View Full Version : Engineering/Technical
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 41 42 43 44 45
  1. AEM V2 Intake
  2. VAFC or SVAFC???
  3. Everything Flickering
  4. Does anyone know actual engine weights?
  5. F/S JDM FIELD SFCVTEC controller
  6. Complete list of swap parts
  7. Serious help needed on Toyota Camry
  8. Spoon info
  9. rev limitor at 4 1/2?
  10. 2001 Accord brake pads last 3000 miles???
  11. H22 in a 96 HB?
  12. Question About Diesel Engines + Emissions.
  13. Changing to synthetic oil
  14. changing a muffler
  15. droping weight
  16. Help!!!
  17. RPM Gage
  18. sidemarker placement (EK)
  19. Where can I buy....
  20. Torqe Wrench Use?
  21. b16 into a 98 civic
  22. supercharging an h22
  23. Have an odd electrical question
  24. 4 bolt pattern....?
  25. 92-95 civic steering going out?
  26. JDM / UK Shop Manuals
  27. ECU in B16a?
  28. KYB AGX Gas Shocks for Civic
  29. Wiring for swap question
  30. h23 into my 88 htch dx???
  31. ZC into 91 civic LX
  32. Fuel
  33. Exhaust & Air Intake
  34. Building a racing automatic tranny
  35. axle question/problem?
  36. what should i swap into an accord?
  37. C2 tranny?
  38. speedometer acting crazy
  39. How do I do these things?
  40. power to weight and torque
  41. apexi
  42. Problems after b16a swap
  43. Exhaust Problem Help!
  44. What Is A Cat Grrrrrrrr
  45. Cat removal
  46. which one would be more practical?
  47. Auto to Manual Conversion?
  48. Bunch of Exhaust Questions
  49. info on engine!
  50. ground wire kits?
  51. Question about Starters & Odd Rattle
  52. Civic O2 Sensor Eliminator
  53. indurence racing H22A or b series
  54. 1986 Cadillac Seville ht 4100 engine trouble
  55. 96 D16y7 in 94 civic D15b7
  56. Quiet down..
  57. JDM '98 Spec ITR Header
  58. b18c vs b16b
  59. !!To All High Performance Exhaust Users!!
  60. !!!!!! Serious Decision !!!!!!!
  61. Zcvtec
  62. vx motor into a crx
  63. Mini me with Gude head?
  64. Turbo
  65. 95 civic EX owners
  66. Power Enterprise Vtec Controller
  67. mazda meliena
  68. Turbo B18C1
  69. How high HP/Torque can NA engines get to?
  70. help installing a cd player for a honda
  71. universal joints
  72. JDM b18 or gsr b18
  73. LS exhaust vs. GSR exhaust
  74. Hondata Ecu
  75. Intake+Exhaust = Better or worse gas mileage?
  76. Torque steer or what?
  77. YES another question!!
  78. Is theftlock gonna be a problem...
  79. Stereo: Capacitor Diagram
  80. H22A, or B18 (series) ina integra
  81. injectors
  82. STUDY HALL!!!hehehehehe
  83. Honda DIY, How To´s, Info Updated Daily ''Must See''
  84. Small block Chevy heads
  85. Rare ecu
  86. fuel systems
  87. h22 install cost
  88. JDM Parts available
  89. Fields Vtec Controller
  90. mod for header?
  91. Acura Integra
  92. help passing emissions!
  93. Cam Springs
  94. how do rotery engines work
  95. Trouble Starting my car
  96. Brake lights
  97. Buying a Used Car
  98. How do car manufacturers decide on which technology to introduce in a car?
  99. Coolant pressure
  100. how does noss work?
  101. whats the best spark plugs?
  102. how does a twin or single turbo work and what does it do?
  103. anyone selling mounts or throw out assemblies? a ? also
  104. pcm pinouts needed
  105. swapping h22a type-s into stock type-sh
  106. Please read
  107. Single Turbo instead of TT???
  108. Hyper Blink
  109. units of compression ratio?
  110. stroker kit anyone?
  111. 10 Grand Redline?
  112. more swap ?'s
  113. which one is better
  114. IF you are looking for the right person or IF you want to refresh your view
  115. "Dressed engine weight"
  116. 96-00 hatchback
  117. insulating exhaust
  118. will 98 GSR axles work in B20b/S80 swap
  119. Vtec-E D16Y5
  120. Bogging and back firing
  121. B20a5
  122. 1977 buick car
  123. Swapping in VA?
  124. F22a to a H22 I have some questions...
  125. Public Domain Hi-Eff Engine Design
  126. spoon fan switch
  127. JDM headlights
  128. Exhaust
  129. B16a to B16B? B18B to B18C5?
  130. engine chart
  131. repair questions
  132. Stuck car door
  133. CRX JDM Front Conversion
  134. stage2 cams
  135. 2 stroke + 4 stroke = 6 stroke!
  136. how do you make B20hybrids?
  137. fab engine mounts for 86 lude? how much?
  138. Timing belts...
  139. fuel upgrade
  140. h22a type S into 95 accord
  141. wiring on swap
  142. Idle control motor???
  143. Turbo or Naturally Aspirated
  144. Engines...Explain please!!!
  145. starter ?
  146. Differential question
  147. Greddy Evo vs Apexi N1
  148. JDM B18C Type-R
  149. please read!!!
  150. What is a good first project car?
  151. transmission, but case is cracked
  152. b series headers? other ?'s also
  153. Car Alarm Starter Disable?
  154. Help, quick question spark plug gap
  155. What do you think about this article?
  156. rear seat in a crx
  157. what else do I need for this B20 swap?
  158. fuel injectors
  159. h23/h22?
  160. axle problems...
  161. home-made tools
  162. Hybrid Revolution?
  163. custom gauge faces
  164. technical questions about oil loss on honda 1.5
  165. Was throwing just code 22. Now, 22 is gone and it's CEL code 21, Why?
  166. Metal vibration noise
  167. WTB oil catch can... where is a good place
  168. at home B16A swap?
  169. Engine bay, really really warm...
  170. HELP!!?? no fuel through Bosch ke jetronic fi distributor
  171. Light Weight Flywheels????
  172. are obx hi-flow cat really hollow?
  173. Best swap for 88 teg?
  174. getting B20 to 1.75 r/s
  175. B16A2 into a '95 Ex coupe
  176. Breather Filter
  177. A Good JDM engine Dealer
  178. H22A or B16a SirII????
  179. VAFC settings for Walbro 255lph
  180. Installing brake pads
  181. K24 vtec
  182. Non V Tec 2.2...help
  183. Is this the right harness for CEL diagnostic? Pics inside!
  184. how can i open door with button??
  185. cam gear bolts
  186. b16a 5th gear to LS?
  187. Hesitation nobody can figure out!!!!
  188. engine mounts B16A
  189. PS pump question
  190. Help! Wiring Problem
  191. jacobs icepack not working Help
  192. P30 Ecu???
  193. Torque settings on Head bolts and cam bolts
  194. New S-AFCII...more tuning pts!
  195. VTEC Quit!!!
  196. Shot peen B16A Rods...any troubles?
  197. car problem
  198. can it be done twin turbo for a 99 honda civic
  199. shaved trunk how to?
  200. Distributer HELP PLEASE!!
  201. TURBO for RSX Type-S
  202. Suspension Help
  203. d15b vtec Fuel Cutoff?
  204. WRX motor in Integra???
  205. hp racing header?
  206. Turbo? or Na
  207. Where did YOU tap in to wire the IAB (secondary intake solenoid) for vtec???
  208. Eg / GSR swap is almost complete! Few various Q's with pics inside!
  209. Cheapest place for JDM front clip
  210. 1999 civic ex vtec
  211. honda accord 94-95 trunk on a 1997?
  212. Fuel Gauge Problem!
  213. knocking????
  214. no power
  215. b18c1 or b18c5 and a smog question
  216. Dsm?
  217. Green harness under intake manifold on GSR motor?? IAB solenoid?? PICS inside!
  218. 1999 civic vtec damaged?
  219. Installing the "bitch pin" (shift linkage at tranny), Best way?
  220. Jdm Ecu
  221. Check this Honda out guys :)
  222. 4 wire o2 shock tower wire locations! Pics w/ detailed text!
  223. interchangable parts
  224. mini me swap dual carbs
  225. Exhaust smells like gas
  226. motor swap cost
  227. 92 honda accord
  228. vtec solenoid
  229. Look!! how do i solve rusted headers???
  230. new clutch ?
  231. notcing the block
  232. Seat Belt problem in Civic!
  233. Long block and Short block
  234. d15b head swap
  235. Tranny
  236. ECM help.....please
  237. 89 CRX Radiator Support
  238. H22s cheaper in canada?
  239. Plasma Booster??
  240. h23 specs
  241. vtec wiring HELP! Couple Q's and Pics!
  242. temp sending unit?
  243. Climate Control
  244. Chassis DYNO shops in So. Cal.
  245. need car buying stories
  246. 18'wheels
  247. synthetic oil
  248. Nopi...
  249. How do you adjust t.p.s
  250. twin scroll turbo...
