View Full Version : Engineering/Technical
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
  1. Legal info?
  2. Where to go!!
  3. 1997 blazer
  4. Question:"Blow-by" in valve cover
  5. 350 engine swap
  6. oil changing pump
  7. storing a engine
  8. Engine swap, reusing existing axles
  9. Okay, I'll get the "stroker" crank, but what rods do I get?
  10. How much????
  11. Corner Shadow Lights?
  12. shoes?
  13. engine swaps
  14. shocks
  15. 85 S10 alternator not charging
  16. crankshaft position sensor Help ???
  17. Duralube oil treatment... good or bad?
  18. plymouth laser leaking power steering fluid
  19. low RPM/ light throttle misfire and hesitation
  20. D-tec
  21. clicking noise when radiator fan turns ON
  22. Lifter Issue/Knocking; Need Help!
  23. #1 cylinder has no compression PLEASE HELP!
  24. driving the wheels...
  25. wheel spacers and bearings
  26. jerkin off
  27. Obd2->1 auto
  28. swap
  29. power windows need repair
  30. Opinions on these modules?
  31. No going back!
  32. how hard to install manifold?
  33. Air Conditioning problem
  34. What are Good Struts?
  35. J1 trans Hoses?
  36. dumb question
  37. Denatures Alchol
  38. Where do I go now? newbie
  39. mk5 or not?????
  40. Are the prices on these ebay SBC cranks for real?
  41. IAT Sensor mod...?????
  42. Any way to install a blow-off valve on a n/a engine ?
  43. towing a BMW (auto trans)
  44. Port and Polish - How to do it? What do you need?
  45. Edelbrok turbo kit...
  46. Stainless Steel Bolts : Any disadvantages?
  47. Slalom or Skidpad
  48. Comprehensive Guide
  49. Msd Ignition
  50. redline
  51. just some fuel system questions
  52. Seized Transmission?!?!?
  53. Crossmember Help
  54. milling the head
  55. Header
  56. dohc and sohc what is the difference??
  57. front rotors
  58. new plugs? new wires?
  59. occasional rough idle/misfire
  60. map sensors
  61. Gas Tank Replacement Affects Accelerator Pedal?
  62. handbrake question
  63. SH-AWD: how works transmission to front wheels?
  64. transmision problem ???
  65. Gear Grinding
  66. I just ordered a JDM B18C5 motor and...
  67. How do you keep the flywheel from turning to remove vibration damper?
  68. * transmission question *
  69. need help?!
  70. would anyone be interested in this kit ?
  71. oxygen sensor
  72. Rev Happy engines
  73. Head gasket or piston rings?
  74. how do i rig or hotwire my power windows so they work?
  75. 350 trans i think??
  76. New Radiator Support and stripped Bushing Bolt - ideas?
  77. I wrecked my car, will you guys help me out a bit, I have a few quesitons
  78. Top Speed ?
  79. Hard wiring with lights and cigerette lighter
  80. Can you file down the backing on brake pads?
  81. torque increase
  82. Stupid Question
  83. Help
  84. Differences between diesel 350 and gas 350
  85. suspension shot?
  86. Torque steer
  87. What is weight reduction on car?
  88. Weight definitions
  89. Tune- Up
  90. No power after 4K RPMS in first
  91. Piston ring end gap
  92. electronically controlled valves
  93. 93 buick lesabre serpentine belt
  94. Quicker Shifts On AT Tranny...
  95. Motor mounts
  96. Does Jumping Another Car Harm YOUR Battery/Alt??
  97. Rebuilding tranny... Need Help
  98. True dual flow exhaust / sensors ..
  99. CD Player/Radio light burned out?
  100. coachbuilder for one off design
  101. Survey: Where did you get your JDM motor?
  102. Go-Kart Engine sound :(
  103. clutch sites
  104. head gasket problem
  105. Improving Compression In Your Engine
  106. gas gauge problem
  107. Toda Throttlebodies
  108. restore
  109. Reading My ECU codes
  110. chipped ecu
  111. Fact or fiction
  112. check engine light keeps going
  113. good or bad to have knock sensor
  114. bad to not have knock sensor?
  115. All car chassis and engine codes?
  116. inlet manifolds
  117. wiring
  118. electrical accesories all screwed up
  119. pop ribet gun
  120. intake manifold diff.
  121. Torque Converter stall?
  122. Total Car Rebuild
  123. What's wrong with my car?
  124. NOTHING has power!
  125. Valve Clikcing...getting worried
  126. aftermarket keyless entry
  127. Ecu Messed Up My Timing?????
  128. Where did this motor come from?
  129. slow signal lights
  130. boost controller
  131. felpro gasket, rubber? do they work? sealer?
  132. cam question
  133. Three speed transmition
  134. check engine light.
  135. Biggest Idiot on earth
  136. Where can I get this, and what is it!?
  137. waterpump question
  138. need advice please...
  139. need advice and information
  140. Transmission issues
  141. the breath of life!!!!
  142. What Next?
  143. You guys prolly have all this...
  144. 2001 Hyundai Elantra Shaking when starting
  145. racing with a automatic?
  146. what exactly is done?
  147. fast turn signals
  148. Getting off the line?
  149. gear ratio
  150. Transmission Flush or Pan Drop
  151. Need to know if i got ripped on B16 head?
  152. did my friends ls motor SIEZE??? HELP!!!
  153. Rear Clicking
  154. Revolutionary Idea!
  155. How far can I drive in one week? 5600 miles?
  156. speed sensor
  157. indentifying an ecu
  158. Ignition module MSD 6AL - Electronic Schematics
  159. car Jerks or jumps after complete stop
  160. downforce? please read
  161. ENGINE or BATTERY?
  162. Where to start on engine rebuild
  163. Difference between high strength alloy and titanium?
  164. Power Pulley Poll
  165. Will this Fit onto my car
  166. 5spd change
  167. PG6B Pistons! What else??
  168. Finally got my Lude running but need help
  169. comparing cams
  170. checking fuel injectors
  171. i heard something about 2nd cam mod
  172. rebuilding a car
  173. small blocks and big blocks?
  174. 4x4 ride is horrible
  175. Monster Motor Problem, Need Help Immediately!!! Please.
  176. EGR Valve
  177. turnsignals & reverse lights won't work
  178. 94 olds 88 cooling system problem.
  179. Aftermarket intake manifold vs. Ported intake manifold
  180. would it be possible
  181. intake question
  182. Guy put wrong gas in my car.
  183. Need advice on conversion
  184. cams and rockers
  185. Valve cover bolt
  186. Fuel Pump?
  187. p30 ecu
  188. New engine
  189. Did I fry my starter?!!
  190. right hand drive conversion
  191. Converting Ur OBD Setup
  192. Help please... Car dies when idling
  193. WOW wut happened to my car???
  194. engine timing
  195. spark plug
  196. How to install your own ZR3 Laser Shifter
  197. just an idea.....
  198. What car does this go to?
  199. 04' Tahoe luggage rack parts needed.
  200. Installing a keyless entry...
  201. Best engine?...
  202. I want more power from my 425
  203. avid vs. hasport
  204. Radiator Leak?
  205. Idle prob
  206. wire harness
  207. g-sport
  208. head gasket question
  209. Rebuilt Engine Sellers
  210. Smell coming from engine
  211. Stereo not working..
  212. convert auto trans to manual imposibel?
  213. Power Shifting
  214. nothing special
  215. FAILED Emissions Test...
  216. all motor, turbo
  217. im trying to recharge my air condition
  218. im trying to recharge my air condition
  219. stroke or not?
  220. Misfiring In 1 And 6 / Brown Dex-Cool
  221. Wat is VTEC???
  222. replacing window tint
  223. Small light fuse keeps blowing
  224. dual AFM for twin intake manifolds
  225. My Wrx Nightmare
  226. Looking for.....
  227. sohc or dohc
  228. viper 2 way pager alarms
  229. reversing the digital clock display
  230. Where IS the best place to buy a JDM H22?
  231. ecu
  232. Bolt Patterns
  233. Pinging or Timing Chain Rattling under Heavy Acceleration, Please help me..
  234. Radio Antenna
  235. clutch problems
  236. LSD busted
  237. orifice tube
  238. swap information
  239. Wire Resistance too High?
  240. Higher Compression
  241. Toggle Switches for DRL's and licenses plate light?
  242. distributer bearing
  243. Using A/C.. Does this Harm the Car?? please respond
  244. Sound problem, what could it be?
  245. engine blowing up question
  246. clutch
  247. new engine for my beat up car... I need help
  248. cam seal
  249. How to tell if a water pump is bad
  250. Painting engine
