Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
> Engineering/Technical |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
Separating Type R Tranaxle from Engine Block
Header for Crx w/B16A
Lsd
North Carolina Emission Laws?
Low fuel indicator light
EDM B16A1 engine
Electrical Issues/troubleshooting
Own a B16B too
So many motors? but what should i do
Which engine would you recommend?
Which engine do u prefer?
check engine light on hELP!
Tranny Troubleshooting
Regain Performance On Beat Up Engine and Trans
what head to put on b20?
D-series engine swap
fuel pressure riser (stillen)
quick start question
Check This Out
quick question about torque converters. . .
Diff intakes
H22 in Civic
jdm engine dealers
Question about KYB AGX Shocks & Struts
Performane Chip Questions
new driver, new car
Air intake for Integra
power steering fluid replacement
Power steering
b16 NA
The TORNADO
ZC compression
Which b16 engine do you recommend for a 5th gen. civic?
H22 Swap .... info needed
Small Dent Removal
Could you ?
Moonroof
how to remove door panel from a 92 civic for speaker installation????
tranny
information required
Obd2 sample source code
HKS Hiper Exhaust!
possible bad alternator?
94 civic b18c5 swap?
transmission swap from auto to manual????
K20 Mugen ECU
Drive axle question
stripped altenator bots
b20 turbo swap
Need Suggestions on engine
what's this noise i'm hearing??
NAPA Exact Fit wiper blades
engine width-wise
Motor will not start.
B18c into a 91 integra
Need help passing MA emmissions test
unorthodox racing Sc (street crank) pulley
Problems with My 92 Cavalier
b16a
b16A3 or b18b1? Turbo or NA???????
CE light after installing coldair intake
Wastegates and BOV's
adding horsepower
1 remote for multiple cars???Possible??
my honda knocks more than I knock women
info
90 Prelude motor swap
engine swap for 91 integra rs
Dual Ram air
Jdm Front Integra
where to get a civic si or gsr front clip
installing side markers?
i need a highly recommened site....
b18c1 swap questions in a 5th gen civic
new england tuner shops?
what does octane booster do?
catalyst - EURO2
I had a wild idea
JDM MAP Sensor
jdm usdm?
Engine Mod help.
Need Transmission help
Auto to stick swap
Jdm Prelude
torque converters
Single Turbo on "V" engine...
Transmission Question
She's In!
2002 honda civic tach help
ls/vtec
B16A Help
anyone with a crx with b16 in it?
Injectors
sport tuning suspension
ignition problems
Headlight Beam Adjustment
Flush Radiator / Bleed Screws
Grease fitting?
Prelude
SWAP FINALLY IN!!!! remember me from 3 months back!!!!
b16a vs 94 LS
obd2 software for pda
Mini me question
Is this clutch slipping?
more power?
yo guys i seriously need help w/ intake
Summer Trailer towing with a 1992 Maxima SE
DSM 450cc injectors into integra ls
Gsr Performance
emission law
exhaust rattling! HELP!!!!
Brakes Lights
Engine for preludes
Final Drive Gears for Cable tranny's????
Help with engine code....
Civic Cabriolet...???
3.2TL TypeS in a 2K Civic SE...Will it work?
k20a swap
I speared my convertible top
Acceleration problems
Direct Gas Injection
gsr swap need help
motor question..
What does a B16B put down at the wheels?
Newbie.....Help
Clutch adjuster
USDM vs JSM
Exhaust dyno results
B16B wiring harness
Opinions neeed
B16B wiring harness
Starting engine for first time after parked 2 years
N1 crank pulley
I Just want a simple answer..What Kind Of CLUTCH do yall got??
woohoooooo!
h22a swap
How can you tell if there was sugar in the gas tank?
Whats Twin CAM?
problems w/ jdm swap
High Tech Suspensions systems
engine swap
Tubos and Superchargers
Civic Got Towed
Changing timing belt...
edelbrock type-R throttle body.....
For Sale B16B Type R engine + Tranny
Any hope for a F22 engine?
Blown Head Gasket? How to tell.
Building Up A D16Y8
B18C any good?
car vibrations
high-speed, high-power diesels
drag tranny b series
Tranny hybrid. Can this be done?
timing belt/cover for DOHC ZC
SKYLINE ENGINE into an MR2
Wiring Harness Question
What exactly is a B16
new transmissions
Need info on rhd conversion for my ek b16b hatch
newbee question on H22A engines
D16Y8 power??
Turbo and exhaust Q
89 teg mpfi?
anyone familiar with the Y5?
B20 Stroker?
does b16a exhaust manifold match b18c
B20 Stroker?
vehicle's weight? GVWR?
brand for manual trans. fluid?
old and new
Books On Forced Induction?
2nd gear problems
TB and intake mani swap on my 98 Dx
who wants to trade???
A/C Powered Ram Air
what is an assymetrically turbocharged system?
95 accord EX Power steering inop.
Axels or something else. HELP!!!
Possible Solution
fuel pump on 90 integra
help
P30 ECU [Auto and Manual]
Why the Wing?
Jammed electric window
Spoon/Mugen Chip for a 96 Teg
working on a non vtec 96 accord
Need Parts Info!!!
Need info 85-89 JDM Accord b18a
b16a2 swap into a 91 teg
Auto tranny and b16??
Difference between 175 hp on I4 and 175 hp on V6/I6?
Shifting on an automatic-- have to release accelerator?
Bad service at Honda Dealership ruined my car
Jdm front end
Itr inner springs
a\c question
When did everyone learn to drive stick?
B18B1 Vtec Conversion
V8 conversions.
aem model no
how much boost can a stock ls motor handle?
which fuel?
b16 in 89 prelude?
why are we downing the d15?
What's the difference between a CTR and DX hb?
Fidanza Flywheel in H22A
Cutting Springs
a/f guage hookup
Auto Starter for a Manual Car?
B16A A/C Help!
these parts necessary with a swap?
What to do?
Just wondering.
suggestions plz on a 96 civic dx
00 Civic Si strange clutch sound.
clutch disc question
A Fun Game
ITB's for S2000
Exhaust Question
timing belt 60K or 90K?
aspire mods
that's a nice head...hahaha
Follow up. MSD, is it worth it?
heated oxygen sensor
Engine Codes?
93 octane limits
Engine swaps?
My stock 10 YO cluch is bad, Any sugg. about aftermarket??
JDM Climate Control - 2001 Type R
Accord V6 tansmission leak
OBD-II Scan Tools
Removing E-Brake
Ultimate Build
just wondering...
Replacement Engine
Integra Engine Swap hp ?
VTEC Wiring
Question about Vents?
CR of JDM b20b anyone?
B20/Ls turbo
coolant problem
ceramic header heat shield
Parts compatability
Need new engine, where to go
Argh!
Carbon Fiber
crossmember bent?
CRX motor swap
Security switch
Web
AF
