View Full Version : 4Runner/GX470
Pages :
1 [ 2]
3 4 5 6 7 8 9 10
- Turbo 4Runner start not disengaing
- 1998 4Runner trim paint code, help!
- Brakes
- Chromed Skid Plate on a 2003 Sport
- 2003 V8 Sport overhead-rattle
- 95 4runner suddleny wont even start!
- Old Man Emu?
- Axle seal
- passing emissions with hollow cat
- Front end
- Head
- Something Weird??
- tranny fluid in coolant
- Best oil?
- Brake lines??
- 2000 4-runner Dashlight bulbs
- Brakes
- 97 tailgate rear door latch problem, won't shut
- Oil
- 1993 4 Runner Acceleration/Idling Problems
- wiring diagram does not help!
- Tranny
- Cooling
- Engine
- need wiring diagram
- 95 4runner step on the brake cluster lights up
- 94 4Runner hesitates, surging, no power. PLEASE HELP!
- 95 4Runner V-6 codes 14 and 71
- need help with rear differential nut removal
- 94 thrown rod?
- Troubleshooting P0171 DTC on 2000 4Runner 5VZ-FE
- 97 LTD that won't start not even crank
- Towing with '99 4Runner
- 05 4Runner tire questions
- 4wheel drive?
- Tired 22RE
- 87 4runner efi problem
- Rear Door fix?
- Alarm setting itself off HELP!!!!
- Rocker
- v6 distributer wiring
- 1997 4runner timing belt questions
- Buying
- Tail light problems w/ 1995 4-runner
- Replacement Hydraulic Bottle Jack '99 4runner?
- 96 4Runner Limited Won't Move
- Code P0770 (check engine light)
- o5 4runner vent smells
- Temp Guage
- 92 4runner speedo problems
- 1994 4 runner water pump replacement
- distributer wiring
- Leaking coolant from the head?
- please please help! no dash lights!
- 95 4Runner Speed Meter
- vibration?
- Rear Bumper 94 4Runner?
- 2003 Sport V8 plastic door moldings
- Keyless remot
- 92 4Runner/Surf 4WD Brake pedal release noise....
- Grrrr...Driver side door sensor?
- '99 4 runner clock and radio fuse?
- 95 4runner two antenna wires?
- 95 4runner power antenna
- dash clock. please help!
- starting problem
- Antenna
- 2003/04/05 4runner
- wiring Diagrams.
- rusted oxygen sensor
- 1995 Toyota 4runner 2wheel V-6
- 85 4Runner - rough idle
- 2003 4 runner 4.7l v8
- 98 4Runner TPS setting
- 4 Runner fuel filter(s)
- 2003 ,4runner, have problems with ABS
- 94 4Runner Fuel Delivery Problem Please HELP.
- Programming duplicate key
- rust repair and treatment?
- Fuel Guage/Tank Problem
- Help identify this part
- 94 4Runner Mass Air Sensor
- 99 4Runner Tranny?
- door lock problem on 00 4runner
- 99 runner starter problem?
- Customizing
- 93 4runner engine problems
- 94' 4Runner shifting problem
- 94 22re rough idle on hot startup
- 1992 4Runner Hesitation Problem
- 88 4Runner- Problems with stickshift
- How do i remove my 1994 toyota 4 runner spare tire?
- 2004 4-Runner ABS Brakes??
- 86 toyota 4runner rear top gasket
- 01 3.4L 4Runner, 'VSC Off', 'VSC TRAC' and 'ABS' lights coming on intermitantly
- 1997 4Runner Dash Clock..
- looking to buy a 4runner not sure of year v6 vs v8
- 1990 $-Runner 6cyl ..max RPM 2100 ingear
- electrical problems....
- 1996 4Runner - no wiper/rear window
- Wheel noise
- '94 4runner power problems
- Tran Trouble?
- 1990 four runner starting problems
- 03 4 runner - VSC Light?
- Brembo rotors
- interested in 86-89 4runner v6 for Baja Chase
- 93 engine noise=
- 95 4runner lower valance
- Please Help Asap
- Engine, Power steering, and smoke problem.
- Blown headgasket 3.0 V6 - to buy or not to buy?
- 99 4runner antenna issue
- 99 4runner chirping/squealing
- 1995 4Runner Fuel/ Gas Leak
- 4 wheel drive troubleshooting
- Idle Problem
- 95 4runner oil and fuel gauge read high
- 97 Radio Theft Lock Code
- 99Runner Starting problems
- switch to live axles and lift.
- 1990 four runner stereo wiring
- 1990 four runner wont start
- suspension issues... do i need new shocks?
- '96 - '98 4Runner Extended EVAP Warranties
- 98 4runner brakes
- 1996 4Runner ash tray light???
- 1996 4Runner Locking diff??
- Thumwheel Dimmer impossible to see at night
- Climate Control Reset Sequence
- 95 4runner jack location
- 1999 4runner bucking or surging tranny
- 15k mile checkup for $250: Should I?
- 4Runner Review - 1998 w/ 114,000 miles
- 97 rear hatch
- 1994 4 runner won't start
- 95 4runner shocks
- Brakes/Gas Guage
- Starting Problem
- safe to drive?
- '99 4runner - loud at 70mph?
- 3rd gen - weird belt like noise
- 3rd gen - heater and ac noise
- 3rd gen - tranny problems
- Reprogram a 2001 4-runner remote
- Brake issues on a 2003 Runner
- Receive safety recall notice for my 97 4runner
- 4Runner 1990 4X4 do not engage
- 4Runner Hood Protector Install Tips?
- 1st and 2nd gen. tailgate
- 91 4Runner Gas Problem Realy weird
- dash light problem
- Hard Starts
- lsd or not
- Brake pedal travel
- 3VZ into 5VZ
- 2003 V8 tranny, 1st gear
- Transmission problems
- 2003 4Runner Sport V8 "issues" and "irritants"
- 60,000 Maintenance Advice Please!!!
- 94...4runner freeze plug replacement
- Gas Gauge issue
- '99 4runner with chirp/squeal?
- 95 4runner motor swap
- 86-88 and 89 differences
- transmission fill on a 2005 4 Runner ?
- 4 Runner Tire Pressure Sensor Question..
- Location of thermostat
- Air Valve vs delayed choke
- 2003 4Runner Sport V8 question
- 97 3.4L 4Runner Throttle Position Sensor
- '97 4runner side marker lights
- temporary tire removal
- 4Runner Glass
- 2003 4Runner Sport V8 Owners Manual + Questions
- Flushing out heater core?
- Rear Suspension Clunk 99 4-Runner
- 4Runner 1990, manual shift problems
- Lift kits
- 2000 4cyl - blown head gasket or no?
- 1990 Engine
- 97 4runner suspension
- 2007 Tocamo 4*4 low range troubles
- Does Toyota recommend Injector cleaners?
- 90 4-runner fuel out of throttle body?
- Suggestions for replacement shocks/struts?
- 2003 4runner - remote starter wont work and causing other key to not work
- replacement bumper piece - 98 SR5
- Maybe need some belt dressing?
- 85 4Runner intermittant sputter and die
- 2003 4Runner Sport (what 2 kno b4 i buy?)
- 4X4 problem
- Blow off vaulve?
- 03 SR5 transmission, anyone having this problem?
- 97 limited with 245k
- 96 head gasket
- 2005 4Runner Uphill Cruise Control Problem
- 98 4-runner leaky moonroof
- My 2003's door lock is driving me nuts, help!
- 94-95 4Runner, a good deal?
- Heating Problem
- Towing with 4cyl 4Runner
- Enlighten a prospective buyer
- There Goes The Starter!!!
- Removing starter 99 6 cyl 4x4 auto
- 99 4Runner fuel injector problem
- 92 4runner with multiple problems
- Fog light short
- 97 4runner dimmer light
- 91 4runner starts then stops.. HELP
- 1997 4runner several electrical issues
- I'm a dummy, brake fluid in the powersteering resevoir!!
- 97 4runner limited
- Starter from hell!
- 99 4Runner starter questions?
- help removing intake manifold!!!
- 93 4-Runner Rear Axle Leak @ Axle-Wheel Junction
- 4 runner 94 air problem
- 91 4runner acceleration problem
- Some help for Rear window Issues
- Newbie saying Hello
- bridgestone a/t tires vs h/t, what difference ?
- floor mounted dimmer switch conversion
- Will these F150 wheels fit on my 97'
- 1998 4Runner Oxygen Sensor Question
- front clip interchange
- my 99 4runner won't start! help plz.
- Safe to tow with '97 4 cylinder?
- Oil Change by the Dealer gone wrong
- 95 amp installation
- 91 4 runner/ power windows not working
- blown head gasket please help!!!!!!!!!!
- 2002 4runner odometer disconnect?
- 03 4 Runner Alarm sounding
- Radio Questions
- SPACERS&RIMS???- confusion need help
- temperature gauge
- Hilux Surf - auto box aint behaving........
- moonroof stuck open - fuse or switch?
- idle problems and no power. HELP!!!
- alarm won't stop HELP!!
- 1996 4 Runner
- starter?
- 2001 4Runner (beeps and antennae replace)
- How to deactivate factory alarm?
- 02 sensor problem
- Rear Window Issues
- Driveshaft reassembly - '99 Limited
- Elec Prob: Tail Lights and Instruments not work
- cherokee or 4runner
