View Full Version : Engineering/Technical
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45
  1. is it possible for a b20/gsr frankenstein?
  2. jdm motor & parts infor/chat
  3. 92 civic CX swap to a h22a??
  4. Motor swap
  5. Racing chips???
  6. H22A Pricing
  7. engine swap
  8. Best motor in 5th gen. civic
  9. Synthetic oil
  10. Flaming Exhaust?
  11. what the hell is a spoon engine
  12. CTR Pistons in 1.7 DOHC VTEC
  13. B18C-R motor
  14. H22 AEM Pulleys
  15. Vtec
  16. Where on can I find Info about engine parts?
  17. Raising the RPM range.
  18. can I use an OBD0 or non OBD JDM ECU on my OBD1 GSR?
  19. What Next??
  20. 2000 Honda Civic EX
  21. cai for hybrid hatch
  22. short shifter for hybrid swap question
  23. Jdm Sucks Balls!!!
  24. The pics are in!!
  25. Oil leak
  26. anyone in Minneapolis area know of a good import shop
  27. need help H22A Engine Swap
  28. Has this happened to you?
  29. Catalytic Converter
  30. All 4 doors losing electrical power?
  31. Need some suggestions for reading material
  32. Got a problem with my H22
  33. How long until we see brake-by-wire on production cars?
  34. ecu ?'s when doing a swap
  35. Where can I find a loud exhaust?
  36. h22 swap
  37. Question about fuel pressure modifier ...
  38. A YES/NO question
  39. a few newbie quesions
  40. 93 Accord EX swap to a H22A
  41. H22
  42. High-Revving a B18C
  43. Rebuilt Engine won't start
  44. B16A and B18C Crank
  45. Noise when I turn my wheels
  46. Adjusting Valves?
  47. car wont start please help
  48. Got B16A ??
  49. b20b in civic?
  50. JDM Integra Front End Conversions?
  51. well that can't be good
  52. A Camber Confusion!!!
  53. Propane kit for setting mixture, 81 Civic
  54. Catalytic Converter / Header????
  55. 1990 Geo Prizm cranks, but will not start
  56. Nitrous additive...
  57. Prelude type-S air box
  58. Limited Slip Differential swap question
  59. 91 Plymouth Laser Transmission
  60. Valve Cover Oil Leak?
  61. JDM tune ups
  62. MSD install w/ Blaster2 coil on 1.5 SOHC
  63. How much would ABS help me in autocrossing?
  64. VTEC activation
  65. H22a @ 12,000 RPM
  66. ZC question
  67. help w/ head swap
  68. need help with engine swap
  69. Any advice on replacing my stock pedals?
  70. Bodykits+Lower vs. Speedbumps
  71. World Sport Series for a 6th Gen Sedan???
  72. Does any one make cams for H23
  73. Naked chick pic inside
  74. h22a tubro setup,wat u think?
  75. '86 Chevy van - how to get the engine dome open??
  76. Passlock System on a 98 Malibu
  77. B16 in a 91 Hatch...How Much?
  78. Drag Car opinion
  79. GA emissions?
  80. B16A Where in the hell from?
  81. Jdm Parts And Accessories
  82. JDM Motor codes
  83. How much is involved in putting a h22 into a 92 integra???
  84. All Show And No Go!
  85. Looking for a new car... need opinions
  86. turbos to much for my engine?
  87. engine overheated
  88. How do u take of an emblem?????
  89. engine .vs. fuel grades
  90. Help
  91. 1993 Acura Integra JDM Recommendations
  92. engine serial number ID
  93. any one heard of...
  94. Spoon engines..
  95. Apex'i vs. Greddy
  96. beware may be dagerous
  97. graphing calculators
  98. Weird smell
  99. b16a swap
  100. Throttle Postioning Sensor
  101. important ECU CODE 9
  102. ECU code 9
  103. distributor question
  104. Want to install a free flow muffler on my....
  105. Alternative Theory
  106. Cylinder coating
  107. air intake question
  108. H22 in a 92 non-vtec??? please help
  109. ls b18b or crv b20z ????
  110. ECU Codes?
  111. h22a jdm cap
  112. i really need help with my decision, i went b-20
  113. i want to buy b20z
  114. some help hea plzzz
  115. ACURA {3.0 CL}....."TIMING BELT" Question
  116. B20 swap questions
  117. What would u do?
  118. AEM or Unorthodox Racing?
  119. Fuel Filter Location for 98 Ford Contour SE
  120. Would a airlock appear if thermostat is not working?
  121. R-12 to R-134
  122. b16a swap ? on speedometer
  123. Fuel Injectors
  124. TPS issues
  125. Coolant Issues
  126. Compression?
  127. 1.5L throttle body
  128. HP Racing vs. Landspeed Racing Powercore Headers
  129. Car won't start but stench of gasoline
  130. cold air intake
  131. matrix cold air kit
  132. Water pump question
  133. throttle cable on jdm b18c type r in 5th gen hatch
  134. MissFiring or Air in gas lines
  135. Sparco seats anyone?
  136. ball joints question
  137. Best place to buy from ?!
  138. very important
  139. Ran out of Gas now Engine Won't Start
  140. UK Honda DOHC 1.8 VTECH
  141. Vtec Controller?...why recomended for H22?
  142. overheating problem, maybe some suggestions please?
  143. perfect engine? and another OT q...
  144. JDM Sr20DET flywheel
  145. b16a1 into a crx dx
  146. V-tec ?
  147. Looking for End Cam Retainers
  148. Engine Swap
  149. Painted headers
  150. Low coolant warning lamp on and air coming out at expansion bottle
  151. Is any body doing a H22 swap I need the old motor!!!
  152. When's the best time to "floor it" when going through a corner?
  153. nsx vtec solenoid
  154. speed and power secrets
  155. Need more power!!!
  156. b16a powered 4g STD civic running like ass
  157. japanese b18b install
  158. New here, thought i'd introduce myself
  159. B16a long block?
  160. What exactly does increasing the stroke of your engine do?
  161. header problem
  162. d16y8 engine block
  163. headlights
  164. Phantom Grip - anyone has pratical experience / comments?
  165. Plasma BOOSTER
  166. HP/torque vs. RPM
  167. bonnet jacking
  168. How To Install CAI On 1990 Accord?
  169. gear ratios?
  170. 01 integra engine upgrade
  171. oil leak problem?
  172. Hi-Flow Cat
  173. cad
  174. For Integra owners
  175. where to get JDM parts??
  176. Calling all ZC experts/ anyone who can help
  177. fuel pump location?
  178. best degreaser and stuff?
  179. turbo + testpipe=good?
  180. crank pulley removal
  181. Mugen
  182. i need 88-91 SI parts
  183. Battery......
  184. Ford Tempo won't stay running
  185. !URGENT! Installing CLUTCH, Need Specifications and Info By 4pm!
  186. How to install a strutbrace
  187. ? year parts to swap DPfi to MPFi
  188. fuel filter fitting question
  189. !!--hardwire vtec
  190. JDM B16A 88-91 CRX Shop Manuel Also includes USDM & ZC
  191. JDM 88-91 CRX B16A Shop Manuel
  192. Exhaust
  193. Custom made front lips and bumpers
  194. Where to get an ECU
  195. exhaust for b16a in 92 cx
  196. My own H22a Thread, please join me!
  197. Forget cold air... you want Ram Air
  198. New Car, New CAT?
  199. Fog Lights: A How-To
  200. Weight difference in 5th gen civic models...
  201. Si coversion?
  202. Can I get some help from the pro's plz, Ime building my car and need help!
  203. exhaust mods...
  204. Air/Fuel monitor
  205. Ime selling my 3000gt and buyin a civic or integra I need help from every1
  206. Check engine light, HELP!!!
  207. Inaccurate speedo
  208. Honda Accord heart transplant !!!
  209. camshafts
  210. B16a questions
  211. B18C1 vs B18C5
  212. !!!help--ECU question--help!!!
  213. Anyone looking for a mugen emblem?
  214. question for ivymike: Ideal Gas Law
  215. Paint chip questions....
  216. Transmisson problems
  217. Looking for books/websites on suspensions
  218. h22 swap question
  219. Skunk 2 stage 3 cams question!!
  220. swap in TO
  221. B16A.. from a SiR-I or SiR-II
  222. Chaasie Number?
  223. iac the problem?
  224. stick-shift...PLEASE help!!
  225. Theoretically, how much torque could the strongest 6-speed manual gearbox take?
  226. need help wiring si motor!!!
  227. JDM final drive question...
  228. Cat
  229. Need some help on understanding the mid-engine AWD layout...
  230. Just a question about vtec controllers....
  231. 3s-fe?
  232. 1.5 tbi
  233. COLD COLD intake
  234. Bizarre D16 problem/engine numbers
  235. b16a1 into 88-91 CRX Si Swap
  236. Help for 2001 civic ex
  237. What do the different gears do?
  238. Need some information regarding spark plugs.
  239. How Can I Stop The Seat Belt Beeping?
  240. Auto Transmission Temp.
  241. b16a1 parts
  242. VTEC Controllers
  243. truth about LS/VTEC
  244. cam gears
  245. conversion from automatic to manual
  246. electric schema for Lancia Delta
  247. Question on Crane Cams roller rockers
  248. An odd problem, need some help.
  249. B16zc
  250. Need help quick
