Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
> Engineering/Technical |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
H22s cheaper in canada?
Plasma Booster??
h23 specs
vtec wiring HELP! Couple Q's and Pics!
temp sending unit?
Climate Control
Chassis DYNO shops in So. Cal.
need car buying stories
18'wheels
synthetic oil
Nopi...
How do you adjust t.p.s
twin scroll turbo...
vtec
just a girl, please help
No Thanks...4 Stroke For Me Please!
speedo is out!!!
dumb lights
difference in exhaust
a20->b18 head swap???
screwed up electrical parts bad help
94 Accord JDM Bumper lens
Shaved doors...
hmm...
Alternator doesnt work right in rain, WHYYYY!!! PLZ Help
97 olds aurora
89 integra
Valve Specs
4 Pt Safety Belt vs. Standard
Looking For A B16a1
Speedometer is stuck at 40
Question on Intakes
I Have Motor Questions!!!
B20 vs B18c5
PLEASE HELP P1457 emission code
Anyone ever seen this????
Snorkel Hood scoop and Ram Air.
mini me question
Major Newb: Exhausts
d16z6 od d16y8 head???
Valves suck
right hand drive conversion
Wiring the Eg / GSR up! Pics inside! Help needed! *56k might get 0wn3d*
2.3cl swap for h22a
I need some major help..
Need second opinion for next mod
95 B16a in a 96 Civic Coupe?
How to....
cam shaft and cam gears in b16a
Exhaust Headers
oil question?
H22 in an 88-91 CRX
fuel cut-off at 3500 on new ZC motor!!! Anyone know why ??
B20 with GSR head: Valve clearance problems
Day 3 working on the Eg / GSR swap **56k stand back about 8 miles**
power for my baby
87 non si swap
prelude throttle body
Piston to Valve clearance and CR questions.
99 B18C5 into 94 Civic EX
Csrv
Such thing as a 92-96 H22 Type-S???
my ZC fuel cutoff is 3500, HELP
Timing advance on a '96 Accord LX
Internals
hesitation
Maybe the first new idea since nitrous...then again, maybe stupid
stupid power steering question
how to remove 96-98 civic dash?
h22 in a civic hatch
What Car?
dohc valve cover
engine parts????
electrical stuff
Should I go full synthetic?
Motor Problem
98civic RearSection Exhaust bolt-on
gsr into my crx?
What is the best synthetic blend oil?
7th gen hondas
h22a w/parts
Seatbelts?
tough question...
vtec not working
ARP head bolts?
91' prelude si
A little B16 Buildup
Honda Prelude help....please
rotary
Y-Pipe in Escort
lookin at new engine for 2G lude and need some help
Freeing stuck fuel sender float
Steering wheel install
e-brake handle
z6 spark plug tube
preachers daughters 318i is in big trouble
differentials
Auto Theft
Is my Y1 trans LSD?
check engine light
ls nonvtec into lsvtec
What's the difference between the 4cyl engines in the Accord?
wut u guys think about droppin a b18c1 ina 94' civic hb?
what to get
Trip-clutch and double clutch...what are they?
High flow cat and engine light
f22b install costs
electronic Load Detector Help
wtb total zc swap
O2 sensor gone bad?
header question
b16 block?
head install ?
need good shop in central jersey area!!!
shift linkage question
just got my car ..........................now what?
help i need somebody
d series into a drag car?
Pistons/Rods for a B20VTEC
Valve Lash?
Best way to clean corrosion off brake system? Pics of my nasty brakes inside!
95 engine into 91
Anything to consider with a 94 GSR tranny on a B20
What's the max compression you should run on 91 gas
B20/VTEC: What accessories to use
96 Civic?!?!?
OBD Who?
B18C1 motor buildup
Completed H22 Swap: Shiftlinkage/Syncros Problem...
dust from vent
Questions about my swap
2003 Civic DX/HX H22 Swap?
Short Shifter
Unichip
igition system and hi flow cat
Help me with my kart!
B16a
98 civic EX/DX PLeasehelp
DOHC ZC Head questions!
motor mount - torque mount?????
what the hell wire is this - need quick answer
Question about what I should buy.
Firebird Engine Swap
Speed Density to MAF
Superchargers
how about an h22a? what will that do to my civics handling?
Easy question, just need the "slang" name
nitrous on a d16y8
Engine Shudder
Estimate cost to fix motormount on 2000 v6 accord
Psi?
b20/vtec hybrid questions
LED Washer Help ???
Wiring for a B20 VTEC in a 94 GSR
Isuzu heater
Sponsorship
Strange grinding noise in 1st gear...
Changing Timing Belt, d16y8
Help Wrong Fuel!
Direct Shifting Gearbox!
I need a Quality Shop in MD,DC or VA HELP
Engine Swapping Questions
OBD2 adpater?
Cam Timing Differences with D18Z6/Y8
tranny's clicking??
cam timing?
Stumped - Finished Swap - Car Won't Start
Mugen Intake
Is an MSD ignition worth it?
2 problems...both with headlights on '98 civic
Popping noise under harsh acceleration
hydro power??
rattling sound from headers
D16z6 HELP!!!
Auto 2 Manual Conversion
Car fluids
TPS and nitrous
Double wishbone suspension
vafc install
jdm intefra
Help! Please????
what do i need
SOHC to DOHC conversion?
BOV & Wastegate position (2JZ)
what car to choose?
Sell your vehicle for FREE?? Is it true?
'88 teg in trouble
Lurching engine when slowing down
Are Nology Wires really worth the $150?
please dont flame!
Help
little water problem...
Tyre pressure effect on balance
Can I use this OBD2 catalytic converter in my Eg hatch?
Optimum Super Car Setup
Dish Volume q's?
Electrical Gremlins HELP!!!
Clean Brakes
Alternative Fuels
Whats it mean when you're driving on Broken CV joints?
gsr distributor
Swap arrived with bag of bolts and stuff...... 56k grab a pillow!
Brake Tru
89 accord gauge install
ZC head on a D16z block
what to do?
wiper question
swap question
Best Cat Converter?
91 Accord Swap
Pretty Loud!!!
What would be louder/est...?
year?
b16a1 in a 91 civic hb PLEASE HELP IF YOU CAN!!!!!!!!!
Best place to get Skunk2 stuff
how to install 3 piece mid spoiler for civic hb
Good eyes...
How do I get ahold of one of these?!!!
Overheating Problems b16a CRX
Louder Muffler!!!
Header Transfer?
Can anyone help me out......Or know a good shop?
PhatNLow JDM imports - anyone ever buy anything from them??
H22a Type-S - Change cam gears + pulley kit??
code23?
Question about Engineering Degree's
Camshafts
Help!! H22a or H22a Type-S worth it?
B16a2 drive axles
aftermarket support for B16b (U.S.)
d15 firing order
I Need Help
90 prelude swap ??
radar detectors
Anyone wanna help me out with the wiring
how much will it cost to swap an integra type r engine in a 95 gsr
Anyone else had problems with an engine from Street Imports?
Supercharger
how to tell if I have an LSD trans
LOTSA problems :(
Eating/drinking and excrement timing for motor racing
Ovals-clockwise or anticlockwise?
Painting and Clearing Head Lights Made easy
h22 to 6G civic swap help
Big time confused :(
WyoTech?
Proper way to bed in brake pads and rotors
CTR cams
Web
AF
