View Full Version : Engineering/Technical
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
  1. Need Help!
  2. Need Help....< Newbie...
  3. quade throttle bodies ?? whats up with that
  4. Volvo 440 overheating HELP Please
  5. I have some weird questions about cars...
  6. front mount cold air intake?
  7. Limited slip???
  8. sport compact pro
  9. Whistling sound
  10. mixture problem
  11. V6ers
  12. disabling a hotwired vehicle
  13. $1,000 To Spend Help Me Do It
  14. Building a Motor Need Help.
  15. Removing Exhaust
  16. shortening a chassis?
  17. Newbie ! also seeking tranny part
  18. Gas Question
  19. Break Pads Help
  20. Programmable ECUs.....
  21. Na - Turbo - super charge
  22. real defintion of "riding" the clutch
  23. rear bumper?
  24. wheel hop
  25. Jackstands vs. Ramps
  26. High compression pistons...
  27. Fuse Blocks???
  28. Couple of question (ignition/engine)
  29. car will turn over but not start please any suggestions
  30. who has the best intake manifold?
  31. slotted or crossdrilled rotors?
  32. tuning up
  33. School Project
  34. Some advice on a swap
  35. MSD Ignition: A Whole New World?
  36. engine hesitation and weird oil pressure
  37. which came first: the axle or the tranny?
  38. Rotary engine
  39. Engine swap Q
  40. Jdm D15b
  41. Car Shutsdown
  42. fuel system upgrades
  43. rich mixture -> reset ecu?
  44. Clutch question
  45. What do you think?
  46. 4t65e Transmissions Slips after 5 min of runtime
  47. Muffler Question
  48. Transmission additives(slipping under load), share your experiences, please help.
  49. plz help me
  50. crower 404's
  51. ???!!more stock clutch questions!!???
  52. How true is it?
  53. ISC device
  54. gas odor
  55. newbie info
  56. Help Plz.
  57. WTF is going on with the Rotor button?
  58. Turbocharged Engines...
  59. re:6al msd ignition
  60. Ignition Wires....
  61. What is the best motor for my hatchback?
  62. ???!!stock clutch questions!!???
  63. How to warm up your car in the morning less than 30 Seconds!
  64. unstable RPM
  65. replacing instrument gauge lights
  66. Motor diagrams?
  67. Anyone know here to find oem headlight wiring?
  68. stock internals
  69. Starter Problems?
  70. alternative to cams and valves ??
  71. Detonation: The Engine Killer
  72. Is this possible?
  73. Can you put an s8 engine in a VW Golf? plse rspnd
  74. Map sensor CEL with a Jet V-Force PCM (Help)
  75. Spark + Fuel = No Start
  76. Convertible spoiler effect
  77. FWD Posi
  78. 5-20w. oil...You've got to be kidding!!
  79. has anyone bought a jdm motor from ardperformance.com?
  80. Programing Instructions for keyless remote
  81. Ceramic VS Stainless Header
  82. Automatic Transmission Stuck in Third Gear
  83. Do variable venturi carburetors ice-up?
  84. 1995 isuzu rodeo overheating
  85. Tough CEL problem.
  86. Turbo Kit
  87. "Cross breeding" engines - Prsh GT2TT engine in Rnalt Clio v6 - dream or reality?
  88. Break Fluid Leaking?
  89. Emissons legel High Flow Catalytic Converters
  90. Car Trouble
  91. Volvo 850 Remote Programming
  92. hp per psi theory
  93. LSD question
  94. What to do? Valve adjustment-> Service messed up
  95. how to remove a really tight head bolt
  96. check out my engine...
  97. A/C help needed.
  98. ZC engine bogs out.. code 7/14
  99. Supercharger question
  100. Starter wiring question??
  101. timing belt position
  102. Valve Adjustment results on my Accord
  103. HOW can I beat a gt with a civic?!
  104. 4-1 or 4-2-1?
  105. Transmission swap?
  106. help! o2 sensor!
  107. O2 sensor
  108. new obx exhaust = check engine light
  109. a problem with my distributor
  110. What is vtec exactly?
  111. What is a Dyno tune?
  112. Mobile Computer CAR interface
  113. are stock jdm engines faster than usdm stock engines?
  114. Help on deciding exhaust
  115. heads
  116. specc sheets?
  117. Fuel injection problem
  118. how long will this last me?
  119. leak problem
  120. New Engine or Rebuild?
  121. How much boost?
  122. Turn T3 Turbo into Internal Wastegate?
  123. Loss of Power
  124. anybody bought their motor from hmotorsonline?
  125. Engine combinations
  126. Intercooler & Aftercooler....
  127. Air bag problem
  128. changing fuel line...
  129. Help with ditributor!!!
  130. power loss?
  131. Headlight Problems....Please help!!!
  132. GM 4T40-E Transmission Torque Limit
  133. Running Lean
  134. Clutch question
  135. CTR pistons?
  136. newbie needing guidance on swap
  137. guys need help fast... ebay header tech question.
  138. Where is a good place to get a JDM motor
  139. Rocker Head cover question
  140. 00 clipse, need speed!
  141. anyone know of a site for Sponsorship?
  142. Shifting
  143. Setting valve clearance in my accord, need help
  144. ram air VS. cold air
  145. Info On catalytic converter
  146. enhance car performance
  147. HELP homemade turbo or something
  148. motor
  149. HELP! (wiring)
  150. ecu question
  151. carter carburetor
  152. JG Engine Dynamics
  153. aftermarket clutch cables
  154. pulling out engine
  155. Valve Tap
  156. Motor pings, knock sensor computer code
  157. Venom 400 vs. Apex'i S-AFC
  158. simple questions to some
  159. how to mix paint
  160. 250+hp on a 2003 V6 Tiburon. ! or ?
  161. oil temp/pressure questions
  162. Where is the mass airflow sensor?
  163. ZEX Nitrous Install
  164. oil and water pump upgrade?
  165. Buick century ignition problems.
  166. Installation of short shifter
  167. Tiburon or Not? PLZ HELP!
  168. racing high flow cat....
  169. P30 O2 sensor?
  170. O2 sensors compatability.
  171. clutch burnage.
  172. HELP!! speedometer problem
  173. legend caliper upgrade on 99 si ?
  174. Car Choice
  175. wich swap
  176. engine swap???
  177. Please help my guys
  178. confusion!! need expert advice
  179. Tach Install
  180. 94 dodge shadow no power to coil
  181. Why does my car whistle?!?!
  182. clutch question?
  183. ecu question "URGENT" HELP
  184. Prelude motor swap??
  185. replaced alternator & battery/battery still dying
  186. line locks
  187. the cars of the future
  188. HELP!!!!!!! Need Engine Coolant Temperature Sensor and Throttle Sensor
  189. where to get a engine built
  190. lsd???? tranny?
  191. Oil change!!!
  192. Climate Control Digital
  193. and it begins.... (pics and such, 56k beware)
  194. Where Can I Get Jdm Parts????
  195. Oh lord...
  196. Bov question
  197. All MOTOR PLEASE
  198. Any good sites with JDM front conversions!!
  199. fuel pressure help
  200. The BEST AFTERMARKET PARTS
  201. air conditioning compressor problems
  202. Problems when wet
  203. help!!
  204. Engine math: I6 + I6 = V12?
  205. Window help
  206. exhaust QQ?????
  207. Smog tubes for headers?
  208. engine leaks oil?
  209. Cleaning Your Mass Airflow Sensor
  210. Tire pressure: Conflicting advice
  211. dome light problem
  212. remove scratches from the windsheild
  213. Injen CAI Damaged my Head Gasket? In Need Of Serious Advice!
  214. Help me Pick
  215. OBD0 to OBD1
  216. Help needed installing autometer gauges
  217. how much does it cost?
  218. is there any AUTO. engine swaps?
  219. Hoods and Hoses! need help!!
  220. need help fast!!!!
  221. Wiring mystery, fuse ghosts
  222. Ignition problems
  223. Need Help!!!
  224. Need Help!!!
  225. 94 dakota stock stereo quit
  226. head swap
  227. Easy Question about cooling fan? How does the Radiator Cooling fan know when to Come
  228. speedo woes....
  229. Wipers
  230. electric choke
  231. carburetor & computer
  232. Engine swap question
  233. Maintance Light....need help
  234. just read and follow along...
  235. Problem with a Plymouth Breeze..Help
  236. Is my boost to high?
  237. Q? about type r engine
  238. Heeeeeeelllppp!!!!
  239. looking for tranny for a 2JZ
  240. rotor vs piston??
  241. Spark Plugs
  242. cold air intake
  243. Rust Repair Panels
  244. Changing Oil on Turboed Motor
  245. She cranks...
  246. 94 Geo Prizm - O/D light flashing- ECM Code
  247. fan Motor blowout
  248. Moisture Sucked Into My Injen RD CAI
  249. catback exhaust
  250. Bigger Fuel System?
