View Full Version : Engineering/Technical
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45
  1. How fast is CRX w/ JDM b16a1?
  2. AUTO 101 questions, HELP since your such a badmutha..
  3. how do u remove isuzu starter???
  4. I need a 6 speed tranny can anyone help?
  5. i just did an f20 swap in my 90 accord
  6. Is there a c/a/i for B18C1 in 5th gen. h/b?
  7. NoS
  8. Underdrive pullies
  9. Changing shift boot
  10. Removal of Shifter Knob
  11. Loads of Newbie Questions!
  12. EGR Valve Disable
  13. R! racing sports questions
  14. gs stock w/ nos
  15. engine swap or engine rebuild
  16. A'PEX Auto Timer
  17. Apexi RSM Rev Speed Limiter
  18. Who digs diesel?
  19. need help identifying sensors
  20. 1991 Nissan NX
  21. My 92 protege and a glasspack
  22. Help stuck?
  23. b16a to crvtec
  24. timing belt fo a zc
  25. Question Re: Installing an H22A in a 95 GSR
  26. automatic transmissison problems need help
  27. How much power can ya get out of an si
  28. New kind of engine
  29. Lights
  30. Wheel Alignment
  31. Tansmission ?
  32. Lsd?
  33. CTR/ITR 5 Lug Conversion
  34. Twin Turbo Zet.
  35. Quick question
  36. 96 CX HB engine swap help?
  37. Torque vs hp?
  38. car circuitry
  39. how do i tell it's a lsd transmission?
  40. tacoma floods
  41. high/low compression
  42. Exhaust
  43. Jdm F20
  44. $mulah$
  45. sensors
  46. B18b
  47. Bypassing Fuse Box
  48. Fake MUGEN valve covers & ect.
  49. 91 integra XSi engine specs. ??
  50. Looking for jdm wholeseller
  51. Which b16 should i put in my hatch
  52. Turbo Vacuum
  53. Full Body Skirt For Toyota Levin
  54. 1994 Accord SiR
  55. autolamp sensitivity
  56. Crazy or what?
  57. What To Take In University???
  58. dash panel blues
  59. Dealer Experience: Lisle Honda
  60. Emissions Warranty Ext. 14yr/150k
  61. Have a little problem!
  62. please read...
  63. Prelude Parts Available On Ebay
  64. Hardware/Gasket for Header Install
  65. Alternator Question
  66. www.a1jdmengines.com
  67. 1991 accord swap info.....
  68. need help! usdm h23 to jdm h22 engine swap on 94 prelude
  69. B16a into 88-91 crx ??????
  70. Need help!
  71. An Automatic!!!! Article
  72. Preparing for winter
  73. H22a Engine problem?
  74. Suicide doors?
  75. Are the G-Tech/ Apexi Rev/ Speed Meter GP any good?
  76. where can I find templates for GMC savana
  77. radiator help
  78. Clutch Masters Stage 3
  79. how do you do a hydro conversion?
  80. 351 Cleveland, am I screwed??
  81. Spoilers
  82. Torque How 2 Question...
  83. Real Mugen Shift Boot?
  84. rechargable batteries?
  85. Best Tranny for 1st Gen B16a.
  86. gauge cluster question
  87. alero engine swap to v6
  88. How diesel engines are switched off?
  89. Replacing clock backlight...
  90. dx or hf? how to tell
  91. does backpressure affect top speed?
  92. ABS Diagnosis
  93. V-tec heads?
  94. sparco tach install
  95. PLEASE HELP!! Need ecu pin diagram 92 integra ls
  96. Best head for B16A2 motor?
  97. Timing Belt, Water Pump?
  98. s2000 engine into a civic
  99. SR20DET swap in a civic...
  100. good B16A2 (99-00si) motor setup
  101. Pajero 3.5l timing problem
  102. parts for b18c
  103. Common sense
  104. Removing Alternator -- HOW TO?!
  105. H22A-R motor in a Honda CRX
  106. Where to purchase a H22A-R motor????
  107. H22a
  108. most power out of a d16y7 motor? ***READ***
  109. What engine for a 93 Prelude
  110. Help driving a Manual?
  111. Some Questions I Have, please answer if possible.
  112. where to get an LS motor???
  113. Blow off Valve??
  114. which msd box
  115. Jdm Zc Tuning And Timing "help"
  116. Suspension Break-In?
  117. 89 accord dx clutch shifting sound
  118. Is it possible to make a 11 sec street legal Honda Civic???
  119. cost of rebuild?
  120. Please help on Vacuum hoses for b16a in crx dx!!!!!!!
  121. CD Player
  122. 91 Prelude ECU code
  123. Are gasoline engines limited to spark igntion?
  124. 97 Integra Type R owners...READ
  125. Why can't clutches be placed between the transmission and the differential?
  126. Heater on really help?
  127. Manual Ecu for Automatic? Will it work?
  128. S2000 starter switch, please help
  129. possible swaps in 85 crx dx?(carbed)
  130. what does "port & polish head" mean?
  131. Maintance Light (Civic)
  132. sunbird stalls HELP
  133. maint. reqd. light in 97 gsr
  134. Rattling noise after header/cat install
  135. tons of white smoke, help!!
  136. Tranny Problems...
  137. SOHC VTEC head
  138. slight backfire sound
  139. Idleing problem
  140. anyone know hp?
  141. Shifting sound
  142. springs and cambers
  143. Accord Euro R Final gear
  144. i found a .30 ci wankel rotary engine!
  145. building an engine
  146. tracking down f22 jdm and usdm
  147. What engine for a 96 Integra?
  148. engine problem, please help
  149. H22 or B18c in 92 hatch
  150. Have You Seen A Bad Pressure Plate
  151. vaccum lines
  152. Left side vs right side dirve swap ?????
  153. b16a on a 97 civic
  154. Yes another 'My brilliant idea'
  155. Low idle problem?
  156. Need some help from you techies
  157. best motor swap for a 1996 civic dx
  158. best motor swap for a 96 Civic DX
  159. Core supports on 96-98
  160. Wierd Problem
  161. valve covers for a sohc non vtec motor
  162. b18c3 in a 96 civic?
  163. Headlight Aim
  164. Turbo timer...
  165. Catalytic Converter SOLUTION!!!!
  166. Buying CRX...NEED INFO!!
  167. Damn those s.o.b's at Speedee
  168. EG-6 ecu code light location
  169. How do ya get a 1.75 rod/stroke ratio in a crvtec?
  170. F20C1 head swap on K20A2 block
  171. Need help with some electrical questions.
  172. I just had a brilliant idea. Time to shoot me down!
  173. best motor in 6th gen civic coupe
  174. H22a in civic hatch
  175. Claimed wieght
  176. Dual Exhaust on Civic
  177. a few quick questions on turbochargers and how to fix lag
  178. Fast & Furious shifting
  179. ripped off
  180. b16 with automatic transmissions
  181. super charging an olds. cutlass supreme
  182. Diagnostic testing
  183. need help ASAP... how to get the hub nut off
  184. Brake light help needed!
  185. Rear drive conversion
  186. zc block questions
  187. I need a zc motor
  188. Need help increasing displacement!!!!
  189. SRS Light
  190. lets build the ultimate street racing car...
  191. 92 chevy cavalier - backup lights
  192. D16z6 Motors
  193. LS/Vtec
  194. LS/Vtec
  195. Help please with friends 97 Accord LX & aftermarket ignition system
  196. increasing catback piping
  197. Trouble filling gas tank - backpressure
  198. tire size ?
  199. F22 engine efficiency
  200. Question about civic ex's vtec 96+
  201. Intercooler questions (kind of long)
  202. jdm engine serial numbers
  203. Engine/Drivetrain in Custom Built Car
  204. D16Z6 Question?
  205. HELP!! Check engine light. Pulled code 41
  206. JDM in the United States
  207. V-Afc questions
  208. H2O pump ?
  209. premium fuel
  210. tack install
  211. Vtec\Shift light
  212. Ranger Oil Pressure
  213. Got my JDM B20A for my 91 Prelude!!!
  214. please help clutch is clicking
  215. Remote oil filter systems
  216. Civic H22a clutch question
  217. Civic H22a clutch question
  218. Timing belt question. . . help!
  219. whats the fastest stock Honda/Acura sans the s2k
  220. B16 ECU to D16Y8
  221. Any Honda Techs In The House?
  222. Why do rings go bad???
  223. LS in a 98 civic LX (need info)
  224. Final Plans (B18C5 motor) questions first
  225. AWD Civic
  226. Best Cold Air Intake?
  227. oxygen sensor
  228. Turbo
  229. K20A Engine
  230. Can coolant/oil channels be machined into a block or must they be cast along with it?
  231. check engine light
  232. Radio looses station/date memory
  233. clutch noise
  234. i need help
  235. B18b, B18a
  236. motor mounts
  237. Civic h22a swap question
  238. b18c5 for 94 del sol
  239. Car won't start: Troubleshoot
  240. Car Won't Start: Troubleshoot
  241. T5 gearbox to cologne 4.0 V6
  242. is it possible for a b20/gsr frankenstein?
  243. jdm motor & parts infor/chat
  244. 92 civic CX swap to a h22a??
  245. Motor swap
  246. Racing chips???
  247. H22A Pricing
  248. engine swap
  249. Best motor in 5th gen. civic
  250. Synthetic oil
