View Full Version : Engineering/Technical
  1. 1968 Mustang 302 Engine Problem
  2. need advice please...
  3. need advice and information
  4. Transmission issues
  5. the breath of life!!!!
  6. What Next?
  7. Chevy Colorado starting problems
  8. You guys prolly have all this...
  9. 2001 Hyundai Elantra Shaking when starting
  10. Will not idle
  11. racing with a automatic?
  12. HELP fix up S10 or buy car?
  13. what exactly is done?
  14. fast turn signals
  15. Getting off the line?
  16. gear ratio
  17. Transmission Flush or Pan Drop
  18. Need to know if i got ripped on B16 head?
  19. did my friends ls motor SIEZE??? HELP!!!
  20. Rear Clicking
  21. Revolutionary Idea!
  22. [TEXAS] Anybody want the personalized plate "ENVY"
  23. How far can I drive in one week? 5600 miles?
  24. speed sensor
  25. indentifying an ecu
  26. Ignition module MSD 6AL - Electronic Schematics
  27. car Jerks or jumps after complete stop
  28. downforce? please read
  29. ENGINE or BATTERY?
  30. i need a spoiler
  31. Where to start on engine rebuild
  32. Difference between high strength alloy and titanium?
  33. Power Pulley Poll
  34. Will this Fit onto my car
  35. 5spd change
  36. PG6B Pistons! What else??
  37. 91 C1500 Part #
  38. Finally got my Lude running but need help
  39. comparing cams
  40. checking fuel injectors
  41. i heard something about 2nd cam mod
  42. rebuilding a car
  43. small blocks and big blocks?
  44. 4x4 ride is horrible
  45. 4x4 ride is horrible
  46. Monster Motor Problem, Need Help Immediately!!! Please.
  47. EGR Valve
  48. GTO vs. Trans Am
  49. Are AMCs good buys.
  50. turnsignals & reverse lights won't work
  51. Buick Riviera floors
  52. crane cams ignition trouble
  53. Best CURRENT muscle cars.
  54. 1966 chevelle 300 deluxe
  55. 94 olds 88 cooling system problem.
  56. Aftermarket intake manifold vs. Ported intake manifold
  57. 425 cid wont stay in time
  58. would it be possible
  59. What kind of car do I have?
  60. intake question
  61. Guy put wrong gas in my car.
  62. 440HP from a 350?
  63. 68/69 RS/SS price
  64. (ABS) light on Silverado 1997
  65. California SMOG Law Vote. URGENT!
  66. Need advice on conversion
  67. cams and rockers
  68. Valve cover bolt
  69. Fuel Pump?
  70. p30 ecu
  71. coil on hei distributor
  72. New engine
  73. Help!!!!!
  74. front struts
  75. need 72 cutlass parts
  76. need id help 65 impala ss conv
  77. Did I fry my starter?!!
  78. right hand drive conversion
  79. Converting Ur OBD Setup
  80. Got torque?
  81. Help please... Car dies when idling
  82. WOW wut happened to my car???
  83. engine timing
  84. spark plug
  85. Building A Muscle Car Help Me
  86. 1967 Chevelle 396 SS Original Colors
  87. How to install your own ZR3 Laser Shifter
  88. 1967 MUSTANG Bench Seat in a 66?
  89. just an idea.....
  90. What car does this go to?
  91. 04' Tahoe luggage rack parts needed.
  92. Old Olds...
  93. 1969 z28 help
  94. Installing a keyless entry...
  95. Best engine?...
  96. Toyota Highlander VS. Lincoln Navigator
  97. 65 gto as a first car?
  98. I want more power from my 425
  99. Novas get a bad rap?
  100. avid vs. hasport
  101. Radiator Leak?
  102. Idle prob
  103. wire harness
  104. 70 Super Bee
  105. g-sport
  106. First Car
  107. manual vs automatic
  108. head gasket question
  109. Rebuilt Engine Sellers
  110. Smell coming from engine
  111. ever heard of this car??????????
  112. Stereo not working..
  113. convert auto trans to manual imposibel?
  114. Power Shifting
  115. camoro or firebird
  116. Holley carb fills up #8 cyl
  117. Looking for other Beaumont owners
  118. Racing? :)
  119. Recommendations - Rear Diff for IRS
  120. nothing special
  121. FAILED Emissions Test...
  122. camshaft change
  123. I need an opinion about my 360 amc
  124. all motor, turbo
  125. im trying to recharge my air condition
  126. im trying to recharge my air condition
  127. stroke or not?
  128. first time resto
  129. Misfiring In 1 And 6 / Brown Dex-Cool
  130. Wat is VTEC???
  131. replacing window tint
  132. Small light fuse keeps blowing
  133. dual AFM for twin intake manifolds
  134. My Wrx Nightmare
  135. Looking for.....
  136. 69 Buick Rivera
  137. sohc or dohc
  138. Need help with color paint(code)
  139. parts for '66 GTO
  140. Could use some pointers on a rebuild
  141. What're the differences between these?
  142. viper 2 way pager alarms
  143. reversing the digital clock display
  144. Serpentine conversion - BBC
  145. Where IS the best place to buy a JDM H22?
  146. I'm lost who makes Novas?I have one waiting for me in PR.
  147. ecu
  148. Bolt Patterns
  149. Pinging or Timing Chain Rattling under Heavy Acceleration, Please help me..
  150. Radio Antenna
  151. Need help with paint color (code)
  152. clutch problems
  153. LSD busted
  154. orifice tube
  155. serpentine conversion SBC
  156. swap information
  157. synthetic fluids
  158. Wire Resistance too High?
  159. Higher Compression
  160. Toggle Switches for DRL's and licenses plate light?
  161. distributer bearing
  162. 92 Sonoma engine swap
  163. Using A/C.. Does this Harm the Car?? please respond
  164. Sound problem, what could it be?
  165. engine blowing up question
  166. clutch
  167. Aug 21 Car Show
  168. new engine for my beat up car... I need help
  169. cam seal
  170. Need help locating part! '67 R/T
  171. How to tell if a water pump is bad
  172. Painting engine
  173. Toggle Switch Bar
  174. whats the different between cold air intake and short ram intake?
  175. what to do?????
  176. Won't start
  177. Serpentine Converson
  178. Origin of suicide doors nickname.
  179. engine mounts
  180. truck beats car... WTF
  181. Spiral Max
  182. Building a real-life Jurassic Park Explorer
  183. Ac Question
  184. shifting help
  185. steering/ suspension acting strange
  186. water temp gauge
  187. 70s CHEVY 350 CARBON FOULING PLUGS
  188. Aluminum AMC engine.
  189. How to Bleed Brakes?
  190. starting problem :( PLEASE HELP
  191. 1970 GS455 Slick Tire Size
  192. noisy transmission
  193. need advice????????
  194. need advice??????
  195. My Truck. (Lifting) any suggestions?
  196. removing crank pulley
  197. 1987 Chevrolet Astro Van A/C Compressor
  198. A/c Enhancement
  199. Runnin Wrong
  200. shifting an automatic?
  201. What is JDM?
  202. can you please give me a spec list of a car?...?
  203. S10 Manual Or Help
  204. Help W Fan Removal
  205. need help jdm swap
  206. parts site
  207. check engine only when towing
  208. Air Condition sucks
  209. Texas Street Racers..
  210. bes muscle car ever
  211. quick question about engines
  212. motor oil companies
  213. Muscle car?
  214. engine knockin
  215. Fairlane
  216. Shift Lever Diameters?
  217. Installing a Radiator
  218. I dont get headers...
  219. Hey a '66 GTO and 04 GTO styling vs. '66 GP and 04 GP styling.
  220. Wiring an electric brake controller 97 chevy
  221. Guage Question
  222. fully built Ls
  223. A/F Gauge Hookup
  224. Half-axle question
  225. who would win?
  226. A few things..
  227. '69 Firebird fuel injection
  228. install a momo steering wheel
  229. header wrap
  230. 63 Ford Fairlane 500 Sports coupe!
  231. 70 Pontiac GTO 455 HO 69k orig.miles!
  232. Need help with a 1970 grand prix
  233. Hot Rod Power Tour
  234. 69 Buick Rivera
  235. Suspension System
  236. Chevy Spectrum Brake lights QUESTION???
  237. JET ecm upgrade after IHE
  238. Can somebody do me a favor?
  239. Intake Manifolds
  240. ECU upgrades?
  241. Auto to manual Complete list of parts
  242. quick newb question
  243. Need Engine Schematics
  244. See if you can solve my problem.
  245. Which is the better spark Plug?
  246. HELP on exhaust/compression stroke!
  247. fuel pump eccentric (69 GTO)
  248. S-10 Problem NEED HELP PLEASE
  249. good carb for 1923 T-Bucket
  250. starting problems. Need help
