View Full Version : Engineering/Technical
  1. Frame Locks
  2. Car Trouble (Seized Water Pump)
  3. rear ends
  4. piston heads?
  5. what type of oil
  6. question on this auction
  7. Engine swap
  8. Formula Help
  9. 1964 GTO Tri-Power help
  10. Selling 1973 Plymouth Scamp
  11. Building a 400 block
  12. What Paint To Use for my Wheels Center Caps..??
  13. Chevrolet Metro lsi 1.3L 2000
  14. front camber need help
  15. slipping 2nd
  16. Radio replacement 1992 Chevy C1500
  17. Fuel Pressure Is To High, I can' change It - New Pump.
  18. car trouble
  19. 2004 short bed 5.3 ??????
  20. DNX Exhaust??? OPINIONS please
  21. cobra vs trans-am ram air
  22. Fuel Pressure Regulator
  23. BB chevy radiator
  24. ??? Best radiator for BB chevy?
  25. Stock 400
  26. question about new springs... need some help
  27. New Hello!!
  28. mustang question
  29. which will be easier for a gs 350, supercharger or turbo charger
  30. helicoil cost
  31. Interior car paint??
  32. firebird body kit
  33. Retro Chevelle... built!
  34. Best radiator for BB chevy
  35. what size carburator
  36. Wanted: Muscle Car Review Magazine issue Sept 99
  37. General Question on Aftermarket Parts
  38. awd question
  39. What exactly do "gears" do for the car.
  40. fuel pressure regulator question
  41. Lights that Brighten to the Revs
  42. Dana Power Lok Assembly
  43. Catalytic convertor placement
  44. 327 chevy engine
  45. For Sale-jet performance module for 4.3 blazer,jimmy,astro,brand new
  46. Horsepower = torque x rpm / 5252
  47. Friend lives in Japan
  48. Diesel f150 project
  49. What would be technical problems?
  50. Will it Fit?
  51. headers and horsepower
  52. lil more help
  53. Dollar Bill Test - it sucks!
  54. Help engine install!!!!!!!!
  55. need advice quick ( '66 ford fairlane)
  56. looking at a 1969 cutlass....advice?
  57. transmission slippage
  58. which headers?
  59. Gime a price
  60. GM A body clutch linkage question
  61. Gasoline Odor
  62. please help! throttlebody makes weird noise!
  63. Brake problem!!
  64. Support Our Troops Cruise Night {Phila}
  65. How to bring down NOx levels?
  66. ECU tech
  67. Clutch Or tranny prob?
  68. question
  69. tachometer installation
  70. How much is it to replace balljoints usually?
  71. My 1970 olds 442 post coupe ^_^
  72. Need help turning my '03 Ranger into a stylin Gear transporter
  73. 351W Gas Mileage & Dyno Tune
  74. Fenders for '72 LeMans
  75. jet performance module
  76. Coins in car cd player - now shorting
  77. Need some help
  78. mechanical and electric speedos
  79. rushed and i got a question
  80. Turn signal problem
  81. 350sbc running ruff
  82. Equipment to Measure Compression Ratio for Diesel Engines
  83. stuff
  84. custom gearing?
  85. code 9 please help
  86. lost locking lug nut key
  87. Which Size Rockers
  88. New Guy Here.
  89. Pics of chargers
  90. Auto Make/Model/Year Software for website
  91. Idiot lights to Gauges
  92. my engine
  93. just advice
  94. Rear end noise
  95. switch to neutral, Good habit ?
  96. Just finished dropping a new motor into my car...
  97. Off road in IH Lightline
  98. oil and engine restorer
  99. transmission debate
  100. Buying an A/C vacuum pump
  101. My 88 Blazer Is Burning Oil
  102. Wiring / manufacturer help please
  103. 66 Mustang Fastback 289 V8 w/Shelby GT350...
  104. strange stink
  105. timing
  106. buying a new used car
  107. ???
  108. nova grill ???
  109. driver door lock
  110. 71 HEMI CUDa
  111. Hyper Voltage System?
  112. CODE 16, form my ECU - what should i go check??
  113. Whats The Best Chip?
  114. Mods
  115. Trying to get this jdm EF9 front end to fit on my 89 STD hatch , HELP PLZ !
  116. drivetrain
  117. Autoapply V1.0 software
  118. torque specs
  119. interference engine
  120. Car-Life muscle car stat list
  121. Damn man
  122. Maybe I figured it out
  123. Our 2004 Colorado smells
  124. Engine Noises HELP!!!
  125. Need advice
  126. Bad vibration when slowing and stopping
  127. Thump noise (Engine Mount?)
  128. thinner wheels????
  129. 94 vtech in 92 accord ex
  130. Looking for Charger 1970 383
  131. need some help.. thx guys
  132. 1972 Dodge Charger
  133. 60 falcon 200obo in CO
  134. plz help - weird starting issue
  135. 4 row aluminum radiator
  136. 440 hemicuda engine
  137. did i waste my $$?
  138. VG30E throttle position sensor adjustment???
  139. Issues with 3100 Motor ... Head Gasket or something else ...?
  140. Okay A Serious Problem!!!
  141. tint help
  142. Who would win ???
  143. 327 crank,,,350 block
  144. 350 to 383 help
  145. 350 to a 383
  146. project car
  147. Disc Brakes Squeaaaaaaaaaaaallllll
  148. Turbo/Generator
  149. Thermal Efficiency
  150. Olds Paint
  151. Distributer Timing
  152. 2000 plymouth breeze transmission
  153. Looking for GM Paint code 40
  154. car inquiry
  155. Alternator problem
  156. Check this out
  157. 89 Toyota Lifted Big...good Idea?????
  158. will it fit
  159. need to be faster
  160. Cracked Power Brake Booster Stud
  161. completely lost need help
  162. need help deciding.
  163. ! ! A P E X I N 1 ? ? ! !
  164. difference between Biturbo and TwinTurbo
  165. Screeching sound
  166. 1972 GTO Hoods
  167. Need solid advice
  168. supercharger ?
  169. TSBs free, yea right!
  170. Fumes inside Audi 90S; from oil or exhaust leak?
  171. intermintent turn signal problem
  172. 1994 Ranger..ignition coil..
  173. 1979 bronco lights
  174. wanted-blower-corvette 350 engine
  175. 1969 383 Cuda
  176. 76 GMC Sprint
  177. help..auto trans
  178. lil more problems
  179. Relay Wiring
  180. 98 Town & Country Engine Fuse keeps blowing
  181. A/C - Power steering belt
  182. Im Begging Everyone Please Help With My Problem No One Ever Replies To My Post
  183. chevrolet s-10 alternator whine and dash lights flicking
  184. Wut to replace before head install??
  185. Salvage Titles????
  186. When a Car is Fixed After an Accident, Is It Okay?? I'm Worried..
  187. in and out of overdrive
  188. delco am-fm-cd player in 1999-s-10
  189. Site FOR SALE!!!
  190. can't remember wed page
  191. TPS Adjustment
  192. Gross Vehicle Weight
  193. Non factory spec'd rims..
  194. tranny problem
  195. MY CAR IDLE's LOW..
  196. wiring diagram
  197. Blower for sale
  198. AC fuse blows out
  199. Buy restored OR restore it?
  200. qjet/edelbrock swap-vacum lines?
  201. Why are so many cars underrated?
  202. Searching for my old "baby":
  203. Searching for my old "baby":
  204. Searching for my old "baby":
  205. need help
  206. Need help with engine swap!
  207. Performance Fuel Pump
  208. Chevy Colorado
  209. ticking-rattling noise when I accelerate
  210. Quick Buick?
  211. 1968 Gto
  212. Pontiac GTO
  213. Suspension Problems, please help...
  214. To All Auto Mechanics
  215. possible guel injection problem Help!
  216. Is this possible....
  217. how to tell if your timing chain is bad
  218. confused: transmission mystery!
  219. wireing harnes
  220. Rattle From Hell continues
  221. Fuel Problems On 67 Gto?
  222. Broken Odometer
  223. trouble starting when HOT
  224. Removing rear seats to install speakers?
  225. 98 Trans Am w/Ram Air 63k mi.$10900 in Indy In.
  226. Like new 65 Mustang Convertible 289 V8!
  227. radical firebird idea...need input
  228. Automotive inspection checklist for mechanics
  229. awesome muscle cars
  230. Colorado Wheels
  231. remote starter install
  232. crank no start 92 3/4 ton
  233. The 1970 Hemi Challenger R/T may be the best Muscle Car!
  234. GM, Chrysler, Ford
  235. What do you guys think about the Buick GS 455 Stage 1?
  236. Is the Chevelle 454 LS6 the fastest Muscle Car?
  237. Is the AMX 390 Go Package the fastest Muscle Car?
  238. need help
  239. The Fastest Muscle Car?
  240. Help Wanted on website...PLEASE READ
  241. 416 stroker from 340
  242. Making your car fast via N/A
  243. What is Starter Signal fuse for ?
  244. 1972 455 Olds Cutlass for sale
  245. Another transmission noise question.
  246. High Performance H1 Alpha Hummer Announced
  247. New Muffler sounds like a race car??? Why?
  248. Colorado rough ride
  249. cost of a new head
  250. A few general questions about shifting...
