Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
> Engineering/Technical |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
Toggle Switch Bar
whats the different between cold air intake and short ram intake?
Won't start
engine mounts
truck beats car... WTF
Spiral Max
Ac Question
shifting help
steering/ suspension acting strange
water temp gauge
How to Bleed Brakes?
starting problem :( PLEASE HELP
noisy transmission
removing crank pulley
1987 Chevrolet Astro Van A/C Compressor
A/c Enhancement
Runnin Wrong
shifting an automatic?
What is JDM?
can you please give me a spec list of a car?...?
S10 Manual Or Help
Help W Fan Removal
need help jdm swap
check engine only when towing
Air Condition sucks
Texas Street Racers..
motor oil companies
engine knockin
Shift Lever Diameters?
Installing a Radiator
I dont get headers...
Guage Question
fully built Ls
A/F Gauge Hookup
Half-axle question
A few things..
install a momo steering wheel
header wrap
Need help with a 1970 grand prix
Suspension System
Chevy Spectrum Brake lights QUESTION???
JET ecm upgrade after IHE
Can somebody do me a favor?
Intake Manifolds
ECU upgrades?
Auto to manual Complete list of parts
quick newb question
Need Engine Schematics
See if you can solve my problem.
Which is the better spark Plug?
HELP on exhaust/compression stroke!
starting problems. Need help
Air Compressor info
What's this about shifting?
1995 Grand Prix sunroof question
Need Help Asap - Trans Problem
passenger airbag removal
"BLUE LED City Light" customized?
wat's he smokin?
spark plugs crossing to distributor cap
what can damage an oxygen sensor?
2001 back hatch stuck?
Car Alarms
1400 DOHC injection
Handbrake problems
Cheap Spray Paint
Tires Size - What's too big?
Sparkplugs
noisy when moving-HELP
Swapping in a 572 Crate
axle-back exhaust??
check engine light
golden eagle conversion kit
best repair book
pondering exhaust
flywheel
Condensor Repair...
gaskets and whatnot
leaking oil seals
Best Motor... I think I found it.
jacking a car up...
About The Rpm
Are my brakes screwed?
Short Ram vs CAI.
no headlights\no running lights 97 cavalier
Backfiring
What ever happened to...
Distributor Dilema
is this a good price?? input please
Universal Parts?
Putting my mitsibishi 2.0 turbo back together
Important
A/C conversion question
clutch info... PLEASE
Need Help
zMax?
Intake bolt on question "dumb newbie Q"
engine replacement question
Electrical Socket Not Working, Please Help...
Climate (A/C) Mode Control
unusual problem
intake
Fuel Pump
Fuel Atomizer 2000??????
1993 S-10 problem
Lowering an Izuzu Amigo
another noob question
Exhaust Questions.
surging when first started
battery desulfaters
Push Button Shifting Part 2
wierd mini me engine,thing?
Blown Head Gasket......Female needs help
valve adjustments
Alemite, anything like it
springs and shocks
remanufactured clutch?
all bolts on my exhaust are seized.....
Expert Tuners, I need your help
Please Help...Balance Shaft Problem
singlecam/doublecam theory
little question
MAP Problems Turbo Teg
DPFI into MPFI
Need Auto Body Parts???
tire mounting machines
Zex Cams
exhaust
Electrical Problem
Why do auto trans. have fewer gears than manual?
Is this a dumb question?
Ferrari Exhaust Sound on a 4.0L V8
Engine Trouble?
Pistons...
added catback and headers..do I need a new catalytic convert????
Door is out of Alignment
electric motors for water pumps
ltranny question
checking refrigerant
Shop accessories (lifts, jacks, creepers, tools, etc.)
strange lag
engine light 95 740iL
oil change accident
Large Bores
What exhaust should i get?
01-04 GT hood scoop
? engine for Odyssey
Ys1 Half Shaft Wanted
No Spark
which muffler
Can't search for V2!
G-Tech Pro
noisy brakes
GM Syncromesh
Thermo-Tec intake heat shield???
noisy transmission
idle problems
Headlight problem
transmission breakthrough
wiring diagram
Cai
Custom fitting rotors
filter help
rotating tires
Smoke and Pop
What to clean with
Timing belt replacement technical problems
how much is a tranny swap?
Checking Map Senser
Do underdrive pulleys increase MPG?
intake(little newb)
Help!! Bad clutch or tranny?!?!
Improving gas milage
Bronco Question
Miss My Dad
loss of power
95 Aurora will not start plaes help
higher flow or higher pressure in exhaust setup.
Not getting a spark need help!
Suggestions for modifying an E46 M3
Is it safe to turn slotted/dimpled rotors?
Ultimate Crazy Supercar Idea
Best Motor Oil
Remove tail lights
summer project
f series!
safc?
please help tranny
Tire Slapping Noise
Code on my Prizm
adding amplifiers to factory headunit any better options?
Disaster! Help please!!
where to learn?
Engine Spec
drive axles
RS*R ExMag or Apexi WSII exhaust?
Clutch...
radiator flush
Gear Grinds at 3rd gear?
z3 insert instructions? help...
96 aspire milage
Pistons w/ sleeves
GM 700 shifting problems
1993 Chevrolet Corsica Problems
2000 cavalier wont start
Spark plug upgrading?
nitromethane
Bronco Questions
How do Fuel Controllers work?
supertrapp muffler
BETTER PERFORMANCE:DC Headers 4-1 or 4-2-1?
On-board timer for drag racing???
What determines overall engine power?
where can i find a b17???
fuel pressure reg.?
Question about diesel engines
vacumm gauge
Tranny Problems
Aspiring Mechanic
Engine additives
Check engine light... EG Valve?
O S handel Ideas?
Need more torque!
To all Holley carb owners
Engine Trouble NEED HELP FAST PLZ
Apexi mufflers
Engine Swap Shifter Qeustion
any suggestions?
trans gears
Im in need of assistance...
Gasoline price
4t65e tranny problems
Intake over K&N?
newb to import racing world need help
Need help on lowering car!!
HICAS/All wheel streering good for performance"
Tranny Broken?
A/C overcharge
How to take a locked door off
Spring Compressor Q...
Idle Air Control Sensor
Push button shifting
Good Idea???????
DIY Rev Limitor
criticize this!
Auto tranny Q's; rotten egg smell
Clunking in left rear
97 expedtion anti theift wire
vinyl interior help
Web
AF
