Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
> Engineering/Technical |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
400h.p. 1.8?
distributor issues on '92 Civic EX
which motor...?!?
I think
Why do manuals roll backwards?
fuel economy
Ignitor
What makes more HP in a JDM engine rather than a USDM engine?
Excellent engine illustrations
H22a Question
aftermarket cruise control
RB26DETT Skyline engine into a 3G Integra???????
need help with vtec light
engine swap
exhaust question...
Transmission troubles (strange stuff)
Integra LS tranny with B16A2?
Overstreer & understeer??
orderin an h22 off net....which place is best to get the h22 from
Help with 87' Chevy Caprice
JDM-USDM Parts list...
Euro-R Parts
Give me and order to buy in here
Question about fine-wire spark plugs...
Used transmissions, what to look for?
Exhaust
civic trouble...HELP
MAP sensor
vtec or not vtec
IACV Problem?
block and crank
Aem Cai ?
Car Problems...Please Help
VTEC Controller for EE9
engine swap ?
Jdm Vs. Usdm
Spark Plug Comparisons & Explanations
Oil and Filter Comparisons
Exhaust Issue
Best Piston Choice
Throtle Body port matching
Carbs for my accord
Calling ZC Experts
n00b question... plz answer.. then laugh
JDM ITR Conversion
Under the Hood MOD'S
How much for a waterpump?
gsr in a del sol
Autometer Tach
need to know code for b16a 92-95 civic code #37
Idle Air Control
kei hin duals
b20b
Power Pulleys/Cam Gears
Accel 300+ in a honda?
How to shave door handles on a 97 Honda Accord 4dr
Parts Needed for b16 swap
B16a
B18c vs Crvtec
Torque Master spark plugs... Do they work?
HELP! Car issue!
funny smell when pedal is put to the floor?
general maintenance outline?
Wont rev above 2800rpms?
Trivia of the day (Can you solve this?)
Where to get OEM parts?
SOHC Cam Sprocket Advance or Retard?
help
b18c comp fit jdm b16a?
I need a little help
Clutch help
car running after shut off?
scraping sound coming from wheel
what do i need for ls/vtec
How close to ECVT? Also question on ceramic coating.
97 EX Parts on a 98 EX?
working a SOHC Vtec
Dumpin' the cluch
exhaust control valve
Engine problem - drained battery
snythetic oil vs. regular oil whats difference
DX With a EX VTEC Head Swap
B16a jdm into a 93 civic coupe
Aem Vs. Unorthodox
Rattle Noise?
swap
Best places to buy Engines?Local and on the net
Question on Natural Aspiration
engine designation question
crank shaft
96-98 B20 Ecu?
Exhaust Cutout/Bypass
Exhaust Cutouts?
Anyone seen this Before on Ebay?
B18b $$$?
Stalling
Need engine help/advice
Mysterious Coolant dissapearance and Overheating!
ls/vtec setup
Autometer Tach problem
What Would You do?
swap question
VTEC Head
Friend With badass CRX
ECU program, or chip?
SRS light
Check Engine light came on
97 s-10 just quit
whats needed for 97 civic to swap b18c jdm
This is going to sound REALLY sad....
Why am I burning so much oil???
nology wires & amp...Need Help?!?
how can i tell i my new engine is a REAL JDM TYPE R
Jdm Gsr Civic!!!
To Stroke or Not to Stroke???
B16 problems
Exhaust Question
Anyone with shaved door handles?
CI fuel injectors
Caaaaan it be done?
My Intercooler Concept (A/C. Nuff Said?)
1999 Honda Civic Ex Vtec 5speed is it fast?
99 ex vtec
Crower Cams
Bolt Size
JDM Parts
Another Header Question.....
Polish?
apex-i rev speed meter
H22A Question?
Jdm One Piece Head Light Kit
Civic Type R
Apex AVCR Questions!!??
Royal Purple Synthetic Oil
why do machine work on head?
Engine Displacement and Cylinders
New Header Gasket Or Keep Stock?
New Car, New Mods
which header????????
Ignition Advance ?Cooler or hotter?
Gm optima/Pontiac Lemans computer question
B series engine swap
Blown Head Gaskets
What do "engine numbers" mean?.....
Which would u buy?
Obd2 to obd1 wire harness conversion help
B18 into a 92-95 VX HB..HELP?
is my ecu automatic?????
żżż 5th gen or 6th gen ???
price and risk of adjusting cam timing
shocks worn out after ~10,000ks
engine racing very high on start up - PLEASE HELP?
B18C/R into 00LS Teg, engine harness wont fit ECU
ls-v-tec build up on a 92 b18a
I need some serious TECH help!!!
Turbo?
1998 Civic Foglight install?
how to install short ram intake on 95 Integra SE
Silencer stuck, please help
'87 Grand Marquis riding a bit rough...
Need help from engine swappers....
Valves, Valves, Valves!?!
Need to know the best swaps for a 98 civic ex coupe
Turn signals only work when car is warm?!?
Stroking (Not that kind, sicko)
Best motor swap for 90 CRX
click click click click click click AAAAHHH!!!
EF9 lighting problem
engine problems, HELP!
O2 vs N2O
good sounding exhaust
Em1
Injecting N2O/Propane into a diesel engine?
hi compression pistons
The purpose of redline on the tact...
S2000
Short Ram vs. CAI
Clutch pedal resistance
4-2-1 or 4-1
window guide loose
Help: Overdrive mode oes not work after transmission replacement
I posted in the wrong place
B16 A SiR2 swap
H22A into integra.. please help
JDM H22A into my integra... opinions...
Help quick please!
reality on H22 engines
changing tranny?
How does a car amplifier work?
need help removing exhaust!
where to buy mounts
H22A, auto and other mods...
Confused about RPM and transmission
brakes: to stop or not to stop
mini me
b16a head on b20 block query
Don't Buy From Importridez.com
Axles
Distributor
Need help with Carb.....
Need to pass emmisions? Check this out
Has anyone heard of this??
HUGE turn signal problem
Gm 3.8 V6
Suspension Ideas
87 Honda Accord-removal of Harmonic balancer-bolt will NOT loosen, Now what?
problem starting gsr swap
obd1 to obd2 questions... type r in 92 hatch
Help with posting pics?
FWD vs. RWD
bore and stroke
bore and stroke
engine changeover
gearing ?
biggest stock throttle body
strengthenin internal for turbo
Hey how about gear ratios?
How do u drive a "standard" car?!?
Tornado - snake oil or something else?
ex swap
were is the fuel filter?
What do you think of Unorthodox?
I need some serious tech help!!!
Where do i find Spoon or Mugen Engines for sale??
Electrical load detector, idle and aftermarket ECU?
Rachet shifter
Someone PLEASE make a list of good JDM part websites
What Makes A Type-R?
if you want new parts cheep............
Help needed with wiring and electrical project...
Keeping my hand on the stick ... does it ruin the transmission ??? Help !
Help for an Acura n00b...
B18B swap
reverse indiglos on a 98 accord
Need Engine swaps scientists, HLPLZ
hard cold start
I NEED info BADLY on this please, any help would be appriciated
Engine Ignorant
b16a1 into 90 integra
Find Civic W/out Motor
grit of sandpaper for valve cover?
race seats
zc block
?'s on angle valve jobs
bad clutch
Web
AF
