Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
> Engineering/Technical |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
91 Accord...
Cooling Fan Problem
Storing Car
do replacement brake lines exist?
fuel pump intermittent?
smart car
What happens to car that idles for an extended time?
Please Help!!! I keep cracking CV joints.
dodge neon troubles HELP!
my car acts dead all the time HELP!!!!
Why?
Any Tips on Getting Dirt Out of Plug Holes..?
Tachometers
LT1 head flow
diy wheel alignment?
Turbo kits for 3.4s
04 crown vic sport exhaust
chatter?
Oil Light on at Low Idle
Proper way to flush
sb 350 mounting?
Car wont start or charge- HELP...
I've done everything still won't start
Vehicle Speed Limit Controller
QPower
hundred spoke rims?
Want to know alot about building up the redline of a 60degree v6
clicking sounds ?
Starting problem related to idiot lights not working?
Vacuum Leak..Or PCV Functioning Correctly..?
Benefits of New Spark Plugs..?
Camry Question
40 below
Quick startup question Olds 88
Carb Help
tbucket help
Exhaust sound
compression ratio..
Hi everyone & this is my first Question in this forum
Can you run an engine backwards.
Outlook for Alternative Fuels
Tools
Ford Aspire Question ?
altitude adjusting
new nitrous sytem
new nitrous oxide
New Engine Smokin !!!!!!!
Tranny trouble
overdrive
non-biased opinions on Amsoil
Overdrive off on matrix, going faster ?
Water in crankcase
feedback carburater
Internal Size..PCV Hose..? How Big..?
how much abuse can rims handle before getting bent?
power windows keep opening
88 Trans An GTA rear brakes
sleeper engine definition
Disconnecting the fuel lines
distilled or tap water for mixing dex-cool?
Ignition Timing
V8 swap question
custom lambo door kit?
Engine Tuner's Calculator (using Absolute Pressure and Relative Humidity)
Electical problems 2
need a direction
The 4A Engine by phat-i (included MODIFYING THE 4AG / 4AGZE)+info
Newbie Question
synthetic oil
Car radiator pictures
stumped
timing question
Damaged Bolt
question for the experts!!!!!!
4cyl/8cyl..Same Car..Same Power..
New Engine
toruqe versus acceleration
Nismo new tech to reduce TuRbO lag?
Variable Valve timing by Dave Coleman...
looking at 4 bolt 350.
Need some help!
Classic car dilemma
2001 Ford Espace spark plug replacement
Measurements
Oil filter question?
Ford Keyless Entry Keypad
WTH Do Oil Filters Come Loose..?
soap mixed with antifreeze: still ok?
simple way to Power up a Natural Aspiration engine.(non V-tec)
car locks
Replacing a matching distributor
How much draw is acceptable? Battery going dead
Timing Belt
towing
I dont know a thing.. I wanna learn
Pi Research/data acquisition
Why use nos?
cv axle
Cylinder Head
fuel pump? HELP!!!!!!!
Electrical puzzle
Clacking axle problem
Which limited slip for me?
solar panel & car efficiency
Atmospheric Pressure Sensor
synchronizer assemblies, and oil pumping systems???
Planet Carrier??
Setting lifter preload
Nissan Sentra 1988 - turn signals unreliable.
Coolant poring from head- Is the head gasket shot?
Nissan and VW engines vs. Honda/Acura high rev engines
Alternator Question
03 Matrix, wont go past certain speed ?
ASE test
Honda Civic
Quick Question
electrical question
Overdrive in A/T..Turned Off..Benefits..?
vibration at highway speed--please help
Infiniti Repair Cd
NOISY door locks
1988 NA LTD Fairlane DIffs
Death to a motor...
Raise/Lower In Car
Best OBDII Code Reader?
OBDII troubleshooting directories
_BLACK_ exhaust
Oil Pressure on Probe 93 GT
Factory Welds on Exhaust Pipes..How Strong..?
99 cougar idle is up and down
Buzzing/Metal Sound..WTH Is It..?
electric supercharger turcharger
Manual CVT?
tunning.
W16 Bugatti engine outclassed outengineered
Small leak: JB Weld, RTV Silicon, QuickSteel, All-Metal?
Tire Question
Build Your Own V8
Hot Rod scoops
Where is the idle adjuster on a 1991 420sel?
GM Dexcool
My Geo has issues accelerating. Too much gas = no power.
whats bad about glasspacks?
Shaved Door Handles
Transponder/Anti-theft devices
alignment question
Aftermarket lighting question
Over Reving Question
Does Compression Ratio effect fuel economy?
Bad miss on start up
flames everywhere!
Getting My Car Inspected.....
Is it possible to drop a 13b or 20b into an 88 mx6 gt turbo
Replace p205/70r15 with p205/75r15
OBDII scanners
1992 Grand Am ignition!
Testing MAP and TPI sensors
Engine milage or kilometers
help me please!
Obd Ii
Cranking engine that hasnt been started for a few years
My A/T runnith over and grinds. Help!!
engine idles rough with black smoke.
engine swap 350 chev into 450 sl MB
65 mustang heater not working
Replacing Sparkplugs
Engine Oil is Low..Adding Some is Bad..?
Need info on training
Do I need a catalytic converter
looking for h22
Need Help. FAST
oil pan cooling
Looking to improve gas milage...
will a chevy 350 parts fit a 305?
P0300 Trouble Code, Multiple Cylinder Misfire
mis-fire all speeds
Something I built actually WORKS
Cylinder Head
Does increased airflow increase gas mileage?
Too late? should I give up?
What Gear..For Getting Out of Snow..?
Man Sized Hooters
Battery drain.
mathmatical conversion question
Motor Dies at Redlights
What does it takes to swap an engine?
transmission problems (5 spd)
Traction Control....? Should it Be On or Off..?
94 merucry sable cruise control and tranny problems
Fuel Injection Problem
obd1/obd2 interface cable and computer software
Front wheel drive pickup trucks
twin engined cars
Chevy 4.3 TBI problem - I think
I-6 vs. V-6
filling up
lugging a diesel engine
What driving style is healthier for a car?
Loctronics alarm system
can ne 1 help me plz aghhhhhhh
Idleing your car
Cornering G-force
suitable oils
Accelerator shaking on 96 F150 I-6
Lift Kit Installation
Car Running..Not Good..?
Car sitting for months
Subaru engine vibration / shake
Fluid Leak Identification
Driving standard for mileage question
A/C and Heat Vents..Not Strong After Accident..?
VALVES, VALVES.... valves. Hmm that's a funny word
longitudinal to transverse swap
Formula one clutch question
guesses of the HP of this combo
intake question on carb'd cars
Explain a burning clutch.
push starting & catalytic convertors
bleeding brakes
dash light
3.8L Olds backfireing
Difficulties with Valve Adjustment
Battery died?
tail-lights out, brake lights work
VOLT Gauge Lowers in Reverse..?
towing and your odometer
custom intake manifold
Whats the fastest
car shakes back and forth please help
Help! Spark plugs fouling
Lights don't work
TIG Welding 4130 (Chrome-Moly)
Built an Oil Pan what should I Coat/Paint it with?
700R4 Assembly Help
Nissan V6 engine runs fine until 2800 RPMs
hot wiring to start van
car problem
engineering
performance gaskets?
1992 dodge caravan braking question
Think I used the wrong kind of RTV
ticking
something draining the battery
how to clean deck surface for head install...
Will This Cause Problems..
Quick fix? Or am I an idiot?
No start (no spark)
Car just stalls at stop lights; turns RIGHT back on
93 Grand Am
Engine worries.
Web
AF
