's octane requirements?
  33. Transmission Swap?
  34. Proportioning valve
  35. My swap...
  36. who is interested in titanium exhaust?
  37. Stronger D Series Tranny
  38. 4WD vs. AWD
  39. engine cough
  40. Modifying a 88-89 Civic Sedan..Which Engine fit??
  41. Help ! ! ! 3g prelude won't start
  42. what kind of hp gains would i get
  43. Cheapest place to order DC Header?
  44. Width and length?
  45. Engine swap
  46. Engine swap
  47. gsr swap - check engine light????
  48. Can i do it?
  49. mugen chip and rev high question!!
  50. B16 oil squirters
  51. How to reroute hood cable.
  52. b16a1 ecu/vtec solenoid problem
  53. Question about 93 Integra GS
  54. LOOK here.. I have a Q for engine swap.
  55. LOOK here.. I have a Q for engine swap.
  56. all power h22a
  57. Fast Idle Control Solenoid Valve
  58. spoon engines
  59. my car is on jack stands.....help
  60. Question
  61. Jdm B20
  62. CIVIC exhaust
  63. a question on motor mounts???
  64. Mid-Range Power
  65. b18c5 in 5th gen hatch
  66. Highest Compression on Pump Gas
  67. Anyone have an IAC valve from their old D series?
  68. Wiring diagram for MSD 5462 Boost Timing Master
  69. composites
  70. Turbo b16a?
  71. Need help on header install 911
  72. Feul cell cars
  73. spark plugs for b16a
  74. Windshield wipers won't turn off!!!
  75. Rev Limiter On 92 CIVIC Si
  76. Advancing timing if running constantly @ 4,000 + RPM's
  77. Headers
  78. cam help
  79. OBX Racing Sports?
  80. 2002 Civic si
  81. ZC swap
  82. compression and cold plugs
  83. Electical ?
  84. b16a1 install q's
  85. strength of stock valvetrain
  86. Where to find.....
  87. FUEL! Im stumped
  88. engine help plz
  89. Just Installed AEM Short Ram...
  90. b18b/b20b/turbo?
  91. SRR rear lower control arms & sway bar?
  92. Are cam gears illegal???
  93. b18b head + b20b block + turbo = good?
  94. Brake pads... Axxis Metal Master vs. EBC Green Stuff
  95. Engine swap cost?
  96. rebuilding b18b
  97. What does BHP mean
  98. torque converter
  99. oil catch cans
  100. lightened flywheel
  101. b20z vtec
  102. need more put you in your seat power
  103. I Have Issues.........Please Help
  104. Kill the MAN lol
  105. Cracked wheel lock update: pic inside...
  106. H22 and B20
  107. The brightest white paint
  108. What's the best belt dressing?
  109. 1st Gen B16a
  110. emissions
  111. h22 or b18c
  112. JDM Engines
  113. Where can I find a h23
  114. EGT Location
  115. How do i install an AEM Short ram on 02 civic ex???
  116. Engine swap in the Honda
  117. Differential Bearing
  118. 97 Del sol vtec engine?
  119. crv 2.0 or Integra Type R?
  120. Next Preformance Part?
  121. What is 70mm equal to in inches?
  122. short intake vs. CAI
  123. b16a o2 sensor
  124. any advice??
  125. hydro to cable?
  126. Good Swapping Sites
  127. '91 Si b18 swap info needed
  128. b16 axles
  129. Honda B16/B18 rebuild books?
  130. Smog legal?
  131. Haven't started the car in 2 years!!!
  132. Cam timing
  133. Questions about boreing (sp?) out the block!
  134. NGK standard vs. NGK V-Power
  135. project d16z6. imput wanted
  136. exhausts
  137. b16a1 throttle
  138. Emergency Problem! Need help asap!
  139. anodized purple cam gears...
  140. Help Help Help !!!B20b!!! Help Help Help
  141. Picture on posts?
  142. Auto ---> Manual??
  143. Power,Power,and More power!! Did I metion Power???
  144. Where to find good deals on performace clutch kits??
  145. tranny problems?
  146. Fuggi's Experiment - STAGE 1
  147. ZC Engine Specs
  148. inew intake too loud
  149. B20b Install Help
  150. What would you guys do?
  151. is there anyway
  152. hessatation
  153. is the resonator in my exhaust really necessary
  154. ZC Engine Specs
  155. attn: 5L eater.. knock sensor
  156. D16Z6 with bolt on hp
  157. anybody with a venom 400 on an auto?
  158. I need instructions on how to install coilovers?
  159. JDM Honda Civic B16A SiR II Automatic Engine
  160. Anyone SUCCESSFULLY performed the CRV-VTEC swap?
  161. ignition stuff
  162. question..NEED HELP!!!!!!!!!!!
  163. Automatic to Manual transformation?
  164. Jdm Parts
  165. B16a swap for 5g Civic HELP
  166. is this deal worth it
  167. Unorthodox underdrive crank pulley
  168. dsm injectors on b series motor
  169. b16b motor swap in 90' integra ls?
  170. b16a1 + hydro tranny...
  171. wich cams
  172. For Sale 89 Civic Lx 4dr!!!really Good Deal!!!
  173. Engine swaps on a 96' GSR!
  174. Jet Chip V-Force Power Modules
  175. maximum boost
  176. jumping wire for diagnosing?
  177. Can a b16 fit into a new civic
  178. b16a1 cap and rotor
  179. Pls Read! Very Important!
  180. Brake pads question
  181. Ceramic engines?
  182. Ceramic engines?
  183. How Much Would You Pay For A.......
  184. what ECU should be used for the B16A engine?
  185. Need some help with a ZC problem!
  186. Need some help with a ZC problem!
  187. GSR engine swap ecu plugs
  188. which dc headers would you guys recommend?
  189. Need help - My trannsmission
  190. advancing timing. What do you set it to?
  191. Can i use the old trans?¿
  192. b16a pros..i have a question..
  193. What is the difference b16a2 short and long block?
  194. ZC or D16Z6 swap in a 91 Civic Si
  195. ATTN: Moppie
  196. Relocating Battery to trunk
  197. cOSTS of a b16 or better engine
  198. Header
  199. Hondamotorsonline.com
  200. D16Z6 Problems in 90 CRX Si
  201. will a 99 civic valve cover fit on a 00 civic engine?
  202. To Be .... or Not To Be JDM
  203. port and polish
  204. aftermarket header for '90 SiR, worth it?
  205. does anybody know how to remove the back seats of a 2000 civic
  206. J1 tranny question!!
  207. Over Drive Is Not Working
  208. 3.2tl engine..?
  209. ECU location on EK?
  210. Looking for a DCOE manifold for a b16a
  211. torque specs on b16 head bolts
  212. Auto Shop
  213. Tranny fluid not gearbox fluid?
  214. Engine Swap advice needed
  215. Cold Air Intake
  216. MSD Ignition question.
  217. Code number 41.
  218. B16 is here! 1 problem...
  219. Brake noise - please advise
  220. missing gas cap
  221. missing gas cap
  222. missing gas cap
  223. computer chip upgrade
  224. computer chip upgrade
  225. PLEASE HELP!!!!!! Erractic Idle!
  226. Ls/vtec
  227. Mis SHIFT
  228. swap question...b16a owners..
  229. A Few Questions
  230. oil
  231. looking for parts
  232. Question about NOS (nitris oxide)
  233. swao question
  234. Why is LSD good?
  235. Metal Coupling Piece Thing?
  236. b16 question!!
  237. B16a in 1995 civic DX.... black smoke???
  238. b16a installed but some vaccuum lines are crossed...
  239. JDM ECU Question
  240. 92 accord automatic tranny question
  241. Brake pads
  242. need the stock bore diameter for a gs-r
  243. Ctr pistons..how can u tell?
  244. Brakes anyone?
  245. Brakes anyone?
  246. Brakes anyone?
  247. sensors on JDM B16A
  248. transfering mods to another engine
  249. Vtec not working!?
  250. JDM EG B16A into a EF SiR?
