View Full Version : Engineering/Technical
  1. Automatic Trans Question
  2. 94 dodge caravan serpentine belt
  3. Wiring an accessory
  4. What's the best way to convert to HID?
  5. Tyre Wear on Citroen C4
  6. Open on Sunday
  7. Sudden brake failure that caused an accident, how?
  8. Looking for lowest viscocity ATF
  9. 1999 s10 truck problems
  10. Ignition Switch Problem
  11. automotive book
  12. Engines: Mitsubishi 2.5L DOHC or Toyota 3.0 DOHC
  13. heater core question
  14. what is this?
  15. Vauxall Corsa 1.2L 1999 Help
  16. Hewlett Packard seeking Automotive Technical Writer for contract with GM
  17. (96 Infiniti I30T) One brake seized, then the next after work - ?
  18. Check Engine Light on 98 Honda Accord DX
  19. Flat tire noise no flat tire?
  20. Rod knock? Hammering Valvetrain?
  21. "wheel of fortune" noise from rear when braking
  22. Superfast lowering spring wear?
  23. Manual: 1998-2002 GM LS1 Drive by Cable EFI Wiring Harness
  24. Battery / alternator electrical question
  25. Front wheel noise (Video included)
  26. engine rebuilt - now sputters from a stop and "bucks"
  27. Auto shop sent me on vacation with worn brake pads
  28. civic 2001 si electric problem
  29. Window Problems
  30. Should I change the Cambelt myself?
  31. Car jerkes when break is applied and released
  32. DIY 1200hp rated Dyno
  33. Difference between Keilrippenriemen (Poly V-ripped Belt ) Antriebsriemen (V Drive Belt)
  34. Cam and Alternator Belts Breakage
  35. Help with AC issue
  36. JC Whitney?
  37. SteeringColumn Noises 2002 Prius
  38. 2008 Kia Optima LX 4Cyl - Hard Vibration & Jiggly Steering Wheel over 50mph.
  39. differential
  40. 2014 Dodge Charger Front Suspension Help
  41. clutch problem is Golf 5
  42. 2000 Jeep Cherokee CKP location
  43. Help!
  44. aesthetic
  45. transmission problems 2007 toyota camry
  46. Ignition panel instal
  47. Wheel overcome obstacle at speed.
  48. Brakes 101 - Function & Maintenance
  49. Exhaust Function 101
  50. Diagnosis needed
  51. Forgot to apply rust converter before touching up stone chip
  52. Hybrid gokart
  53. Gas Charged Lift Supports
  54. Low oil pressure .....
  55. Source of coolant leak
  56. starting headache
  57. automatic transmission slips when cold
  58. Bad Alternator?
  59. How to correctly check transmission fluid-vauxhall astra club 1.6 automatic
  60. engine wants to be run at 30 BTDC...?
  61. weird battery problems
  62. Vauxhall astra club auto 56 plate-noisy gear change
  63. Is there a 'permanent' fix for a manifold leak?
  64. Check engine light issue
  65. No Power Under 1500 RPM
  66. Whistling sound after 30 minute driving
  67. Shifting hard into 2nd but then fine after that.
  68. 3 Issues - One problem?
  69. Wayward wheel
  70. Tapping Sound Coming From Engine Bay - Can Anyone Give Suggestions?
  71. 1997 chevy cavalier 2.2 pos
  72. Rust proofing stuff TEST
  73. Overvolting Lead Acid Batteries
  74. Camshafts Not Aligned Correctly
  75. Frickin' Cold Tires lol
  76. Dealership is opening my dash up again
  77. Reverse differential operation
  78. Turbo charger
  79. How to provide motor assist to engine?
  80. Dealership cannot Diagnose Origin of Problem!
  81. How well should a car track? What causes pulling?
  82. vehicle possibly sabotaged
  83. 2002 Ford Taurus will not start--ideas?
  84. Identify This Part?
  85. How long does it take for oil to circulate through an engine?
  86. Battery Charger Operating Voltages Puzzling
  87. Clicking sound under pedals & Warranty
  88. Automotive Detailing by Jeff Lilly Restorations
  89. No Engine Start After Rebuild
  90. Smart Starting System
  91. how to check engine mounts
  92. Starting problem and other
  93. Trying to find what this carburetor fits...
  94. Dual Battery wiring help
  95. 1996 Jeep Grand Cheokee 4.0 L6 No Start
  96. Rack and pinion steering parameters
  97. Not another P0102 code! Test your troubleshooting skills!
  98. hypoid ???
  99. Automotive Jumper Cable Amperage Claims
  100. My Ford Mondeo quality - what do You think about this
  101. What can I do with a 2000 VW Passat?
  102. Need help with battery Ah and starter calculation
  103. Motor oil polymers in engine Toyota Yaris - cleaning??
  104. Survey for School
  105. Brake failure
  106. Possible Damage After Incorrectly Seated Torque Converter
  107. Turbo car running badly/bogging down, blowing black smoke
  108. DIY: Porting & Polishing a Throttle Body (Video Tutorial)
  109. flushing the cooling system
  110. 94 Ford Thunderbird 4.6...air system/electrical issue
  111. Hand Tigten only?
  112. 92 metro dies on acceleration. please help!
  113. Who Loves To Read !?
  114. First post (Multiple questions)
  115. 2008 TrailBlazer LS HighBeams
  116. Reducing fuel consumption
  117. ECU Remaping
  118. Need help in finding a scan tool
  119. Need help in project involving microcontroller
  120. Is there any relay which can be programmed to work under certain voltage, current or load range?
  121. Open-source Automotive Project
  122. Windshield-Roof Leak 1991 Honda Accord LX
  123. CVTs
  124. "service engine soon" codes
  125. Block Sanding By Jeff Lilly Restorations
  126. 2001 GM 3800 Unidentified Wire
  127. Your diagnostic guess, please? Car ran over rocks, emits smoke
  128. epoxy flooring, any advices ?
  129. Roll Cage by Jeff Lilly Restorations
  130. easy access to changing voltage regulator components
  131. Frames
  132. Older the engine, poorer the mpg.
  133. starting problems with hot engine
  134. 1991 Honda Accord Unidentified Part
  135. My 78 Ford LTD won't start
  136. Chevy help with a used car with problems.
  137. Timing chain guide rebuilder
  138. Rover Batteries
  139. Old Car That Hasn't Been Started In A While
  140. Need Help! Something has fallen off (pics attached)
  141. How to repair beginning rust on the hood
  142. feeling the fuel pump
  143. Vehicle Electrical System related Questions
  144. New cars, no headlights on.
  145. ford fiesta 1.25 zetec
  146. i need help with my 66 impala
  147. AC wont switch
  148. Exhaust wall thickness
  149. Idiotic girl needs help! Gears!
  150. sr20de...old radiator (i guess) popped like a balloon, new one hisses. Not (specifically) the thermostat. Wut do?
  151. back again, no start
  152. Autel AULDS708 Automotive Diagnostic and Analysis System
  153. Engine Rebuild Basics
  154. Name that Part!
  155. Change the battery without losing data
  156. OBD mobile scan tool - univeristy projecto
  157. SBC starter issues
  158. the cool guy
  159. 6-stroke engine thermodynamic analysis
  160. Carburetor scoop questions
  161. Green technology
  162. Turbo's
  163. Compression ratio
  164. Engine won't Start, Turns over and SPARKS
  165. Taking tires off one set of rims and put them on another car
  166. What's the difference between cast iron and chromoly steel flywheels?
  167. Gear CVT
  168. Automotive in the future
  169. Looking to learn more about auto repair
  170. Formula one car body panels
  171. Any suggestions?
  172. create DTC (failure) for obd II tool
  173. Alternating current (1 - 1.5 A) in alternator output
  174. where to buy launch x431 master?
  175. Electric Power Steering Redux: SCARY Article!
  176. ASE or shop manual leak down test for court
  177. Teach me the Basics of exhaust
  178. .►► Real THERMAL IMAGING Night Vision Custom Install
  179. Is this Battery Leaking? Pic Inside
  180. How to get into engineering?
  181. using a/c compressor as supercharge
  182. Emission: HC's same as Gasoline?
  183. Charging Systems in New cars. curious!
  184. Need starter gear tooth geometry
  185. Fraction of Fuel burnt
  186. D light malfunctioning on a honda civic
  187. Distributor - Breaker Points
  188. Combustion equation
  189. Don't be soldering your automotive electrical connections
  190. Custom high angle cv drive shafts?
  191. Dana 44 cross pin diameter?
  192. Hello from the UK
  193. Double Wishbone Suspension
  194. Help: See accident damage in service history?
  195. Holley carburator, need help and information
  196. Used Car Pre-purchase question
  197. Central locking used to break into a car?
  198. New Bosch wipers don't smear.
  199. 2003 Chevrolet Cavalier auto won't shift to park and reverse its stuck on neutral and drive
  200. Possible Hydrolock and Solution?
  201. 1991 Ford: Battery drain caused by both engine and meter fuses
  202. Replacement bolts - Canada
  203. Portable battery jump starter which one to buy??
  204. quick question about an increasing source of 12v as revs go up
  205. HELP Gas Tank Issues!
  206. Urgent question about "Guaranteed to pass" for cars!
  207. Trailblazer remote start issues
  208. VW Jetta Vibration
  209. Advice for silencing a noisy hood + muffler
  210. AWD not as safe as it seems?
  211. Remote Car Locking
  212. Electrical issues
  213. Speed Limitations & Monitors
  214. Cloud of white smoke and burning plastic smell from under the hood
  215. Starter motor troubleshooting
  216. LED strip mod, Turning Signal
  217. 2 barrel dual carb vs 4barrel single carb
  218. Is a 04 base Sebring a good car to mod?
  219. It is possible to broke the car hood hinge by walking on the hood?
  220. A request for help, from an ignorant - a question on databases
  221. Hub/bearing assembly issues
  222. Need definition for crossword clue
  223. Cooloing problem, challenge for anyone who can help!
  224. 2008 Kia Optima - Manual Steering Rack Conversion
  225. Help me rewire my AC system to bypass the computer
  226. distributor question
  227. Wheels 101: what affects ride quality most?
  228. You used toothpaste - how's the windshield now?
  229. Best Way To Clean Engine Block Threads
  230. Driving while blind
  231. CV driveshaft
  232. A couple of brake questions
  233. Modified fuel pump setup, PLEASE ADVISE!
  234. help me in design calculation for hybrid car
  235. Carb Choke Plate to Provide TBFI Properties
  236. Car loses power when accelerating hard after using Seafoam
  237. sealed vs 'cap topped' batteries
  238. Hole in brake rotor
  239. Which way to face thermostat
  240. A Car Repair Wiki with How To's, Instructions, Diagrams
  241. Permanent Oil residue in the Coolant?
  242. Can overheated exhaust result in engine damage?
  243. Bonnie shudders and dies...a lot.
  244. Battery/electrical issue?
  245. Cooling system: Does it circulate the coolant in the resevoir?
  246. volvo
  247. Help my turn signals and hazards won't work
  248. What is the material build up on my rotor?
  249. Moist underlay in recently purchased car
  250. '89 chrysler electrical problem
