View Full Version : Engineering/Technical
  1. Comp. controlled 1987 700R4
  2. Muscle Cars - Chevy vs Ford
  3. 700R4-Function As A 3speed(TH350)??
  4. new carb help 2 brl /4brl
  5. 89 Accord Hesitates and Dies HELP!
  6. 73 Nova carb help
  7. Rochest 2jet
  8. Trying to fix stalling/chugging problem
  9. steering goes "woogie-woogie"
  10. What Vehical Is This From?
  11. brake bleeding
  12. Keyless remote program: 1999 Grand Prix SE
  13. external trans fluid cooler
  14. Spped limiter
  15. 77 Mg Midget A/c Question
  16. this is crazy
  17. Car wreck
  18. Fuel Tank Filler Pipe Broken!
  19. i need help! airbags presentaion!
  20. UncleBob could you respond to this please?
  21. Copo
  22. Why does my front end bounce?
  23. can this be a transmission prob.....
  24. A/C Electrical HELP!!
  25. T56 Swap
  26. Where is ignition control module, chevy metro
  27. charging pressures for ac system
  28. Shaved door Handles
  29. engine rpm and tire rpm question
  30. Brakes
  31. my ride!1
  32. What is a good restoration project?
  33. Mpg On Engines
  34. MPG On Engines
  35. 93 Yukon front diff losing oil out of breather tube?
  36. clutch or syncro?
  37. bolts for the air compressor
  38. First Muscle Car
  39. Over Heating...
  40. 96 silverado fuel pump
  41. Is there a way to fix this.. or am I out of luck?
  42. "ABS" "Track on" "Service Engine" lights on at same time
  43. Oldsmobile Supreme cutlass 1981/86/87 8 cylinder
  44. Scanner tools: 3130 vs 6000 vs 3499. Info and questions
  45. 78 Dodge A/C
  46. Jump start pack question.
  47. astroflex j5f-tx2000 instructions
  48. Crankshaft Oil Leak
  49. 91 tracker
  50. anyone have anything??
  51. no-start
  52. how to add horsepower
  53. Clean-slate exhaust--What am I missing?
  54. Protecting internal engine components
  55. bypass valve
  56. 1980 Camaro
  57. The IAC is acting up...
  58. rebuilding gm 3.1L ?
  59. 71 302 carb problem
  60. Project Search
  61. Radio LCD displays the word "CAL"
  62. Firebird weight
  63. Vacuum over hydraulic brakes
  64. What car?
  65. Stop fuel cut off/ safety stop?
  66. Removing a broken bolt (and replacing an exhaust manifold)
  67. Lock up TH350, Help
  68. PowerStart Remote Starter
  69. any suggestions?
  70. a/c locked up bypass ???
  71. What's the easiest 4-door 5-speed car to fix up?
  72. skunk oil down my vents
  73. Question about and old Anti-Sway device
  74. 1995 buick supercharger
  75. New braking design
  76. Help with a 2003 Chevy
  77. Stop the speed limiter/fuel cut off???
  78. 76 Malibu 350 2bbl Carburator HELP ME!!!!
  79. 72 Camaro...where to start
  80. 1966 mustang for sale asking 7900
  81. correct ECU for 92 GM TBI with D1 hot
  82. 1998 Silverado CK1500
  83. Buy Rebuilt Engine...or what?
  84. 1963 Dodge 880 - Charging problem
  85. custom turbo on mini van oil line question
  86. How hard is it to lift a 1975 Pontiac?
  87. 350z Performance Boost Questions
  88. Hydrogen inside Air Intake increases Gas Mileage?
  89. What is that car on this photo, pls?
  90. vacuum advance help?
  91. 383 build
  92. Canadian Emissions Question
  93. Mazda B2600 G6 overheating help please
  94. idling a car with ac on bad?
  95. GM Recall Notifications Site
  96. Engine Cleaning
  97. 1997 dodge ram stalls after going 10-15 miles
  98. Engine Vibration
  99. tranny leak
  100. bike carb bank on car engine
  101. need help 95grand am
  102. 65 mustang ac drip tube?
  103. 1996 Bonneville Help...Please
  104. Brake rotor replacement
  105. Spark Retard with a Turbo
  106. how to tell when cylinder fires based off engine rpm
  107. Burning too much petrol?!!
  108. is this a misfire?
  109. sloshing noise
  110. need answer on fuel pump
  111. My own diagnosis of a misfire...
  112. Torque vs. Horsepower, AGAIN
  113. Starter for 99 Gran Am
  114. OBDII tools/scanners; why are they limited to PCM codes?
  115. cold air intake sys for SBchevy
  116. 1974 Roadrunner GTX
  117. anyone know anything about vw turbos?
  118. Career path
  119. electric scavenger/oil pump ?s
  120. Trans Am
  121. Injector signals.
  122. ls6?
  123. Question about what causes exhaust noise
  124. the big 3?
  125. 93 camaro lt1
  126. Help on 98 Aurora
  127. Anyone know wherei can find a convertable diesel in the states?
  128. starting car
  129. Auto TC Lockup.
  130. help with xenon HID
  131. Air Conditioner: Kicks in, but no cold air
  132. 1969 camaro restoration
  133. Fault Diagnosis
  134. Problem with my Trans Am. Whats wrong?
  135. Electric steering; Good, bad or maybe?
  136. gear ratios
  137. 1971 AMC Javelin SST 360 V8 for sale!
  138. 1971 AMC Javelin SST 360 V8 for sale!
  139. 1971 AMC Javelin SST 360 V8 for sale!
  140. 67 mustang
  141. LED Headlights?
  142. Strut and Shock Absorber
  143. help! how many cc's?
  144. Four wheel disc required for ABS?
  145. Where can i find a good book on how everything in a car works?
  146. Handling of pony cars?
  147. rubbing brake?
  148. Auto Trans Fluid Change 90,000
  149. header help
  150. Name that small block!
  151. GoCart Help!
  152. idle
  153. Fuel pump requirement?
  154. FWD Rumbling Noise/Vibration
  155. Wierd dash lights...
  156. Rubber Gaskets and silicone
  157. Replacing a control arm
  158. D16a1 Swap need assistance/opinion
  159. 1995 mustang
  160. Help w/rear main leak in a 75 454?
  161. Car stops running when going down the road
  162. Oil Extreme "Better Than Synthetic in my Vette
  163. Car hinges manufacturing process
  164. Stuck Up
  165. Remove door/window handles
  166. Stumble/idle prob
  167. v6 vs v8
  168. Can Anyone Help Me??
  169. Towing limits on '99 durango
  170. Question - Compression Test Results
  171. complete noob, switching engines?
  172. experienced proffesional mechanics
  173. Check Engine Light Goes On & Off - Gas Cap? Sensor?
  174. 99 Tahoe Aftermart Tire Pressure
  175. I need someone with so-called "grey Hair"
  176. A/C fuse keeps blowing
  177. Testing Instrument Cluster/Speedometer
  178. 2000 windstar engine problems
  179. Silverado dash lights
  180. Dead out of nowhere
  181. 2000 Olds. Alero Transmission Help!
  182. Camaro Wheel Needed
  183. 2001 Blazer
  184. Brushguard upgrade
  185. so many questions so little time
  186. egt sensor
  187. Dealership repairs/mechanics
  188. 2003 Tahoe
  189. Car revs while coasting
  190. Buick Superbeast
  191. obd codes
  192. SIenna shaking, what could it be?
  193. Muscle Car Youngsters?
  194. windows wont go down??
  195. Trailer Lights Peugeot 307
  196. Running Great Automotive in Tampa, FL?????
  197. Car dying but nothing showing up on the board
  198. Dodge Neon Squeeks Like a *****
  199. Best lubricant for car keys/locks?
  200. Air Bags
  201. Accelerator sticks after throttlebody clean
  202. Pierburg 1B Carburetor Adjustment
  203. need help with b18a1 into a civic hatch 92 suspension
  204. fog lamp wiring
  205. Success with Painting Aluminum Rims?
  206. 1987 toyota supra
  207. Chilton or Haynes pontiac firebird
  208. Valve seals
  209. Multiple Gear Ratios in Reverse???
  210. Help Please!
  211. Please help-Sounds like me car is about to blow up!
  212. 1998 kia sportage
  213. starting problem
  214. engine electric system (sensors)
  215. Does a "beep beep horn" really go "beep beep"?
  216. Digital Timing Light
  217. '93 Chevy Silverado won't start
  218. Is soda blasting worth it?
  219. Colorado 05 keyless entry
  220. Allard J2X...9778lbs of downforce?!
  221. Break Drums-48 ford
  222. 429 Boss Mustang?
  223. Is ABS plastic good?
  224. help needed quick-96 sunfire!!
  225. pistons
  226. Complete explanation to Dynoing
  227. Who can I trust these days?
  228. West Coast F-Bodies Meeting - 6/15/07
  229. 1980 camaro restoration
  230. Seized parking brake
  231. Engine Swap
  232. 93 Concorde Idle Problems
  233. turbo charging
  234. Wheel broke apart from the car for no reason?
  235. Centerline wheels for sale.
  236. Lucas Oil Products??
  237. transmission on 96 jimmy v-6 4 wheel
  238. Centerline Auto Drags For Sale
  239. coolant in oil - low pressure?
  240. Rear Main Leaking. Help a.s.a.p.!!
  241. 350 runs rough
  242. Impotance of yawrate in ACC
  243. Breaks fail?
  244. Emission problems
  245. MIL Eliminators
  246. 2000 Accord Brake lights dont work, need advice
  247. 1966 dodge dart
  248. Acetone A.K.A. Nail Polish Remover Increases MPG in Gas?
  249. Double Clutching
  250. transistors
