View Full Version : Nova
Pages : 1 [2] 3 4
  1. 73nova original paint removal
  2. BB crank pulley info
  3. just got my first nova
  4. Turbocharger Help!
  5. rear impact bumper strip
  6. Sagging SS
  7. BBC header interferance
  8. frame mount replacement
  9. Noisy Voltage Regulator -71 Ventura
  10. New here
  11. Steering Hub Qusetion??
  12. Converting from column shift to Hurst promatic 2
  13. Leaf Spring Clips
  14. Ford 9 Inch Conversion - 68-72 Nova
  15. 70 BB Nova P/S hoses location?
  16. The Ultimate Nova ???
  17. In need of 73 Nova VIN tag and Title
  18. 71 Quarter window trim
  19. Transbrake Help
  20. '86 tpi 305 into '69 w/ 250-6 & powerglide?
  21. 66 chevy nova
  22. 62 nova center link
  23. tranny issue
  24. 75 Nova.....need body parts
  25. '66 nova / mustang II front suspension??
  26. Tire size, rim size, how big is your limit?
  27. What brand of shocks?
  28. Chrome spray paint- cheap fix or big no-no??
  29. kickback
  30. 74 Nova - Lookin for...
  31. Rearend/suspension on 77
  32. replacing shocks
  33. New to Novas- '77 with 406, rearend has major problem
  34. rear windows.
  35. 350SBC to 454BBC
  36. starting issue needs resolution
  37. CHROME rear quarter window trim
  38. brake shoes!!
  39. stupid enterior question
  40. Restoring 71 Nova SS - graduation project
  41. 1964 Nova headers
  42. for sale
  43. flat black paint
  44. Front End
  45. 1968 SuperNova
  46. why novas?
  47. 77 nova
  48. 73 nova steering part needed (wanted)
  49. Ring and Pinion info
  50. 1969 Nova Rear End housing code?
  51. Rear end transfer
  52. Need help with '79 Nova
  53. nova subframes
  54. Best of the Best
  55. Should I put on a higher ratio rear axle?
  56. Powerglide
  57. Need some NOVA parts?
  58. Bucket seats for a 71 Nova
  59. need help w/ 74' nova wiring.
  60. tubbing out my fender wells ???
  61. question on window channel clips
  62. 74' need help
  63. '75 Nova Parts (wrecked car)
  64. floor mount shifter
  65. window molding clip question plz help
  66. Problems with my 71
  67. Owner of 78 Nova RS
  68. real SS or Clone
  69. battling rust :(
  70. console
  71. 63 Nova Rear end
  72. can i afford to make a 1975 nova fast?
  73. electric fuel pumo advantages
  74. Power Drain in 77 Nova - HELP!
  75. dash trim
  76. Crashed Nova parts lot
  77. subframes
  78. need help!!88 chevy nova
  79. tranny cover
  80. Engine and Tranny
  81. Auto to manual tranny
  82. 63 nova starter problem
  83. mount coming through the floor
  84. 88 Nova fuel filter
  85. Crashed 71 Nova-Pictures
  86. Disc Brake conversion
  87. Transmission linkage
  88. PS Crashed 71 Nova parts...
  89. 71 Nova totalled, parting out
  90. 63 nova ss for sale!!!!
  91. accelerator cable 71
  92. Chevy2 Tpi swap
  93. 63 Nova 2dr Bolt-in X-reference
  94. In Need Of>>>wanted
  95. Gas tank?
  96. 1968 Gauge Instrument Panel
  97. 400 sbc block info needed!
  98. 72 and 73 doors
  99. 65 Nova trim piece
  100. port polish
  101. Original Owner needs help looking for his 69 Nova
  102. TH350 or Powerglide?
  103. need posi rear carrier
  104. Doulble hump camelbacks sb chevy heads for sale
  105. rear swap
  106. Auto to Manual Swap
  107. nova door shell 72
  108. Heat shrinkable vinyl covering
  109. 70 Nova 350 4bbl thottle linkage
  110. engine ground
  111. going ot be looking for a nova in mid february up to $1k
  112. asking price
  113. windows and weather stripping
  114. 70 nova brake problems
  115. How to remove Windshield and Trim?
  116. help with brake lights
  117. needing 68-72 moulding for door around window and back quarter window
  118. Alternator wiring
  119. 1966/67 Chevy II
  120. Roll Cage
  121. tires rubbing...
  122. need 69 nova roof
  123. vapor canister removal
  124. 72 nova windshield
  125. Crate SB or BB?
  126. Replaceing Rocker Panles
  127. carb prob
  128. 70 Nova - blower motor only works on low
  129. 1970 nova wheel limitation
  130. trouble
  131. what is this?
  132. a/c compressor and box for sale
  133. New guy - Frame to body Bushing replacement
  134. parts for a 73, please!
  135. 76 nova i found on craiglist in california $400
  136. Which Heads to use on a SBC
  137. new and looking for this part??? or any help
  138. 62-65 nova rear end swap; HELP!!!!
  139. Door hinge pin replacement
  140. Power steering
  141. tranny help
  142. '73, needing some help
  143. My 68 4 door nova
  144. breaking in my 350
  145. 73 nova overheating no one knows why?plz help
  146. 73 bumper on 72 mounts
  147. Tune up HELP/ emission stickers?
  148. distributor help...
  149. distributor help...
  150. 1962 Pro Street Nova for Sale or trade
  151. powersteering brackets?
  152. freeze plug count...
  153. ' 78 6 Cyl Freeze Plugs
  154. Ping Thing
  155. 73 windshield
  156. 64 Pontiac Acadian power steering
  157. 63 Nova Tubbed
  158. 6 Cyl motor mounts
  159. 77 nova...swaping 6cyl for small 8 will trans mount work?
  160. 1970 Nova Floor Replacement
  161. 73 nova hatchback heater core how to remove?
  162. new guy w a 68 Nova
  163. '64 chevy II manual flywheel
  164. 94 350 in 73 Nova
  165. 72 nova parting out
  166. Tranny kickdown cable
  167. warning!! BRAINFART QUESTION
  168. tranny linkage help
  169. Too Tall
  170. 1977 nova car help
  171. 74 nova body panels
  172. Allignment problems?
  173. 1966 chevy 2 nova big block motor and frame mounts
  174. 73 nova bumpers
  175. rear differential gear ratio
  176. 6cyl to V8 70 Nova, mount ?
  177. Engine Parts
  178. 8.5" rebuild problem
  179. th-350 to 4speed
  180. BB header fitment
  181. chevyII 6cyl headers
  182. BOLT PETTERN on a 73?????
  183. stock wheel backspacing
  184. SMOKe?
  185. Nova Hood??????need Advice
  186. stripped flywhel bolt
  187. SB chevy 400 crank and 400 rods
  188. 350 heads for sale
  189. Block ID??
  190. what size carb
  191. 73 nova airconditioning
  192. 64 nova
  193. ss stripe dimensions
  194. 1964 nova
  195. Front end rebuild kit Nova vs. Camaro
  196. 1969 Nova on Ebay 4579753099
  197. Tilt column swap 75 up into 74 earlier?
  198. Rebuilt 327 for sale
  199. 1969 nova for sale
  200. 70 nova parts
  201. modern frame replacement for 63 nova
  202. Misc SBC parts for Sale
  203. How much horsepower
  204. For Sale: LT1 long block, complete or parts, dirt cheap
  205. motor swap
  206. Poor driveability
  207. undercar appearance questions
  208. 64 nova posi
  209. 70 nova rear suspension
  210. trasmission modulator how to hook it up
  211. 74 nova 454 what exhaust to use
  212. 74 nova doesn't shift
  213. big block swap
  214. Instrument Panel Removal
  215. No Spark
  216. floor sealer
  217. Wiring help
  218. 396 Timing
  219. Not a good sound?
  220. starter/flywheel gear mesh
  221. Great condition 1976 Nova for sale!
  222. Problems shifting gears...
  223. 1969 nova over 400 horsepower
  224. distributor hitting firewall???
  225. This can't be right.
  226. For sale: rims and tires for 1970 Nova (RI)
  227. smog
  228. 74 Nova For Sale
  229. ignition box
  230. Compression Test
  231. Black Smoke at W.O.T.
  232. headers for angled plug heads
  233. will it fit?
  234. Sub frame connectors 1972 nova
  235. GM Heavy Duty Ignition or MSD 6T(6A) and HEI?
  236. Decoding Engine Vin
  237. sandblasting?
  238. '74... needing some help
  239. 78 nova rear gears
  240. best way to remove rust
  241. draining my TH350
  242. Bad Switch????? Help!!
  243. 1977 engine and transmission help
  244. 3 or5 leaf?
  245. rearend gear ratio
  246. sanding?
  247. 72 Nova
  248. Front Springs on a 67...
  249. 1975 Nova Record?
  250. Whats The Price Guys?
