View Full Version : Engineering/Technical
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
  1. ticking noise b/t head and manifold
  2. b16a need help
  3. Oil leaks on a B18A & B16A
  4. Can't get those head lights to close...
  5. 5Zigen Borderslash axleback
  6. My Integra XSi
  7. Ffasssttt Integra Ls
  8. IS a turbo worth it??
  9. v8 in civic???!!!
  10. b16 parts?
  11. I ran over something and it tore my gas tank open..
  12. where to go??
  13. What Next
  14. Manual Tansmission Conversion
  15. dohc zc head/d16 block
  16. Whats a sleeve
  17. i need help quck im desperate
  18. Coolant leak
  19. J-spec H22A in a Civic
  20. b16 coolant problem
  21. Exhaust system vs. Exhaust tip
  22. cam gears
  23. 03 F-350 Super Duty Deisel
  24. What happens when your CAI sucks up water???
  25. newbie vtec help
  26. iNSXtegra
  27. motor trade
  28. Gains from cam sprockets?
  29. Rebuild 302 Windsor
  30. Headers
  31. engine swap
  32. Clutchity clutch clutch
  33. Help!! Need parts!!
  34. what are the best exhaust system?
  35. P N R D 2 1 <-shifting for speed
  36. Solid axle rear coil over suspension help?
  37. I'm beginning the process...
  38. Tranny Troubles Need some Technical Expertise
  39. Problem starting my 91 honda civic
  40. wiring headache
  41. Vtec indicator light problem
  42. 90-93 Accord Swap
  43. testing the DPS unit from K&G
  44. I Need Some Good WEBSITES FOR ENGINES!
  45. Bed painting
  46. swap making rattling sound
  47. 87 or 93?
  48. 1 thread...2 questions
  49. s2000 upgrades
  50. tap tap taparoo
  51. Aftermarket Header Install on 2000 Prelude VTEC
  52. power window crap
  53. Quarter Mile
  54. B16A ==> B18A Wire Harness
  55. my vtec is very loud why
  56. engine swap
  57. part question
  58. Blown motor 91 accord
  59. can a car keep running with no battery?
  60. Concern About Main Bearing Journals (On The Block Side)
  61. Internals or Turbo 1st??
  62. What is an ECU??
  63. Custom Turbo For H22a Vtec
  64. '99 acura 3.2TL: FUSE OUT or st else?
  65. Tranny problems?
  66. one time use head bolts
  67. B18C1 swap i need price info!
  68. Good price to yank out your engine.
  69. Power Steering
  70. Maintain vehicle in North USA w/sand HOW ??
  71. 94 civic for 7000$ is it worth it? need OPINIONS!
  72. chevy 305 heads
  73. Port and Polish?
  74. Help, I killed it!
  75. cheap b18c5
  76. When Would My 95' Civic Vtec Engine Kick In?
  77. 2003 Civic SI interior hatch assembly
  78. Hydraulics to the Flywheel: Clutch Operation Explained
  79. engine swap
  80. Starting a 6 Month Dormant 924
  81. Will an H22 engine fit in a 92 teg!?!
  82. radar jammers
  83. Motor Swap Help Please!!!!
  84. Wet Sleeves vs Dry Sleeves
  85. Exhaust for 95 integra rs
  86. 1998 Lumina LTZ - 3800 engine
  87. For all you LS/VETC guys
  88. H23 engine parts
  89. carburetor problems...
  90. ls/vtec swap
  91. Engine swap on Mustang
  92. JDM Headlights for sale
  93. new ls swap!!!!!!!
  94. Steering problems
  95. Nissan Primera GX 2.0 TD - stalling problem
  96. Difference between B16A1 and B16A2
  97. Increasing underbody downforce
  98. Lightweight steel cars?
  99. rebuilding d16y8?
  100. Engine swap part replacments...
  101. Lsvtec?!?!
  102. Why would a wheel wobble??
  103. Why is it so hard to SHIFT GEARS?
  104. Need technical explanation of Valve Float
  105. OBD II Scanner purchase help
  106. i want to knoe
  107. Good move or not? y8 head on z6 block?
  108. Confusing question
  109. JDM Prelude Tranny
  110. JDM H22A into 98 Prelude SH....
  111. JDM Tranny Codes
  112. transporting old motor/tranny
  113. which cams should i get
  114. Cold Air Intake Installation..."mounting brackets"?
  115. Need speed sensor for 98 civic ex
  116. how to remove the valve cover ?
  117. Parts needed for...
  118. jdm cr-x front conversion
  119. Engine HELP
  120. boosting ls/vtec
  121. 89 Honda Civic Hatchback
  122. Type-R Head Swap
  123. intake swapping.
  124. Motor swap info
  125. DX to MPFI swap with AC
  126. honda car codes
  127. oil Burn in Vtec
  128. com. chips
  129. HELP! Lost on engine swap
  130. Head Gasket took a shit???
  131. What HP should this run?
  132. Fuel Question (Octane)
  133. 86 legend questions (engine, etc.)
  134. Headlight bulbs
  135. sport shifter in a civic auto?
  136. power steering cap? how to open?
  137. Suspension Series 101: Tire Basics by Dezoris
  138. Radio code?
  139. How Do I start a Shop, Piece by Piece
  140. JDM Honda Prelude
  141. Battery Help Please!
  142. replacing the IAC
  143. diagram of a car and how it works
  144. my 93 Civic Lx is DEAD!! HELP ME
  145. new pipes?
  146. Shift Knob Question
  147. Is this normal ??
  148. Speedometer stopped working
  149. [95 Accord VTeC] Engine turns over, butdoesn't start
  150. Remote Start Flashing LED's
  151. Coolant Problem.. Pls help
  152. B16a alternator??
  153. 95 and everything dies
  154. how to turn 10,000 plus rpms??????
  155. Lookin For Power in a GS-R
  156. Putting a fuel rail for a 94 gsr on a 91 rs integra
  157. stock fenders
  158. Sunroof stopped working
  159. OHV vs. OHC
  160. Muffler sound
  161. Selecting A Turbo For Your Car
  162. type r pistons on gsr
  163. H22 in a Del Sol
  164. direct parts from Japan
  165. ? about Idle
  166. What else do I need?
  167. Throttle Body spacer question
  168. trust or spoon exhaust?????
  169. Engine Swap
  170. Want to swap engine in my 84 Civic!
  171. Accord swap with a 3S-GTE
  172. synthetic oil
  173. Peugeot 406
  174. Air intake
  175. gutting out crx???
  176. turbo question!!!!!
  177. interior names?
  178. interior kits
  179. Indiglo Gauges
  180. Engine swap for an Accord
  181. DPS concern/question
  182. Motor Swap
  183. Lube control / Fuel Power
  184. anyone got an ls motor hatch/coupe
  185. spray it!?
  186. Injector ID on CRX
  187. h22a into civic??
  188. What is synthetic
  189. B18c4???
  190. questions...
  191. GM 305 Swap
  192. Battery Short (Internal)
  193. turbo idle
  194. help: Gearbox and Engine
  195. compression test
  196. help with 91 integra ls
  197. could a Y engine ever be produced?
  198. BuLbZ!!
  199. fuse box info
  200. any benefits to an auto civic
  201. Turbo: Vtec or no Vtec
  202. Suspension
  203. frankenstine swap!!! help!!
  204. remote starter
  205. puddle on floorboard!!!
  206. ctr cams in 99 gsr
  207. V8 Honda Civic
  208. 4G63 GSX Engine in an Integra
  209. transmission probelms
  210. What head can I use on a B18A1?
  211. h22a v. B18c1!! Help!!
  212. Fast Idle Honda Accord LX
  213. Double Clutch..
  214. what do I need
  215. Shaving side moldings-fiberglass?
  216. Vin Number
  217. gasoline compression ignition?
  218. Thrust powerd car; can it be done??
  219. engine specs
  220. Nissan Silvia (S13) VS Skyline GTS (R32)
  221. Performance Exhausts- Do they get louder over time? PLEASE ANSWER
  222. Quick Muffler Question
  223. loud ticking noise
  224. throttle body question
  225. P1607 - Internal PCM Failure - what is the cause
  226. Lube control / Fuel Power
  227. dx head hf bottom????
  228. Cosmo Racing
  229. Engine Upgrades
  230. higher redline?
  231. b16 ecu
  232. B16A tuning question!
  233. Do I need to get a new ECU
  234. hot spots, what are they
  235. need help shift linkage
  236. ECU Location/Install
  237. is this a good deal??
  238. is this a good price ????
  239. tsudo catback
  240. D16z6 head on Del Sol 1.5 block
  241. h22 swap
  242. Cheap h22
  243. b18/b20 setups
  244. Weatherstripping removal help needed...
  245. Noob Question on ODM
  246. jdm or usdm h22, help!!!!!!!!
  247. stock fuel presure b16a1?
  248. chipping ecu's
  249. h22 engine swap
  250. dodge rampage
