Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
> Engineering/Technical |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
need help with gauge install
crank pulley???
smoke from valve cover breather
Alternator
cold air intake
Need Help
OXYGEN sensor problems
JDM vs USDM?
New Web-site!!!
Maintenance Service Info
A Few Questions
tranny swap
Possy traction?
polished aluminum
mugen programming a p30 ecu
RPM fluxuation?
car won't start
help on engine?
performance chip, hp and torque
Whats the difference? Please help!!!!
LSD's
Climate Control Help!!
having a clutch problem
Leaking fuel filter
what ecu do i use with this
Drive Shaft Problem
Annoying whine
automatic vs. manual
keyless entry install
which radiator to use for b16a2 swap 92 95 civic
Quarter Mile ?
Where to buy a P30 ecu?
need a service manual
Lsd
drivetrain problem
95 Boniville
Backfiring question
FS JDM bb6 Pistons with snap rings and wrist pin
what is LSD?
Headlights won't come on at start, please help!
Peformance FWD tranny's 5spd/6spd
question about individual throttle body's and spacers????
Braided hoselines
new to the site, quick question
head stud boltss
cheap bolt ons..????
Home made strut bars
Compression Ratios.....
3.1l Engine Swap Questions And Concerns
What can I do to make a 95 ford escort LX faster
Which would work best?
power drop headlights, dash lights, AC/heater..
PIAA H3 and H4 Bulbs... Are they universal?
power drop to headlights, A/C, dashlights...
3000gt in talon
Cylinder Compression Test Results....need some help
Absolute throttle @ 78%
tranny swap
suspension opinions, semi trailing arms..
squeaking brakes after driving hard.....
Charcol Engine
an idea
Fuel Injector upgrades, life expectancy
Special edition Problem
Need help with exhaust system
Stering conversion LHD to RHD
ebay
Axels?... How much HP
Weight is Time
flywheel
wut does N\A stand for?
Prostart CT-3300 Install problems
heh...
A real jdm ECU
Turn signals/Directionals not working correctly
I'm a little disappointed
New Website!!!
New Website!!!
Lsd ????
Need help with my 280zx
Is my tansmission/clutch going.....the car revs by itself
sell the car with turbo or not?
VIN on engine also?????
Cranks but wont start
reliability
The Lego effect
HELP! Where can I get top fuel stuff from japan?
Plz help, I think I blew my clutch
which head gasket to buy?
77 golf beginning to worry me
targa top
Newbie needs help
Rolling Chassis where do i find them
buying pre-swapped car...Good or bad?
Fuel Rail...
??? Light weight parts lose torque ???
intake manifold gasket - Gasket Goo?
Battery Quirks
EGR valves
98 pistons in a 90?
Swaping Engine in a 93 ford escort...
Switching power
Engine 'convulsing' below 1k RPM
Laptop/PDA in car Dyno, Diagnostic programs
are there free automotive manuals out there?
need transmission answers
Possibly pulling teeth off belt?
Do injectors go bad overnight?
Transmission problem
92 nissan sunny
confusion
Could high Octane fuel like 101 cure no NOx problems ?
Sacrificial Magnesium??
cause of old gasoline?
greddy emange
whatsupwiththis?
what will happen if i cut off my muffler?
Please help! Troubleshoot my prob...
If engines are equally rated, then what?
what do u need to mod a d16 JDM engine??
advancing ignition timing
Gauges
how would you suggest i remove my speakers on a 97 civic
Best Sounding Exhausts
help changine engines
Decreased gas mileage with new exhaust...help
imports suck
NE Body know a good site about...
Exhaust, Headers T304 Stainless Steal Question
Rust resistance?
FWD toyota vvt-i 4 bangers
Right hand drive conversion in a civic hatchback
clutch flywheel compatibility
P28 or P72 chipped for jdm gsr??
cold air intake
Positronic Transmission...
replacement parts?
diesels on vegetable oil
Mazda B3000 engine swap
Battery Backwards. Any Ideas?
whats a code 23 or is it 10 and 13 code??
Brake Reface
dohc zc ?'s
Screaming Distributor
Leaking gasoling out manifold?
engine swap
Importing an EG6 SiR-II
lower compression ratio
Intercooler Question?
Improving Speed on a Four-Cylinder Engine
"Check engine" light reset
hydrolics
Gm Window Crank Regulators
Show or Go?
identifying CTR cams
Funny smell
91 Excel Speedometer problem-please help!
power braking for more then 5 seconds
Car won't start - below freezing temperatures
Block heater cords.
Block heaters and other options for a cold winter.
what problems come with Ls V-tech
BIG problem.. need help
Adjustable Cam gears
If you're a girl, don't take your car to a shop if it's broke
Automatic Doors
EECS Incorrect Purge Flow?
Supplying Oxygen to Air Intake System
cold weather problem?
i need opions
Best Performance Meter
speedo problems need advice
Dry Sump oil system
Stock Exhaust
timming question
Check this out...
any monte carlo boys out there
weird problem
swapping
starting problems
Head Work
fuel injector's will it work???help??
I Need Help With Compression Ratios
good idea?
the dumb kid with the closed deck
Thermostat
tranny with lsd question.
Playing wiht the computer
Slotted Rotors VS. Drilled Slotted Rotors
Battery, alternator or other?
A Contraversial Issue!
Need some advice
twin turbo bseries
help finding alternator
Thermal effiency
Car servicing intervals
Engine Hoists
Could Direct prot fuel injection cure knocking?
Motor swapping help
92 BMW Computer chip
improving 0-30mph
JDM Valve colors??
Where to buy engines?
My Assignment
starting problem???
on a budget so wondering if...
fuel injector problems?
How much
Installing new headunit and 6x9s
Need help wiring pwr wndws to work in both directions.
Please help, car won't start and wife is mad at me!
pontiac stereo
serious problem
I think I found a cheaper alternative to my dream engine...
Car wont start.
Weber 32/36 DGEV tuning for 1.5 ltr
Cheap Speed?
I want louder exhaust
Obd2 Car W/ Obd1 Engine
Question about FI versus Carbs?
Misbehaving Horn
Having problems starting car after swap
need help on my mini-stock engine please
How Do I incorporate gen3 rx7 motor in my truck
I need help with purchasing new rims.
engine runon
What mods do i get?
Tranny Problem
Customizing my interior...
Tachometer light
Window went down and I can't get it back up
tuning/reseting ECU after mods?
Valve adjustment & Timing Belt
swapping questions
where to have dyno done?
Arospeed, any good?
anybody know where to get engine mount hex bolts for a 289!?
Beat by an Iroc-z cant let that happen need help!!!
Auto to Standard Trans switch?
sites for buying engines?
swapping questions
swapping problems
What determines the limit of cylinder pressure?
Code Check Connector
Gauge install. NEED HELP!!!
air conditioning
Need Help With Swap Fast.....!!!!!
Blown Second Gear?!
Web
AF
