Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
> Engineering/Technical |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
Auto tranny Q's; rotten egg smell
Clunking in left rear
97 expedtion anti theift wire
vinyl interior help
Front End Camber Problem After Rebuild
ac charging?
idle surging 91 taurus 3.0l
Cleaner Cams ?
1953 chevy truck only runs hotwired!!
Need Help with Shifter....!
satin paint job
Ground Wires
Online machining
Supercharger
help/suggestions on prelude swap
Jumping RMP's
Gas Pump
83 Mercedes 300SD Rear End Problem
more grip(possibly 4WD)
Would bad crank sensor cause random misfire and rough starts?
car hesitates off the line
converting my Bertha into a convertible
taillights
How to fix the defost??
Will this exhuast man fit
Tuning!!!
2004 Town & Country Lemon
MUST see for all DIY enthusiasts
polyurethane filler for car chasis
The TRUTH if you an handle it
manual
engine knock ??!!
Is the PCV vent tube important enough......
what engine
water pump
anyone bored out an F22?
New Thread Starters Read This First!!!!!
Pump that Fuel
S-AFC vs. Fuel Pressure Riser
Weird idle
Would I benefit from an itr tranny?
Engine Ques.
Dont Know
need help, 2 cars = two issues
Distributor
small v8
1999 silverado horn chirp
help on a swap
motor specs
Other gears in auto
pothole = sputtering engine?
How many horses can i get out of my Engine
Is this a legit deaL...
Proper Downshifting
noisy, noisy, damn potholes...
how much power will a d15 w/ d16a6 head and mfpi get?
Carb or Injected
Why am I running rich
DIY race gas
Safety lockout switch for 5spd remote starter
All those rear wings and spoilers
Car will not start
Hesitation... need help please!
Interpreting Leak Down Test Results
non-hp speed increase
Car is running awful/not starting at all.
Head Gasekt!
Got Some Questions...
kind of a dumb question about intakes
zc info
weird noise, second opinions wanted.
Made a big mistake, how bad is it
Correct Me If I'm Wrong PLEASE
prices?
PCV Valve location question
Being an auto mechanic
ls turbo vs b16 all motor
Tranny Conversion
Gun Metal
apexi afc
CRACK found in cylinder head intake runner
Body Control Module
Steering Wheel Extension
electronic rust control
cold air intake
Axle replacement
hks air filter
engine trouble
Best Exhaust Pipe Size
Internal brake light
Downshifting
pls help, Question about rebuilt engine
Need help with caprice
Short Shifter Questions.....
car weight
car weight
GM RDS radio question
alternator problems (help!!!)
Looking for a conversion shop near Buffalo, NY
100K Miles. (Whats the deal???)
Brake Service: Ceramic Pads and Fluid Replacement
Ignition Wires
Secure your hardwork...
door open, but locked
OBD II Software for Volvo S40
$5000??
H & R or Eibach?
POWER/COMFORT switch on 1994 nissan maxima auto.
turbo 400 vs. 700R4 transmissions
I Want To Buy!!!!
Dreaming...
9005 low beam conversion
Best of the best
Odyssey cabin/pollen filter
ECU removal Procedures
Forum Newb with a swap question Please Read
ecu?..or....Ingnition system?
Stripped a lug bolt..
how fast?
how do i remove climate contols
Window Question?
Valve stem seal function, leak down test
t-56 rebuild ?'s
Creaking from the clutch
Built Engine Buyers
whining sound
V-Tec?
Oil treatments.
Timing belts and Honda
Rebuilding a transmission...
Car drives better on a near empty tank?
Upgrade spark plug wires?
GM Transmission service question
N/a Or Turbo
MAS questions
4.785 Final Drive!
Busted Head Gasket?
1986 jimmy 2.8
what's ground mean?
Newb Transmission Question
ASE test prep help
Does this sound right?
82 accord
Speedometer not working?
Piston rings or what!?!?
Audi A4 body kit
is this
please help, 2 problems
need walk through on coilover install
Vibrant Performance--Universal Mufflers
97 malibu auto trans
Manual Choke to Automatic, HELP !
strange A/C behavior
help!!
Whats going wrong with my tranny....
MR vs. FR
Hack my Brakes Up
Exhaust....
Your opinion? Is it worth it?
Please help, JDM H22a info needed
remote start on a manual tranny
Sorry Im Dumb
5 Angles Valve with Domed Pistons
A/C Problems w/ Squeaking... Clutch?
86 2.5l Cutlass Ciera Cutting out--Please help
Cyl Manifold sequence/Trq
van battery dying HELP!!!
rpm's possessed devil
turbo on automatic
Weber carburetors and fuel supply pressures
inline and block
Hydrolock Please help
backfire prob
MAF and BOV
low oil pressure
Lightning booster
Need Torque specs
increasing compression ratio?
Really Important
help! install el glow gauge faces
Lug Nut Question
I need sumthin cleared up
LS6 into 85 Z28
DYI front end alignment Chevy truck
Car won't start, Please Help!
Help! Help! Help! Gas Leak!!!
Glitter in oil
Miami Mechanic Needed
iat location
A.T to 5 speed swap for civic
Key won't work, who to call?
Another JDM emissions question
The Tuning Numbers
Choosing Turbo Size...
measuring alternator current
engine idle
How much would it be if i wanted to convert?
Hydro-Boost & Power Steering Problem
Effects of retarded ignition timing
Stupid Q, need a Smart Answer
Disconnect o2 sensor -> better performance?
Aftermarket age?
Gearbox problems, help.
physics of power steering
1994 pontiac Grand Am head gasket
Wut happens if I pull this fuse....
grinding in front
Weight Question
Hood Shocks
Want to pick up speed on a Automatic 99 honda accord?
Convert OBD1 motor to OBD2 possible
stall...wont turn ova
common engine swaps in 70's model cars
Block Guard + Sleeving
spark plugs on 1997 chevy monte carlo z34
Oil sending unit going off
Intake Manifold probs
questions on long blocks
power plus typhoon intake manifold
96 ford probe gt 2.5L
Universal Exhausts
Strange problem
Turbo Q
Valve timing question
Headgasket gone need info
Flames grom tailpipe
Injectors and fuel pump?
Follow Up
Gaining power?
Cold Air Intake Help!!
design process
Transmission Coolers
Rims = No warranty??
302 and 351W headers? are they the same?
catback systems
CA smog law finer points; aftermarket parts
Corsica fan relay
Engine Swap Question
dirty o2 (oxygen sensor) ? Will it read lean or rich?
best place to buy aftermarket parts
Air Filters
fuel injection vs. carbuerator
Need Help!
Need Help....< Newbie...
quade throttle bodies ?? whats up with that
Volvo 440 overheating HELP Please
I have some weird questions about cars...
front mount cold air intake?
Limited slip???
sport compact pro
Web
AF
