Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
> Engineering/Technical |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
where can i get a clutch?
muffler conversion..
Report car mods to insurance company?
info for jdm f20a dohc?
OBDI Diagnostic Software?
turbo for a 95 DX coupe?
B16A parts compatible with a B16B engine?
B16A ECU and Distributor
was up
Steering wheel Vibrations
noob question: My car gets NO Power!! HELP
all motor help
JDM Motor Info
miss firing system?
h22a!!
Pro/Cons of painting brakes?
b16/b18 head gasket
02 SI --> K20A (Rsx type R) Swap
B16a distributor and ECU
b18c swap 3800 installed good or bad?
RWD integra??
Interests
Q: How to reach ideal R/S safely?
LS/VTEC Don't Believe the Hype.
Need help with Intake Manifold vacuum hoses
b18a build
2 engine crx, its been done
1.5 jdm dud
need advice for engine work
consistent surging when A/C is on...
Royaly fucked my car
Type R Turbo
is this possible for a CRX?
type s pistons
Newbie Question about D16A1 motor...
holy crap! blow head gasket
2000 DX -> 1990 Si question
question about horsepower?
Need blueprints for head gaskets
How to wire secondaries Eg/GSR Hybrid?
combustion chamber
will type R clutch pad work?
all motor Ls?
accord with issues
parts sourcing help needed
Catback
Front Clip
vtec problem
Im starting my swap im doing it myself help
help, My in dash lights don't work
Pro-Gard, Techron or BG44K ... makes any sense?
help...its not supposed to rev
JDM engine install on USDM questions
vtec?
JDM Engines? Japan and Indonesian quality difference?
03 civic si vs rsx type s
real cam gains?
racing clutch
Skunk 2 Intake Manifold
high performance engine for a del sol
sparkplugs
an N/A killer accord
B18C or B18C5?
Need EGR Help
gsr, or not to gsr
i wanna get more power out of my b17 what do i do
flywheel
vtec controller
help delsol nonv-tec with gsr vtec
Turbo Timer Problems > Starter Motor
Honda CRV head on Integra LS block?
Honda 2.2L problem
tranny swap for a lude
88 prelude swap
will it fit?
need 2 b taught
Voltage Regulator Stuck?
Replacing B16A3 with.........
Supercharge, turbocharge, what will they do
Can someone explain compression to me in english
Honda Prelude Swamp B21A1 with B20A5
looking to start building slowly..any suggestions?
Engine Control Modules
Conversion
B18C1 vs. B18C5 vs. LS/GSR
Prelude Engine swap help!!!
B18C1 vs B18C5 vs LS/GSR
Sun roof leaking
Gutting a 1997 Honda Accord
Type R fuel injectors
Integra ECU for b18a vtec?????
need advice!
Honda Fuel System
help on swap
I need help swap b16 which tranny to get
Cheapest Engine?
Mugen Grill for 94-97 Accord
ECU Question
Catalytic Converter Question
hello
hello
Help for a friend!
obd2 to obd1 cost?
hondata
car flooding itself
89' crx with B18A motor swap...questions.....
Transmission? problems
Buying Intake etc. for a swapped engine
Need help with 1990 Accord
Kinda dumb but: Iridium vs Silver?
honda civic swap
Throttle 'Lag'
mix and match
Im clue less
B16B buildup questions
inline 6 honda motor??
h22 swap
clutch shrudder
B16A or B18C
How do i change gear oil?
Tranny removal on 98 civic Si
when do I have to check transmission fluid?
Performance of a B16B
DX harness
New to Fiberglass
Civic Type R specs and pics
CAMS and Stroker kits
Moon Roof
oil in spark plugs
JDM Companies
failing clutch?
times
timing belt
H22
What's better mini-me or D16Z6?
Air Conditiong-Old vs New
Transmissions
JDM Engines
Car started rough after car wash
What is the most effective way to increase torque and low to mid end power?
Pushrod vs DOHC
Diff. between turbo and supercharger?
Disc Brake Problem: Frequent Scoring.
just a lil confused on swap
Engine Identification
b18a and b18b whats the difference really need to know!!
Longblock or shortblock?
Oil?
Lights question
Civic EX or Integra GS-R?
H22a swap
I swear i didnt write that! sorry for the bs!
H23a head swap!! ? need help
Civic Ferio logo
JDM Type r Wheels specs
ported polished and milled
OEM Tail Lights
01 civic swap info
90 civic si hb engine swap help
'97 JDM Accord SiR into 'USDM 93 Accord SE....any problems???
check engine light on jdm b18c
suicide doors
super or turbo
4th Generation Power Folding Mirrors
2003 civic engine swap
VIN checks
When do I need a FPR?
4wd Integra? Likely possible.
oxy enrichment
Short wheel base vs. Long wheel base
I have no clue what the hell that means!
Civic 2002 Engine code
90 civic hb
Engine doing something VERY strange...
Help aftermarket info
HElp plz
What fits in my car?... I want most possible torque and hp available...
Straight pipes
help gsr wire harness
Turbo on an LS
battery
S2000 engine code
Where can I get a high flow cat. converter...
Engines
v-tec???
Please Help Me
Getting to Hard to reach Spark Plugs
Air conditioning recharge question...
Levelling Brake and Accel pedals. Also wiper fluid nozzle.
cost of crvtec?
How to install rear seats on 97" GSR?
1996 Cavalier - cylinder 4 misfire, barely runs
b16a1 into a 98 EX
Help Gsr
Ok, who knows cars? help me out here
Rods And Pistons
Plz Help - Car Goes Vrrruuuuut
W engines???
rough running lumina HELP
Maintenance Requires Indicator
Reglage Apexi V-AFC on B16A2
Exhaust Video Clips
How to Install Rear Speakers?
How to instal ground wires
Cam Gear Installation
!!! Important, Dirtbike Owners !!!
How much should i offer this dude?
What should I do?
b18 head on what bottum end?
One Piece headlights
Civic or Integra engine??????
strut bar
Mach 10 Chip
Where to get oil line for B20/VTEC
fuel pumps
H22/F22 parts
H22 or H23 for Accord?
passing smog test
b21A1 swap in a 87 si
Smoged car didn't pass Knox
Adding HP with bolt ons...
1984 Mercedes Benz
To do or not to? H22A swap
Accord Front swap?
LS/Vtec (Conversion/Swap)
make up my mind
buying h23
motor swap
Engine specs
top speed
98 Civic and 91 Integra swap questions
cam gears, help please!!
computer
Cam Gears, what are best?
shotpeened
Does anyone here own a..
internals---JDM or not????????/
!!!!!HELP ME !! No more VTEC at 5 RPM
Spoon Engines???
H23 Dohc Vtec Blue Valve Cover?
H23 Dohc Vtec Motor Bloue Valve Cover????
Spoon Specs?
Balljoints Question
85 S-10 Blazer
Merkur XR4Ti Turbo
wiring diagram for civic o2 sensor
info
o2 sensors with b16a1
Web
AF
