Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
> Engineering/Technical |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
Alarm Siren
Stereo problem!
Bad Oil Pump!?!?
speakers problem
AC causes overheating
how many pounds of torque??
Uneven brake wear & other ?s from newbie DIYer
Is This A Misfire..(put noise from exhaust)..?
rocker panle 94 olds
cheap upgrades do they work
When flooring your car...
Certified Technician for car's on-board computer
Automatic to Manual swap question
Turns over, sparks, no start...
Please help need some advice!!
Engine possibly TBI problem
TV pressure port bolt
throttle increaser
Tire pressure gauge
A/C loud noise and powerdrain
flex fuel
condenser motor/Fan not kicking in?
Ever - Ware fuel cleaning system
Engine Coolant draining too fast
Automotive Life? Jobs?
How do i know i have a bad fuel pump?
camshaft bearing order
Clock and Temp Guage
AC not as cold after comp replacement
5-Link vs. Double wishbone
Correct a/c gauge readings?
Governor cleaner
DIY Exaust + Good Sound 3.0l Push rod V6
vavle interference engines
Exhaust scavenging and valve overlap...
tire mounting
honda ATF
installing an intake
throttle body, cat back?
Orifice tube on '93 Mustang
R12 & R134a
Premium Fuel?
oil pan?
Worn ball joints?
"WHY" Does Old Oil Slow Engines..?
holly dominator carburetor
Engine Temp's.
Startup problems, please help
OBD-II interface cable to PC
Urgent! Need Help. Pic Provided
automotive sabotage
Lhd Vs Rhd
Added regular gas into a Diesal fuel tank...
A Problem with my Grand Prix
how to increase fuel economy
350 ramjet california smog legal???
mazda breaking belts
main bearing bore
1991 ford tempo gl
Inspection sticker..
help setting up a 8.5" 12 bolt
!!! Idle Adjustment Help !!!
clutch question
Stripped threads
wideband o2 sensor? and gauges?
belt and steering wheel help
Air Conditioning Only Works on Full Blast !!!
A good time to buy a car???
2001 GrandAm Sunroof blows 20A fuse when opening/closing and...
Can bad gas do this kind of damage?
determining best cruise RPM
too confused.
is starter bad?
Track On A Car
Brake discs
AC Pushbutton/Light Blinking
american car user query
balance shafts vs. harmonic balancers
1995 Ford Taurus SHO electrical
Aftermarked Cruise Control Units
air conditioner killing engine
Stutter Problem and Fuel Mileage
81 malibu with camaro driveline
camshaft bearing installation
Is there a oil that is extra thin?
fixing wiper fluid squirters?
Is freon the problem here?
Freon alternatives
Cutting Coil Springs
CAN I USE o2 sensor?
after the replacement of head gasket.....
need nice smooth shocks..
Powering a Car TV, amplifiers, and woofers
Brake Issues yet again.
How much does a performance exhaust and cool air intake help?
Hesitation upon hard acceleration?
Starting Problems
quick fuel injector question
Selected gear signal
Thumping sound from front wheels while turning at low speeds... :(
Fuel Type?
Universal tq plate?
Finally got a new car..
94 park ave ultra battery light/computer
Buying first car
automotive tech
Need Help With Exhaust System!!!
impact gun??
Mustang Engine Exchange
Carb - EFI
repost (G10 Van stalls when hot)
1999 ford escort a/c
Need help with car.
Help - No brakes!
Brake Lights/turn Signal Issue
My daughters Barina Help
How dead could an engine be???
98 Chevy Lumina Issue
1993 ford escort fuel cut off
EGR system mystery malfunction
ignition coil or distributor?
Overhaul Questions
MSD Ignition
Alternator doesn't work unless accelerator is pressed
Help...........follow link
Straight Pipe Exhaust
Material Strength
helical(?) vs straight cut gears
Level10 trannies
Fair repair costs - mystified student
Through the hood
New Fuel Pump - Ignition Delay!
"Clunk" when accelerating
belt making noise
Great Tech Site
Humming Noise in Engine
Help With Brakes..Why Is One Pad Off Center..?
How High on Stock Engine?
Shaking and making weird noises
Finding which cars some new wheels fit?
what to do
Big Engines In Small Cars..
Possible engine damage due to NO coolant
How Much $$ Should Labor Be..Rear Pads Replacement..? (i need help fast)
Race gas on stock GSR???
Brakes
No start
Too much CO%!
timing gear
Spark Plug Gap application chart
Complete Short Circuit
8cyl. vs. 4cyl. turbo?
Fan Speed Controller
Car towed, something wrong w/ gearshift :(
Srt-4
highway performance
a few drivibilty and other questions
help me out please
re-designing / building a 30+ yr old electrical system
Vehicle been sitting for a LONG while, need help
93 civic DX not running right.
slotted rotors
Help with my car
N/A Guage Question
Dodge SRT-8 vs. standard Hemi
transmission in a manual
Need advise: Breaking in a brand new car
AC compressor noise
Leaking Fuel
Uh-oh. Drove with the parking break on...
Prestone Flush 'N Fill
Battery @ .59 volts raises questions
help big trouble!
ongoing injector woes
please help!
1993 Ford Probe GT Headlights Stay UP
Insulation under the hood
exhaust manifold question
Your opinions on alternator failure
Trans Help PLEASE
Fuel Filter Question (easy)
Remote Entry/Alarms
electrical help
Hand brake light stays on! Should I be concerned?
320 turbodiesel, intake fuems question
Rusted Engine
what's worse for the engine?
PLZZ HELP ME RUNNING OUT OF TIMe
Newbie Question
What should I do to learn about cars?
Do it myself?
targa
Need Help ASAP!! What does this mean?
how to hook it up
Problem with a TENZO kill switch
Electrical Problem?
Humming/whirring sound coming from engine...
gas turbine engines
fans for downforce
Manually advancing milage
how would i know if a repair has been done?
Transmission-repair or replace?
your thoughts on waiting at the shop
Question
car dies out after running shortly
International scout keeps cranking
EGR System Problems
any places that do shear strength tests?
'87 S-15 rough acceleration.
how much to replace Head gasket?
tranny cooler?
1993 Dodge Colt
Exhaust H-pipe
how do the ABS work ?
i was wondering
Steering Wheel Alignment?
4.3l problems
NightMare Sugar in the gas
Going back from Synthetic Oil
open injector circuit
dern thing wont stay running
compression ratio and boost
Gokart setup
My lincoln town car makes a funny noice when i put it into gear
Engine Ticking??
HELP!!! Timing Chain Tensioner Question
How much are they going to charge..... if
how to install intake on 94 eclipse
why my car keeps dieing?????
where i can get free 2005 Nissan Murano service manual
Door "catch"
eratic changing auto in 98 camry
Nitrous Oxides
Turbo firebird
OBD I & II Which one to buy
kerosene in cars
no fire at plugs
Alignment
Electric Fans
Torque conversion 1/2" drive to 3/8" socket
lug patterns
car pops out of 4th gear?
Few technical questions
Question on Hydrogen Engine
Blower motor problem
amc motors
XX Tuning EFI 101?
1996 chev corsica v6 3.1 engine codes
Oh boy!
Web
AF
