View Full Version : Engineering/Technical
  1. stock internals
  2. Starter Problems?
  3. alternative to cams and valves ??
  4. Detonation: The Engine Killer
  5. Is this possible?
  6. Can you put an s8 engine in a VW Golf? plse rspnd
  7. Map sensor CEL with a Jet V-Force PCM (Help)
  8. Spark + Fuel = No Start
  9. Convertible spoiler effect
  10. FWD Posi
  11. 5-20w. oil...You've got to be kidding!!
  12. People Who Drive Glass Dodges...
  13. has anyone bought a jdm motor from ardperformance.com?
  14. Programing Instructions for keyless remote
  15. Ceramic VS Stainless Header
  16. Automatic Transmission Stuck in Third Gear
  17. Do variable venturi carburetors ice-up?
  18. 1995 isuzu rodeo overheating
  19. I Need an overdrive transmission. HELP!!
  20. Tough CEL problem.
  21. Turbo Kit
  22. B-Series: no moderator
  23. "Cross breeding" engines - Prsh GT2TT engine in Rnalt Clio v6 - dream or reality?
  24. Break Fluid Leaking?
  25. Emissons legel High Flow Catalytic Converters
  26. Car Trouble
  27. Volvo 850 Remote Programming
  28. hp per psi theory
  29. LSD question
  30. What to do? Valve adjustment-> Service messed up
  31. how to remove a really tight head bolt
  32. what are some good 2wd pu trucks?
  33. Car Entusiasts Needed!
  34. camaro engine help
  35. check out my engine...
  36. A/C help needed.
  37. ZC engine bogs out.. code 7/14
  38. Supercharger question
  39. Finally got me one of them Muscle Cars
  40. Starter wiring question??
  41. Aztec gold
  42. timing belt position
  43. '64 GP Fireing order
  44. Valve Adjustment results on my Accord
  45. 77 Gremlin X
  46. HOW can I beat a gt with a civic?!
  47. 4-1 or 4-2-1?
  48. Transmission swap?
  49. 70 Gs parts compatability
  50. help! o2 sensor!
  51. O2 sensor
  52. new obx exhaust = check engine light
  53. Air Pump
  54. What About Car Movies?
  55. a problem with my distributor
  56. What is vtec exactly?
  57. What is a Dyno tune?
  58. School Project
  59. GMC 1992 Sierra
  60. Mobile Computer CAR interface
  61. Engine Questions
  62. weber carb
  63. are stock jdm engines faster than usdm stock engines?
  64. TRW Pistons for 30 over 402 BIG BLOCK CHEVROLET
  65. Custom Rod Builder Profiles - Check it out!
  66. Help on deciding exhaust
  67. heads
  68. Is this rare for a Sebring?
  69. Paint job
  70. specc sheets?
  71. Fuel injection problem
  72. how long will this last me?
  73. tranny questions
  74. leak problem
  75. New Engine or Rebuild?
  76. How much boost?
  77. Turn T3 Turbo into Internal Wastegate?
  78. Loss of Power
  79. Best car/engine combo for a newbie?
  80. help help help please god help
  81. 97 Chevy Transmission Problem
  82. 2000 Isuzu Rodeo CEL, fuel tank sending unit
  83. Seats and Consoel
  84. anybody bought their motor from hmotorsonline?
  85. Engine combinations
  86. Intercooler & Aftercooler....
  87. Using water to clean the combustion chambers
  88. Air bag problem
  89. changing fuel line...
  90. Help with ditributor!!!
  91. Need Some help on getting my 1967 Nova SS Running
  92. 2002 honda civic lx for sale
  93. Flowmaster Delta flow vs regular
  94. 400 sml blk max power
  95. 70 Gs 455
  96. a sick 93 typhoon
  97. power loss?
  98. Headlight Problems....Please help!!!
  99. GM 4T40-E Transmission Torque Limit
  100. Running Lean
  101. Clutch question
  102. Increase horsepower
  103. CTR pistons?
  104. newbie needing guidance on swap
  105. is it my fuel pump
  106. 82 Malibu Engine
  107. guys need help fast... ebay header tech question.
  108. Where is a good place to get a JDM motor
  109. Rocker Head cover question
  110. 00 clipse, need speed!
  111. anyone know of a site for Sponsorship?
  112. Shifting
  113. Setting valve clearance in my accord, need help
  114. ram air VS. cold air
  115. 99 s-10 runs rough need help!
  116. Info On catalytic converter
  117. enhance car performance
  118. HELP homemade turbo or something
  119. motor
  120. HELP! (wiring)
  121. Charger
  122. ecu question
  123. carter carb
  124. carter carburetor
  125. JG Engine Dynamics
  126. aftermarket clutch cables
  127. pulling out engine
  128. Valve Tap
  129. supercharger+nitros question?
  130. Motor pings, knock sensor computer code
  131. Venom 400 vs. Apex'i S-AFC
  132. LED tail lights
  133. simple questions to some
  134. 1962 221 V-8 4-door Fairlane
  135. how to mix paint
  136. 1969 390GT Motor & 4-speed Transmission
  137. Hagerty insuranceDoes
  138. Caliper Stuck...HELP!!!
  139. Robotic Hummer Competes for $1 Million Prize
  140. 250+hp on a 2003 V6 Tiburon. ! or ?
  141. A New Type of Attack by ELF
  142. A Domestic Terrorist Brought to Justice
  143. oil temp/pressure questions
  144. 94 GMC Truck problem please help!!
  145. Where is the mass airflow sensor?
  146. ZEX Nitrous Install
  147. oil and water pump upgrade?
  148. Buick century ignition problems.
  149. Installation of short shifter
  150. Tiburon or Not? PLZ HELP!
  151. 1966 cyclone gt parts wanted
  152. racing high flow cat....
  153. P30 O2 sensor?
  154. O2 sensors compatability.
  155. where did yall start?
  156. clutch burnage.
  157. HELP!! speedometer problem
  158. What was the Heavy Chevy Chevelle?
  159. What is a Ralley Nova?
  160. legend caliper upgrade on 99 si ?
  161. Plymouth road runner 69
  162. Car Choice
  163. wich swap
  164. engine swap???
  165. heater fan problem
  166. Towing Using A Chevy Astro.
  167. Please help my guys
  168. confusion!! need expert advice
  169. Tach Install
  170. 94 dodge shadow no power to coil
  171. How to find old car
  172. Help me build a 289
  173. Why does my car whistle?!?!
  174. Hot Rod Power Tour 2004
  175. clutch question?
  176. looking for a demon
  177. looking for a duster
  178. Skylark Wiring Harness
  179. ecu question "URGENT" HELP
  180. cars in my price range
  181. Prelude motor swap??
  182. replaced alternator & battery/battery still dying
  183. new to the scene
  184. heater fan is a no go
  185. Leather Seats?
  186. Ford Truck Motor-vs-Car Motor
  187. line locks
  188. the cars of the future
  189. HELP!!!!!!! Need Engine Coolant Temperature Sensor and Throttle Sensor
  190. Timing Problems
  191. where to get a engine built
  192. lsd???? tranny?
  193. Questions about 50 fastest list
  194. Oil change!!!
  195. Climate Control Digital
  196. info on modifying a 91 regal gs
  197. and it begins.... (pics and such, 56k beware)
  198. Where Can I Get Jdm Parts????
  199. Oh lord...
  200. Bov question
  201. All MOTOR PLEASE
  202. Any good sites with JDM front conversions!!
  203. fuel pressure help
  204. The BEST AFTERMARKET PARTS
  205. air conditioning compressor problems
  206. The Baja 500
  207. Problems when wet
  208. Trucks on the Cutting Edge
  209. help!!
  210. 1974 road runner lock up stall conveter ?
  211. thermometer rigging
  212. Engine math: I6 + I6 = V12?
  213. S-10 rear end
  214. Window help
  215. exhaust QQ?????
  216. Smog tubes for headers?
  217. engine leaks oil?
  218. Cleaning Your Mass Airflow Sensor
  219. Tire pressure: Conflicting advice
  220. dome light problem
  221. remove scratches from the windsheild
  222. Injen CAI Damaged my Head Gasket? In Need Of Serious Advice!
  223. Help me Pick
  224. New Here!
  225. Muscle Car picture gallery
  226. OBD0 to OBD1
  227. Help needed installing autometer gauges
  228. camaro back seat belts question
  229. how much does it cost?
  230. is there any AUTO. engine swaps?
  231. Hoods and Hoses! need help!!
  232. need help fast!!!!
  233. Buy a CARFAX Report for only 4.99 from me today!
  234. 1969 roadrunner
  235. Wiring mystery, fuse ghosts
  236. Ignition problems
  237. Need Help!!!
  238. Need Help!!!
  239. 94 dakota stock stereo quit
  240. head swap
  241. 86 gmc
  242. Easy Question about cooling fan? How does the Radiator Cooling fan know when to Come
  243. speedo woes....
  244. Wipers
  245. Denali DVD Navigation
  246. electric choke
  247. carburetor & computer
  248. Engine swap question
  249. Maintance Light....need help
  250. 65 comet
