View Full Version : Engineering/Technical
  1. 1986 jimmy 2.8
  2. 4 wheel drive?
  3. looking for 68 charger
  4. what's ground mean?
  5. Newb Transmission Question
  6. ASE test prep help
  7. Does this sound right?
  8. 82 accord
  9. Stories
  10. What Car is it Anyway
  11. 72 Javelin AMX
  12. Speedometer not working?
  13. Piston rings or what!?!?
  14. Which car is that??? Please help ...
  15. Overheating Problems
  16. Audi A4 body kit
  17. is this
  18. please help, 2 problems
  19. need walk through on coilover install
  20. Vibrant Performance--Universal Mufflers
  21. 97 malibu auto trans
  22. Manual Choke to Automatic, HELP !
  23. strange A/C behavior
  24. help!!
  25. Whats going wrong with my tranny....
  26. MR vs. FR
  27. Anyone with a truck and a dolly near Newark, DE?
  28. 426 Hemi intake on a Ford 429?
  29. Hack my Brakes Up
  30. 85 CRX cluth problem, PLEASE HELP!
  31. Exhaust....
  32. Your opinion? Is it worth it?
  33. My 318 isnt running right i need some ideas please
  34. Please help, JDM H22a info needed
  35. remote start on a manual tranny
  36. Sorry Im Dumb
  37. 5 Angles Valve with Domed Pistons
  38. A/C Problems w/ Squeaking... Clutch?
  39. turbo350
  40. Should I buy it?? (2002 Silverado 2500HD)
  41. 86 2.5l Cutlass Ciera Cutting out--Please help
  42. Cyl Manifold sequence/Trq
  43. van battery dying HELP!!!
  44. rpm's possessed devil
  45. My GTX isn't running right!!!!
  46. Sport mirrors
  47. Leaking dash?!!
  48. turbo on automatic
  49. Weber carburetors and fuel supply pressures
  50. inline and block
  51. Hydrolock Please help
  52. "88" C-3500 auto Transmison
  53. IT"S AN F BODY!!!
  54. backfire prob
  55. MAF and BOV
  56. low oil pressure
  57. 1966 Dodge Charger 383 4bbl
  58. Lightning booster
  59. Need Torque specs
  60. increasing compression ratio?
  61. buying a sweet 65 malibu?
  62. Really Important
  63. help! install el glow gauge faces
  64. Lug Nut Question
  65. I need sumthin cleared up
  66. LS6 into 85 Z28
  67. DYI front end alignment Chevy truck
  68. What is it? 352 360 390?
  69. crate engine
  70. crate engine
  71. Car won't start, Please Help!
  72. Help! Help! Help! Gas Leak!!!
  73. Third Member Rear End
  74. Ranger clutch line removal
  75. good mustang muscle year?
  76. AMC 258 Chrome Valve Cover and Header
  77. big tires
  78. Glitter in oil
  79. buying camaro
  80. Miami Mechanic Needed
  81. iat location
  82. all around what is the best muscle car?
  83. A.T to 5 speed swap for civic
  84. Buick 455 What year?
  85. Buy & Sell
  86. 50 Fastest Musclecars
  87. Elk River Car & Bike Show : Monthly
  88. Key won't work, who to call?
  89. Another JDM emissions question
  90. The Tuning Numbers
  91. Choosing Turbo Size...
  92. measuring alternator current
  93. engine idle
  94. Need Brake & Clutch Pedal for 1970 Mustang
  95. Just Wanted to introduce myself
  96. How much would it be if i wanted to convert?
  97. Hydro-Boost & Power Steering Problem
  98. Effects of retarded ignition timing
  99. Stupid Q, need a Smart Answer
  100. Disconnect o2 sensor -> better performance?
  101. Aftermarket age?
  102. Ram Jet 350!!
  103. Gearbox problems, help.
  104. physics of power steering
  105. 1/4 mile and 0-60 times
  106. 1994 pontiac Grand Am head gasket
  107. Stick Conversion
  108. Wut happens if I pull this fuse....
  109. grinding in front
  110. Weight Question
  111. Hood Shocks
  112. Want to pick up speed on a Automatic 99 honda accord?
  113. 1985 trans am 305 t.p.i to a 454cid
  114. Best engine rebuild kits?
  115. Convert OBD1 motor to OBD2 possible
  116. stall...wont turn ova
  117. common engine swaps in 70's model cars
  118. Block Guard + Sleeving
  119. spark plugs on 1997 chevy monte carlo z34
  120. Oil sending unit going off
  121. Intake Manifold probs
  122. 1960s gto
  123. 68 Dart Hemi
  124. questions on long blocks
  125. power plus typhoon intake manifold
  126. 96 ford probe gt 2.5L
  127. Universal Exhausts
  128. Strange problem
  129. Turbo Q
  130. Valve timing question
  131. Headgasket gone need info
  132. Flames grom tailpipe
  133. Electrical Prob.
  134. Injectors and fuel pump?
  135. Follow Up
  136. Gaining power?
  137. Cold Air Intake Help!!
  138. What does 1/2 ton and 3/4 ton mean?
  139. design process
  140. Transmission Coolers
  141. Rims = No warranty??
  142. 302 vs 351W headers? are they the same?
  143. max horsepower out of a 351?
  144. My drag truck...
  145. 302 and 351W headers? are they the same?
  146. catback systems
  147. CA smog law finer points; aftermarket parts
  148. Mustang Muscle??
  149. Corsica fan relay
  150. cowl hoods
  151. Engine Swap Question
  152. dirty o2 (oxygen sensor) ? Will it read lean or rich?
  153. best place to buy aftermarket parts
  154. Air Filters
  155. 67 Cougar headlight covers
  156. 1983 s10 engine swap
  157. How do I remove filler tube on my 74 cuda?
  158. fuel injection vs. carbuerator
  159. Muscle Car: What's a muscle car?
  160. Need Help!
  161. Need Help....< Newbie...
  162. quade throttle bodies ?? whats up with that
  163. Need some help on a 87 firebird
  164. Volvo 440 overheating HELP Please
  165. Looking for a car
  166. 87 Firebird...
  167. I have some weird questions about cars...
  168. front mount cold air intake?
  169. Limited slip???
  170. sport compact pro
  171. I need a few questions answered
  172. Help me with my 70 chevelle ss
  173. Whistling sound
  174. tranny question
  175. mixture problem
  176. V6ers
  177. Let's See What Happens
  178. disabling a hotwired vehicle
  179. $1,000 To Spend Help Me Do It
  180. Building a Motor Need Help.
  181. Dilemma with '66 Charger
  182. Removing Exhaust
  183. shortening a chassis?
  184. Newbie ! also seeking tranny part
  185. Gas Question
  186. Break Pads Help
  187. Programmable ECUs.....
  188. 455...What year would be best?
  189. Hockey stripes on 1st gens
  190. Na - Turbo - super charge
  191. real defintion of "riding" the clutch
  192. rear bumper?
  193. Ultimate Hummers Magazine
  194. wheel hop
  195. AAA & Parents Magazine's Picks for Best Family Vehicles
  196. Pics of my car
  197. Tax Deductions and SUVs: Get The Facts Before You File
  198. Help
  199. Jackstands vs. Ramps
  200. 69' shelby GT350 convertible for sale !!!!!
  201. Nice 100K Carmaro
  202. Worth $100k (69 Carmaro)
  203. High compression pistons...
  204. Fuse Blocks???
  205. Couple of question (ignition/engine)
  206. car will turn over but not start please any suggestions
  207. who has the best intake manifold?
  208. slotted or crossdrilled rotors?
  209. tuning up
  210. School Project
  211. Some advice on a swap
  212. MSD Ignition: A Whole New World?
  213. engine hesitation and weird oil pressure
  214. which came first: the axle or the tranny?
  215. Rotary engine
  216. Engine swap Q
  217. Jdm D15b
  218. Car Shutsdown
  219. fuel system upgrades
  220. WTB 76-78 mustang
  221. rich mixture -> reset ecu?
  222. Learning how to restore
  223. So sad. :(
  224. Clutch question
  225. What do you think?
  226. 4t65e Transmissions Slips after 5 min of runtime
  227. Muffler Question
  228. Transmission additives(slipping under load), share your experiences, please help.
  229. plz help me
  230. 1970 Mustang Mach1 Registry
  231. crower 404's
  232. ???!!more stock clutch questions!!???
  233. How true is it?
  234. ISC device
  235. gas odor
  236. Picked up a "Mini Muscle"
  237. newbie info
  238. Help Plz.
  239. WTF is going on with the Rotor button?
  240. Turbocharged Engines...
  241. What is this?
  242. re:6al msd ignition
  243. Ignition Wires....
  244. What is the best motor for my hatchback?
  245. ???!!stock clutch questions!!???
  246. How to warm up your car in the morning less than 30 Seconds!
  247. unstable RPM
  248. replacing instrument gauge lights
  249. Motor diagrams?
  250. Anyone know here to find oem headlight wiring?
