Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
> Engineering/Technical |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
Head problems - Pin in Vtec rocker arm Sheared off
Electric Turbo/Blower
Cfm = Pounds
sohc v-tec IAC valve ?
Interesting Read
Need Help/Ideas(grassroots upgrade)
Mechanics please help
difference between blowoff valve and wastegate?
Supercharger
B16A Starting problems
O2 Sensor Question
Bosch Spark Plugs?
2+ litre engines...
I have a question about engine materials.
Nology Hot Wires
n20 on a jdm b18c
Really Wide? or none at all :P
B16A into Dodge Neon
Grassroots upgrade (4th gen accord)
Exhaust Cut-Out
Please help! LS/VTEC
b18b swap help!!
b18b swap help!!
Engine Swap
torque vs horsepower
torque vs horsepower?
-=CR-VTEC or Turbo B16 ?=-
audi 100 won't run off idle
PrBLM with 3rd Gear
go-cart
Test Pipe Bad, Good? Help Please!
JE Piston Rings, where??????
half-shaft replacement
need hlp prepping for a cross-country trip
High pitched whine
Rear-wheel Driven Honda?
which engine is the best build on???
JDM auto tranny!?
APEXI N1 colored muffler NA or TURBO
Where can i get a B16 or a B18C1??
Turbo Install help
One Piece Headlights For Vigor
bad way to fix control arm
what performance cams should i get?
front end prob....
check engine,HELP!
Strange "loose" feeling in rear in an 89 Honda Accord coupe
Buy from Honda?
Car Broke Down, Need Help!
Need help from the AC people.
I know this is probably a dumb question but...
mini me
Lights wont turn off!!!!
Stock intake parts
trouble shooting!
Need help: connecting wires to a fuse box
Engine dress-up question
OEM or AFTERMARKET?
Neuespeed Short Shifter Bushing
keeping cai cool
Clutch not making vtec work!?
Upgrade to Cold Air Intake?
More spark plug ideas
Engine Mods
Clutch issue
How to tell if a fuel injectors cleaning is in order ?
Looking for snow tires for slippery T/A
Fuel injector cleaners tests
Oil and Filter Comparisons
b16a distributor.....how do these plugs wire up???
*news flash* 10 dollar exhaust mod adds 20 horsepower!!!!
Pics of my car... What to get next?
Starting problems!!!!!
Which one is better?
Optimum Point to change Gear
pneumatic and electro-magnetic valves
An idea I had at work
b18c1 swap help
automatic to 5 speed tranny conversion
B series in canada
Does anyone know the Chassis codes?
High Flow Cat for Accord?
mozart exhaust opinions
97 CRV Code
97 CRV Code
Jdm Garage Sale...
Auto To Manual Conversion...??
Flowmaster
4WD VTi-R Integra
built engines
List of motors please
sparco custom floor mounts?
If I made my own ghetto intake, would I get any real power?
torque??
best engine??
Swap B16C-R???
OBX Racing Sports????
read it
What engine???
how do i install new tail lights on my '92 civic hatchback?
sparco seats in 5 gen
Big Problem Please Help
The Search continues for the JDM B20a
H22A Swap Question
92 Civic Start Problems?!?
Polishing valve cover
Put An End To This Craziness
4th gen Civic hatch, B16a
automatic transmission pickup filter/screen
ES Universal Oval Muffler
Iceman?
cylinder head question?
Help!
Best Acura/Honda Car
brake troubles
engine swap for 2001 civic
97 civic EX tranny Question
wiring woes in b16a ef civic
burning oil
ls/vtec
Si Ecu Help!!!!
What Oil filters are you guys using and.....
Auto Tranny
Lights question
Spark Plug Gapping....
b16a swap issues
Swap in an H22 or get a GSR
no reverse
Question about Catalytic converters.....
Tach hook-up
Any sites selling type r or si accessories
Bent Valve?
Apexi
1st gen B16a head on B20 crvtec
Apex'i world sport exhaust
is it worth it?
95 Integra GSR transmission problem
Need 4 speed
Is 22psi possible on a GS-T?
5zigen angled? tenzo angled?
which of these is a better exhaust?
how much performance decline?
Burning about a quart of oil a week. Yikes!
what should I do?
Aluminum Flywheel ???
CAI or Front Mount CAI
1991 Honda Accord EXR Intermittent Starts
SI engine with auto tranny
oil "weights"??
Air Conditioning and engine
Need tips on launching...
What is prevailing torque?
2000 Civic 3door to b16a2
Fair asking price, input please!
Crank Pulley Bolt Torque Setting?
Front Wing/Splitter/Diffuser
wireing diagram for car stereo!
ac autotechnic revolution intake
brake lights stay on.... all the time.... not good...
Engine lubrication
zc distributor in place of b16a?
92 chevy 1/2 ton pickup
car out of commission...
Aluminum flywheel questions
Car Wont Start
JDM using USDM parts?!?
Engine Swap Questions
axle help....pleeease!
Auto tranny + TURBO ok??
swap in california?
Oil Question
jdm b16a vacuum hose HELP/CRX
question
pivot air/feul controller
Slower acceleration with new clutch?
For Sale-jdm folding mirrors 90-93 integra 2dr
Vtec not working!? (Again)
Volts vs Amps
Vacuum Shifter?
I need help
Head Lights!
Nipple's
JDM lights on a 90 Integra...
question about transmission
cheap engine?
What steps do I need to take to get my car in the 13's...N/A?
advice on engine swap...
b16a intake mani
obd2 to obd1 conv. harness question
I'm a N00B
Best engine setup for turbo?
b16a oil pump
Fuel Question
vacuum hoses
Itr pistons v.s. JE
fuel filter
'91 Integra motor in '89 Civic... NEED HELP Please
New Engine for 92 Integra
pleazzzzzzzzz tell me its posible!!!!!!!!
CAI vs. Short Ram.
Brake lights stay on while driving??
is this everthing ?
Wiring harness for denji projectors
Compression ratio
How too grab a code
Torque Converter Question
Common Question, but please humor me
timing problem??
Gasket HELP FAST!!!!
Please help so i don't get ripped off
92 Marquis
Windshield washer adjustment
Questions- HP Gains
hybrid ?
Mini me hatch?
learning to drive a manual (5 speed)
front alignment question
What way to go.....Engine swap?????
Where in Indiana
How to tell?
Air filter cleaning question...
In-line Transmission Filter With Bypass Valve
Overdrive question
Honda Tranny Code HELP
Thanks to everyone here!
Can i use a turbo and a super
Odd tranny problem
Dump Valves
Frankenstein B20Z with B18c5 head ?
transmission cooler installation
weird question...
400h.p. 1.8?
distributor issues on '92 Civic EX
which motor...?!?
I think
Why do manuals roll backwards?
fuel economy
Ignitor
What makes more HP in a JDM engine rather than a USDM engine?
Excellent engine illustrations
H22a Question
aftermarket cruise control
RB26DETT Skyline engine into a 3G Integra???????
need help with vtec light
engine swap
exhaust question...
Transmission troubles (strange stuff)
Integra LS tranny with B16A2?
Web
AF
