View Full Version : Engineering/Technical
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
  1. Help With Transmission
  2. Check Engine Codes
  3. Broken Radar Detector?
  4. my 91 caprice wont start up
  5. y-pipe or not
  6. What timing belt for y8 head and Sohc ZC
  7. braking analysis
  8. Cars that defy belief??
  9. Headers
  10. sohc zc internals
  11. Radar Detector
  12. QUestion....
  13. Really Quick!!
  14. knocking sound in engine
  15. Timing/ spark knock relationship
  16. Burning these tires
  17. Most offective of really cleaning a engine
  18. Performance from a FWD vehicle.
  19. Anyone using EFIsystems PMS on a N/A?
  20. use 2 map-sensors??
  21. Bare With Me Here..What are Clutch Pedal For on Manuals??
  22. Cobalt SS tuning question
  23. what is this?
  24. 2 More Questions...
  25. advancing the odometer
  26. what does BOV mean?
  27. mini me
  28. timing parts for 3800
  29. dvd entertainment video noise
  30. Good Place For Jdm Parts
  31. Oil Filter
  32. How do I take off my spoiler?
  33. Breaks squeak at a certain range.
  34. Difficult HP?
  35. engines
  36. Speedometer Cable Help
  37. Head/Block Setups
  38. Keep or Remove Cat?
  39. changing oil pump 99 v6 dakota
  40. Electrical problems
  41. Advice needed....
  42. Remove rear view mirror adhesive...this is kinda funny
  43. J32a2
  44. Bigger the better (cams)?
  45. Exhaust system check...
  46. Busted Alternator... Suggestions?
  47. Underdrive? Overdrive?
  48. New to the board - so im just gonna post this here
  49. gas milage
  50. S4C gear box
  51. crankwalk...
  52. im having trouble with my reverse glow gauges
  53. Warped rotors... New pads?
  54. ECU Code 9
  55. FMU's
  56. KandN=Bad For Engine??
  57. auto to Manual
  58. Exhaust manifold question
  59. Brake question
  60. what is caster
  61. Spark plug Modification
  62. What is a vtech?
  63. 1994 Infinity J30 headlight problems....any help greatly appriciated.
  64. tire ???
  65. elevation and engine preformance
  66. Quick Question
  67. Oil
  68. RAce GAs??
  69. Cylinders
  70. Clutch Terminology
  71. best RPM range for normal driving
  72. Duratec drivetrain...
  73. Lucas Petrolium products
  74. electronic injection pump
  75. code 17
  76. Running Straightpipes, will It Cause Damage??
  77. Low RPM Power Problem
  78. Anti-theft demobilization techniques
  79. Shifting Problem, Please Help...
  80. when to use overdrive.
  81. Compression problem
  82. Installing clutch
  83. need some pre-purchase info.
  84. Frame Locks
  85. Car Trouble (Seized Water Pump)
  86. piston heads?
  87. what type of oil
  88. question on this auction
  89. Formula Help
  90. What Paint To Use for my Wheels Center Caps..??
  91. Chevrolet Metro lsi 1.3L 2000
  92. front camber need help
  93. slipping 2nd
  94. Fuel Pressure Is To High, I can' change It - New Pump.
  95. car trouble
  96. DNX Exhaust??? OPINIONS please
  97. Fuel Pressure Regulator
  98. question about new springs... need some help
  99. mustang question
  100. helicoil cost
  101. Best radiator for BB chevy
  102. General Question on Aftermarket Parts
  103. awd question
  104. What exactly do "gears" do for the car.
  105. fuel pressure regulator question
  106. Lights that Brighten to the Revs
  107. Catalytic convertor placement
  108. Horsepower = torque x rpm / 5252
  109. Friend lives in Japan
  110. Diesel f150 project
  111. What would be technical problems?
  112. headers and horsepower
  113. lil more help
  114. Dollar Bill Test - it sucks!
  115. Help engine install!!!!!!!!
  116. transmission slippage
  117. which headers?
  118. Gime a price
  119. Gasoline Odor
  120. please help! throttlebody makes weird noise!
  121. Brake problem!!
  122. How to bring down NOx levels?
  123. ECU tech
  124. Clutch Or tranny prob?
  125. question
  126. tachometer installation
  127. How much is it to replace balljoints usually?
  128. jet performance module
  129. Coins in car cd player - now shorting
  130. mechanical and electric speedos
  131. rushed and i got a question
  132. 350sbc running ruff
  133. Equipment to Measure Compression Ratio for Diesel Engines
  134. stuff
  135. custom gearing?
  136. code 9 please help
  137. lost locking lug nut key
  138. Which Size Rockers
  139. Auto Make/Model/Year Software for website
  140. Idiot lights to Gauges
  141. just advice
  142. switch to neutral, Good habit ?
  143. Just finished dropping a new motor into my car...
  144. oil and engine restorer
  145. transmission debate
  146. Buying an A/C vacuum pump
  147. My 88 Blazer Is Burning Oil
  148. Wiring / manufacturer help please
  149. strange stink
  150. timing
  151. buying a new used car
  152. ???
  153. driver door lock
  154. Hyper Voltage System?
  155. CODE 16, form my ECU - what should i go check??
  156. Whats The Best Chip?
  157. Mods
  158. Trying to get this jdm EF9 front end to fit on my 89 STD hatch , HELP PLZ !
  159. drivetrain
  160. Autoapply V1.0 software
  161. torque specs
  162. interference engine
  163. Damn man
  164. Maybe I figured it out
  165. Engine Noises HELP!!!
  166. Need advice
  167. Bad vibration when slowing and stopping
  168. Thump noise (Engine Mount?)
  169. thinner wheels????
  170. need some help.. thx guys
  171. 4 row aluminum radiator
  172. 440 hemicuda engine
  173. VG30E throttle position sensor adjustment???
  174. Issues with 3100 Motor ... Head Gasket or something else ...?
  175. Okay A Serious Problem!!!
  176. tint help
  177. Who would win ???
  178. 327 crank,,,350 block
  179. 350 to 383 help
  180. project car
  181. Disc Brakes Squeaaaaaaaaaaaallllll
  182. Turbo/Generator
  183. Thermal Efficiency
  184. 2000 plymouth breeze transmission
  185. car inquiry
  186. Alternator problem
  187. Cracked Power Brake Booster Stud
  188. completely lost need help
  189. need help deciding.
  190. ! ! A P E X I N 1 ? ? ! !
  191. difference between Biturbo and TwinTurbo
  192. Screeching sound
  193. TSBs free, yea right!
  194. Fumes inside Audi 90S; from oil or exhaust leak?
  195. intermintent turn signal problem
  196. 1979 bronco lights
  197. help..auto trans
  198. lil more problems
  199. Relay Wiring
  200. 98 Town & Country Engine Fuse keeps blowing
  201. A/C - Power steering belt
  202. Im Begging Everyone Please Help With My Problem No One Ever Replies To My Post
  203. Wut to replace before head install??
  204. When a Car is Fixed After an Accident, Is It Okay?? I'm Worried..
  205. in and out of overdrive
  206. Non factory spec'd rims..
  207. MY CAR IDLE's LOW..
  208. wiring diagram
  209. AC fuse blows out
  210. Why are so many cars underrated?
  211. need help
  212. Performance Fuel Pump
  213. ticking-rattling noise when I accelerate
  214. Suspension Problems, please help...
  215. To All Auto Mechanics
  216. possible guel injection problem Help!
  217. Is this possible....
  218. how to tell if your timing chain is bad
  219. Rattle From Hell continues
  220. Broken Odometer
  221. trouble starting when HOT
  222. Removing rear seats to install speakers?
  223. radical firebird idea...need input
  224. Automotive inspection checklist for mechanics
  225. remote starter install
  226. need help
  227. Making your car fast via N/A
  228. What is Starter Signal fuse for ?
  229. Another transmission noise question.
  230. New Muffler sounds like a race car??? Why?
  231. cost of a new head
  232. A few general questions about shifting...
  233. how do you check your coils
  234. Brake Horsepower
  235. Looking To upgrade to Cold air intake "tracer"
  236. Transmission problems
  237. new headers cost?
  238. best conventional oil?
  239. Looking for Local shop selling jdm engines FL
  240. Excessive A/T Shifting?
  241. OHC vs. DOHC
  242. f-150 super in a mustang
  243. butterfly scoop question
  244. auto question
  245. Tranny Problem
  246. Scraping noise after start
  247. N/A tune
  248. Damn more questions
  249. venom 400 diagnostic
  250. Legal info?
