Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
> Engineering/Technical |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
Gauge install. NEED HELP!!!
air conditioning
Need Help With Swap Fast.....!!!!!
Blown Second Gear?!
Engine rebuild kit???
:: Problem, Any Help Appriciated ::
:: Problem, Any help Appriciated ::
double wishbone vs. struts
Dyno
Pushrod vs. SOHC vs. DOHC
Blew motor, starting mini me!!!
head unit+receiver
Anyone here an actual Honda tech? 1.5 carb problem I need help with
Engine will not start
When to use high octane gas
Few questions before swapping engines!?
18,000 mile oil change
Need Heater Help
v6 vs. v8
Which Helms manual?
oil on spark plugs
Rear Wheel Drive Conversion
Maintance Required light blinking to much
How Screwed Am I?
Your theories
ECU swapping for Performance
Engine Fire
need help
speedo works when it wants???????? plz help!!!
:dunno: Is my clutch going?
best engine build for boost
Bad News....
weight between Stock Engine and JDM B16A SIRII
Flamethrower Kit ?'s
In need of opinions!
pulling out and dropping in engine???
Idle Problems on 99 GMC 4.8L V8
88 Integra Coolant temp Sensor
a question for the wiring experts...
B18c with type r head?
valve seal problem
Ford Tempo Problems
Micro polish crank
looking for salvaged honda frame and body
PocketPC OBD Scanner
engine pictures
Need Help!!!
quick question
need help in understanding english!!!!!!!!!
question re fluid pressures and flow rates...
Would this car run 12s or high 11's?
Ek H22 swap help
b16a vs ls
Help with a B18A component!
Help with gettin power to car
Which engine ??
Whats going on with my shifting?
Where can i find a helms?
how to run a itb setup?
Need some part help ASAP!!!!!
manual ECU convert
My civic is having issues, please help!
fuel pressure adaptor
I Need Help picking out a car
running lower oil temps?
Can anyone identify this tool?
Possessed SUV Wiring?
PLease..Help a girl out! Desperate!
What oil should i use???
jdm d15
B16A1 vs. B18C1
Any Tips On The Zc Swap for 88-91 Civics?
ECU conversion
Where Can I Find.....
Spark problems!
autozone's free diagnostic service
power to wieght ratio
my 350 keeps dying
Making My Motor Into Type R?
turbocharged JDM b16a
rebuilt engine costs
ls tranny or Crx si tranny??
Rebuilt Engine vs. Custom Engine
Dazed And Confused
2.4+ liter B-series motor
Skunk2 Vs. Toda Cams?
V2 intake good?
catastrophic intermed. shaft failure-why?
98-02 accord 4cylinder vtec question!!!
flywheel ?s
removing the rear seats in honda civic 97
Battery Replacement
aftermarket parts and an h22a
Valves springs and retainers.
jdm single cam vtec????
ls/vtec vs b16b
Simple mechanical question
type r engine swap
Oil pump replacement
Engine problem! Help please!
low 11's
Still can hear the Vtec,no power lose.but not as lord as be4...
b16 head on a d15 block
how do i dismantl a 92-95 civic ex dashboard?
About H22
Help. Strange problem.
chose engine oil ~?
transmission problem
where do u get high octane gas?
KYB AGX shock settings????
New Greddy Titanium Exhuast
octane boost?
EGR Valve Help!
TB and throttle question
what's the difference between catback and dual exhaust?
CV boot and Axle replacement help
DOHC Zc Internals..Help!!
distributor cap direction
need part number ?
What exactly is horsepower?
88 Accord Wont Start Cold
Tuned Up - Now Problems - HELP!!!
d15b/vtec and dx
volkswagen gti motor swap
didn't know where else to post this
problem
a couple inquiries
2002 Tahoe Fuel Pump Problem
Igniton timing mystery
B18b1/vtec Vs B20/vtec
Big problem please HELP asap!!!
92 civic si w/B18B1 motor swap help
Increasing bore and stroke
Exhaust Question
help dx to si problems revs bounce at idle
questions about an f20b
difference between si and can. sir
Hp deterioration ?
what do you think....liar?
question about a turbo f22
front crank oil seal compose of?
Front crank oil seal removal.
is it possible to put a spoon chip on a odbII?
Why doesn't my remote start work properly?
Need Help..Poked hole In Gas Tank..
Installed short shifter...problems!
frankeinstien lsvtec
Spoon exaust...is it as good as everyone says
2001 celica gts V.S. 1999 integra gsr
auto to manual wont start
help with remote sensor
resleeve vs. block guards
R.o.n.
Voltage surges
b20 with type R head question
mufflers??
catalytic converters
Engine Angle
Need Radio code for 03 civic?????
How do I remove/replace the passenger headlight for my 91 integra?
How do I replace the headlight for my 91 Integra?
What's going on with GM's 3800 ??
where to buy built engines
????transmission??????
Engines
possible motor swap in my civic suggestions?
Exhaust system, strange things?
hydraulic clutch in a civic w/JDM B16
strut bars?
How do I set Top Dead Center (TDC)?
need to know if trans will work
$1,000 to spend on parts, what to buy...
tuning d16 pointless?
Gsr question
LS/v-tec help needed!!
tranny swap
stock 94 honda civic hatchback.
I need more consistant voltage
SOHC ZC Compression
SOHC ZC Compression
Raw gas exiting through exhaust? What the hell!
dash illumination lights
Head Gasket
F22 parts will fit F20a?
Prelude Turbo
Need help with head swap!!!
B20 Honda CR-V
how do you fix a 1991 honda accord's transmition?
Transmission Slippage
b18 injectors in a zc?
A 1st gen b16a problem that will make you go nuts!!
popping noise from power window?
Is there a website????
more hp, more mpg?
b18 question
crank sensor??
Head swap on a F20A
91 accord heater problems
HELP my '94 civic wont START. Its not the fuses or the starter.
D15B7 Upgrades.....
B16a speed sensor for SiR cluster?
"Tak Tak Tak Tak" sound on morning start
SOHC ZC/VTEC and NOS
rim polishing
Can someone help me out please?
B18C5, really worth it?
HELP! Got new clutch installed and SMELLS! also a clutch technique ive never heard!
Repair your own STARTER
trans axle? stupid ques.
Rebuild your own alternator
Valves Making Noise
Engine swap gone bad HELP!!!!!!!!!!!!
field sfc-d (not vtec)
B20 complete
Wrong fluid in wrong place... help
suspension mods for b18c5?
please help with speed sensor on b16 swap
For Sale AEM Tru Power Pulleys 94+ GSR
how do i install a flowmaster
brake replacement
What would be more Expensive...???
D15b/vtec
all i need: 1/4" snow & an e-brake
Remus Exhausts
Another Ebay Item...
H22a LSD Transmission
aluminum blocks
'88 Civic runs great for 30-50 minutes, then hesitates and stalls...
What's wrong w/ my car?
help slamin D15b in 89 hatch
High Compression SOHC CRX
LS/Vtec
converting ECU
SRR cam gears any good ?
Obd2 to Obd1 Converters
D15B Timing
vw solid rear suspension????
exhaust question
wierd racing question please answer
autocross
import tech coilovers?
what does "seasoned block" mean?
alarm keeps messing up!!please help!car cant start!
removing the rev limit
AEM intakes vs.. Intercooler...
92 1.6 GSR motor?
Help with Exhaust choice
Tachometer installation help
how to tell year of tranny for dohc zc?
Web
AF
