Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
> Engineering/Technical |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
is this a good price ????
tsudo catback
D16z6 head on Del Sol 1.5 block
h22 swap
Cheap h22
b18/b20 setups
Weatherstripping removal help needed...
Noob Question on ODM
jdm or usdm h22, help!!!!!!!!
stock fuel presure b16a1?
chipping ecu's
h22 engine swap
dodge rampage
painting
Vtec not working and some other things, someone help!
Litres to Horse Power conversion?
89 hatch, need help wiring mpfi in to hf
ls vtec question.
how do i make a signiture
looking for help
j-spec h22a into a 94 teg
Stripped Bolt on Valve Cover
crx b18 swap
horsepower questions
b16a g1 (SiR) swap
ecu question HELP!!!
Where can I find a Euro Type R H22A engine for 92 Accord
possible help or opnions
ecu question
Apexi Vafc 2 tuning
more precise shifting
H22 into 90 accord
looking for advice
remote starter
h22a in a 89 civic si?
Painting Q's
what do u think?
weber carb
what's the biggest motor and trans swap for a 89 civic si?
new taillights
grinding noise while driving
ITR / CTR cams
exhaust system for '88-'91 crx
B20 / B-series tranny
newbie 94 civic electrical problem?
Gasoline Diesel
Valve Covers
tranny
existing exhaust?
civic light
strobes...
running rich
I need some INFO!!
110 octane in a car
Stock Valve Springs?
Charcoal cannister.. emissions control question.
How much money do i need?
B16a2, B16b or H22
automatic shifting question
suicide doors
mufflers:which is better!? please help
Has anyone done a Distributorless Ignition Conversion on a B-series Engine?
engine died while driving
air conditioning question
apexi gt spec
NEED Advice on engine choice
Stratus R/T Keyless entry programing
Can someone explain the difference...
East Coast Distributers
Obd2 B16a2 Engine!!!!!!
What's better, sports shift or manual?
Engine Swap
newbie motor question
failed emissions help
D15b Vti Swap
b22a1 in a civic
Topic: Where to buy cheap but quality power inverter?
B16,18 & H22 ITB's on sale
Throttle Problems
H22 Motor...H23 (p14) ECU...will it run?
need help replacing stock w/ coilovers
Clutch problem with '03 Accord 6MT - HELP!
wanted: integra gear knob
how do you know when you re clutch is going?
What is a spoon engine
Nsx
weight vs. hp
Engine swap
Pontiac hestitation & rough accel.
Please help ASAP... very odd problem w/'98 Civic!!!!
clutch adjustment - 96 integra
deep sounding exhaust
Integra Type R ecu on a B16a.
Trying to find drain plug!
Remote start installation on a manual
de-immobilise 02 honda accord for remote start
95 Avenger Help
rotors on 2002 civic
Will a Chevy 350 fit in my civic?
wat are my options?
WHats up with the redline on the skyline?
Help on parts
ECU how much $$ and where to buy?
Overheating after block seal
synthetic oil poll
imports?
Some help on low budget mods.
license plate lights
Weight Savings
V-spec h22 vs Jdm h22 type s
Grinding Noise
V-tec not so high tec
Engine running really rich.
2 step rev-limiter
project sol
ls/vtec
top speed and integra questions
b16a2
ECU question
Good place to buy a JDM D16 motor??
alteration
Fool a OBD11 accord ecu into thinkn rear O2 is ok?
Can someone please tell me what "compression ratio" is?
motor mounts: street, street/race, race??
96-98 Mugen Civic Lip Pictures..
high compression & pump gas
b18c
Convert to power windows
auto tranny lock-out???
b20/vtec reving problems pr3 ecu
How LSD and Positraction works??
b16a PROBLEMS!!!! HELP ASAP
fault codes Acura 3.0 1998?
how much would u guys pay
o2 sensor
Intake Manifold PROBLEMZ PLZ HELP!!
this freaked me out
Attention wiring help for iacv.
CEL error codes.
99 Acc. Steering wheel shake during braking
Jdm Motors!!!!!!!!!!
Rotary engines
What exactly is torque?
can the b18b gimmie wat im lookin for
vtec controller
Sumone PLease Answer....
Tenzo R Muffler??
JDM question...
injectors not working
any luck
ls/vtec
jerky taurus
Becoming an Auto Mechanic, how? what to do?
prolly a stupid question
Automotive Books
where do i get a type R motor?
Can spark still jump across an open wire???
2wire vs 3 wire help!!
Integra Cluster In Civic?????
Catalytic Converters?
B20 motor
B18B and cable tranny???
GSR swap help Please
Turbocharger and engine swap question...
How to clean off engine?
H22A Swap
CRV-Tec
engine question
jun 2 cams
Intake Manifold Swap Question
Brake Grinding....
B20 Swap Help
JDM B16A 2nd gen cams vs GSR cams
water logged lights
Best Swap?
whats it worth?
$'s the issue
HKS vs APEXi
Port size
Cooling system desperation!
damn you honda
whats the diff
Rough Idle HELP
oil question?
An idea?
throttle bodies
which h22 do we have here????
rebuilt head... now rod bearing and oil ring shot... why?
Rear road noise
Help With reseting Used emanage
CRVTEC base map
Whining noise when in reverse.
what would be a good engine swap 4 a 90 teg
Ecu
Angle Mounted Cat-back Exhausts
Questions for the knowledgable: Type R Integra
can you identify this distributor
B18C5 swap
K20a swap into 5th Gen. Hatch 92-95
Reflective Tint??
What is the best engine to put into a 97 civic LX?
Engine does not start
H22 Transmissions
h22 mounts
beef up the current motor or swap?
gauge repair
b16a lsd vs b16a non lsd
no oil pressure to 70psi.?
Cold Air Intake Question
exhaust pop...
EX vs Si Civic
CAI/Header Problem
D series Transmissions
f20c
99 Accord,synth oil->engine making ringing sound
sohc vtec...??
Fuel Filter
94 delSol S with SOHC Non-Vtech. Mods?
obd1 obd2
Honda Inspire?
Is an LS swap not worth doing?
Tdc
Alignment question
Catalytic Converter
S2000 W/ Turbo
91 CRX HF Axles for B16A swap
Engine swap cost!???
Brake system replacement help
Help with gauge cluster
maintenance weekend project, need ideas.
2002 Honda Accord reverse gauges installation
Clearing out the headlights on my 2002 Accord
rear motor mount brackets
Alcohol injection?
Help ! Because of this I cant even drive to college !
new kid on the block needs help!!
turbo
Stock motors
s2000??
EGR Valve & Port Cleaning Question...
B20 Vs. H22 Which Swap Is Better????
Rover V8 gearbox combos?
Does size matter?
Gsr Head Gasket
creating muffler fireballs
Intake mani question
have ls/vtec but rpms seem to rise slow
Engine Codes...
Need some help in comparing Belt Tensioners
Web
AF
