View Full Version : Engineering/Technical
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45
  1. who knows the specs on the JDM Honda/Acura Vigor ??
  2. timing belt
  3. Downshift in Automatic?
  4. Is This It?
  5. Eagle or Crower Rods for High Boost from Turbo
  6. D16A8/9 or ZC
  7. Catalytic Converter Fit Issues after engine swap
  8. robo shifters worth a damn?
  9. Theories on this?
  10. Which motor mounts should I use?
  11. prelude swaps
  12. paint spotting
  13. lowend torque on a/t
  14. pistons, cam, valve springs ect..
  15. integra jdm tranny...need help
  16. Differences In B16 Heads?
  17. I Need Help
  18. Help me please!!!!
  19. 5g Civic b16a Axles?
  20. 2nd gen integra tranny swap
  21. CIVIC H22A Engine transplant
  22. crank angle sensor for 1992 Civic
  23. off the line
  24. Help! weird buzz when acclering
  25. B18B or B18A
  26. ractive strut bar?
  27. Injectors
  28. Stand Alone Ignition System
  29. coil for 1993 prelude
  30. 3.2 TL Starting Problem
  31. 89 Integra...few problems
  32. Exhaust Noises??
  33. The rear drivign lights are not working...
  34. How to Install OEM ITR intake manifold onto B16CRX???
  35. civic 97 hx swap questions
  36. Installing Gen 2 Yangson Design Tail lights
  37. Nos
  38. FlashOptions.com?
  39. my brakelights just stopped working
  40. Brake job on a 97 Hyundai Accent
  41. need help with my B16A
  42. Honda Parts in Germany
  43. clicking noise
  44. IDIOT needs help installing first autometer gauge, hurry b4 i electrocute myself
  45. My Car won't start...
  46. Vehicle Brake Information (very long)
  47. B18C1 into a 94 civic si
  48. b18 turbocharged?
  49. ratchet/automatic shifters
  50. torkstep headers
  51. It's Dead !!!
  52. What kinda of mufflers are on the three honda civics in the fast and the furiou
  53. Power Steering Probs
  54. Effect of Snow/Salt...
  55. engine note
  56. Advan Decals For Sale
  57. info on parts...need help.
  58. is AC bad for the engine?
  59. Bomz High Flow CAT
  60. what's the diff btw b18b ls and rs???
  61. Destroked H22
  62. idle problem
  63. Ignition!?
  64. Blown Head Gasket
  65. Automatic to Manual
  66. JDM DC5 Integra Type R SRS Steering Wheel
  67. engine swamp on a junker
  68. Could anyone info me some stuff about cars?
  69. will switching oil types harm?
  70. b18c engine into a 95 Civic CX easily
  71. Help! brake lights on
  72. transmission and clutch install/do's dont's
  73. Ceramic or Stainless Steel??
  74. Perfect spark plug?
  75. Integra front end on civic
  76. b16a torque specs
  77. HELP B16A Engine Problem!!!!!!!!!!!
  78. HELP B16A Engine Problem!!!!!
  79. new alternator
  80. Do I need rear new trailing arms for 5 lug conversion in a 97 Civic?
  81. tranny rebuild
  82. shifter bushings
  83. looking 4 a jdm brown top zc
  84. osakajdmmoters.com?
  85. longblock/shortblock????
  86. looking for a SiR2 engine
  87. muffler
  88. Looking for some 240 info ...
  89. the real problem
  90. oil changes
  91. Pectel T2 ECU pinout
  92. some JDM questions for ya
  93. fuel pump relay problem??
  94. A Newbie's question about the B20 swap
  95. what are blocks and heads?
  96. what are blocks and heads?
  97. HP Racing headers?
  98. Pedals for heel-toe downshifting?
  99. b18c comparison
  100. b18ci swap questions
  101. h22 swap
  102. No start condition 91 civic
  103. crank pulley help
  104. Racing Help!!!
  105. dum-dee-dum-dumm-dummm Q's
  106. Jdm engines wholesaler and distributor www.flashoptions.com *BONUS**
  107. Tranny Help
  108. FS: Skunk 2 Cams (B-Series)
  109. auto tranny to manual tranny
  110. exhaust system; '91 318i
  111. translate into liters?
  112. Engine Help?
  113. more help with a tach retrofit
  114. Which shop do you use?
  115. installing a bodykit
  116. bad a$$ civic 1200 for sale
  117. bad a$$ civic 1200 for sale
  118. flooding an FI car?
  119. 91-92 integra b18 question
  120. Power Steering....Keep it??
  121. Mileage
  122. B16A Headers
  123. B16A Oil Question
  124. Mugen LA-EP3 Civic
  125. 2k2 civic - engine bay problems?
  126. sae on oil lable
  127. high flow cats
  128. any 4th gen accords w/ adjustable cam??
  129. honda engine swap
  130. b16a vs. h22a
  131. new injectors and header...
  132. Exhaust System
  133. Timing belt
  134. Exhaust System Back-Pressure
  135. Any good Install Guide websites?
  136. Engine Knock
  137. Drop in a Small Block Chevy?
  138. Stamping Aluminum Body Panels?
  139. Better Header?
  140. Wanted! b18b LS Motor
  141. nickel hydrogen battery
  142. In the need of ECU
  143. Mendral vs. Crushed exhaust piping! Difference that big?
  144. Wiper Blades
  145. civic 1200 or city turbo
  146. fuel pump 1990 Accord
  147. Side Door..Meet A Pillar
  148. JDM parts
  149. A 92-95 Civic D15b7 engine....D16z6 parts?
  150. 92-95 Civic D15b7 engine....D16z6 parts?
  151. Best engine swap for a 94 accord Lx ?
  152. OBD II Accord distributor codes for H22 swap
  153. Tough VSS Question about Compatability
  154. On the back of a block
  155. Tell me what you think
  156. What happened to jdmcivic.com?
  157. Igniton Troubles
  158. H22 swap distributor issue...NEED HELP NOW!!!!!
  159. H22 swap distributor problem...NEED HELP NOW!!!!!
  160. The PERFECT compression ratio?
  161. Engine problem. Help please
  162. 194/168 bulbs into 2040 sockets
  163. type s and type sh...
  164. Oil question(s)...
  165. *TWIN-PLATE Clutch Questions, HELP!!!
  166. b16a1 question
  167. lowend torque with a/t's
  168. B18 Ls
  169. b18b in 4th gen dx no fire!!
  170. 96 Subaru Legacy stalls
  171. Rear Disc Conversion
  172. does the year have any 'bearing' on the type of bearings
  173. friend in distress...
  174. Painting your brake Calipers, a How-To
  175. Where to go from here? B16A
  176. Tornado?
  177. sensor question
  178. 9004 to H4
  179. B18d?
  180. need to know
  181. gear grinding
  182. performance chip for 98 Civic??
  183. 2002 Civics
  184. Port and Polish - whats wrong here?!?
  185. best engine managment computer
  186. h22a or h22a1 need help
  187. automatic...
  188. Recommendations on engine rebuild--D16A6
  189. !!** HELP ... creating a Driving Simulator with Toyota Matrix **!!
  190. Port&Polish Intake Man&Throttle Body?
  191. Ex head, DX motor
  192. b16a supercharger(compression?)
  193. 1990 hyndai excel loses all power
  194. help Legend 95 Abs sensor
  195. individual throttle bodies
  196. H22A motor swap in a 89 Accord DX Coupe
  197. fuel injection swap?
  198. Anyone live in PA.
  199. need CTR vin#
  200. pure O2 injection?
  201. JDM H23A specs?
  202. best engine to go all motor
  203. more b16a O2 questions
  204. Auto to manual tranny possible?
  205. help with sohc vtec swap into 96 dx
  206. Is the bypass worth the trouble?
  207. Dyno Days Oct 26th @ AAM
  208. automatic
  209. 91 b18 integra
  210. anybody with 90integra/B16a
  211. I need some help on a vtec search
  212. 88 CRX si swap
  213. what type of HEADER to use??
  214. Advan Decals
  215. Is there anyone that sale Engines in MD,DC,VA?
  216. JDM B16A water pump
  217. test
  218. B16a V.s. B16b
  219. Putting the "turbo" back in turbodiesel
  220. Hp??
  221. need help ,two or one O2 sensors
  222. To: CraigFL
  223. OBD-II information
  224. 00 si b16a2 into a 98 honda civic dx wiring probl
  225. Shock Absorber Experiences Please
  226. engine washed, now i got issues. lol
  227. engine washed, now i got issues. lol
  228. engine help
  229. Ff Squad, Where'd They Go?
  230. Anyone Know What 0bd1 0bd2 And Non Obd
  231. Question about Intake Manifold
  232. Newbie Questions: Whats JDM????????
  233. JDM SIR fog lights?????
  234. about vtec
  235. 2000 Civic EX Swap help
  236. what to swap in 90 prelude
  237. Bare B16 block..need ideas..
  238. Immobilisers
  239. Air Conditioner
  240. looking for parts
  241. CRX: B16a For Sale
  242. Which tranny do I have?
  243. Odometer problem on my '99 Cavalier
  244. Skunk2 Intake Manifold - Need an install guide
  245. 96 oem tail lights
  246. Wobbly crank pulley
  247. Buick Park Ave Wiring problem
  248. dull noise coming from engine....
  249. Clutch Situtation
  250. B18b Ls Motor
