Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
> Engineering/Technical |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
engine swap or not??
88 Accord - My oil yearns to be free!!
Getting ready to order JDM swap.......
automatic to stick converstion
Need some technical help
oil pressure goin crazy
AEM Tru Power Pulley kit
H22a Into 94 Integra Ls Coupe
Where do I hook up an A/F gauge on an Integra LS?
Pricing on ported polished heads???
Skunk2 Intake Mani.
Distributor Cap
about civic hb
Oxygen Sensor and Code 1 CRX SI
question about the infomation that subaru gives
99 Accord: Power steering stalls Engine?
Custom exhaust and cold air intake
Jdm Swap
Looking for Onstar stories for article I'm writing
Pinning?
engine
some Q's about my car
jdm conversion
intake manifold mixups
White smoke????
How do you...
AIRMASS header?
what to do?
01 Civic Engine Swap
H22 Swap
engine help
Octane Booster
Brake Questions
Block sleeves
Recommended Exhaust Systems
dual throttles
Painting plastic fascia?
New cold air intake
Project Mu?
What do i need???
Running with no muffler
help sought!!!
adjustable cam gear
Dodge Grand Caravan Problems
Changing TPS sensor..
Catalytic Converter
JDM/USDM shopping?
losing some weight...
Engine bearing help.
Crower Valves springs and retainers
anyone interested?
Espelir Exhaust?
Tripple Sticking -- Question for the Pros
Ignition upgrade or not..........
Ecu Codes
redline when starting up the car
Brakes help!
external wastegate
driving without power steering
I need HELP, please?!?!
jdm conversion
b16 question
More Engine help please
New engine swap problems, someone help me
Cheap b16a's
I Need Help??????????????
Question about '99 Regal
yet another s2k swap thread
How do you tell the difference...
How Much Boost...
What Clutch To buy?
uncontrolled reving
B16 acting slow..
B16 acting slow..
horsepower definition?????
New to hondas need help please
ls hatch
holy shIIIt?
COST$... H22 swap vs vtec head swap
help plz! my clutch??
Help ! My clutch? help fast plz....
5th gen zc?
JDM new and used parts
Piston/rod questions
Fuel Injectors...
Resetting ecu worth anything
Tornado: Waste or Must Have?
HIgher RPMS
turbo dx or ls motor
I just don't get these low horsepower ratings...
B16a1 times
Terminology
1.8 I/H/E versus 2.2 I/H/E
B18C Oil Cooler on a B20
88-91 civic parts...stuff must go
accel plug wires on zc
What can i do
Please Help, I don't wanna walk
Rebuilding Wrecked Cars...
H22 or B18C5?
MST research project
N/A xperts...help
Problem Help Please!!!!!!!!!!
boost the zc or b16 or ?....please reply
gas gauge light?
Will d16y7 block work?
D16Z6 in 93 Civic EX question
rotten egg smell
Jerking from my Toyota
Big CAMS
fog lamps on 2003 honda accord
Crank Pulley questions
ZC into 89' LS
Help! loud screeching sound that stops when I disconnect the battery
GSR ECU or H22 ECU?
Put EX tranny into a DX any wiring needed
Dealer engine swap?
Need info on OBD II Codes
2002 SI exhaust
help me out plz
1 pulse or 2 pulse
Exhaust
ls header fit b16a?
90 Honda Civic Electrical Problem
porting
Turbo & Tranny II
DIY Cam Timing Adjustment
AEM Pulleys=Upgrade Alternator?
how to build lsvtec?????????
Del Sol owner looking for B16 engine
SiR2 Block From Japan w/ Internals...
alternator belt for b20vtec in EG
Gibson Exhaust for chevy blazer? good/bad?
Please Help!!!!!
F20A Motor Swap
DONT BUY FROM THIS GUY!! admins please make a sticky of this
How fast will i be w/ a B16A w/LSD in a 93' hatch.
99 Si
cheap mods!!!!!!!!
What does the distributer do?
Building a H23a Engine
Help on project... (Turbocharging)
What grade fuel do you use?
GReddy Profec-B VS. GReddy Profec-B Spec II
Mustangs smoking me.......Help!
Exhaust Theory
messed up gearbox
remote starter
Engine Cranks Longer When Cold
Surging idle after motor swap?
Transmission leaking
Knock/Ping?
Ls B20
Best Head Gasket
how to take out my power steering??
My guess
ZC engine bogging
air\fuel problem
What Mods should be done to a F22a SOHC to boost HP's etc.
skunk2 SFC or Apexi VAFC
n00b question- 2002 Civic head light question.
What happens after 100K?
92 Integra JDM 1 piece headlights ... HELP!!!!
Ground wires kit question
Gauge Wiring problems
bad a/c compressor
Problem: Blown Headgasket
PCV Valve question
crx axle nut removal
I have the same Clank
gtech pro
Newbie to engine mods
noise when i turn
1993 Accord EX H22 or H23
Engine Swap h22 in 99 honda civic
Pcv Valve?
ecu question
b20b non-vtec
GM fuel pressure regulator Q
Question about variable vane turbochargers.
installing clutch without dropping tranny?
92 Prelude F22a what is the HP????
I am new, and I got questions
4-2-1 header in a one piece or two piece?
JDM Type R Integra
Maintenance Light
B16
quick question
What should I expect to run in a LsVtec and a CrVtec both stock and fully built?
dirty oil and emissions
auto tranny question
Tranny question
Speedometer not working.
b18b1 turbo (LS)
JDM OBD-1 B16a head for sale, OBD-1 B16a engine harness for sale, GSR intake manifold
I need a b18C5 for a swap
b18c1 swap in my 93 teg
what type of engine should i choose??????
q's
Where can I find a b20 block from a cr-vtec?
What should I expect to run in a stock ls-vtec? And also a cr-vtec?
h22a swap, emission tests
Honda Acc Fuel Pump
auto to manual mess up
Turbo LS/VTEC.....
COld Air Intake
Found a car to put my motor in, need help
headers
B18c5 versus B18c1
used car/fluid questions
B18B into 93 Civic
1998 S10 Question (electrical)
What's typical compression on GM 3.8L?
warming up my car
gettin ls/vtec got some q's
clutch questions
japanmotorimport.com
I really need help with this grinding sound problem that I can't locate
Hondata and Turbos
HP Without Dyno
Specs
b16a or NOT????
comp cam???
battery seems dead?? help
Very odd engine problem..need help
95 CX HAtch Swap
DIY Exhaust?
bad coil?
Horsepower Question
Tranny Question?
B18c into my EF civic HELP????
AEM V2 intake installation
AEM CAI for Accord 1997
Shame on Mugen!
timing belt help
What b16 Cable tranny has the shortest gear ratios? Where can I find one?
motor swap
Type R
f22a1 swap
f22a1 swap
swaping in to my civic
first car
Big brake/rotor kit install help
General shifting question...
spark plugs
Squeeking noise when I shift in low gears?
engine care
accord engine type
Web
AF
