Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
> Engineering/Technical |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
engine care
accord engine type
wastegates and BOV's
B18c1
custom return line or not??????
Altenator for home power!
My Type-R
High performance crate motors?
Type-R ITR tranny....
speedo problem
TSB's
head gasket....?
about getting Sponsored
Ricochet! B16B Q
drifting in a acura and d1!!!!it was asowme
b16a2 and V-AFC
b16 swap into 6g
teach me about the B series motors...
how to install new xenon bulbs
99 Civic EX Swap
What is milling your head?
What is the difference between boring and stroking a motor?
Best Tranny for Ls-Vtec???
I want a faster Civic for daily driving!
V12 @ 8500 Rpm ???
Electronics on the brink!
Oil Filter!
#--- Help I Need Air ---#
can I do anything with this?
HELP! Clutch Pedal won't come back up.
shop swap rates
powerful engine
jdm d15b sohc vtec
Jdm Motors And Accesories For Sale
i am wanting to do an engine swap onmy 92 civic please help me out
d16z6 swap info needed!
reading ecu codes
Whats wrong with my car?!
auto to manual
b16a valvve job
ZC timing belt question
Speedometer Fuse????
Starter bad?
1991 Acura Integra RS - Starting Problem
engine reinforcement
Exhaust
94 Blazer 5.7 Missing and Hesitates when Excellerating
is it possible to put a turbo and supercharger under one hood
More Power???
Vtec Controller???
92-95 2door civic H22A conversion / need experienced comments
Engine Mods
how to adjust shifting cable
Is it possible to convert from carb to fuel injection?
ls 1/4 mile help?
Turbo Stock LS or B16a2 LS/Vtec
Engine Weights...Effecting handling?
timing belt
Change Manual Tranny Fluid on B Series
dc header question please HELP!!!
Hardwireing a Passport 8500.....
Knocking (Rod knock?)
acura distributor
Raising Redline
B18C1 in crx
how to install cold air intake 98 civic ex
ODB2 conversion to ODB1
b16b
Civic Speaker Rewiring
corner lights!
OBD II or OBD I
synthetic oil
I Feel Power Loss!!!!
prelude digital climate control
zc question
timing belt
help me with a tranny swap
JDM B16A or USDM B18C1
engine all loud when cold
O2 simulator Question?????
battery question
exhaust question
head gasket
VTEC problem!!
LS/Vtec Really that good?
I-Vtec vs Vtec, compare and contrast
anyone with b16a jdm help!!!!!!!!!
Honda 2000 EX
o.k. its a dumb question, but help
Refurbish
ringing noise???
ATTS indicator light (on your gauges)
I think I have been dupped ?
Grim Tranny Reaper (repair)
1994 S-10 pickup running rough
best of the basics help
tailgate locking mechanism problems
engineering software
Anyone ever seen this? Oil filter??
gsr parts bolt to b20crv?
crvtec or ls/vtec
f22 exhaust
white smoke???
VTEC or not??
Idle Fluctuation
OZ Wheels - Cast or Forged?
Please help! Whats crankshaft Horsepower?
Missing Vacuum Hose
Oil Tac gone crazy
2000 Civic EX Swap!?
"Technical" learning websites?
idle revving problem, mpfi swap ...
why the swap?
engine/tranny conversion
How to fix an Evaporative Emission Control System Malfunction - OBD II Code P0440??
Is this swap really as good as it sounds?
Swapping a RB26DETT into a 92-96 Prelude
r12 to 134a conversion
90 Si wireharness/ radiowires
grrrrrrrrrrrrrrrrrr
how much did your swap cost?
please help! ignition issues. (reposted w/edits)
how to get maximum HP from a stock d16 engine (decided not to swap)
Engine Build-up
what is next?
1991 Ford Escort Fuel Cutoff Help!
Electrical issues, bad ground? loose connection?
how do you like to shift?
question on pulleys
Best susp. set up for front wheel drive cars?
TA sensor?
99 civic swap question!!!!!!!HELP PLEASE
JET VFORCE PCM do they work?
b-series technical articles
alternator question
My Micra wont start.. any ideas??
Best head for an LS/VTEC?
Lister Storm
Possible Warped Disc?
Accord engine swap
Cold as ice?
B16A2 engine swap into 94civic
Gas in Oil
Honda Civic Exhuast
Car wouldn't run fast enough to pass emissions test...HELP
Coupe V6 exhaust...how restrictive?
Engine swap for a 97 civic hb.
need an h23
Tranny Question....
JDMeet in San Diego (Balboa Park) Sept 14th @ 2pm
usdm b18c1 vs jdm b16a2
I need help starting car
Got problem with radiator fan integra 1988
i have a few newbie questions
idle problem help~~~!!!!
brake lights out
4d4g civic engine swap in dc/md area
This is a JDM forum!
dropped nut in oil pan
hurting dx
89 Honda Civic Trunk won't close...suggestions on fixing it?
fiberglass
Any Referees for motor swaps out there???
Sanding/Primering Your Car?
will this throttle body work?
caddy probs and some ?s
Trans am engine swap
b16 Sir1 codes?
Cold Air Induction and MPG
94 civic, which swap would be best for me?
jspec b16a legal pass smog?
Manual transmission/shifting question
Car has dead cylinder, but still has fuel, spark and great compression????
JDM EF8 Legal?
1999 Honda Civic EX
jdm sir 1 gen info
E-Manage from Greddy....
How Do I Test My Brake Light Switch?
84 carb to 87 fuel injection swap
5 lug conversion???
Engine weights
NZ Civic Trans Swap
Oldsmobile 3.5L twin OHC
what could be the problem?
Oiling Problems
ECU Question
Which model of spark plug is the best for integra GS (B18B1)?
Looking for a JDM ITR front end!
bomz header
D16Y8 issues
Synthetic in a never synthetic car
H22 in a 92 Accord
P08
best turbo kit for d16z6
JDM B16 Osakajdmmotors.com
How much is this car worth?? Look@@
converting from auto to standard
changing from auto to standard
Strong like bull
integra gsr or prelude si
Oil dipstick tube question
2000 Sunfire --> engine keeps cutting out
2003 Accord Coupe - Dual Exhuast on the I4?
torque
grey smoke and no power in first
Help Urgent with lights
73 Duster ignition ?
Car Alarms
Need suggestion that which plug better than ZFR5F-11 when useing in integra B18B1
NGK ZFR5F-11 , what's mean of "Z" "F" "R" "5" "F"
"B" Series Engine Info
duck duck goose
check my paint job and kit...tell me what you think
Engine and Upgrades '96 Accord V6
Learning To Drive Stick
Accord swap?
Maps??
will a b18a head interchange w/ b18b?
good place to buy dohc zc?
Transmissions
please help me
not feeling V-Tech
Carburetor cleanup...
Which Engine for Forced Induction??
What kind of engine...
91 prelude
3 angle valve job
GSR or B16
Spark plug wires
installing pistons and rods
suspension
Need help with a leak...
h22a swap in a 91 prelude
Buying civic,,, need info Help please~~
crvtec questions
I love my B16B
enyone no the jun motor website
Tranny Problems with H23A1 Engine Swap
H series frank?
sudden oil leak
Convert Auto to Manual Transmission (95 Accord)
money
Si-R key?
JDM emblem
Whats the best N2o?
3.2 to civic
what diameter pipe for for custom exhaust?
Nissan's CVTS
Cat Back Exhaust Systems
Web
AF
