Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
> Engineering/Technical |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
Blower motor problem
amc motors
XX Tuning EFI 101?
1996 chev corsica v6 3.1 engine codes
Oh boy!
Anodizing Aluminum Rims
add on ABS?
s10 4.3l questions
How many volts to the A/C coil?
Suspension bottoming issue
Air Bag suspension
tranny noise
Noisy new windshield wiper
code po401
Curtis the moderator
b16a timing belt?
b16a Cams
cap and rotor coil etc
engine light Flashing!
Humidity sensors as part of engine control
Coil position on Air Condtion Compressor
siphoning gas
intercooled non-turbo
Tire rotation, front<->back vs. cross to the drive-wheel
i need u experts again
Oil Pressure problem... It's wierd!
Transmission grinding gears
potateo in exhaust
an "advanced" question (spark that is) mechanical vs. vacuum
engienerring/technical
Weird sound when right after starting
AC compressor, new or remanufactured?
exhaust sound problem (after catback replacment)
GM is a Sh*t
Improving Gas Mileage
Lots Of Blue Smoke..All Of A Sudden..?
Falcon Question?
you guys are the experts thats why i need ur help
engine parts conservation
macpherson, double wishbone?
Century 2002 Anti-Lock/Trac off/SES
exhaust leak?
Starting Problems (87 Rx7 w/Chev 350)
"Seasonal" Starting Problems
need help!!??
can anyone help
bad spark plugs?
Project for this summer from a disturbed mind
1971 Nova engine not started in 20 years
GM to Ford tranny swap possible?
Hunting Idle When A/C is On..?
please advise on cat heat problem
1999 Dodge Durango FIRE!
Sluggish Drive, Gas Hog & Grinding?
tire/cv question
Simple Question
Jet Valves......how is it different?
My brand new car makes a loud noise when I brake... ???
amsoil synthetic oil/filters/ etc.
Did I Mess Up My Engine....Help Curtis..
car wont crank
blown head gasket?
Smaller Plug Gap vs. Larger..Pros and Cons..?
Where can I learn auto mechanics?
air filter
rotary
bad wiring?
Firebird/Auto parts in Orlando???
Best Rpm
somene please help me...
How does one Dive in??
Anyone else seen this?
Abs Stopped, Dangerous?????
connecting rod strength
Is my A/C overcharged or undercharged?
ENGINE PROBLEMS... knock knock ...NEED HELP!
Can't get er going. 88' Firebird
Pulsating brakes
Vehicle History Check
Quick question
Setting up winch switches
fuel line plumbing
Primer questions
Siphon from civic
NOS Question?
84' Toyota Tercel
Engine Management Systems
vaccum advance
skid pad
tire sizes
Definition of STS...
Transmission
standard transmission
Engine Hours?
OT: Lawnmower revs quicker with lighter fluid.
Budget Racecar
Engine Problems 350
Very High Octane
'94' Probe NO SPARK
Damn Valve Stem Caps! Please help
Q on 454 Big Block Engine Seals...
Best bang 4 the buck Hp increase - Honda
Transmission Fluid to flush an engine
engine tuning, carby'd
problem with accelerating???
Car Problems - Need Reliable Help
water injection
H22A Transmission problems
this sucks so much!
91 Civic DX Vacuum
engine swap question
Electrical Problem?
Engine stalls
Custom Engine Question
direct injection questions.
another electrical problem
CV Joint or Tie Rod?
starter motor used for electric bike?
problem with my transmission... any ideas?
tire rotation (2 different ways for fwd?)
Help With Rear Wheel Caster..? |
best place to learn
Engine Swaps
SuperCharger
calling all mechanics/tuners
Disconnecting a battery
leaking valve cover
Embittered antifreeze
FlyWheel
motor swap questions
4x4 air bag suspension
Brake Question
Wider Rims
biggest engine you've ever seen
alternator output
pressing pistons to rods
a/c lowside. Any help please.
What Takes Off Old Shine on Tires..tried everything...?
Idle Question.. (car stalling)
VR6 Not Smooth
Convention oil compatability with Synthetics
Does Gas Burn Faster At High Speeds..?
How Bad Is It Staying In 1st In An A/T..? |
OBD II readers
Antifreeze ref guide
flame thrower
Common Sense?
electric window problems
62mm Thorttle Body Spacer
engine runnin' on stand ?
oil gallery plug installation
AWD mystery?
Chevy SB400 question-It's one HOT Chevelle
car not de-revving smoothly?
Engine mods for RX7
Engine pinging after water pump installation
Carb question
One broken Windsheild Wiper
Aftermarket Tach on DIS?
Update on the Wagon 454 (sorry, long.. but technical)
hp engine question
3.8L information????
Can LEDs be put into a household device
exhaust/whitish/greyish smoke....
Fuel Rails?
high milege oils
detecting a ground wire?
exhaust question
Stalling in the cold for unknown reason..
Chevy Impala 2000 with passlock 2
front brakes locking up - 92 bonneville
HELP 92 sunbird unusual stalling
maf ?
oil filter
OBD II mode 6 tedt ID
Drain plug in a TC; why not?
ATF fluids
bogging problem
Transmission or clutch?
freeze plug ?'s
79datsun 210
PLEASE HELP!! Odometer Fraud or Clerical Error?
not so technical but need help gas lid
limited slip
short ram intake vs cold air intake?
4AG Cylinder Head 0n 4AF Block ....
Car safety ratings greatly flawed
Lsd's and Drifting
Engine Swapping
Synthetic or conventional in fresh rebuild?
El Camino 383 stroker
Clutch bleeding for dummies
Someone Help Please?
Purpose of dual fuel tanks in trucks??
Radiator Probelm
2001 Mercury Cougar ZN problem
Reversed boxer engine?
Screeching Noise
96 ford contour
mobil 1 silver top or blue top
test and tune... who does it?
just simple question about b16a1 wiring
Tps
cv boots
engine rebuilding
Cracked Block?
Leaf blowers for real power!!
tC high stall torque converter
learning cars
Intake/Exhaust Tubing Size
big block into ford pinto
Holes in K&N Filters..Hmmm..
identifying torque converter
Hybrids from an engineering standpoint
tranny cooler design questions
blockoff oil cooler?
What sounds better
most mechanical loses?
valves
Rochester Carburetor
Engine heats up too fast
general maintainence questions
RPM questions
96 nissan 200sx Sr20de OBD II Cutting out at 2500RPM feels like rev limiter
Radiator Drain and Refill.. Good Enough..?
I hope someone can help!
Steering Problems..Rpms drop..Hard to Turn..?
Programming Instructions for programming instructions EZSDEI474V
new new new nitrous system
Hydrogen engines
Light Problem
Maintenance Question
Do I need a new clutch?
87 maxima-stalling issues
Some helpful FAQs, newcomers PLEASE READ!
need help
How's it Done..Radiator Flush..?
Dead Radio -- Need Help
Engine I'm looking at buying
piston suggestions
Lowrider Hydraulics
Need to replace a cigarette lighter
Compressing/Decompressing Shocks?
Non Technical but congrats Curtis73
Rebuilt Engines
1998 Buick Regal GS will not start sometimes
transmmsion, ford
CV joint or transmission
Battery Discharge problem
Web
AF
