Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
> Engineering/Technical |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
D15B Timing
vw solid rear suspension????
exhaust question
wierd racing question please answer
autocross
import tech coilovers?
what does "seasoned block" mean?
alarm keeps messing up!!please help!car cant start!
removing the rev limit
AEM intakes vs.. Intercooler...
92 1.6 GSR motor?
Help with Exhaust choice
Tachometer installation help
how to tell year of tranny for dohc zc?
does this sound good....
b18a1 with b16a head or b18c5
b18 motor for sale
B18c5
Need some help w VAFC-II
Hatch versus Coupe Cat Back Exhausts
Just a quiz question that not many people know...
b18a1 vs b18b1
B18A1 Components
5speed vs 6speed
mugen chip
BOMZ mufflers and Spoilers
B20 progress
How hard to install new brake lines?
windshield wipers going crazy
eBay Header/Intake/Exhaust
93 Prelude H22 into a 92 Civic LX
Rocket boosters
Help Need A Part!!
Brake Booster
bosch KE Jetronic pressure actuator
Small Question
Question on 93 Accord...Adding Hp
Best brake rotor design?
92 Integra GS Engine Swap
Blew up b16 w/50 shot...getting LS long block
Questions for 90 crx Si
92-95 civic jdm front fenders
Will ECU work
going the other way 93 prelude
Rotory engine efficiency
Properly using nitrous
B18C1 to what???? Have a 97 GSr, ready to upgrade to ???
Oil & Gas, whats the real truth
APC Mufflers
HELP !! Hard start with 89 Camry - Only when COLD !!
How tell a JDM H22 or USDM H22
93 accord cruise control problem with H22 swap
Heads
toyota 3s-gte into a 96 honda civic ex
intake manifold
6th Gen Cat?
2001 Honda Civic Idle Adjust?
Clutch Problem
Engine seized
b20b or b18b
B20 in a few minutes! a few ?'s tho.
Noisy D16Y7
code ques.? 23?
89 prelude h22 swap?
Rear disk brakes 88 legend
Jdm Motors With 30 Day Warranty.
V10's?
Speed Sensor Removal on 1999 Mercury Sable
short shifters
Car Is Dead Please help me revive it someone please!
emissions dilemma
What U guys think about this?
OEM style
prelude swapped
Bore/Stroke question
air suspension
K24 Block K20 Head
Turbocharged b16 engine
B16A2 in crx hf
USDM B16A2(99-00)SI in 91 CRX Hf Question
B16a Shirts
Zdyne Software
open headers
Dry Sump Oil System
Which spark plugs for mini-me?
Where can I find a b16 engine for my '93 civic hatchback?
Motor swap questions...
b16a --> b18c1
Project Car: 1986 Toyota MR2
gas mileage
Annoyed
eek!!! help me
Honda swap with mitsubishi..?
How can i make my CRX faster and faster..
New to site Need to know about B18C1
The Ideal Engine
Engine sizes
want to swap d16 to b16a2
motor swap
extra hose in throttle body
how much work for a b-series into a 7th gen civic?
h22a4 OBD2 into 88 Prelude OBD0
Wiring Diagrams for JDM H22 OBD1 Distributor???
H22 Need Help With Jdm Distributor
An explanation of "JDM" for newcomers
front clip swap
Broken Clutch
eclipse air intake installation
Removing stock fenders (2000 civic si)
My B16 not running so good
Any DIY power up for a toyota 3a/-c engine
Engine swap: H23A VTEC
Different Engine Design Attributes
B16a Crx misfire popping weird?
Radio does not work after intalling new battery... (Passlock/VATS)?
Radar Detectors
Mandrel Bent vs Crush Bent
Clutch & Flywheel, which brand is the best.
Alternator Repair
Prelude H/E/I
LS?VTEC project idea
is catback worth it??
Dark sticky crap on the inside of my wheel... wtf
85 firebird with v6, and install a 350 small block
tranny
b16b or gsr???
h22 civic swap
Mini me compression ratio
EGT Probe/Gauge ?
head bolts--95,2.4L Tacoma
smoke from grill
Rsx
Technicians
help with b16 swap need parts and help
H23 with H22 head
vtec not working on b18c swap
b16 crx running like crap
How would you spend $5000 on a 1998 V6 Accord?
rpm on honda civic
d15b vtec problem & idle problem
Type R into EF (90 civic SI HB) QUestions
what's a good price?
distributer problems
rear windshield bulged, crumpled & died
stinky air conditioner/fan
hp question
what does compression ratio mean?
messed up on header install, help!
piggy-back system
Civic overheated...
machine shops?????????
NEW- Haynes Extreme Manuals?
Short Shifter and a swap question.
New computer for 92 teg?
b18b1
I need to know the location of IAT on 98 neon
Help!!!
installing exhaust
94 Accord stalls after highway drive
Gas line anti-Freeze?
what is a good engine to get for a 92-95 civic
engine help
Temperature gauge
15000 rpm american V8!
Cold start trouble
What the HELL is a B21
5 Angles Valve Job
my vtec doesent work =(
what kind or msd do i get????
good price on engine w/ tranny??
Need info on B16 motor swap
B18B1 into 96 EK
The little things needed for a swap
High revving B16B
i need a custom pully!!
timing belt, oem or greddy
Turbo B18B1 or All Motor B16A
b16a swap passing smog
B16 motors
Bad Vibrations
need help on install for b16b for 1995 civic hatchback
Jumping cars with differing #s of cylinders?
gains w/cam
b16a distributor sub assembly
Blown Head Gasket???
Help me paint my car
b18c civic 98 swap?
what are the benefits of as body kit
help with headers and exhaust
HELP!! Which exhaust to buy for a present!!
b18c good deal?
how do i fixed curbed rims
Need more Speed, B18B1 Powered 95 Civic ex
New 5' Apc Tachometer...need Help Installing
Lenses for lights
Easy HP?
need more rear brake bias.
Adjustable Clutch
How the Hell does Sponsoring Work?
Lifter problems
Vtec head on B18b
Hot To?
Honda/Acura HP vs Torque
head
96 Accord Tranny problem
93 civic dx tranny??
2000 jimmy wont reprogram
Installing a grounding kit
extending o2 sensors
2stroke/4stroke hybrid
Piston Rings?? HELP!!!
i'm looking for a stock hood for a del sol
blown head gasket
Who makes the worst Car
schizophrenic automatic transmission
FS: P72 ecu, and P73 Intake manifold COMPLETE!~
Amber or Clear?
289W & 302W Rods
any one know any thing about motor swaps?
Someone please explain downshifting for acceleration to me!!
warming up a cold engine
need trans gsr typeR
Need tranny for my b16a...
exhaust systems
How Much Power With These Mods
1993 Lude Si 2.3L engine rebuild - 130K
automatic LS/v-tec questions
Apex-i N1 exhaust on d16y8...
civic hx (what motor swap)
welding.....
Could someone offer some advice to a certified car-idiot like me?
Electrical system problems??
short ram or cold air
Strange Question....
b18 swap into an 88-91 crx and the difficulties
Which Head?
An 100mpg car
auto trans won't shift up
Oils, Mobile 1 Amsoil and the Others
Fishcat is a faaaaag
chevy LT1 350 ,carbable?
Lower end work while the head is off?
civic radiator fit on integra?
Advice on low mileage driving with new car - remote starter, oil changes, etc.
water on engine from vented hood
G-Tech Pro Performance Meter
Which Head?
A Bad Tranny??
rusty exhaust bolts
Web
AF
