View Full Version : 4Runner/GX470
Pages : 1 2 3 [4] 5 6 7 8 9 10
  1. 1994 4 Runner Fuel Pressure Problems.
  2. fixing antenna?
  3. Question about specs/replacing factory speakers and head unit on 2000 4Runner.
  4. Running hot
  5. Easy way to change oil filter on 2000 4runner?
  6. 2003 4runner problems
  7. rear window defrost retrofit
  8. 1990 4 runner shifting problems
  9. 1999 4runner starter problem
  10. CD stuck in Player (1998 4Runner)
  11. Question about the rear hatch on a 2001 4runner
  12. 4runner won't start
  13. 84 4runner
  14. 1999 4runner 4wd v6 surge and die with cold engine
  15. Noisy Clutch Pedal
  16. 92 4Runner Auto Trans. Shifter Bushing
  17. Gas Mileage for 98 4Runner SR5 V6/Tacoma
  18. Steering gear box reseal
  19. 1990 lift
  20. A/C fuse blowing under hood. '98 Runner
  21. 1997 toy 4-runner no start
  22. valve stem seals
  23. question that relates to the transmission
  24. Clicking brakes?
  25. Does TRD Supercharger increase chance of blown headgasket?
  26. steering wheel is shaking at parkway speeds
  27. Toyota 4 Runner keeps overheating
  28. Power Antenna and CD Player
  29. 1995 4runner Overdrive
  30. 93 Rear Window Channels
  31. 93' 4Runner Rear Window
  32. Overdrive sounds bad
  33. how to tell if my '01 is remote entry equipped?
  34. Head Gasket problem
  35. 2.4Lt 22-REC 4cyl throttle cable lenght
  36. Gearing after lifting
  37. alarm recommendation?
  38. type of coolant
  39. 2000 4Runner-cannot manually unlock door
  40. fill-up problem
  41. $8 Subscription to Car & Driver, Motor Trend, and Road & Track
  42. 00' Toyota 4runner fuel filter?
  43. where is the lock cylinder?
  44. 1990 Toyota 4Runner Styling Set-Fender Flares
  45. 2001 auto 4x4 Transmission left me stranded...
  46. 93 4 runner brakes
  47. Gas mileage
  48. EGR Gas Temperature Sensor 1992 4runner
  49. Can not get steering wheel unlocked....
  50. any advice??
  51. 91 4runner -"electronic control unit " or " electronic ignition"?
  52. 91 4runner
  53. anyone with advice on my 4runner
  54. 91 4runner running rough
  55. Help!!
  56. A couple of problems and questions
  57. Seat belt minder alarm removal
  58. power locks
  59. 00' Engine light comes on... "System too lean?"
  60. Looking at buying brand new 4runner, need some opinions please!!
  61. Changing differential fluid and gas mileage
  62. Oil Pan Removal
  63. '86 4runner power window/lock conversion
  64. Help, 1991 4-runner, loss of power, strange
  65. 97 4runner auto trans problems
  66. air conditioning 94 4runner
  67. Lifting
  68. Ignition fixes?
  69. 2000 4runner 5 speed clutch slipping?
  70. need opinions... rookie 4Runner owner
  71. Lost Compression on all cylinders, right side
  72. Fuse blowing for radio,clock,antenna
  73. 1989 V6 std clutch replacement
  74. Speedometer Working Sporadically on 92 4Runner
  75. head gasket / block problem with '91 4Runner 22RE
  76. cat. converter???
  77. 1997 radiator flush
  78. 1999 4Runner Timing belt replacement...
  79. CA Emission codeP0420
  80. Rodent infestation...HELP!!!
  81. 1994 toyota 4 runner owners plz help!!
  82. '99 4Runner Sputtering and stalling, thoughts?
  83. speedo weirdness rant
  84. Help Me Find Parts Please!!!!!!
  85. delayed start problem
  86. Fuel filter location on '00 4Runner
  87. 1999 4Runner shaking during braking/Clunking when stopping
  88. Headlight Removal 2000 4Runner LTD
  89. Cruise control not working HELP!
  90. Gas Mileage for 98 4Runner SR5 V6
  91. 00 4-runner
  92. Rear door interior assembly
  93. 1992 4runner how to clean the egr valve
  94. 1992 4runner egr problem code 71
  95. No dashes lights. HELP!
  96. car fax
  97. 1997 v6 4wd misfire cylinder 3
  98. 1997 v6 4wd-cylinder 3 misfire
  99. extractors
  100. Engine removal 3VZE
  101. 2003 V6 Timing Belt??
  102. Dash Lights...
  103. Gas Mileage and General Questions '03 V8
  104. rear glass won't come up!
  105. 1998 Crazy Starting Problem - Part 2
  106. 90 runner with starting problem finally fixed
  107. 2002 4Runner, warped rotors again?
  108. 95' alarm system
  109. 99 4Runner hard to shift out of Park
  110. A340H 89 4runner
  111. Qs about Suspension, Torsion, and other French Words...
  112. 22R-E cold start injector sending unit???
  113. Crud Build up in engine 2001 $Runner
  114. no. 4 solenoid, a340h
  115. 95 4Runner Rumbling transmission
  116. is there any difference between a 1997 and a 1998?
  117. Carfax on a 98 4runner, what exactly do these mean?
  118. 86runner suspension help please
  119. 1998 Crazy Starting Problem
  120. Rattle under 95 4runner
  121. 91 4Runner Throttle Body/Intake "Idle valve?"
  122. Need a new transmission
  123. 2001 4Runner - Brake warning lights on
  124. downeys's lsd's and tougher cv joints
  125. 1987 4 Runner Manifold Glowing Red
  126. 1998 4 runner fuel filter
  127. Tranny shifting problems, + misfire
  128. passing gear/transmission problem
  129. False Water Pump Idler Pulley Bracket
  130. Major Electrical Problems
  131. Oxygen Sensor '95 4Runner
  132. rough shifting in 4low
  133. 2003 4Runner rough cold start
  134. Another Tranny problem!!!
  135. load sensing valve have any rubber parts inside?
  136. 94 v6 4runner timing belt replace
  137. About to replace timing belt.
  138. Back hatch light not coming on with door open
  139. 1999 V6 Check Engine Light
  140. Removing Grille on '94 4Runner
  141. Compatibility
  142. Help: 2003 4Runner (auto function) for Power Reset
  143. 94 4Runner o/d light and transmission probs
  144. '93 4Runner manual transmission problem
  145. 1995 4Runner: All power windows stopped working
  146. Help!!!!!!!!!!
  147. air conditoning help
  148. Electrical Problem Please Help
  149. Optimum Tire Size for my 95 4runner
  150. Noise under 4Runner
  151. $ Brake Jobs, Need Help PLEASE
  152. Squeeky clutch pedal
  153. not starting??????
  154. bigger rims
  155. Chugging when accelerating
  156. 1988 runner. radiator, or water pump?
  157. 4Runner Purchase
  158. Replace side mirror glass..any help greatly appreciatted
  159. 95 hesitating and grinding into 2nd gear
  160. radiator flush 98 runner
  161. transmission filter flush - 98 runner
  162. 88 4runner psyco electrical issues
  163. 99 Limited Stereo Replacement
  164. Thump in tranmission while stopped
  165. Caliper Noise?
  166. Length of brake lines for 85 4-Runner (4x4)
  167. 98 4runner autotrans. problem
  168. 4" pro crap lift
  169. front and rear diff for 91 4rnnr
  170. '91 throttle body issue
  171. Service Manual
  172. Removing Emblems
  173. 05 4runner maintenance light
  174. 2000 Mileage 3.4
  175. check engine light (erg problems)
  176. brake light
  177. Code 0171 - sets only when cold.
  178. Alternator Question
  179. Mysterious Noise-1995 4/RUN-THOUGHTS?
  180. key program
  181. Loud screech when I start my engine
  182. A/C leaking inder dash?
  183. 2001 4Runner Sport feels like it's going to stall...
  184. motor feels forced
  185. Clutch fluid
  186. Moonroof seal 1989 4runner
  187. 2002 4runner transmission problem ?
  188. Paint chipping? Anyone having problems with
  189. wont start after being ran?
  190. 90 4Runner Timing Chain repair oil leak
  191. Rotors
  192. Tailgate Window
  193. Center Cap Rear wheel (passenger)
  194. 4 runner problem-loss of power
  195. trans/auto
  196. 99 SR5 idle problem
  197. 97 Limited Tranny Won't Move From Park! Help?
  198. 1993 4runner back window problem!
  199. Low engine knock
  200. 2001 4runner wont start
  201. A/T Oil Temp Light and Shifting
  202. Oil seeping - rear main seal or oil pan
  203. 87 4runner turbo problems
  204. HELP...timing chain help needed
  205. sr5 vs limited
  206. Head Gasket Question
  207. 1993 Toyota 4-Runner Auto. Trans. Temp. Light Coming On
  208. How to change sunroof on 93 runner?
  209. 94 4runner ac
  210. very odd please help
  211. starter 4runner
  212. 01 4-runner stereo removal help
  213. Sunroof switch - how to get access or remove the head liner
  214. My 93 4-runner is slow and sluggish
  215. Radio light
  216. antenna motor
  217. Fresh air vent blowing moldy air, resolution ?
  218. Antenna
  219. Easy Accessory Belts Question, '02 SR5
  220. recall on front ball joint problem ?
  221. Inside tire wear 97 4Runner, need help diagnosing
  222. 4runner body on pick up frame
  223. tail light problems
  224. Water in Exhaust
  225. Fuse location for oil pressure/water temp gauge
  226. Manual vs Automatic
  227. Whining
  228. Heating Control Unit
  229. 91 Toyota 4runner power problems
  230. Looking to buy a new 4runner need advice
  231. ? how to remove brake light bulb
  232. Fuel Injector Question
  233. steering wheel audio controls
  234. Major problems W 88 Runner Please Help
  235. Help - Major fluid leak
  236. 1990 Low idle
  237. Leaky Moonroof...HELP!
  238. 87 4Runner Automatic Tranny Clunking
  239. 90 manual shift
  240. freeway driving i dont get it
  241. fuel pump cut-off switch
  242. Hilux Surf steering wheel
  243. 97 4Runner exhaust
  244. 1992 Front Wheel Removal Bang? Lube? Crowbar? Heat???
  245. Sound System
  246. Time for New Tires, Which Ones to Buy?
  247. 1992 4wd auto trans shift problems - hrlp!!!
  248. Blowby Gases/ Oil Catch Can
  249. 90 4runner break issue
  250. transmission filter change.
