View Full Version : Engineering/Technical
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
  1. online shop help?
  2. turbo leak?
  3. How do I make an exhaust flame kit?
  4. Which gear oil to use??? Please advise!
  5. Which oils are good for B18c5?
  6. Which oils are good for B18c5?
  7. Boost Controlling
  8. vss help
  9. Teg Tranny Swap Part 2
  10. losing oil pressure
  11. cat-back exhaust question
  12. Just bought a 97 EK4. Want to build a B16 frank. Need help.
  13. how to install the screen mesh
  14. Rotary mini Drag-car
  15. the best for a 97' Civic LX (engine)
  16. apex'i VAFC harness
  17. K&N ENG now has a new Forum section added
  18. Help With MUFFLER!!!
  19. How do i get my dash out corectly???
  20. engine swap
  21. B16a Turbo For Sale -- 94 And Up Acura Integra Side Skirts 4 Sale Too...
  22. Mig
  23. Pics of an B16a, please!!!
  24. 1988 Acura starting problems?
  25. ls to ls vtech
  26. tranny swap
  27. shop
  28. b-series valve springs and retainers
  29. Problems w/ VTEC after SWAP
  30. Prelude Climate Control
  31. Engine Prob
  32. my idle is all messed up
  33. short shifter
  34. Help! I'm not a mechanic
  35. Learning about mechanics of cars
  36. Whats a good way to learn about your car and get into tuning it?
  37. JDM & Aftermarket Parts
  38. measurements on DA bumper lenses
  39. What injectors do I need?
  40. car wont start
  41. weak minivan
  42. nissan GTiR Pulsar (perfect WRX killa)
  43. Cylinder walk.
  44. jdm headlights
  45. h22a weight issues
  46. HID Conversion
  47. General question about timing
  48. 4th gen. engine swap
  49. ignition upgrade
  50. what can i keep?
  51. Need help on Engine infomation+Tuning
  52. Need More Power Please HELP???
  53. civic header specs
  54. B16A or B16A2 ??? Confused... Help!
  55. a safe cheap way to adjust camber on accords
  56. wat size spark plugs for b16a?
  57. which spark plugs are good for b16?
  58. Valve Cover Breather
  59. A Challenging Problem :S
  60. Double clutching
  61. type one racing exhaust (T1R)
  62. Blow off valve
  63. DX Redline
  64. automatic integra
  65. what are pullies
  66. Speed baby
  67. 3SGTE Info Please
  68. ls/vtec or CRVtec
  69. 5th gen How-To's
  70. B-Series Transmissions
  71. 1St Generation Engine Swap
  72. How do you install a Manual Valve Body?
  73. project help
  74. Engine probs! help!
  75. obd1 to od2 necesary?
  76. help!!!! h22a tranny problems
  77. b16 problem!!!!!
  78. I have an 03 525i and am wondering what to trade it for
  79. Clearing out my stock headlights on my 2002 Civic ex
  80. advice please
  81. Problem with my 98 civic, alternator I think...
  82. Do You Like Ratchet Shifters?
  83. I Got $2,000, What do I Do, D16z7. Please Look...
  84. Problem with emission/smog
  85. Where is the horn?? VW 1999 Beetle
  86. oiling problems
  87. Tire wear?
  88. Help me take off my ac and power steering belt
  89. efficiency of intake 1995 prelude
  90. 93 prelude h22a drop
  91. engine swap
  92. Oil-changing tip
  93. how to install my tach on a b16?
  94. 2 liter gsr build
  95. GSR or CR-V????
  96. Power window problems
  97. Turbo B15 help ASAP
  98. getting 4g's on the 15 and 2g's pn the 29th
  99. Turbo Question
  100. i need help with motor swap
  101. ignition ?
  102. OBD 1 type R ECU
  103. How to replace Headlights 94-97 Integras?
  104. B16A Head Polished and Ported
  105. idle problem
  106. V4 advantage
  107. HELP need more power from the D16y
  108. thoughts
  109. b16 engine problem help!!!!!
  110. How VTEC works
  111. 3rd gear grind
  112. turbo on a b18c5
  113. mugen twin loop copy
  114. 2nd grind...
  115. Air Bypass Valve
  116. Tranny swap
  117. Starting problems
  118. V8 Cam profiles
  119. Full H22 system swap for del sol
  120. Type r parts
  121. Drum problem
  122. best for turbo
  123. Project help needed
  124. UnderDrive Pulleys ECT, are they worth it?? COMMENTS!!
  125. USDM parts in Japan?
  126. mini me swap
  127. should i get JDM
  128. how to rev to 9k ?
  129. ls or b16?
  130. crane cam ignition.
  131. Tranny Problem
  132. Aftermarket anti-lock brakes?
  133. my cars slow?
  134. Physical difference between GSR and Type R motor (B18c1 and B18c5)
  135. D16z6 swap
  136. b18b1 prices
  137. Is an EGR valve like eating poop?
  138. new synchros
  139. engine swap help plz
  140. vtec controller
  141. Clutch noise
  142. Engine Swap
  143. was up
  144. power steering
  145. Sound Clips/Videos so I can hear the sound of ur muffler!
  146. Hydrolocking
  147. Downpipe
  148. free stuff
  149. What v-tech would best fit my 84 prelude
  150. Timing Belt Change
  151. full jdm conversions??
  152. H22 timeslips???
  153. flat 8
  154. Need a RHD steering conversion facility
  155. Is double clutching bad?
  156. whats faster LS/v-tech or h22
  157. Fog Light install
  158. New guy with a few cold air questions
  159. B16 hesitation and unplugged holes
  160. Timing belt jumped?
  161. Help, I need some Flywheel recomendations NOW!!
  162. What to do?!?
  163. b18b1 cam gear timing
  164. vaccum/fuel prob 96 kia sehia
  165. Ecu
  166. Someone help me with a engine swap!!!!!
  167. in need of a b18
  168. 1991 Honda Prelude 16V 140HP
  169. geo prism remote
  170. Newbie Need Help!
  171. In need of HELP!
  172. Engine & Transmission
  173. Timing Problem
  174. No fuel to carb.
  175. Dohc & Sohc
  176. A little help for a nUbie
  177. teg GSR vs. lude si
  178. suspension settingsTEIN
  179. Pronunciation of Mugen
  180. Engine Swap
  181. best head for b20
  182. Good Engine Swap
  183. Engine stalled while charging AC
  184. Electronics Problem
  185. Rev limiter??? Distributor???
  186. b16a SIR 1 in a 98 civic
  187. Compression Test on DOHC Vtec engines
  188. Need help please
  189. CTR headlights bulb designations HELP
  190. Need help with my civic
  191. swaps in nj
  192. need help please
  193. JDM Type R
  194. throttle body size?
  195. Convertible Top Repair Myself
  196. anyone know how to install coilovers on a 97 accord?
  197. trueth about magnets on air and fuel hoses?
  198. Which Valve Angle to grind
  199. RB20DET/SR20DET for my 2000 Civic
  200. Coil
  201. Car Wont Start
  202. H22a Swap Question?
  203. To Swap or not to Swap
  204. Is it worth it to fix up an '85?
  205. Q. on Shift Problem
  206. Help me go faster
  207. head gasket swap
  208. 99% Noobie
  209. C32b
  210. i need help with a new decision
  211. Question for ctr engine owners
  212. civic header question
  213. Blow Off Valve required?
  214. my b20 vtec
  215. b16a idle bouncing once warm
  216. b16a idle problems bouncing when warm
  217. If you are a 95 Civic EX owner you might/need to know
  218. got a question and i gotta know soon! Garrett TA-51 turbo
  219. Valve Lash???
  220. K20A2 stock cams
  221. Fuel Cell Car Performance Specs
  222. Need help with switches, LEDs and fuses ...
  223. Please Help!!
  224. Anyone ever buy an engine online??????
  225. Rb26dett
  226. Rb26dett
  227. Fuel Injector Life Expectency
  228. CRVtec
  229. ebay chips
  230. Cable vs. hydraulic tranny
  231. body differences between 96-98 civic &99-00 civic
  232. D16a1 Swap
  233. was up
  234. Quiafe LSD
  235. teggy compression
  236. tuning recommendations
  237. I need help with this decision
  238. first car- exhaust
  239. Separating Type R Tranaxle from Engine Block
  240. Header for Crx w/B16A
  241. Lsd
  242. North Carolina Emission Laws?
  243. Low fuel indicator light
  244. EDM B16A1 engine
  245. Electrical Issues/troubleshooting
  246. Own a B16B too
  247. So many motors? but what should i do
  248. Which engine would you recommend?
  249. Which engine do u prefer?
  250. check engine light on hELP!
