Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
> Engineering/Technical |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
h22 or h23?
Chikara Header NEED HELP
help please!!!! brake lights
Mini Me Questions
Idle problem with B16a2
buick tech help
B16A or ZC D16A8/A9
what's jdm anyway?
tranny swap
how does a wrx motor wrk?
PIAA H3C Light bulbs
Questions About NOS
B18B1 bottom end build
gsr girdle
why the hell'd you put a b16 into a GSR? dynos of B16a1 and B17a1 please
need info
Ditto Thread
power lose over using the f22 trans over h22 trans?
throttle troubles, HELP!!
how do you do lambo style doors
Front end Conversion
94 civic-94 integra front end swap
Cross drilled rotors, better or not?
Hemis
Anybody swap a 96'or newer engine into a 4th gen. civic dx
LSD questions
civic std model same as hf crx model?
B16a2 error codes.
injector resister box location?
header
Available: Engine Swaps
How much power will a b18c1 have with an non-vtec block???
car dies at full stop...please help! 00civic EX AT
276 and 350 GM starters
P0401 (EGR Flow Insufficient)
Ned hep with putting a d16a7 out of a 96 into my 89?'
Anyone know how to
Dc Sports
honda civic 92
fuel pressure 88 hatch
Swapping and need trans.
Car isn't running very well
Field's SFC-VTEC and Apexi V-AFC
Y1 transmission
mugen vs. greddy
Cams or Cam Gears
FS: CRX Si B16a $2,500
Thermal Research vs. APEXi catbacks
woody wood pecker?
Anti-lag (misfiring) systems...
All My Questions About Cars(Please Help Me)
turbo parts
Engine swap
stock civic motors
parts for sell.......
92+ civic z3 metal fenders brand new $140 shipped
help need stuff 4 f20
test pipe
b16a from ebay?
V-AFC problems
No such thing as forged steel engine blocks?
OBD0 into OBDI
vtec performance bar
please help me diagnose a problem
The loudest 14inch long muffler out Their.
It's going to drive me to insanity...
Help
blown plug
heater core clogging
:p
Nowhere To Turn
For all you honda motor buffs------->
MSD Ignition....???
Which Helm Manual?
rotor upgrades.
Replacing the starter
lose plug
Auto Jobs-stunt driving..on and on
88 hatch question
Panthom grip
how to remove struts
Car revs by itself
what parts can i swap to a non vtec f22
Question for the mechanics out there..
Parts
B16 head on a d16 block?
fuel filter bolt stuck
jdm si hatchback spoiler?
Experience with Gude?
Cai
Spaceframe versus monocoque
Propane gas.
kit car using accord 1990-1996
helping out an old motor....
b20b into 97 civic coupe
Throttle Adjustment
Why not more than 2 turbos?
H22a or us H22?
5Zigen exhaust???
Help!!!! I Need My Integra To Go Faster!!!
strut bars?
Share your experience
New Voltage Regulator
Exporting problems
License plate light wiring???
The "Rotten Egg" Smell.
what goes with mugen lip?
F20B in 4th gen accord
V-TECing a LS...!...?
strut bar
What is torque?
Any 2nd Gen CRX or 4th gen Civic with a B16a swap!
2002 Civic Help
what does vvti stand for?
building a D16Z6
Emergency Engine Swap Need Help!!!!!
what engine will fit this tranny
Misc Problems with 95 Civic EX
mugen or spoon racing chips???
PR3 sub-harness
My Frankenstein
JDM Type R B18c w/ 94 GSR Head
60k service on 98 civic lx
Hybrid Accord Questions...
What exhaust should I get???
ECU location?
burning up distributors HELP!!!!
Helms Service Manual
Interesting battery problem...
Civic Type R?
changed Spark plugs and i found Oil...
JET performance chip?
Interga Type-r Conversion On A 99 Civic!?!?!?!?!?
Crower Stage 4 Head Package
Acura Gold Plated Emblem Kit
engine stulmbles
Jdm Odyssey In Uk
Axles
Intake Manifold
Slight engine vibration just before changing gears.
silicone grease on plug wires?
Zex vs. Gude vs. Crower Cams
Totalled :*(
Breather valves??
B16a
hydraulic pump
Rock Chips Repair... Langka! anyone try this stuff?
High Tension Wires Help
Best Way to Add hp...?
Important Question
JDM Transmissions
quick Civic Type R cams question
tips for my 93 Accord
red "H"
Engine Troubles
transmission conversion?
ecu removal
JDM 88-91 Civic SiR Cluster For Sale
Open and Heat Shielded Air Filter--What's the Difference?
Camshafts
d16y8 into 96 dx
weird vibration that varies with speed and steering?
weird vibration that changes with speed and turns..?
why is my ACT HDSS clutch slipping?
Dodge Caravan Transmission
Engine/tranny Question
Can't decide what new car to get.
Vibration Question (2000 Maxima 5spd)
Need Help !!!
type r cams
Airbag expulsion location
Fuel pressure question...
non-vtec to vtec
PIAA Plasma Light Bulbs any good?
Door mirrors.
Passing Inspections
What mufflers would you perfere?
Exhaust
Cat. conv. problem
Knocking sound on slow turns on my 2003 Acura EL
H22A swap sensor problems
What Happened!?!
Merry Christmas!!
apexi or fields vtec controller setting
93 Civic HB Swap
Engine/Tranny Question...
TornadoFuelSaver
Need motor swap + F/I
run 12's
CRVTEC or simple B18C1
bunch of stuff
b16a sir1 auto tranny?
Muffler is too loud!
What to do to engine before swapping in
94 GSR with 96+ Spec R B18C Wiring Harness work?
B16A Header
Thrush Turbo Mufflers??
My Integra ran over a puddle and now my engine has knocking noises!!
Amsoil?
New Ecu??
Mini me conversion
How to ground wires
Help me Buy a new car
motorswap for 95 civic coupe
JDM D-series
non OBD injector question?
93 sol, what to watch for
Nsx
Hardcore JDM Lovers only!
cam gears & Pulleys??
is it bad to drive with the E brake?
Header or Pulleys?
Black smoke with downshift
R-1 Racing Performance head
Auto Paints
Coilovers Vs Lowering Springs
help with throttle body
How to change brakes on a CRX`
Need Help
Need Advice
New Plugs?
need to get check engine code
Integra or Prelude
Anyone see a crx with power steering???
Honda's VTEC.
goveners
weird engine noise
Engine suddenly turn it off when i came to a stop sign???!~
simple break light question, eh
Loudest Exhaust!!!
The Fast and the Furious Eclipse
2001 tahoe
Civic Type R cams or not?
Engine year??
B16 distributor
funny idling
Timing belt repair
redline
1996 JDM H22 authenticity
ZC or not?????
What Is The Loudest Muffler Out There?
93 Civic HB Motor Swap
Oil film longetivity on cylinder walls
91 SSE Climate Control Problem
B16a2 or B18C
The Importance of automobiles survey.
help!!
Web
AF
